56409
56409
    KLEINTOOLS
    9'(2.7M)MID-FLEXGLOWRODSET
56409 数据手册
Wire Pulling and Conduit Tools Pulling wire and working with conduit is very challenging without the proper tools. Klein Tools' complete line of conduit tools allows you to get the job done while saving time, effort and materials. Wire Pulling & Conduit Tools FISH TAPES Unique sloped handle optimizes hand position for quick hand-over-hand rewinds Polypropylene case and handle offer the maximum in impact resistance Raised fingergrips transfer 100% of the winding power from your hand and fingers Round inner ring design provides a smooth, surface for winding and rewinding Available in steel and fiberglass with a wide variety of tips US Patents: 8899554 D574,277; 8,212,178; 8,168,921; 8,164,025 Other patents pending Multi-Groove Fiberglass Fish Tapes Additional Features: Fiberglass Performance at 25% Lower Cost!* Rigidity for long distance Less surface contact when pushing through crowded conduit Durable 7" (178 mm) leader helps push through crowded conduit Available resin eyelet for total non-conductivity • • • • • Old Profile New Profile 56055 Less surface contact with wires Cat. No. Tape Size Reel Diameter Weight 13" (330.2 mm) 17" (431.8 mm) 3.0 lbs. (1.36 kg) 6.2 lbs. (2.81 kg) 13" (330.2 mm) 13" (330.2 mm) 17" (431.8 mm) 2.3 lbs. (1.04 kg) 3.1 lbs. (1.41 kg) 6.0 lbs. (2.72 kg) Multi-Groove Fiberglass - 7" (179 mm) Spiral Leader 56055 56056 100 ft. L x 3/16" W (30.5 m L x 4.8 mm W) 200 ft. L x 3/16" W (61.0 m L x 4.8 mm W) Multi-Groove Fiberglass - Non-Conductive 56057 56058 56059 50 ft. L x 3/16" W (15.2 m L x 4.8 mm W) 100 ft. L x 3/16" W (30.5 m L x 4.8 mm W) 200 ft. L x 3/16" W (61.0 m L x 4.8 mm W) Replacement Parts and Kits Cat. No. 56115 Description Fiberglass Fish Tape Repair Kit 56025 56116 56120 Non-conductive Fish Tape Repair Kit Fiberglass Fish Tape Replacement Eyelets Fiberglass Fish Tape Replacement Leaders Included (1) High Leverage Crimper, (2) 7" (177.8 mm) Flexible Leaders, (2) Eyelets, (1) Tube Quick-Drying Glue Non-Conductive Eyelets ( 2 Ea.), Tube Quick-Drying Glue (1 Ea) — — Weight 2.2 lbs. (1.00 kg) 2.2 lbs. (1.00 kg) 1 oz. (27 g) 1.8 oz. (50 g) *When compared to published price of Klein Tools fiberglass fish tapes. 122 www.kleintools.com See page 310 for additional information on warnings. WARNING: Never remove screws while fish tape is coiled inside reel. Wire Pulling & Conduit Tools Fish Tapes Fiberglass Fish Tapes Additional Features: Designed for flexibility and easy navigation through conduit runs Non-conductive, fiberglass fish tape slides easily over existing wires and through multiple bends Durable 7" (179 mm) leader helps push through crowded conduit The lightweight and strong fiberglass composite tape resists harsh elements and is strength rated up to 500 pulling pounds Repair kit (Cat. No. 56115) available to replace tips Replacement metal eyelets (Cat. No. 56116) and spiral steel leaders (Cat. No. 56120) available • • • • 49’ 50’ 1' permanent laser etched descending increments. • • Cat. No. 56009 56010 56014 Tape Size 50 ft. L x 3/16" W (7" Leader) (15.2 m L x 4.8 mm W [177.8 mm Leader]) 100 ft. L x 3/16" W (7" leader) (30.5 m L x 4.8 mm W [177.8 mm Leader]) 200 ft. L x 3/16" W (7" Leader) (60.96 m L x 4.8 mm W [177.8 mm Leader]) Reel Diameter 13" (330.2 mm) 13" (330.2 mm) 17" (431.8 mm) Weight 2.8 lbs. (1.27 kg) 3.5 lbs. (1.59 kg) 6.2 lbs. (2.81 kg) 56010 Replacement Tapes Cat. No. 56115 Description Fiberglass Fish Tape Repair Kit 56116 56120 Fiberglass Fish Tape Replacement Eyelets Fiberglass Fish Tape Replacement Leaders Included (1) High Leverage Crimper, (2) 7" (177.8 mm) Flexible Leaders, (2) Eyelets, (1) Tube Quick-Drying Glue — — Weight 2.2 lbs. (1.00 kg) 1 oz. (27 g) 1.8 oz. (50 g) 1/8" (3 mm) Wide Steel Fish Tapes Additional Features: High strength spring steel fish tapes are stiff for long runs and are great for heavy duty wire pulls Full grip style handle gives you a firm, steady grip as youpull tape from the case Stainless Steel fish tape (Cat. Nos. 56007, 56008) is corrosion resistant and extends the life of the tool • • • 1' permanent laser etched descending increments. Cat. No. Tape Size Reel Diameter Weight 125' L x 1/8" W x 0.062" H (38.1 m L x 3.2 mm W x 1.57 mm H) 240 ft. L x 1/8" W x 0.062" H (73.2 m L x 3.2 mm W x 1.57 mm H) 13" (330.2 mm) 13" (330.2 mm) 4.7 lbs. (2.13 kg) 7.5 lbs. (3.40 kg) 25 ft. L x 1/8" W x 0.045" H (7.6 m L x 3.2 mm W x 1.14 mm H) 50 ft. L x 1/8" W x 0.045" H (15.2 m L x 3.2 mm W x 1.14 mm H) 65 ft. L x 1/8" W x 0.062" H (19.8 m L x 3.2 mm W x 1.57 mm H) 125' L x 1/8" W x 0.062" H (38.1 m L x 3.2 mm W x 1.57 mm H) 240 ft. L x 1/8" W x 0.062" H (73.2 m L x 3.2 mm W x 1.57 mm H) 7" (177.8 mm) 7" (177.8 mm) 9" (228.6 mm) 13" (330.2 mm) 13" (330.2 mm) 1.0 lbs. (0.45 kg) 1.3 lbs. (0.59 kg) 2.6 lbs. (1.18 kg) 4.7 lbs. (2.13 kg) 7.5 lbs. (3.40 kg) Stainless Steel for Corrosion Resistance 56007 56008 56001 Flat Steel 56000 56001 56002 56003 56004 Replacement Tapes 56065 56125 56240 65 ft. L x 1/8" W x 0.062" H (19.8 m L x 3.2 mm W x 1.57 mm H) 125 ft. L x 1/8" W x 0.062" H (38.1 m L x 3.2 mm W x 1.57 mm H) 240 ft. L x 1/8" W x 0.062" H (73.2 m L x 3.2 mm W x 1.57 mm H) ​ — ​— ​— 1.7 lbs. (0.77 kg) 3.3 lbs. (1.50 kg) 6.1 lbs. (2.77 kg) 123 See page 310 for additional information on warnings. WARNING: Never remove screws while fish tape is coiled inside reel. www.kleintools.com Wire Pulling & Conduit Tools Fish Tapes 1/4" (6 mm) Wide Steel Fish Tapes Additional Features: Tempered, high quality tape keeps its stability as it glides between surfaces for effective pushing and pulling of wire under carpets, through insulated walls and over suspended ceilings 25' length with no snag tip, is perfect for short wire runs associated with light commercial, residential and voice-data-videoaudio installations (Cat. No. 56005) • • 56005 has a no snag plastic tip 1' permanent laser etched descending increments. Cat. No. Tape Size 56005 25 ft. L x 1/4" W x 0.030" H (7.6 m L x 6.4 mm W x 0.76mm H) 56006 100' L x 1/4" W x 0.062" H (30.5 m L x 6.4 mm W x 1.57 mm H) Reel Diameter 7" (177.8 mm) 13" (330.2 mm) 56005 Weight 1.1 lbs. (0.50 kg) 6.8 lbs. (3.08 kg) Spiral Steel Fish Tapes Additional Features: Designed for super flexibility and easy navigation through conduit runs Slides easily over existing wires and through multiple bends The durable spiral steel tape construction yields a maximum pulling force of up to 250 lbs. Replacement metal eyelets (Cat. No. 56116) and spiral steel leaders (Cat. No. 56120) available • • • • Cat. No. 56013 Tape Size 50 ft. L x 3/16" W (15.2 m L x 4.8 mm W) Reel Diameter 13" (330.2 mm) Weight 5.1 lbs. (2.31 kg) Replacement Parts and Kits Cat. No. 56116 56120 Description Fiberglass Fish Tape Replacement Eyelets Fiberglass Fish Tape Replacement Leaders Length 1-1/2" (38.1 mm) 8-15/16" (227.0 mm) Weight 1 oz. (27 g) 1.8 oz. (50 g) 56013 Fish Tape Accessories Fiberglass Fish Tape Repair Kit high leverage ratcheting crimper, two replacement eyelets, two 7" (179 mm) replacement • Contains leaders, one tube of quick dry glue and comprehensive instructions ratcheting crimper (Cat. No. 56115V) cuts tape cleanly, strips tapes and