1269.003.01
1269.003.01
    FEIGELECTRONIC
    ID ISC.ANT.PS-B ANT PWR SPLITTER
1269.003.01 数据手册
 HF Antenna Power Splitter ID ISC.ANT.PS-B FEATURES  Facilitates connection of two antennas to one reader  Supports dynamic tuning of the antennas  Designed for installation inside and outside (IP 65)  TECHNICAL DATA SHORT DESCRIPTION Dimensions (W x H x D) 130 mm x 94 mm x 57 mm Housing Plastic Polycarbonate (white) Weight approx. 275 g Protection class IP 65 Cable fittings 4 x cable fitting M16 x 1,5 Supply voltage 12-24 V DC (optional) Power consumption maximum 4 W Operating frequency 13.56 MHz Max. transmitting power* Only phase shifter** Else 5W 10 W HF connections 1 x input 2 x output SMA jack (50Ω) SMA jack (50Ω) Carrier frequency 13.56 MHz SWR maximum 1.2:1 (50Ω) Input loss maximum 0.6 dB Temperature range Operation Storage -25°C up to 55°C -40°C up to 85°C Order description: ID ISC.ANT.PS-B HF Power Splitter The ID ISC.ANT.PS-B is a 3 dB power splitter with galvanic isolation between input and two outputs. At the operating frequency of 13.56 MHz the impedance on all inputs and outputs is calibrated to 50Ω. Output X2 also provides a 90° phase shifter. This can be enabled by using two jumpers. The current on output X3 can be rotated by 180° with respect to output X2. If the device is connected to a suitable voltage source using terminal X4, the coaxial outputs can be used to power two antennas (using the Dynamic Tuning Board ID ISC.DAT-A) with DC voltage. Both outputs are internally wired in parallel. The galvanic isolation can be enabled by using two jumpers. The device is designed for installation indoors and outdoors. The connection cable from the reader to the Power Splitter is 3.6 m in length. * at input ** with resp. without transformer STANDARD CONFORMITY EMC EN 61000-6-3 EN 61000-6-2 Vibration EN 60068-2-6 10 Hz up to 150 Hz: 0.075 mm / 1 g Shock EN 60068-2-27 acceleration: 30 g Flame proof UL 1950 (Flame Proof HB, without cable) FEIG ELECTRONIC reserves the right to change specification without notice at any time. State of information: November 2016.
1269.003.01 价格&库存
很抱歉,暂时无法提供与“1269.003.01”相匹配的价格&库存,您可以联系我们找货
