Angle Position Sensors
ANG Sensors
Thin, programmable, non-contact magnetic position sensors
capable of continuous rotation, with dual outputs available.
Description
The ANG Series sensors are non-contact, intrinsically linear position sensors with one or two independent (redundant) outputs. The
sensors operate through the use of Hall Effect technology with magnetic fields generated by permanent magnets. They provide a
linear change in voltage output (ratiometric to the input voltage) corresponding to an angular rotation of the input shaft.
Actuator magnet part number AS500106 is required to assure proper operation (ordered separately).
Features
Typical Applications
Angular position sensor with high tolerance for misalignment
O
Non-contact angular position sensing and full 360 rotation
Custom programming available for: angle range, slope, PWM
output – contact factory
No mechanical interface means no parts to wear out or jam
Comes with 20 AWG 305 mm (12”) discrete wire leads
RoHS Compliant
IP68*
Maximum air gap of 6 mm (0.24”)
Compliant to industrial/automotive EMC/EMI/ESD directives
Hydraulic valves
Hydraulic controls
Electric drives
Pneumatic controls
Zero-contact encoder alternative
Gear selection / shifting position
Lifting / ride height position
Throttle / pedal position
Steering wheel position
Environmental Specifications
Operating Temperature
Ingress Protection
-40 ⁰C to 140 ⁰C (-40 ⁰F to 284 ⁰F)
IP68*
**Contact ZF for details on testing conditions
Electrical Specifications
Input
Supply Voltage
5.0 VDC ± 10%
Output Signal
Input Current
Resolution
Accuracy, overall
Output Linearity
Maximum Overvoltage
Reverse Battery Protection
16 VDC
12 VDC
0.5 – 4.5 VDC (with 5 VDC input)
Single output
8 mA typ., 10 mA max.
Dual output
16 mA typ., 20 mA max.
12 bit
Programmed angle sensing range 35⁰ < 65⁰ : ± 2.5% Full scale
Programmed angle sensing range: 65⁰ < 360⁰ : ± 2.0% Full scale
Programmed angle sensing range: 65⁰ < 360⁰ : ± 1.0% Full scale
Mechanical Specifications
Measuring Range
Air Gap
Eccentricity
0⁰ to 360⁰, customizable (see graph)
1 mm to 6 mm (application dependent); 2.5 mm typ.
± 2 mm (0.08”)
www.cherryswitches.com
Page 1 of 2
Last update 2016-07-12; specifications subject to change without notice.
Products
Part Number
ANG-11HAW1
ANG-21HAW1
Output
Analog single
Analog dual
Interface
20 AWG x 305 mm (12") discrete wires
Typical Output vs. Angular Rotation (as percentage of input)
Dimensions mm (inches)
Page 2 of 2
很抱歉,暂时无法提供与“ANG-21HAW1”相匹配的价格&库存,您可以联系我们找货
