AAT006 Low-Field TMR Angle Sensor
Features
• Tunneling Magnetoresistance (TMR) technology
• Extremely low power (as low as sub microamps)
• High output signal without amplification
• Immune to airgap variations
• Operates with as little as 15 Oersted field
• Sine and cosine and outputs
• −40°C to +125°C operating temperature
• Ultraminiature TDFN6 packages
Applications
• Battery-powered applications
• Knob position sensors
• Rotary encoders
• Automotive rotary position sensors
• Motor shaft position sensors
Description
AAT-Series angle sensors use unique Tunneling
Magnetoresistance (TMR) elements for large signals and
low power consumption.
The sensors provide sine and cosine signals defining the
angle of rotation. Outputs are proportional to the supply
voltage and peak-to-peak output voltages are much larger
than conventional sensor technologies.
Functional Diagram
Vcc
Vcc
Rota
tio
n
The AAT006 is a high-sensitivity member of the AATxxx
family, operating with as little as a 15 Oersted magnetic
field.
Cos
Sin
AAT006 sensors consist of two half-bridges, with a typical
bridge resistance of 1.25 MΩ for ultralow power.
GND
Parts are packaged in NVE’s 2.5 mm x 2.5 mm x 0.8 mm
TDFN6 surface-mount package.
GND
1
NVE Corporation
11409 Valley View Road, Eden Prairie, MN 55344-3617
Phone: (952) 829-9217
Fax: (952) 829-9189
www.nve.com
©NVE Corporation
Absolute Maximum Ratings
Parameter
Supply voltage
Reverse supply voltage
Storage temperature
ESD (Human Body Model)
Applied magnetic field
Min.
−40
Max.
7
−12
170
2000
Unlimited1
Units
Volts
Volts
°C
Volts
Oe
Operating Specifications
Parameter
Operating temperature
Symbol
Tmin; Tmax
Min.
−40
Typ.
Max.
125
Units
°C
0.8
1.5
3
MΩ
25°C with required
magnetic field.
130
200
mV/V
Over full rotation.
Device resistance
Peak-to-peak output signal
Offset voltage
Supply voltage
Required applied magnetic field
Repeatability, fixed bias2
Repeatability, variable bias3
VPP-SIN
VPP-COS
VOFFSET-SIN
VOFFSET-COS
VCC
−10
+10
mV/V
5.5
100
±0.5
±3
Test Condition
Temperature coefficient of resistance
TCOR
+0.09
V
Oe
deg.
deg.
% of peak-to-peak output;
25 Oe applied field; 25°C
%/°C
Output voltage temperature coefficient
TCOV
−0.13
%/°C
Nonsinusoidality4
Notes:
1.
2.
3.
4.
±1.5%
Constant
supply voltage.
Large magnetic fields CANNOT damage NVE sensors.
“Fixed Bias” means a fixed airgap between the bias magnet and sensor so the magnetic field at the sensor is constant.
“Variable Bias” means the magnetic field strength at the sensor can vary across the specification range.
Maximum deviation of either output from an ideal sine wave.
2
NVE Corporation
Fax: (952) 829-9189
www.nve.com
©NVE Corporation
Operation
Overview—Unique TMR technology
The heart of the unique sensor is an array of four Tunneling Magnetoresistance (TMR) elements in each quadrant. TMR
technology enables low power and miniaturization, making the sensors ideal for battery operation.
In a typical configuration, an external magnet provides a saturating magnetic field in the plane of the sensor, as illustrated below
for a bar magnet and a radially-magnetized disk magnet:
Figure 1. Sensor operation.
The device contains four sensing resistors at 90 degree intervals. The resistors are connected as two half-bridges, providing the
sine and cosine voltage outputs. For each half bridge, the resistance of one element increases and the other decreases as the field
rotates. Thus the bridge resistance, device resistance, and output impedances remain constant with rotation.
Transfer function
The half-bridge configuration provides a simple interface and can simplify external circuitry such as amplifiers and comparators.
