JTH6E06BE
JTH6E06BE
    KLEINTOOLS
    3/32''HEXBALLJOURNEYMANT-HAN
JTH6E06BE 数据手册
Hex-Key Wrenches Klein hex-keys are the tools professionals cannot afford to be without. Heat-treated and tempered for superior strength and durability, Klein hex-keys are designed for a precise fit in sockets, preventing slippage and stripping of the socket. Hex-Key Wrenches Blade-through handle design for high torque applications T-Handle Hex-Keys T-handle design delivers maximum power Ball-End TORX® Hex Soft touch grips for maximum control and comfort Chamfered end for ease of use Tip-Ident™ sizes marked Convenient hang hole Size laser etched on blade TORX® is a trademark of Acument Intellectual Properties, LLC. T-Handle Ball-End Hex-Keys - SAE Includes core Journeyman™ T-handle hex-key features plus: Short blade-through handle provides maximum tool versatility • JTH6E13BE Cat. No. JTH6E06BE JTH6E07BE JTH6E08BE JTH6E09BE JTH6E10BE JTH6E11BE Hex Size 3/32" 7/64" 1/8" 9/64" 5/32" 3/16" Blade Length 6" (152.4 mm) 6" (152.4 mm) 6" (152.4 mm) 6" (152.4 mm) 6" (152.4 mm) 6" (152.4 mm) Weight 0.64 oz (18.1 g) 0.80 oz (22.7 g) 1.0 oz (28 g) 1.1 oz (31 g) 0.12 lb (0.05 kg) 0.14 lb (0.06 kg) Cat. No. JTH6E12BE JTH6E13BE JTH6E14BE JTH6E15BE JTH6E17BE Hex Size 7/32" 1/4" 5/16" 3/8" 1/2" Blade Length 6" (152.4 mm) 6" (152.4 mm) 6" (152.4 mm) 6" (152.4 mm) 6" (152.4 mm) Weight 0.17 lb (0.08 kg) 0.27 lb (0.12 kg) 0.35 lb (0.16 kg) 0.45 lb (0.20 kg) 0.70 lb (0.32 kg) T-Handle Ball-End Hex-Key Set with Stand - SAE Includes core Journeyman™ T-handle hex-key features plus: Metal stand for convenient hanging, storage on bench or wall Short blade-through handle provides maximum tool versatility • • Cat. No. JTH610EB Set Contains Weight 3.0 lb (1.4 kg) Cat. No. Hex Size Blade Length JTH6E06BE JTH6E07BE JTH6E08BE JTH6E09BE JTH6E10BE JTH6E11BE JTH6E12BE JTH6E13BE JTH6E14BE JTH6E15BE 3/32" 7/64" 1/8" 9/64" 5/32" 3/16" 7/32" 1/4" 5/16" 3/8" 6" (152.4 mm) 6" (152.4 mm) 6" (152.4 mm) 6" (152.4 mm) 6" (152.4 mm) 6" (152.4 mm) 6" (152.4 mm) 6" (152.4 mm) 6" (152.4 mm) 6" (152.4 mm) 90 www.kleintools.com JTH610EB See page 310 for additional information on warnings. Hex-Key Wrenches T-Handle Hex-Keys T-Handle Hex-Keys - SAE Includes core Journeyman™ T-handle hex-key features plus: Short blade-through handle provides maximum tool versatility • T-Handle Hex-Key Sets with Stand SAE Includes core Journeyman™ T-handle hex-key features plus: Metal stand for convenient mounting on bench or wall Short blade-through handle provides