ANG-11HAW1
ANG-11HAW1
    ZF
    ANGLE POSITION SENSOR, PROGRAMMA
ANG-11HAW1 数据手册
Angle Position Sensors ANG Sensors Thin, programmable, non-contact magnetic position sensors capable of continuous rotation, with dual outputs available. Description The ANG Series sensors are non-contact, intrinsically linear position sensors with one or two independent (redundant) outputs. The sensors operate through the use of Hall Effect technology with magnetic fields generated by permanent magnets. They provide a linear change in voltage output (ratiometric to the input voltage) corresponding to an angular rotation of the input shaft. Actuator magnet part number AS500106 is required to assure proper operation (ordered separately). Features Typical Applications                   Angular position sensor with high tolerance for misalignment O Non-contact angular position sensing and full 360 rotation Custom programming available for: angle range, slope, PWM output – contact factory No mechanical interface means no parts to wear out or jam Comes with 20 AWG 305 mm (12”) discrete wire leads RoHS Compliant IP68* Maximum air gap of 6 mm (0.24”) Compliant to industrial/automotive EMC/EMI/ESD directives Hydraulic valves Hydraulic controls Electric drives Pneumatic controls Zero-contact encoder alternative Gear selection / shifting position Lifting / ride height position Throttle / pedal position Steering wheel position Environmental Specifications Operating Temperature Ingress Protection -40 ⁰C to 140 ⁰C (-40 ⁰F to 284 ⁰F) IP68* **Contact ZF for details on testing conditions Electrical Specifications Input Supply Voltage 5.0 VDC ± 10% Output Signal Input Current Resolution Accuracy, overall Output Linearity Maximum Overvoltage Reverse Battery Protection 16 VDC 12 VDC 0.5 – 4.5 VDC (with 5 VDC input) Single output 8 mA typ., 10 mA max. Dual output 16 mA typ., 20 mA max. 12 bit Programmed angle sensing range 35⁰ < 65⁰ : ± 2.5% Full scale Programmed angle sensing range: 65⁰ < 360⁰ : ± 2.0% Full scale Programmed angle sensing range 35⁰ < 65⁰ : ± 2.5% Full scale Programmed angle sensing range: 65⁰ < 360⁰ : ± 1.0% Full scale Mechanical Specifications Measuring Range Air Gap Eccentricity 0⁰ to 360⁰, customizable (see graph) 1 mm to 6 mm (application dependent); 2.5 mm typ. ± 2 mm (0.08”) www.cherryswitches.com Page 1 of 2 Last update 2016-07-12; specifications subject to change without notice. Products Part Number ANG-11HAW1 ANG-21HAW1 Output Analog single Analog dual Interface 20 AWG x 305 mm (12") discrete wires 20 AWG x 305 mm (12") discrete wires Typical Output vs. Angular Rotation (as percentage of input) Dimensions mm (inches) www.cherryswitches.com Page 2 of 2 Last update 2016-07-12; specifications subject to change without notice.
ANG-11HAW1 价格&库存
很抱歉,暂时无法提供与“ANG-11HAW1”相匹配的价格&库存,您可以联系我们找货