Outputs are sinusoidal, centered around half the supply, and ratiometric with supply voltage. Mathematically, the outputs can be
expressed as:
VSIN = [VCC-SIN][(VSIN-MAX – VSIN-MIN) / 2)Sin θ + VCC-SIN / 2 + VOFFSET-SIN]
VCOS = [VCC-COS][(VCOS-MAX – VCOS-MIN) / 2)Cos θ + VCC-COS / 2 + VOFFSET-COS]
Where:
θ is the magnetic field angle;
VCOS and VSIN are the sensor output voltages (mV/V);
VCC-SIN and VCC-COS are the sensor supply voltages (normally tied together);
VSIN-MAX, VCOS-MAX, VSIN-MIN, and VCOS-MIN are the sensor output peak signal levels (mV/V); and
VOFFSET-SIN and VOFFSET-COS are the sensor offset voltages (mV/V),
defined as the average of the maximum and minimum outputs minus half the supply voltage.
Wide range of magnets and magnet locations
The sensors operate with fields from 15 Oe to 150 Oe. This wide magnetic field range allows inexpensive magnets and operation
over a wide range of magnet spacing. Larger or stronger magnets require more distance to avoid oversaturating the sensor; smaller
or weaker magnets may require closer spacing. Low-cost radially-magnetized ferrite disk magnets can be used with these sensors
in production. Bar magnets are also used in some configurations.
3
NVE Corporation
Fax: (952) 829-9189
www.nve.com
©NVE Corporation
Ideal for battery and harvested power
AAT-Series sensors are resistive devices with no active components, so they have no minimum voltage and can be powered from
single cells. With their low power, the sensors are well-suited for operation from batteries or harvested power, and can run
continuously for many years on small alkaline, silver oxide, or lithium button cells.
Harvested power is often intermittent, and AAT-Series sensors detect and maintain absolute position information. The sensors
immediately powers up indicating the correct position after power is restored.
One cycle per revolution
Other sensor types such as AMR have two cycles per revolution, so they cannot determine absolute position for 360-degree
rotation. AAT-Series sensors output one cycle per revolution and can unambiguously determine position within a full rotation.
Detects absolute position
Unlike some encoder types, AAT-Series sensors detect absolute position, and maintain position information when power is
removed. The sensor immediately powers up indicating the correct position.
4
NVE Corporation
Fax: (952) 829-9189
www.nve.com
©NVE Corporation
Application Circuitry
External comparators
A dual comparator can provide digital outputs from AAT angle sensors. Low-power comparators and large resistors are used to
avoid adding power consumption to low-power applications:
3.3 V
AAT00x Sensor
1
Vcc
6
Vcc
R3 (Cosine)
5M
100 nF
R2 (Sine)
R1 (Sine)
5M
GND
3
MCP
6542
GND
4
R4 (Cosine)
Sgn(Cos) Sgn(Sin)
5
Sin
2
Cos
90˚
180˚ 270˚
Rotation
360˚
Figure 2. External dual comparator for digital outputs.
Inherent comparator hysteresis eliminates noise at the transition points. The MCP6542 comparator hysteresis of 3.3 mV
corresponds to about 1 angular degree of hysteresis. Higher hysteresis comparators can be used for more noise immunity at the
expense of hysteresis.
NVE also offers ADT-Series sensors that include integrated comparators to replicate the circuit of Figure 2.
Quadrant outputs
A 2-to-4 line decoder can provide digital signals to indicate the quadrant of rotation:
3.3 V
AAT00x Sensor
1
Vcc
100 nF
R3 (Cosine)
6
Vcc
5M
R2 (Sine)
5
Sin
2
Cos
R1 (Sine)
GND
3
R4 (Cosine)
750
A Y3
Y2
Y1
B Y0
GND
4
5M
MCP
6542
0˚-90˚
270˚-360˚
90˚-180˚
180˚-270˚
SN74LV
C1G139
Figure 3. Digital Quadrant Outputs.