maximum tool versatility • • JTH6E15 JTH610E Cat. No. Hex Size Blade Length Weight Cat. No. JTH410E Cat. No. 4" Length JTH4E06 JTH4E07 JTH4E08 JTH4E09 JTH4E10 JTH4E11 JTH4E12 JTH4E13 JTH4E14 JTH4E15 JTH4E17 3/32" 7/64" 1/8" 9/64" 5/32" 3/16" 7/32" 1/4" 5/16" 3/8" 1/2" 4" (101.6 mm) 4" (101.6 mm) 4" (101.6 mm) 4" (101.6 mm) 4" (101.6 mm) 4" (101.6 mm) 4" (101.6 mm) 4" (101.6 mm) 4" (101.6 mm) 4" (101.6 mm) 4" (101.6 mm) 0.05 oz (1.4 g) 0.05 oz (1.4 g) 0.05 oz (1.4 g) 0.06 oz (1.7 g) 0.11 oz (3.1 g) 0.13 oz (3.7 g) 0.14 oz (4.0 g) 0.24 oz (6.8 g) 0.30 oz (8.5 g) 0.38 oz (10.8 g) 0.59 oz (16.7 g) 3/32" 7/64" 1/8" 9/64" 5/32" 3/16" 7/32" 1/4" 5/16" 3/8" 1/2" 6" (152.4 mm) 6" (152.4 mm) 6" (152.4 mm) 6" (152.4 mm) 6" (152.4 mm) 6" (152.4 mm) 6" (152.4 mm) 6" (152.4 mm) 6" (152.4 mm) 6" (152.4 mm) 6" (152.4 mm) 0.05 oz (1.4 g) 0.05 oz (1.4 g) 0.05 oz (1.4 g) 0.06 oz (1.7 g) 0.11 oz (3.1 g) 0.13 oz (3.7 g) 0.14 oz (4.0 g) 0.24 oz (6.8 g) 0.30 oz (8.5 g) 0.38 oz (10.8 g) 0.59 oz (16.7 g) 3/32" 7/64" 1/8" 9/64" 5/32" 3/16" 7/32" 1/4" 5/16" 3/8" 1/2" 9" (228.6 mm) 9" (228.6 mm) 9" (228.6 mm) 9" (228.6 mm) 9" (228.6 mm) 9" (228.6 mm) 9" (228.6 mm) 9" (228.6 mm) 9" (228.6 mm) 9" (228.6 mm) 9" (228.6 mm) 0.05 oz (1.4 g) 0.05 oz (1.4 g) 0.06 oz (1.7 g) 0.06 oz (1.7 g) 0.11 oz (3.1 g) 0.14 oz (4.0 g) 0.18 oz (5.1 g) 0.27 oz (7.7 g) 0.35 oz (9.9 g) 0.45 oz (12.8 g) 0.70 oz (19.8 g) 6" Length JTH6E06 JTH6E07 JTH6E08 JTH6E09 JTH6E10 JTH6E11 JTH6E12 JTH6E13 JTH6E14 JTH6E15 JTH6E17 9" Length JTH9E06 JTH9E07 JTH9E08 JTH9E09 JTH9E10 JTH9E11 JTH9E12 JTH9E13 JTH9E14 JTH9E15 JTH9E17 See page 310 for additional information on warnings. Set Contains T-Handle Set with Stand, SAE, 4" Blade 10 Pc Cat. No. JTH610E Blade Length JTH4E06 3/32" 4" (101.6 mm) JTH4E07 7/64" 4" (101.6 mm) JTH4E08 1/8" 4" (101.6 mm) JTH4E09 9/64" 4" (101.6 mm) JTH4E10 5/32" 4" (101.6 mm) JTH4E11 3/16" 4" (101.6 mm) JTH4E12 7/32" 4" (101.6 mm) JTH4E13 1/4" 4" (101.6 mm) JTH4E14 5/16" 4" (101.6 mm) JTH4E15 3/8" 4" (101.6 mm) Set Contains T-Handle Set with Stand, SAE, 6" Blade 10 Pc Cat. No. Cat. No. JTH910E Hex Size Weight 2.7 lb (1.2 kg) Hex Size Weight 2.7 lb (1.2 kg) Blade Length JTH6E06 3/32" 6" (152.4 mm) JTH6E07 7/64" 6" (152.4 mm) JTH6E08 1/8" 6" (152.4 mm) JTH6E09 9/64" 6" (152.4 mm) JTH6E10 5/32" 6" (152.4 mm) JTH6E11 3/16" 6" (152.4 mm) JTH6E12 7/32" 6" (152.4 mm) JTH6E13 1/4" 6" (152.4 mm) JTH6E14 5/16" 6" (152.4 mm) JTH6E15 3/8" 6" (152.4 mm) Set Contains T-Handle Set with Stand, SAE, 9" Blade 10 Pc Cat. No. Hex