crimps on • Multi-function new attachments • Newly crimped on eyelets meet or exceed original factory pulling strength requirements • Protective carry case firmly holds all tools and additional parts in handy, organized compartments • Cat. No. 56025 is for repairing non-conductive fiberglass fish tapes Cat. No. 56115 56025 Included (1) High Leverage Crimper, (2) 7" (177.8 mm) Flexible Leaders, (2) Eyelets, (1) Tube Quick-Drying Glue Non-Conductive Eyelets ( 2 Ea.), Tube Quick-Drying Glue (1 Ea) 124 www.kleintools.com 56115 Weight 2.2 lbs. (1.00 kg) 2.2 lbs. (1.00 kg) See page 310 for additional information on warnings. Wire Pulling & Conduit Tools Fish Tape Accessories 2-Pack 7" (179 mm) Replacement Flexible Leaders & 6-Pack Replacement Eyelets • For use only with fiberglass fish tapes (Cat. No. 56009, 56010 & 56014) • Attach with Klein Tools ratcheting crimper (Cat. No. 56115V) available in kit 56115 only Cat. No. 56120 56116 Length 8-15/16" (227.0 mm) 1-1/2" (38.1 mm) 56120 Weight 1.8 oz. (50 g) 1 oz. (27 g) 56116 13" (330 mm) Flexible Leader for Steel Fish Tapes • For use with 1/8" (3 mm) wide steel fish tapes • Heavy duty construction is strength rated up to 250 pulling pounds • High capacity eyelet holds up to five #12 unstripped wires and seven #10 bare wires • Retrofit instructions included 3/16" (5 mm) diameter tape has a rustproof inner steel cable core wrapped with a • The spiral cover for exceptional flexibility leader guides steel tapes through 90° bends and makes pulling and pushing • Flexible flat steel tapes easier Cat. No. 50350 Diameter 3/16" (4.8 mm) Length 13-1/2" (342.9 mm) Weight 1.6 oz. (45 g) 6 Loop Wire Pulling Leader • Save time by attaching leader to the end of a fish tape and pull up to six wires at once • Braided steel construction provides up to 450 lbs. pull strength on main eyelet • Flexible construction allows for easy navigation through multiple bends in conduit • Staggered loop lengths won't overlap and clog pipe • For use with 1/8" and 1/4" (3 mm and 6 mm) flat steel fish tapes Cat. No. 56107 Length 11-1/4" (285.8 mm) Diameter 3/16" (4.8 mm) See page 310 for additional information on warnings. 56107 Weight 3.2 oz. (91 g) Steel Fish Tape Swivel Eyelet • For use with 1/8" (6 mm) wide steel fish tapes • Swivel head design helps prevent kinks and allows smoother, easier fishing in tight turns • High capacity eyelet holds up to five #12 unstripped wires or seven #10 bare wires • High strength steel construction allows for optimal performance over repeated uses • Retrofit instructions included Cat. No. 50351 50350 Length 1-1/2" (38.1 mm) 50351 Weight 0.5 oz. (14 g) 125 www.kleintools.com Wire Pulling & Conduit Tools Fish Rods & Accessories Exclusive Splinter Guard™ protection from painful fiberglass splinters LO flex – long, straight feeding HIGH flex – tight bends in walls MID flex – all needs in between Rods have threaded beveled connectors to attach to desired length and prevent snagging on obstructions Luminescent glow rods provide added visibility in dark work spaces Shines 2X brighter and lasts 2X longer than ordinary glow rods Fish and Glow Rods Additional Features: Variety of flexibilities and lengths for any application such as walls, drop ceilings, attics, crawl spaces, etc. Sets include bull nose and hook attachments to attach and grab wires Cat. No. 56430 also includes illuminated tip • • • 56325 56418 Cat. No. Description Included Diameter Overall Length Weight Fish Rods 56312 56324 56325 12' (3.7 m) Lo-Flex Fish Rod Set (3) 1/4" (6.4 mm) Diameter 4' (1.2 m) Fish Rods with Bullet Nose and Hook