5
NVE Corporation
Fax: (952) 829-9189
www.nve.com
©NVE Corporation
Speed and direction signals
Commodity CMOS circuits can be added to create a precise encoder with direction and speed outputs. A flip-flop determines
direction by detecting the phasing between the two outputs. An exclusive-OR gate provides a digital signal with two cycles per
revolution, and transitions every 90 degrees:
3.3 V
AAT00x Sensor
1
Vcc
100 nF
6
Vcc
R3 (Cosine)
5M
R2 (Sine)
R1 (Sine)
5M
GND
3
R4 (Cosine)
7SZ86
Speed
(2/rev)
5
Sin
2
Cos
GND
4
TLV
3502
90˚ 180˚ 270˚ 360˚
D
Q
Direction
CLK
SN74
AUP1G79
Figure 4. Speed and direction signals.
Rotation reference signals
An AAT angle sensor and a single comparator can provide a precise angular reference point and a one cycle-per-rotation signal.
Comparing the sine and cosine outputs is more precise than comparing either to a reference because it corrects for temperature.
0.9 to 5.5 V
AAT00x Sensor
1
Vcc
100 nF
R3 (Cosine)
6
Vcc
R2 (Sine)
Sin
Cos
5
Sin
2
Cos
R1 (Sine)
GND
3
R4 (Cosine)
OUT
GND
4
0 45˚
OUT
TLV3691
225˚
360˚
Figure 5. Angular Reference Point Rotation Signal.
In this circuit, the output is high from nominal 45 to 225 degrees, and low from 225 to 45 degrees. A low voltage, low quiescent
current comparator is used to preserve the AAT sensors’ ultra-low power and wide supply range. Inherent comparator hysteresis
eliminates noise at the transition points. The TLV3691 comparator hysteresis of 17 mV corresponds to approximately 6 degrees of
hysteresis with a 1.5 V supply. A TS881 or similar comparator has a typical hysteresis of 4 mV, corresponding to 1.5 angular
degrees of hysteresis.
6
NVE Corporation
Fax: (952) 829-9189
www.nve.com
©NVE Corporation
Low-power amplification
AAT-Series sensors have high output signals without amplification, but if amplification is required, a circuit like the one below
can be used. The 10 megohm resistors and nanopower TLV522 op-amp minimize the added power consumption of the amplifier.
A gain of three amplifies the sensor’s typical peak-to-peak signal level of 200 mV/V to 60% of rail-to-rail (one volt/volt),
providing more usable signal without risk of saturating the amplifier for a sensor at the high end of the output signal range:
1.7 V
to 5.5 V
AAT00x Sensor
1
Vcc
10M
6
Vcc
R3 (Cosine)
100 nF
R2 (Sine)
R1 (Sine)
TLV522
10M
10M
GND
4
R4 (Cosine)
3Sin
10M
5
Sin
2
Cos
GND
3
10M
10M
3Cos
2x 10 pF
Figure 6. AAT006 3x Preamplifier.
Although AAT006 sensors are designed to be used primarily as two half bridges, if quadrature outputs are not required, a similar
differential amplifier circuit can provide a larger signal, more precision, and less temperature dependence than either the sine or
cosine output alone:
5V
AAT00x Sensor
1
Vcc
100 nF
R3 (Cosine)
6
Vcc
R2 (Sine)
Sin-Cos
OUT
5
Sin
2
Cos
R1 (Sine)
GND
3
R4 (Cosine)
2x
100K
GND
4
0 45˚
225˚
RG=33K
(Gain = 2.5)
(Vp-p)
REF
2x
100 pF
360˚
INA826
Figure 7. 2.5x AAT006 Sensor Differential Amplifier.
The differential (VSIN − VCOS) voltage has an amplitude of 1.41 times the amplitude of either output, or typically 282 mV/V peak-topeak. Therefore the amplifier gain of 2.5 provides a typical peak-to-peak output of 71% of rail-to-rail (one volt/volt). Note that the
zero crossing is at 45 degrees, versus to 0 degrees for the Sin output and 90 degrees for the Cos output. An instrumentation
amplifier can be used to minimize parts count when power consumption is not critical.