Size Blade Length JTH9E06 JTH9E07 JTH9E08 JTH9E09 JTH9E10 JTH9E11 JTH9E12 JTH9E13 JTH9E14 JTH9E15 3/32" 7/64" 1/8" 9/64" 5/32" 3/16" 7/32" 1/4" 5/16" 3/8" 9" (228.6 mm) 9" (228.6 mm) 9" (228.6 mm) 9" (228.6 mm) 9" (228.6 mm) 9" (228.6 mm) 9" (228.6 mm) 9" (228.6 mm) 9" (228.6 mm) 9" (228.6 mm) Weight 3.6 lb (1.6 kg) 91 www.kleintools.com Hex-Key Wrenches T-Handle Hex-Keys T-Handle Ball-End Hex-Keys - Metric Includes core Journeyman™ T-handle hex-key features plus: Short blade-through handle provides maximum tool versatility • Cat. No. JTH6M2BE JTH6M25BE JTH6M3BE JTH6M4BE JTH6M5BE JTH6M6BE JTH6M8BE JTH6M10BE Hex Size 2 mm 2.5 mm 3 mm 4 mm 5 mm 6 mm 8 mm 10 mm Blade Length 6" (152.4 mm) 6" (152.4 mm) 6" (152.4 mm) 6" (152.4 mm) 6" (152.4 mm) 6" (152.4 mm) 6" (152.4 mm) 6" (152.4 mm) Weight 0.64 oz (18.1 g) 0.80 oz (22.7 g) 1.0 oz (28 g) 1.1 oz (31 g) 0.15 lb (0.07 kg) 0.19 lb (0.09 kg) 0.35 lb (0.16 kg) 0.48 lb (0.22 kg) JTH6M8BE T-Handle Ball-End Hex-Key Set with Stand - Metric Includes core Journeyman™ T-handle hex-key features plus: Metal stand for convenient mounting on bench or wall Short blade-through handle provides maximum tool versatility • • Cat. No. JTH68MB Set Contains Weight 2.7 lb (1.2 kg) Cat. No. Hex Size Blade Length JTH6M2BE JTH6M25BE JTH6M3BE JTH6M4BE JTH6M5BE JTH6M6BE JTH6M8BE JTH6M10BE 2 mm 2.5 mm 3 mm 4 mm 5 mm 6 mm 8 mm 10 mm 6" (152.4 mm) 6" (152.4 mm) 6" (152.4 mm) 6" (152.4 mm) 6" (152.4 mm) 6" (152.4 mm) 6" (152.4 mm) 6" (152.4 mm) JTH68MB T-Handle Hex-Keys - Metric Includes core Journeyman™ T-handle hex-key features plus: Short blade-through handle provides maximum tool versatility • Cat. No. JTH6M2 JTH6M25 JTH6M3 JTH6M4 JTH6M5 JTH6M6 JTH6M8 JTH6M10 JTH9M10 JTH9M2 JTH9M25 JTH9M3 JTH9M4 JTH9M5 JTH9M6 JTH9M8 Hex Size 2 mm 2.5 mm 3 mm 4 mm 5 mm 6 mm 8 mm 10 mm 10 mm 2 mm 2.5 mm 3 mm 4 mm 5 mm 6 mm 8 mm 92 www.kleintools.com Blade Length 6" (152.4 mm) 6" (152.4 mm) 6" (152.4 mm) 6" (152.4 mm) 6" (152.4 mm) 6" (152.4 mm) 6" (152.4 mm) 6" (152.4 mm) 9" (228.6 mm) 9" (228.6 mm) 9" (228.6 mm) 9" (228.6 mm) 9" (228.6 mm) 9" (228.6 mm) 9" (228.6 mm) 9" (228.6 mm) Weight 0.64 oz (18.1 g) 0.80 oz (22.7 g) 1.0 oz (28 g) 0.10 oz (2.8 g) 0.15 lb (0.07 kg) 0.17 lb (0.08 kg) 0.35 lb (0.16 kg) 0.48 lb (0.22 kg) 0.48 oz (13.6 g) 0.05 oz (1.4 g) 0.05 oz (1.4 g) 0.06 oz (1.7 g) 1.4 oz (40 g) 0.18 oz (5.1 g) 0.22 oz (6.2 g) 0.42 oz (11.9 g) JTH6M8 See page 310 for additional information on warnings. Hex-Key Wrenches T-Handle Hex-Keys T-Handle Hex-Key Sets with Stand - Metric Includes core Journeyman™ T-handle hex-key features plus: Metal stand for convenient mounting on bench or wall Short blade-through handle provides maximum tool versatility Cat. No. JTH68M Cat. No. • • Cat. No. JTH98M JTH68M Set Contains 6" Metric Journeyman T-Handle Set 8 Pc Hex Size Weight 1.8 lb (0.8 kg) Blade Length JTH6M2 2 mm 6" (152.4 mm) JTH6M25 2.5 mm 6" (152.4 mm) JTH6M3 3 mm 6" (152.4 mm) JTH6M4 4 mm 6" (152.4 mm) JTH6M5 5 mm 6" (152.4 mm) JTH6M6 6 mm 6" (152.4 mm) JTH6M8 8 mm 6" (152.4 mm) JTH6M10 10 mm 6" (152.4 mm) Set Contains 9" Metric Journeyman T-Handle Set 8 Pc Cat. No. Hex Size Blade Length JTH9M2 JTH9M25 JTH9M3 JTH9M4 JTH9M5 JTH9M6 JTH9M8 JTH9M10 2 mm 2.5 mm 3 mm 4 mm 5 mm 6 mm 8 mm 10 mm 9" (228.6 mm) 9" (228.6 mm) 9" (228.6 mm) 9" (228.6 mm) 9" (228.6 mm) 9" (228.6 mm) 9" (228.6 mm) 9" (228.6 mm) Weight 2.1 lb (1.0 kg) T-Handle Hex-Keys - TORX® Includes core features plus: Short blade-through handle provides maximum tool versatility • Cat. No. JTH6T10 JTH6T15 JTH6T20 JTH6T25 JTH6T27 JTH6T30 JTH6T40 Hex Size T10 T15 T20 T25 T27 T30 T40 Blade Length 6" (152.4 mm) 6" (152.4 mm) 6" (152.4 mm) 6" (152.4 mm) 6" (152.4 mm) 6" (152.4 mm) 6" (152.4 mm) Weight 0.80 oz (22.7 g) 1.0 oz (28 g) 1.1 oz (31 g) 0.13 lb (0.06 kg) 0.16 lb (0.07 kg) 0.18 lb (0.08 kg) 0.29 lb (0.13 kg) JTH6T40 TORX® is a trademark of Acument Intellectual Properties, LLC. T-Handle Hex-Key Set with Stand - TORX® Includes core features plus: Metal stand for convenient mounting on bench or wall Short blade-through handle provides maximum tool versatility • • Cat. No. JTH67T Set Contains 6" Torx® T-Handle Set with Stand 7 Pc Cat. No. Hex Size Blade Length JTH6T10 JTH6T15 JTH6T20 JTH6T25 JTH6T27 JTH6T30 JTH6T40 T10 T15 T20 T25 T27 T30 T40 6" (152.4 mm) 6" (152.4 mm) 6" (152.4 mm) 6" (152.4 mm) 6" (152.4 mm) 6" (152.4 mm) 6" (152.4 mm) Weight 1.3 lb (0.6 kg) JTH67T TORX® is a trademark of Acument Intellectual Properties, LLC. See page 310 for additional information on warnings. 93 www.kleintools.com Hex-Key Wrenches Folding Hex-Key Sets Hex-Key Sets • Two key positions (straight-out or right angle) for extra leverage ends are square-cut for a secure full-depth fit and maximum contact with the hex • Hex socket to prevent slippage and stripping of the socket • Handy sets fit in your pocket or tool box easily and help eliminate the lost key problem • Made in the U.S.A. Improved Strength 70579 Cat. No. 70591 70581 70579 70582 70580 Description Nine-Key Inch Folding Hex Key Set Eight-Key Inch