Attachments 24' (7.3 m) Lo-Flex Fish Rod Set (4) 1/4" Diameter 6' (1.5 m) Fish Rods with Bullet Nose and Hook Attachments 25' (7.6 m) Fish and Glow Rod Set (5) 1/4" 1/4" (6.4 mm) Diameter 4' Diameter 4' (1.2 m) Fish Rods, Fish Rods, (1) 3/16" 3/16" (4.8 mm) Diameter 5' 1/4" (6.4 mm) 12 ft. (3.7 m) 1/4" (6.4 mm) 24' (7.3 m) 1/4" to 3/16" 25 ft. (7.6 m) (6.4 to 4.8 mm) 1.1 lbs. (0.50 kg) 1.9 lbs. (0.86 kg) 1.8 lbs. (0.82 kg) 5/32" (4.0 mm) 3/16" (4.8 mm) 3/16" (4.8 mm) 5/32" (4.0 mm) 3/16" (4.8 mm) 3.2 oz. (91 g) 8.8 oz. (249 g) 13.6 oz. (386 g) 13.6 oz. (386 g) 1.2 lbs. (0.54 kg) Glow Rods 56406 56409 56415 56418 56430 6' (1.8 m) Hi-Flex Glow Rod 9' (2.7 m) Mid-Flex Glow Rod Set 15' (4.6 m) Mid-Flex Glow Rod Set 18' (5.5 m) Hi-Flex Glow Rod Set 30' Glow Rod Set ​ (6) 3/16" (4.76 mm) Diameter 18" (457.2 mm) Glow Rods with Bullet Nose and Hook Attachments (3) 3/16" (4.8 mm) Diameter 5' (1.5 m) Glow Rods with Bullet Nose and Hook Attachments (3) 5/32" (4 mm) Diameter 6' (1.8 m) Glow Rods with Bullet Nose and Hook Attachments (6) 3/15" (4.7 mm) Diameter x 5' (1.5 m) Glow Rods with Bullet Nose, Hook, and LED-Illuminated Tip Attachments 6 ft. (1.8 m) 9 ft. (2.7 m) 15 ft. (4.6 m) 18 ft. (5.5 m) 30 ft. (9.1 m) Deluxe Fish and Glow Rod Kit • Heavy-duty storage case with fitted pockets and straps for organization • Large handles fit over the shoulder for easy transport • Convenient zipper pocket for accessory storage Cat. No. 56326 Included (2) 1/4" (6.4 mm) Diameter 6 ft. (1.8 m) Lo-Flex and (2) 1/4" (6.4 mm) Diameter 4 ft. (1.2 m) Lo-Flex Fish Rods, (3) 3/16" (4.8 mm) Diameter 5 ft. (1.5 m) Mid-Flex Glow Rods, (3) 5/32" (4 mm) Diameter 6 ft. (1.8 m) Hi-Flex Glow Rods, (1) Hook, (1) Bullet Nose, and (1) Carrying Case Illuminated Fish Rod Tip • Lights up for maximum visibility in dark spaces • Bright white, omni-directional LED light for long life • Threaded top for hook or bullet nose attachment (not included) • Fits drilled holes as small as 5/8" (16 mm) • Compatible with Lo, Mid and High flex rods • Replaceable batteries included • U.S. Pat. No. 9,062,834 Cat. No. 56119 56326 Description Illuminated Fish Rod Tip 126 www.kleintools.com Dimensions 2.5" L x 37/64" Diameter (63.5 mm L x 14.7 mm Diameter) Overall Length 75" (1905.0 mm) Weight 3.8 lbs. (1.72 kg) Fish Rod Accessories help guide, grab, • Attachments attach and steer wire or cable with Lo, Mid and High • Compatible flex rods 56104 56119 Weight 5.0 oz. (142 g) Cat. No. Description Included 56104 3 Piece Fish and Glow (1) Whisk Attachment (1) Bullet Nose Rod Attachment Set Attachment (1) Hook Attachment Weight 0.2 oz. (5.7 g) See page 310 for additional information on warnings. Wire Pulling & Conduit Tools Wire Pulling Tools WireSpanner™ - Telescopic Pole 18' • Extends to 18' (5.4 m) in 10 seconds • Easily retrieve cable from a distance without needing an extra pair of hands to shorten installation time • Large hook attachment pulls multiple wires easily • Friction-twist lock pole design stays locked in place Cat. No. Compact Length • Lightweight resin slides easily over obstructions SRS56036 32" (812.8 mm) • Compact design retracts to 32" (813 mm) for easy storage SRS56036 Extended Length 18 ft. (5.5 m) Weight 2.8 lbs. (1.27 kg) Polymer Fish Rod Set with Glow-in-the-Dark Leaders • Non-conductive rods designed for working in confined spaces • Great for routing cables in wire racks and on short runs • Attachments glow in the dark for ease of use 14" (356 mm) rods of various flexibilities and illumination for a range of individual (or • Includes 56" (1.4 m) combined) wire pulling applications • Includes five Glow-in-the-Dark leaders (hook, bullet, mini-eyelet, domed-eyelet and claw) • Convenient storage tube protects the rods between use and fits easily into your bag or toolbox Cat. No. SRS56038 Extended Length 56" (1.4 m) Weight 4.0 oz. (113 g) Magnetic Wire Pulling System system allows you to effortlessly pull cable • This behind walls by yourself • Navigates through insulation and other obstructions for routing cable between drywall and • Perfect insulation or fixture installations leader eyelet securely connects to most • Swivel wires and mesh wire pulling grips nylon leader-pull with 20' (6.1 m) of • Non-marring heavy-duty nylon rope eyelet for wire tie-on SRS56038 5 Attachments Included Hook Bullet Mini-Eyelet Domed-Eyelet Claw SRS56037 Cat. No. SRS56037 Length 20 ft. (6.1 m ) Weight 6.4 oz. (181 g) Wire Pulling Lubricant Description Wire Pulling Foam Lubricant Weight 1.2 lbs. (0.54 kg) *Based on job site pulls with foam in 3/4" conduit when used as directed. WARNING: • Contents under pressure. Do not expose container to direct sunlight or temperatures above 120°F. Do not transport or store near heat sources. Keep cans dry and away from sources of ignition. If frozen, gradually warm to room temperature. • Do not use wet product on live circuits. Compound is electrically conductive before it dries. See page 310 for additional information on warnings. LING COM UL UND PO Cat. No. 51100 WIRE P Wire Pulling Foam Lubricant • NO DRIPS! NO STAINS! NO MESS! • One can equals one gallon or 4 quarts of wax/gel lubricants* • Foam lubricant is applied directly into the conduit. No need to pre-coat wires • No mess formula stays where it is applied, even in vertical conduit • Dissolves clean from hands and clothing 51100 127 www.kleintools.com Wire Pulling & Conduit Tools Wire Pulling Lubricant One-Quart Premium Synthetic Clear™ • Designed for use primarily in finished workspaces (i.e. around painted walls and carpeted floors) • The crystal clear formulation is easy to clean-up and will not stain • Excellent all purpose lubricant for electrical or datacom applications • Compatible with most types of cable jackets • Will not separate out in hot environments for when exposed to freezing temperatures Cat. No. 51028 Size 1 Quart (0.9 L) Container Squeeze Bottle Temperature Range 20° F to 122° F (-6° C to 50° C) Weight 2.3 lbs. (1.04 kg) Wire Pulling Lubricant 842F 51028 Premium Synthetic Wax™ • High performance lubricant for general electrical and utility applications • Temperature stable and does not liquify and drop off after high temperature exposure • Compatible with most types of cable, including low density polyethylene • Superior "clingability" coats wires and conduit evenly • Exceptional lubricity • Non-staining, slow-drying, easy clean-up formula Wire Pulling Lubricant 842F Cat. No. 51010 51012 51013 56117 Size 1 Quart (0.9 L) 1 Gallon (3.8 L) 5 Gallon (18.9 L) 1 Quart (0.9 L) Container Squeeze Bottle Bucket Bucket Squeeze Bottle - 6 Pack Temperature Range 20° F to 122° F (-6° C to 50° C) 20° F to 122° F (-6° C to 50° C) 20° F to 122° F (-6° C to 50° C) 20° F to 122° F (-6° C to 50° C) Weight 2.3 lbs. (1.04 kg) 8.8 lbs. (3.99 kg) 44.0 lbs. (19.96 kg) 13.5 lbs. (6.12 kg) 51010 51012 51015 51017 56108 56110 Premium Synthetic Polymer™ • Excellent all-purpose lubricant for electrical, telecommunications and data applications • Easy-to-apply gel evenly clings instantly to the cable for easy handling and application • Compatible with most types of cable, including polyethylene and semi conducting jackets • Superior "clingability" coats