7
NVE Corporation
Fax: (952) 829-9189
www.nve.com
©NVE Corporation
Noise mitigation
High-impedance circuitry is inherently susceptible to noise. Common noise mitigation steps include:
• Power supply decoupling capacitors near the sensor (100 nF typical).
• Limiting the sensor output bandwidth to only what is needed. Because the sensor outputs are resistive, filter capacitors can
be connected directly to the outputs. The sensor output impedances are half the bridge resistance, so the cutoff frequency
is:
fc = 1/(π RB C)
where RB is the bridge resistance and C is the output capacitance.
• Digital filtering or averaging in microcontroller systems.
External comparator considerations
Low voltage, low quiescent current comparators are generally used to preserve the AAT sensors’ ultra-low power and wide supply
range.
Some hysteresis in external comparators is desirable to reduce noise and jitter at transition points. Too much hysteresis, however,
may cause undesirable errors. Low-hysteresis comparators are especially important in low voltage applications, since hysteresis is
a larger portion of the signals. Angular hysteresis relates to comparator hysteresis as follows:
θH =
(360/π)(VHC)
(VCC)(VPP)
Where:
θH the angular hysteresis in degrees;
VHC is the comparator’s hysteresis;
VCC is the sensor power supply; and
VPP is the sensor’s peak-to-peak sensitivity (typically 200 mV/V).
For example, MCP6542 comparators have hysteresis of 3.3 mV, corresponding to about 1 angular degree of hysteresis. TLV3691
or similar comparators have hysteresis of 17 mV, corresponding to approximately 6 degrees of hysteresis with a 1.5 V supply.
Ultralow power external CMOS
Any of the application circuits described in this section can use 74AUP-family logic rather than 74LVC if lower power is required
and five-volt operation is not needed.
8
NVE Corporation
Fax: (952) 829-9189
www.nve.com
©NVE Corporation
Pinout
1
Vcc
Rota
tio
n
0˚
6
Vcc
5
Sin
2
Cos
3
GND
4
GND
Part Marking: “FDSe”
AAT00x
Pin
1
2
3
4
5
6
Symbol
VCC-COS
Cos
GND
GND
Sin
VCC-SIN
Description
Supply voltage (up to 5.5 V) for the Cos sensor elements.
Corresponds to the cosine of the rotation angle.
Ground for the Cos sensor elements.
Ground for the Sin sensor elements.
Corresponds to the sine of the rotation angle.
Supply voltage for the Sin sensor elements.
Notes:
• Clockwise rotation as viewed from the top of the package is interpreted as increasing angle.
• The package center pad may be left floating or connected to ground.
• This product has been tested for electrostatic sensitivity to the limits stated in the specifications. However, NVE recommends that all
integrated circuits be handled with appropriate care to avoid damage. Damage caused by inappropriate handling or storage could range
from performance degradation to complete failure.
9
NVE Corporation
Fax: (952) 829-9189
www.nve.com
©NVE Corporation
2.5 mm x 2.5 mm TDFN6 Package
2.00 ± 0.05
0.80 MAX.
6
4
6
2.50±0.10
1.30±0.05
4
C0.10
PIN 1
ID
1
1
3
3
0.30±0.05
(6X)
2.50 ± 0.10
0.0-0.05
0.30±0.05
0.65 TYP.
(4X)
1.30 REF (2X)
0.20 REF
RoHS
Notes:
• Dimensions in millimeters.
• Soldering profile per JEDEC J-STD-020C, MSL 1.
COMPLIANT
10
NVE Corporation
Fax: (952) 829-9189
www.nve.com
©NVE Corporation
Revision History
April 2017
November 2016
Changes
• Improved device resistance spec. from 0.6 MΩ –2.5 MΩ to 0.8 MΩ –3 MΩ (p. 2).