Folding Hex Key Set Five-Key Inch Folding Hex Key Set Seven-Key Metric Folding Hex Key Set Six-Key Metric Folding Hex Key Set Size 5/64", 3/32", 7/64", 1/8", 9/64", 5/32", 3/16", 7/32", 1/4" 1/20", 1/16", 5/64", 3/32", 7/64", 1/8", 9/64", 5/32" 3/16", 7/32", 1/4", 5/16", 3/8" 1-1/2 mm, 2 mm, 2-1/2 mm, 3 mm, 4 mm, 5 mm, 6 mm 3 mm, 4 mm, 5 mm, 6 mm, 8 mm, 10 mm Handle Length 4-3/8" (111.1 mm) 3-1/16" (77.8 mm) 5-3/8" (136.5 mm) 3-45/64" (94 mm) 5-3/8" (136.5 mm) Key Lengths 2-11/16" to 3-13/16" (68.3 to 96.8 mm) 1-7/8" to 3" (47.6 to 76.2 mm) 2-11/16" to 3-13/16" (68.3 to 96.8 mm) 19/32" to 1-25/32" (15 to 45 mm) 2-3/8" to 4" (60 to 101 mm) Color Silver Silver Silver Silver Silver Grip-It™ Hex-Key Sets • Blades rotate independently up to 270° fit so hex tool end reduces stripping problems. Keys are industrial strength, impact• Precision resistant and tested for performance to below freezing • Glass-reinforced nylon handle ends are square-cut for a secure full-depth fit and maximum contact with the hex socket • Hex to prevent slippage and stripping of the socket (Cat. Nos. 70570, 70573, 70574, and 70575) design allows for a thicker neck diameter increasing torque capacity, while maintaining • Ball operational angles to 25% (Cat. Nos. 70571 and 70572) • Made in the U.S.A. Cat. No. 70570 70571 70572 70573 70574 70575 Description Grip-It® Five Key Hex Set - Inch Grip-It® Five Key Ball Hex Set - Inch Grip-It® Five Key Ball Hex Set - Metric Grip-It® 12 Key Hex Set - Inch/Metric Size 3/16", 7/32", 1/4", 5/16", 3/8" 3/16", 7/32", 1/4", 5/16", 3/8" 5 mm, 6 mm, 7 mm, 8 mm, 10 mm 5/64", 3/32", 7/64", 1/8", 9/64", 5/32", 1.5 mm, 2 mm, 2.5 mm, 3 mm, 4 mm, 5 mm ® Grip-It Nine Key Hex Set 2 Positions 5/64", 3/32", 7/64", 1/8", 9/64", 5/32", 3/16", 7/32", 1/4" Grip-It® Nine Key Hex Set Square Cut 3/64", 1/16", 5/64", 3/32", 7/64", 1/8", 9/64", 5/32", 3/16" Weight 0.50 lb (0.23 kg) 0.20 lb (0.09 kg) 0.85 lb (0.39 kg) 0.27 lb (0.12 kg) 0.85 lb (0.39 kg) 70570 Handle Length 4-7/16" (112.7 mm) 4-7/16" (112.7 mm) 4-7/16" (112.7 mm) 4-7/16" (112.7 mm) Key Lengths 1-37/64" to 1-31/32" (40.1 to 50.0 mm) 1-35/64" to2" (39.3 mm to 50.8 mm) 1-19/32" to 1-15/16" (40.5 to 49.2 mm) 1-7/16" to 2-17/64" (36.5 to 57.6 mm) Color Yellow Yellow Red Blue Weight 0.58 lb (0.26 kg) 0.58 lb (0.26 kg) 0.58 lb (0.26 kg) 0.30 lb (0.14 kg) 4-7/16" (112.7 mm) 3-13/16" (96.8 mm) 1-3/4" to 2-17/64" (44.5 to 57.6 mm) 1-25/64" to 1-27/32" (35.3 to 46.8 mm) Yellow 0.33 lb (0.15 kg) Yellow 0.20 lb (0.09 kg) TORX® Sets Folding