3249.000.00
3249.000.00
    FEIGELECTRONIC
3249.000.00 数据手册
 HF Loop Antenna ID ISC.ANT310/310 FEATURES  Transmission power up to 8 W  Protection class IP65  Useful in many ways with several HF readers  Manual alignment electronics for optimal adjustment to different surrounding conditions  , SHORT DESCRIPTION TECHNICAL DATA HF Antenna ID ISC.ANT310/310-A is distributed, already adjusted for most applications ex works. By means of jumpers the antenna can be adjusted to changing surrounding conditions, optimally. Typical applications for the antenna are libraries, document tracking, video shops, logistics at conveyor belts or sorting systems, access control and industrial data acquisition. The antenna can be employed in indoor- and outdoor use (IP65). With a maximum transmitting power of up to 8 W, the antenna can be operated with several HF readers by FEIG ELECTRONIC. Due to the used reader, read ranges of up to 70 cm can be realized. Dimensions (B x H x T) 318 mm x 338 mm x 30 mm Weight approx. 700 g Housing Plastic ASA Color white Protection class IP 65 Temperature range - Operation - 25 °C up to 55 °C - Storage - 25 °C up to 60 °C Relative air humidity 5…95 % (non-condensing) Operating frequency 13.56 MHz Maximum transmitting power 8 W Admissible transmitting power EU (REC 70-03 An. 9F1)* 8 W EU (EN 300 330) 4W USA (FCC Part 15) 4W Read ranges 1 1.0 W transmitting power 2 4.0 W transmitting power 3 8.0 W transmitting power 43 cm** 60 cm** 70 cm** Antenna connection 1 x SMA plug (50 Ω) Antenna connection cable RG58, 50 Ω, length approx. 3.6 m *In connection with the reader ID ISC.LR2500 and according regulations EN 300 330 and ERC Recommendation 70-03 Annex 9 Vol. F1 **Read ranges using a transponder 46 x 75 mm2 over the centre of the antenna and parallel orientation to the antenna 1 For example Mid Range Reader ID ISC.MR102 2 For example Long Range Reader ID ISC.LR2500 3 For example Long Range Reader ID ISC.LR2500 STANDARD CONFORMITY ORDER DESCRIPTION ID ISC.ANT310/310 HF Antenna Radio approval Europe USA EN 300 330 FCC 47 CFR Part 15 EMC EN 301 489 Safety Low voltage Human Exposure EN 60950 EN 50364 FEIG ELECTRONIC reserves the right to change specification without notice at any time. Stand of information: November 2016.
3249.000.00 价格&库存
很抱歉,暂时无法提供与“3249.000.00”相匹配的价格&库存,您可以联系我们找货