• Reduced maximum applied field for operating specifications (p. 2).
• Clarified repeatability vs. accuracy (p. 2).
• Added nonsinusoidality specification (p. 2).
• Lower-power amplifier circuit (p. 7).
Changes
• Initial release of separate AAT006 datasheet (split out from AATxxx datasheet).
• Revised applications section.
11
NVE Corporation
Fax: (952) 829-9189
www.nve.com
©NVE Corporation
Datasheet Limitations
The information and data provided in datasheets shall define the specification of the product as agreed between NVE and its customer, unless NVE and
customer have explicitly agreed otherwise in writing. All specifications are based on NVE test protocols. In no event however, shall an agreement be
valid in which the NVE product is deemed to offer functions and qualities beyond those described in the datasheet.
Limited Warranty and Liability
Information in this document is believed to be accurate and reliable. However, NVE does not give any representations or warranties, expressed or
implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information.
In no event shall NVE be liable for any indirect, incidental, punitive, special or consequential damages (including, without limitation, lost profits, lost
savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on
tort (including negligence), warranty, breach of contract or any other legal theory.
Right to Make Changes
NVE reserves the right to make changes to information published in this document including, without limitation, specifications and product descriptions
at any time and without notice. This document supersedes and replaces all information supplied prior to its publication.
Use in Life-Critical or Safety-Critical Applications
Unless NVE and a customer explicitly agree otherwise in writing, NVE products are not designed, authorized or warranted to be suitable for use in life
support, life-critical or safety-critical devices or equipment. NVE accepts no liability for inclusion or use of NVE products in such applications and such
inclusion or use is at the customer’s own risk. Should the customer use NVE products for such application whether authorized by NVE or not, the
customer shall indemnify and hold NVE harmless against all claims and damages.
Applications
Applications described in this datasheet are illustrative only. NVE makes no representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Customers are responsible for the design and operation of their applications and products using NVE products, and NVE accepts no liability for any
assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the NVE product is suitable and fit for
the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customers. Customers should
provide appropriate design and operating safeguards to minimize the risks associated with their applications and products.
NVE does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s
applications or products, or the application or use by customer’s third party customers. The customer is responsible for all necessary testing for the
customer’s applications and products using NVE products in order to avoid a default of the applications and the products or of the application or use by
customer’s third party customers. NVE accepts no liability in this respect.
Limiting Values
Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the
device. Limiting values are stress ratings only and operation of the device at these or any other conditions above those given in the recommended
operating conditions of the datasheet is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the
quality and reliability of the device.
Terms and Conditions of Sale
In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. NVE hereby expressly objects to
applying the customer’s general terms and conditions with regard to the purchase of NVE products by customer.
No Offer to Sell or License
Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication
of any license under any copyrights, patents or other industrial or intellectual property rights.
Export Control
This document as well as the items described herein may be subject to export control regulations. Export might require a prior authorization from national authorities.
Automotive Qualified Products
Unless the datasheet expressly states that a specific NVE product is automotive qualified, the product is not suitable for automotive use. It is neither
qualified nor tested in accordance with automotive testing or application requirements. NVE accepts no liability for inclusion or use of non-automotive
qualified products in automotive equipment or applications.
In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall
use the product without NVE’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the
product for automotive applications beyond NVE’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies
NVE for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond NVE’s
standard warranty and NVE’s product specifications.
12
NVE Corporation
Fax: (952) 829-9189
www.nve.com
©NVE Corporation
An ISO 9001 Certified Company
NVE Corporation
Eden Prairie, MN 55344-3617 USA
Telephone: (952) 829-9217
Fax: (952) 829-9189
www.nve.com
e-mail: sensor-info@nve.com
©NVE Corporation
All rights are reserved. Reproduction in whole or in part is prohibited without the prior written consent of the copyright owner.
SB-00-054_AAT006-10E
April 2017
13
NVE Corporation
Fax: (952) 829-9189
www.nve.com
©NVE Corporation