TORX® Set • TORX® drive cuts slippage, saves fasteners, efficiently transmits more torque to the work • Keys are tough, heat-treated chrome-nickel alloy steel for strength and durability • Keys fold flat into handle • Can be used straight out or at an angle for extra leverage Cat. No. 70586 Size T10, T15, T20, T25, T27, T30, T40 Handle Length 4-3/8" (111.1 mm) Key Lengths 2-13/16" to 3" (71.4 to 76.2 mm) Color Silver Weight 0.30 lb (0.14 kg) 70586 TORX® is a trademark of Acument Intellectual Properties, LLC. 94 www.kleintools.com See page 310 for additional information on warnings. Hex-Key Wrenches L-Style Hex-Keys Rust and corrosion resistant surfaces Top-grade alloy steel Ball-End Extra length for hard-to-reach applications Heat-treated and tempered for added strength and durability Hex Short length for higher torque situations and low clearances BL8 L-Style Hex-Keys L-Style Ball-End Hex-Keys Includes core L-Style hex key features plus: Allows easy access, even in restricted areas • Cat. No. LL2 LL4 LL5 LL6 LL7 LL8 LL9 LL10 LL12 LL14 LL16 LL20 LL24 LL8 Hex Size 0.050" 1/16" 5/64" 3/32" 7/64" 1/8" 9/64" 5/32" 3/16" 7/32" 1/4" 5/16" 3/8" Short Arm Length 9/16" (14.28 mm) 5/8" (15.87 mm) 11/16" (17.46 mm) 3/4" (19.05 mm) 13/16" (20.63 mm) 7/8" (22.22 mm) 15/16" (23.81 mm) 1" (25.4 mm) 1-1/8" (28.57 mm) 1-1/4" (31.75 mm) 1-3/8" (34.92 mm) 1-9/16" (39.68 mm) 1-3/4" (44.45 mm) Long Arm Length 2-7/8" (73.0 mm) 3-1/16" (77.8 mm) 3-1/4" (82.6 mm) 3-1/2" (88.9 mm) 3-11/16" (93.7 mm) 3-7/8" (98.4 mm) 4-1/8" (104.8 mm) 4-3/8" (111.1 mm) 4-11/16" (119.1 mm) 5-1/16" (128.6 mm) 5-1/2" (139.7 mm) 6-5/16" (160.33 mm) 7-1/8" (181.0 mm) Weight 0.08 oz (2.3 g) 0.08 oz (2.3 g) 0.08 oz (2.3 g) 0.16 oz (4.5 g) 0.32 oz (9.1 g) 0.32 oz (9.1 g) 0.48 oz (13.6 g) 0.48 oz (13.6 g) 0.80 oz (22.7 g) 0.70 lb (0.32 kg) 0.10 lb (0.05 kg) 0.18 lb (0.08 kg) 0.25 lb (0.11 kg) 1.5 mm 2 mm 2.5 mm 3 mm 4 mm 5 mm 6 mm 8 mm 10 mm 9/16" (14.28 mm) 11/16" (17.46 mm) 13/16" (20.63 mm) 7/8" (22.22 mm) 1" (25.4 mm) 1-1/4" (31.75 mm) 1-7/16" (36.51 mm) 1-11/16" (42.86 mm) 1-15/16" (49.21 mm) 3-1/8" (79.4 mm) 3-1/32" (77.0 mm) 3-9/16" (90.5 mm) 4" (101.6 mm) 4-1/2" (114.3 mm) 4-7/8" (123.8 mm) 5-11/16" (144.5 mm) 6-5/16" (160.33 mm) 7-1/8" (181.0 mm) 0.08 oz (2.3 g) 0.08 oz (2.3 g) 0.16 oz (4.5 g) 0.32 oz (9.1 g) 0.48 oz (13.6 g) 0.80 oz (22.7 g) 1.3 oz (37 g) 0.15 lb (0.07 kg) 0.25 lb (0.11 kg) Metric LLM15 LLM2 LLM25 LLM3 LLM4 LLM5 LLM6 LLM8 LLM10 Includes core L-Style hex key features plus: Allows easy access, even in