wires and conduit evenly • Non-staining, slow-drying, easy clean-up formula CERTIFIED TO CSA STANDARD C22.2 NO. 249-96 Cat. No. 51015 51017 51018 Size 1 Quart (0.9 L) 1 Gallon (3.8 L) 5 Gallon (18.9 L) Container Squeeze Bottle Bucket Bucket Temperature Range 20° F to 140° F (-6° C to 60° C) 20° F to 140° F (-6° C to 60° C) 20° F to 140° F (-6° C to 60° C) Weight 2.3 lbs. (1.04 kg) 8.8 lbs. (3.99 kg) 44.0 lbs. (19.96 kg) Wire Pulling Supplies Poly Pull Line polypropylene line with manual or power fishing • Use systems for light duty cable or rope pulling applications to use storage containers quickly dispense a • Ready tangle free line and also protects line from direct sunlight • Line is resistant to rot and mildew • Up to 210 lbs. (95.2 kg) average breaking strength Cat. No. 56108 56110 Description Poly Pull Line with Orange Tracer 500' Poly Pull Line with Orange Tracer 6500' 128 www.kleintools.com Container One-Quart Size w/Locking Lid Five-Gallon Bucket Weight 1.0 lbs. (0.45 kg) 11.0 lbs. (4.99 kg) See page 310 for additional information on warnings. WARNING: Do not use wet product on live circuits. Compound is electrically conductive before it dries. Wire Pulling & Conduit Tools Conduit Tools Conduit Locknut Wrench • Easily attach locknuts in tight or deep cut-in boxes • For 1/2" and 3/4" connectors • Direct-drive heads rotate each other when twisted • Heavy-duty steel construction enables needed torque to loosen or tighten connectors • Perfect for remodel work where box is filled with existing wires 56999 US Patent pending Cat. No. 56999 Fitting Size 1/2" and 3/4" Overall Length 9" (228.6 mm) Weight 11.2 oz. (318 g) High-Leverage Side-Cutting Pliers - Fish Tape Pulling Additional Features: Easily pulls 1/8" or 1/4" flat steel fish tape without damaging the tape High-leverage design. Rivet is closer to the cutting edge for 46% greater cutting and gripping power than other pliers designs Streamlined design Cat. No. J2000-9NECRTP crimps non-insulated connectors, lugs, and terminals • • • • Cat. No. D213-9NETP Nose Type Overall Length New England 9-3/8" (238.1 mm) Jaw Length 1-19/32" (40.5 mm) D213-9NETP Jaw Width 1-1/4" (31.8 mm) Jaw Thickness Knife Length 5/8" (15.9 mm) 25/32" (19.8 mm) Handle Finish Handle Color Plastic-Dipped Dark Blue Weight 1.1 lbs. (0.50 kg) 1-19/32" (40.5 mm) 1-1/4" (31.8 mm) 5/8" (15.9 mm) 25/32" (19.8 mm) Journeyman Dark Blue/Black 1.1 lbs. (0.50 kg) 1-19/32" (40.5 mm) 1-1/4" (31.8 mm) 5/8" (15.9 mm) 25/32" (19.8 mm) Royal Blue 1.1 lbs. (0.50 kg) 1-1/4" (31.8 mm) 1-1/4" (31.8 mm) 5/8" (15.9 mm) 5/8" (15.9 mm) 25/32" (19.8 mm) Journeyman 25/32" (19.8 mm) Journeyman Light Blue/Black Blue/Black 1.1 lbs. (0.50 kg) 1.1 lbs. (0.50 kg) JourneymanTM Series – Dual-material handles J213-9NETP New England 9-1/2" (241.3 mm) 2000 Series* – Heavy-duty cutting knives D2000-9NETP New England 9-3/8" (238.1 mm) Plastic-Dipped JourneymanTM 2000 Series* – Dual-material handles J2000-9NETP New England 9-1/2" (241.3 mm) J2000-9NECRTP New England 9-1/2" (241.3 mm) 1-19/32" (40.5 mm) 1-19/32" (40.5 mm) *Cuts ACSR, screws, nails, and most hardened wire. Features combination polished and black-oxide finish. Conduit Locknut and Reaming Pliers • Tightens 1/2" (13 mm) and 3/4" (19 mm) EMT or 1/2" (13 mm) rigid locknuts • Fits liquid tight fittings and caps • Reams and deburrs both inside and outside of conduit • Knurled jaws at nose tip pull wire or fish tape • Machined nose fits snugly into locknut wings Tightens Bodies & Caps Cat. No. D333-8 Overall Length 7-3/4" (196.9 mm) Jaw Length 1-5/8" (41.3 mm) Jaw Width 15/16" (23.8 mm) Cuchillas