1663.000.00
1663.000.00
    FEIGELECTRONIC
1663.000.00 数据手册
 HF Pad Antenna ID ISC.ANT340/240 FEATURES  Read range up to 30 cm  Elegant design  Also available as antenna module  SHORT DESCRIPTION TECHNICAL DATA ID ISC.ANT340/240 is designed as a particularly flat external antenna for contactless data exchange with HF transponders and impresses with its excellent performance and elegant design. These characteristics allow desktop applications in offices or libraries for file and document tracking and capturing loaned on the issue and redemption. The read range of individual transponders can be up to 30 cm. ID ISC.ANT340/240 has a coaxial cable and can be operated with a reader, immediately. Beside the variant with plastic housing, the product is also available as an antenna module without housing. Dimensions (W x H x D) 337 mm x 237 mm x 8 mm Weight 530 g Housing Plastic ABS Color grey-white Protection class IP 40 Temperature range - Operation - Storage 0 °C up to 55 °C –25 °C up to 85 °C Relative air humidity 5…95 % (non-condensing) Operating frequency 13.56 MHz Max. transmitting power 1.2 W Antenna connector RG58 coaxial cable with SMA plug (50 Ω); length 230 cm STANDARD CONFORMITY EMC EN 301 489 Safety Electrical Safety EN 60950 Human Exposure EN 50364 ORDER DESCRIPTIONS ID ISC.ANT340/240 HF Pad Antenna ID ISC.ANT340/240-B HF Pad Antenna Module FEIG ELECTRONIC reserves the right to change specification without notice at any time. Stand of information: August 2016.
1663.000.00 价格&库存
很抱歉,暂时无法提供与“1663.000.00”相匹配的价格&库存,您可以联系我们找货