restricted areas Ball-end works on angles up to 30° • • Cat. No. BL2 BL4 BL5 BL6 BL7 BL8 BL9 BL10 BL12 BL14 BL16 BL20 BL24 Hex Size 0.050" 1/16" 5/64" 3/32" 7/64" 1/8" 9/64" 5/32" 3/16" 7/32" 1/4" 5/16" 3/8" Short Arm Length 9/16" (14.28 mm) 5/8" (15.87 mm) 11/16" (17.46 mm) 3/4" (19.05 mm) 3/4" (19.05 mm) 7/8" (22.22 mm) 15/16" (23.81 mm) 1" (25.4 mm) 1-1/8" (28.57 mm) 1-1/4" (31.75 mm) 1-3/8" (34.92 mm) 1-9/16" (39.68 mm) 1-3/4" (44.45 mm) Long Arm Length 2-7/8" (73.0 mm) 3-1/16" (77.8 mm) 3-1/4" (82.6 mm) 3-1/2" (88.9 mm) 3-11/16" (93.7 mm) 3-7/8" (98.4 mm) 4-1/8" (104.8 mm) 4-3/8" (111.1 mm) 4-11/16" (119.1 mm) 5-1/16" (128.6 mm) 5-13/16" (147.6 mm) 6-5/16" (160.33 mm) 7-1/8" (181.0 mm) Weight 0.03 oz (0.9 g) 0.03 oz (0.9 g) 0.08 oz (2.3 g) 0.08 oz (2.3 g) 0.16 oz (4.5 g) 0.32 oz (9.1 g) 0.32 oz (9.1 g) 0.48 oz (13.6 g) 0.80 oz (22.7 g) 1.0 oz (28 g) 1.4 oz (40 g) 0.17 lb (0.08 kg) 0.23 lb (0.10 kg) 1.5 mm 2 mm 2.5 mm 3 mm 4 mm 5 mm 6 mm 8 mm 10 mm 9/16" (14.28 mm) 11/16" (17.46 mm) 13/16" (20.63 mm) 7/8" (22.22 mm) 1" (25.4 mm) 1-1/4" (31.75 mm) 1-7/16" (36.51 mm) 1-11/16" (42.86 mm) 1-15/16" (49.21 mm) 3-1/16" (77.8 mm) 3-5/16" (84.1 mm) 3-9/16" (90.5 mm) 4" (101.6 mm) 4-1/2" (114.3 mm) 4-7/8" (123.8 mm) 5-11/16" (144.5 mm) 6-5/16" (160.33 mm) 6-1/8" (155.6 mm) 0.16 oz (4.5 g) 0.16 oz (4.5 g) 0.16 oz (4.5 g) 0.32 oz (9.1 g) 0.48 oz (13.6 g) 0.80 oz (22.7 g) 1.3 oz (37 g) 0.14 lb (0.06 kg) 0.24 lb (0.11 kg) Metric See page 310 for additional information on warnings. BLM15 BLM2 BLM25 BLM3 BLM4 BLM5 BLM6 BLM8 BLM10 95 www.kleintools.com Hex-Key Wrenches L-Style Hex-Key Sets L-Style Caddy Sets Includes core L-Style hex key features plus: L-style hex-keys organized in convenient, durable caddy sets Each set contains a unique locking feature and marked slots for each key Ball-end works on angles up to 30° (Cat. Nos. BLK12 and BLMK10) • • • Cat. No. BLK12 Cat. No. Cat. No. BLMK10 BLK12 Cat. No. LLK12 Cat. No. LMK10 LMK10 96 www.kleintools.com Set Contains L Style Ball End Hex Key Caddy Set 12 Pc Hex Size Short Arm Length Weight 0.53 lb (0.24 kg) Long Arm Length BL2 0.050" 9/16" (14.28 mm) BL4 1/16" 5/8" (15.87 mm) BL5 5/64" 11/16" (17.46 mm) BL6 3/32" 3/4" (19.05 mm) BL7 7/64" 3/4" (19.05 mm) BL8 1/8" 7/8" (22.22 mm) BL9 9/64" 15/16" (23.81 mm) BL10 5/32" 1" (25.4 mm) BL12 3/16" 1-1/8" (28.57 mm) BL14 7/32" 1-1/4" (31.75 mm) BL16 1/4" 1-3/8" (34.92 mm) BL20 5/16" 1-9/16" (39.68 mm) Set Contains L Style Ball End Hex Key Caddy Set Metric 9 Pc 2-7/8" (73.0 mm) 3-1/16" (77.8 mm) 