Jaw Thickness Couteaux 1/2" (12.7 mm) D333-8 Tightens Locknuts Cuchillas Point Thickness Couteaux 3/16" (4.8 mm) Handle Finish Plastic-Dipped Handle Color Yellow Weight 8.8 oz. (249 g) Conduit-Fitting and Reaming Screwdriver design keeps tip from slipping out of screws, especially when • Hooded-blade tightening hard-to-reach conduit fittings. Thicker hood is designed for rugged use and smooths 1/2" (13 mm), 3/4" (19 mm), and 1" (25 mm) thin-wall • Reams conduit ends to protect wire and permit correct installation of fittings • Reams both the inside and outside of the conduit at the same time • Longer Cushion-Grip handle provides comfort and more torque for reaming • Replaceable reaming blade is now held in place with a 1/6" (1.5 mm) set screw Cat. No. 85191 19353 Tip Size 5/16" (7.9 mm) See page 310 for additional information on warnings. Shank Length 2-1/2" (63.5 mm) Conduit Reamer Replacement Blade 85191 Overall Length 7-1/2" (190.5 mm) Weight 8.0 oz. (227 g) 0.16 oz. (4.5 g) 129 www.kleintools.com Wire Pulling & Conduit Tools Conduit Benders The tradtional Benfield® head design accurately and consistently performs common bends such as Stub Ups, Offsets, Back-to-Back and Saddle Bends Exclusive design reduces rippling and ovaling of conduit Wide foot pedal provides excellent stability, leverage and comfort Interior hook surface prevents conduit from rolling or twisting during bends Interior clamp securely holds conduit while cutting with hacksaw Easily visible arrow for ease of alignment on conduit marks Bold cast-in symbols, degree scales, multiplier scales and center of bend marks help save time on the job Aluminum Conduit Benders Additional Features: Lightweight die-cast aluminum construction Both Cat. Nos. 56206 and 56207 come assembled with #51427 handle • • Cat. No. 56206 56207 Description Aluminum Conduit Bender 1/2" EMT Assembled Aluminum Bender 3/4" EMT Thinwall/EMT 1/2" (12.7 mm) 3/4" (19.1 mm) Rigid/IMC ​— 1/2" (12.7 mm) Radius 4" (101.6 mm) 5" (127.0 mm) Weight 4.4 lbs. (2.00 kg) 5.4 lbs. (2.45 kg) 56207 Iron Conduit Benders Additional Features: High strength steel handle features a swaged end for inserting conduit to correct overbends (Cat. Nos. 56203 & 56204 only) Bright orange color handle is easy to spot on the jobsite • • Cat. No. 56208 56209 56210 56211 56203 56204 56205 Description 1/2" Iron Conduit Bender Head 3/4" Iron Conduit Bender Head 1" Iron Conduit Bender Head 1-1/4" Iron Conduit Bender Head Assembled Iron Conduit Bender 1/2" EMT Assembled Iron Conduit Bender 3/4" EMT Assembled Iron Conduit Bender 1" EMT 130 www.kleintools.com Handle ​— ​— ​— ​— 51427 51427 51428 Thinwall/EMT 1/2" (12.7 mm) 3/4" (19.1 mm) 1" (25.4 mm) 1-1/4" (31.8 mm) 1/2" (12.7 mm) 3/4" (19.1 mm) 1" (25.4 mm) Rigid/IMC ​— 1/2" (12.7 mm) 3/4" (19.1 mm) 1" (25.4 mm) ​— 1/2" (12.7 mm) 3/4" (19.1 mm) Weight 2.1 lbs. (0.95 kg) 3.2 lbs. (1.45 kg) 5.5 lbs. (2.49 kg) 16.9 lb (7.67 kg) 5.5 lbs. (2.49 kg) 6.6 lbs. (2.99 kg) 11.6 lbs. (5.26 kg) 56205 56211 See page 310 for additional information on warnings. Wire Pulling & Conduit Tools Conduit Bender Handles Bender Handles • Available in multiple sizes and lengths and are compatible with all Klein Tools conduit bender heads • High-strength steel eliminates flex and provides excellent feel, control and leverage • Handle features an enlarged diameter hollow end for inserting conduit to correct overbends (Cat. No. 51427) • Bright orange color is easy to spot on the jobsite 51427 Cat. No. 51427 51428 51429 Description Conduit Bender Handle for 1/2", 3/4" Conduit Bender Handle for 1" Heads Conduit Bender