3-1/4" (82.6 mm) 3-1/2" (88.9 mm) 3-11/16" (93.7 mm) 3-7/8" (98.4 mm) 4-1/8" (104.8 mm) 4-3/8" (111.1 mm) 4-11/16" (119.1 mm) 5-1/16" (128.6 mm) 5-13/16" (147.6 mm) 6-5/16" (160.33 mm) Cat. No. Hex Size Weight 0.62 lb (0.28 kg) Short Arm Length Long Arm Length BLM15 1.5 mm 9/16" (14.28 mm) BLM2 2 mm 11/16" (17.46 mm) BLM25 2.5 mm 13/16" (20.63 mm) BLM3 3 mm 7/8" (22.22 mm) BLM4 4 mm 1" (25.4 mm) BLM5 5 mm 1-1/4" (31.75 mm) BLM6 6 mm 1-7/16" (36.51 mm) BLM8 8 mm 1-11/16" (42.86 mm) BLM10 10 mm 1-15/16" (49.21 mm) Set Contains L-Style Hex Key Caddy Set 12 Pc 3-1/16" (77.8 mm) 3-5/16" (84.1 mm) 3-9/16" (90.5 mm) 4" (101.6 mm) 4-1/2" (114.3 mm) 4-7/8" (123.8 mm) 5-11/16" (144.5 mm) 6-5/16" (160.33 mm) 6-1/8" (155.6 mm) Cat. No. Long Arm Length Hex Size Short Arm Length Weight 0.54 lb (0.24 kg) LL2 0.050" 9/16" (14.28 mm) LL4 1/16" 5/8" (15.87 mm) LL5 5/64" 11/16" (17.46 mm) LL6 3/32" 3/4" (19.05 mm) LL7 7/64" 13/16" (20.63 mm) LL8 1/8" 7/8" (22.22 mm) LL9 9/64" 15/16" (23.81 mm) LL10 5/32" 1" (25.4 mm) LL12 3/16" 1-1/8" (28.57 mm) LL14 7/32" 1-1/4" (31.75 mm) LL16 1/4" 1-3/8" (34.92 mm) LL20 5/16" 1-9/16" (39.68 mm) Set Contains L-Style Hex Key Caddy Set Metric 9 Pc 2-7/8" (73.0 mm) 3-1/16" (77.8 mm) 3-1/4" (82.6 mm) 3-1/2" (88.9 mm) 3-11/16" (93.7 mm) 3-7/8" (98.4 mm) 4-1/8" (104.8 mm) 4-3/8" (111.1 mm) 4-11/16" (119.1 mm) 5-1/16" (128.6 mm) 5-1/2" (139.7 mm) 6-5/16" (160.33 mm) Cat. No. Hex Size Short Arm Length Long Arm Length LLM15 LLM2 LLM25 LLM3 LLM4 LLM5 LLM6 LLM8 LLM10 1.5 mm 2 mm 2.5 mm 3 mm 4 mm 5 mm 6 mm 8 mm 10 mm 9/16" (14.28 mm) 11/16" (17.46 mm) 13/16" (20.63 mm) 7/8" (22.22 mm) 1" (25.4 mm) 1-1/4" (31.75 mm) 1-7/16" (36.51 mm) 1-11/16" (42.86 mm) 1-15/16" (49.21 mm) 3-1/8" (79.4 mm) 3-1/32" (77.0 mm) 3-9/16" (90.5 mm) 4" (101.6 mm) 4-1/2" (114.3 mm) 4-7/8" (123.8 mm) 5-11/16" (144.5 mm) 6-5/16" (160.33 mm) 7-1/8" (181.0 mm) Weight 0.63 lb (0.29 kg) See page 310 for additional information on warnings.
JTH6E06BE
- 物料型号:文档列出了多种型号的六角扳手,例如JTH6E06BE、JTH6E07BE等,以及它们的尺寸、刀片长度和重量。 - 器件简介:Klein hex-keys是专业人士不可或缺的工具,经过热处理和回火以提供卓越的强度和耐用性,设计用于在插座中精确配合,防止滑脱和损坏插座。 - 引脚分配:文档中没有明确提到引脚分配,但列出了不同型号的六角扳手及其对应的尺寸。 - 参数特性:包括不同长度的刀片、重量、以及一些特殊设计,如球头TORX®六角扳手的软触握把、倒角端部和尺寸标记。 - 功能详解:文档介绍了不同类型的六角扳手,如直通手柄设计适用于高扭矩应用的Journeyman系列,以及提供最大力量的T型手柄六角扳手。 - 应用信息:文档提供了不同尺寸和长度的六角扳手,适用于不同的应用场景。 - 封装信息:文档中列出了不同套装的六角扳手,包括它们包含的型号和重量。
JTH6E06BE 价格&库存
很抱歉,暂时无法提供与“JTH6E06BE”相匹配的价格&库存,您可以联系我们找货
JTH6E06BE
  • 1+70.009491+8.74837
  • 5+64.859145+8.10478
  • 10+62.7724610+7.84403
  • 25+60.1165625+7.51215
库存:25