Handle for 1-1/4" Heads Item Conduit Bender Handle Conduit Bender Handle Conduit Bender Handle NPT Tap Size 3/4" (19.1 mm) 1" (25.4 mm) 1-1/4" Length 38" (965.2 mm) 44" (1117.6 mm) 54" (1371.6 mm) Fits 1/2" and 3/4" Bender Heads 1" Bender Head 1-1/4" Bender Head For Use With 56208 and 56209 56210 56211 Weight 3.5 lbs. (1.59 kg) 6.0 lbs. (2.72 kg) 8.9 lbs. (4.04 kg) Armored Cable Cutter BX and Armored Cable Cutter • Cuts BX and 3/8" armored cable • Eliminates burrs • Does not nick cable cuts 3/8" flexible conduit and #10, 12, and 14 armored cables with • Easily up to 4 wires with a couple of turns of the handle • Depth of cut adjusts between standard MC and reduced diameter MC • Extra blade storage in handle • Use with Klein Tools replacement blade Cat. No. 53726-SEN Cat. No. 53725 Length 7-1/4" (184.2 mm) Weight 2.0 lbs. (0.91 kg) Replacement Parts Cat. No. 53726SEN Description BX Cutter Replacement Blade For Use With Klein Tools Cable Cutter 53725 53725 Weight 1.6 oz. (45 g) Conduit Scoring Tool Electrician's Conduit Scoring Tool • Durable zinc cast scoring tool eliminates spiraling • Used for scoring 1/2", 3/4" and 1" EMT conduit patented scoring wheel scores and allows • Klein-designed, clean conduit snaps without leaving burrs inside wheel conveniently located in base of the handle; • 1"noscoring tools required to replace scoring wheels • Four roller tracks specifically designed for professional use • Compact, enclosed design for use on job sites Cat. No. 88906 Length 6" (152.4 mm) Conduit Diameter Scores 1/2", 3/4" and 1" (12.7 mm, 19.1 mm and 25.4 mm) EMT Conduit 88906 Weight 1.3 lbs. (0.59 kg) Replacement Parts Cat. No. 88907 88908 Description 1/2", 3/4" EMT Replacement Scoring Wheel 1" EMT Replacement Scoring Wheel See page 310 for additional information on warnings. Weight 0.3 oz. (8.5 g) 0.3 oz. (8.5 g) 88907 88908 131 www.kleintools.com Wire Pulling & Conduit Tools PVC-Cutters PVC-Cutter • Cuts up to 3/4" schedule 40 PVC • Makes clean burr-free cuts in PVC and flexible pipe • Reversible blade doubles life • Cuts 1-3/8" outer diameter flexible plastic pipe • Steel construction for strength • Guide helps cut pipe squarely • Handle latch keeps tool closed 50506-SEN Cat. No. PVC Cutting Capacity 50506SEN 3/4" (19.1 mm) Schedule 40 Non-metallic Tubing Cutting Capacity 1" (25.4 mm) Length Weight 8-1/2" (215.9 mm) 1.0 lbs. (0.45 kg) Length 3-1/4" (82.6 mm) Weight 1.3 oz. (37 g) Replacement Parts Cat. No. 50549 Description Replacement Blade for Cat. No. 50506 50549 Ratcheting PVC-Cutters straight cuts 1/2"-2" I.D. (13 mm-51 mm) • Provide O.D. 5/8" - 2-1/2" (16 mm-64 mm) of white and • • • • gray schedule 40 and 80 PVC Quick, one-handed blade release Ratchet action allows easy, one-hand cutting No tools required for instant blade change Replacement blade and pin available Cat. No. 50031 50034 PVC Cutting Capacity O.D. 5/8" to 1-5/8" (15.9 to 41.3 mm); I.D. 1/2" to 1-1/4" (12.7 to 31.8 mm) O.D. 5/8" to 2-1/2" (15.9 to 63.5 mm); I.D. 1/2" to 2" (12.7 to 50.8 mm) Length 9" (228.6 mm) Weight 1.1 lbs. (0.50 kg) 11" (279.4 mm) 1.3 lbs. (0.59 kg) 50031 Replacement Parts Cat. No. 50032 50035 50033 Description Blade for Ratcheting PVC Cutter Blade for Large Capacity PVC Cutter Replacement Retaining Pin for PVC Cutter Length 4" (101.6 mm) 4" (101.6 mm) 2-3/8" (60.3 mm) Weight 3.0 oz. (86 g) 3.0 oz. (86 g) 0.1 oz. (2.7 g) 50032 WARNING: Do NOT cut cold PVC. 132 www.kleintools.com 50033 WARNING: Do NOT use to cut metallic pipes, cable or wire. See page 310 for additional information on warnings.
56409 价格&库存
很抱歉,暂时无法提供与“56409”相匹配的价格&库存,您可以联系我们找货
