93225
93225
    KLEINTOOLS
    TAPEMEASURE-25'MAGNETICDOUBL
93225 数据手册
Levels and Measuring Tools Quick, easy and accurate measurements can mean the difference between a job well done and one that misses the mark. Klein offers a variety of levels and other measuring devices that will help you measure up to the task. Levels and Measuring Tools Aluminum Levels Patent Pending MAGNET TRACK Tapered nose easily slides into pockets and fits in tighter spaces ULTRA POWERFUL Top V-Groove fits contour of pipe High-visibility orange levels won’t get lost on conduit Rare-Earth Magnets Large, high visibility vials are easy to read Lighted Billet Aluminum Torpedo Level Additional Features: Professional grade billet aluminum body is precision machined for high-accuracy leveling Large, bright LED high-definition vials are easy to read in any lighting condition Vials are at 3 angles: level, 90 and 45 degrees 3-minute auto shut-off saves battery life Water and impact resistant • • • • • NEW! Super Bright High-Definition LED Vials 935RBLT Cat. No. 935RBLT NEW! Overall Length 9" (228.6 mm) Weight 11.2 oz. (318 g) Billet Aluminum Torpedo Level Additional Features: Professional grade billet aluminum body is precision machined for high-accuracy leveling Vials are at 4 angles: level, 90, 45 and 30 degrees • • NEW! 935RB Cat. No. 935RB NEW! Overall Length 8" (203.2 mm) 116 www.kleintools.com Weight 7.4 oz. (210 g) High-Visibility Orange won't get lost or blend into conduit See page 310 for additional information on warnings. Levels and Measuring Tools Levels Aluminum Torpedo Level NEW! Additional Features: Vials are at 3 angles: level, 90 and 45 degrees Made from aluminum for added durability Cat. No. 931-9RETT has tether hole for working at height • • • Cat. No. 935R NEW! 9319RETT NEW! Overall Length 9" (228.6 mm) 9" (228.6 mm) 935R Weight 8.5 oz. (241 g) 1.6 oz. (45 g) Tether ring available on Cat. No. 9319RETT for working at height Torpedo Level Additional Features: Vials are at 3 angles: level, 90 and 45 degrees Magnetic bottom holds securely to conduit and metal surfaces NEW! • • Cat. No. 935 NEW! Overall Length 9" (228.6 mm) 935 Weight 4.3 oz. (122 g) Accu-Bend™ 4-Vial Level NEW! Additional Features: Professional grade billet aluminum body is precision machined for high-accuracy leveling Thumb screw attaches level to conduit to measure angle while bending Large, easy to read high-visibility vials at 4 angles: level, 90, 45, and 30 degrees • • • Cat. No. 935AB4V NEW! Overall Length 6-1/4" (158.8 mm) 935AB4V WARNING: Brass bolt contains lead, a chemical known to the State of California to cause cancer, and birth defects or other reproductive harm. Wash hands after handling. Weight 5.9 oz. (168 g) Accu-Bend™ 1-Vial Level Additional Features: Professional grade billet aluminum body is precision machined for high-accuracy leveling Ensures precise 90º bends Thumb screw attaches level to conduit to measure angle while bending Non-magnetic 1 vial: 90º • • • • • NEW! 935AB1V Cat. No. 935AB1V NEW! Overall Length 2-1/2" (63.5 mm) See page 310 for additional information on warnings. Weight 2.4 oz. (68 g) WARNING: Brass bolt contains lead, a chemical known to the State of California to cause cancer, and birth defects or other reproductive harm. Wash hands after handling. 117 www.kleintools.com Levels and Measuring Tools Patent Pending Tape Measures Magnetic end hooks with dual angle polarity attaches to conduit and steel studs to easily read from above or below Retraction Speed Brake controls blade speed and protects fingers from having to touch blade Up to 9-1/2 ft. (3 m) STAND-OUT WARNING: • Protect hands when cleaning magnetic tip end. Use gloves or cloth. • Avoid magnetic contact with sensitive electronic or computer equipment. • To avoid personal injury and damage to this tool, do not allow the tape blade to retract into case. • Do NOT open case. Spring motor is under tension, and opening case may cause injury. Blade-printed conduit multiplier bending table helps calculate offsets and saddles NEW! Tape Measures - Magnetic Additional Features: Heavy duty nylon coating protects blade printing Super-sized back clip holds securely to wide belts and extends into pockets Cat. Nos. 86315 and 86375 feature double sided printing with centimeters and inches U.S. Patent Pending • • • • Cat. No. 86216 NEW! 86225 NEW! 86230 NEW! Blade Length 16 ft. (4.9 m) 25 ft. (7.6 m) 30 ft. (9.1 m) Hook Double Double Double Weight 13.0 oz. (367 g) 17.6 oz. (498 g) 20.4 oz. (580 g) 5m 7.5 m Double Double 13.0 oz. (367 g) 18.1 oz. (514 g) 86225 Metric 86315 NEW! 86375 NEW! NEW! Tape Measure - Non-Magnetic Additional Features: Heavy duty nylon coating protects blade printing Super-sized back clip holds securely to wide belts and extends into pockets U.S. Patent Pending • • • Cat. No. 86125 NEW! Blade Length 25 ft. (7.6 m) 118 www.kleintools.com Hook Single Weight 17.9 oz. (506 g) 86125 See page 310 for additional information on warnings. Levels and Measuring Tools Tape Measures Tape Measures-Steel with High-Visibility Case • High-visibility, high-impact orange case makes it easy to find in a tool box, pouch and on the jobsite • 16" stud markings and 19.2" truss markings Cat. No. 928-25HV Blade Length 25 ft. (7.6 m) Width 1" (25.4 mm) Weight 16 oz. (454 g) 928-25HV Tape Measure Holders • Klein offers a complete selection of leather or nylon Tape Holders and Pouches 5707 5195 Tape Measure 86216, 86315 Holder Cat. No. 5195 5707 5196 5707 5195TT 5196 5707 5712 86125, 86225, 86375 86230 5196 Description Medium Leather Pouch Nylon Tape Measure Clip/Holder Large Leather Pouch Nylon Tape Measure Clip/Holder Tape Measure Holder with Ring Large Leather Pouch Nylon Tape Measure Clip/Holder Tape Measure Holder with Ring 5712 5195TT Overal Size 4-1/2" x 7" (114 mm x 178 mm) 4-1/8" x 3-3/4" ( 104 mm x 95 mm) 5" x 7" (127 mm x 178 mm) 4-1/8" x 3-3/4" ( 104 mm x 95 mm) 3" x 3.5" (76 mm x 89 mm) 5" x 7" (127 mm x 178 mm) 4-1/8" x 3-3/4" ( 104 mm x 95 mm) 8-1/4" x 4-1/2" (210 mm x 114 mm) Weight 2.9 oz. (82 g) 1.6 oz. (45 g) 3.4 oz. (95 g) 1.6 oz. (45 g) 1.6 oz. (45 g) 3.4 oz. (95 g) 1.6 oz. (45 g) 3.8 oz. (109 g) Laser Measuring Tools Laser Distance Measurer • Meter provides measurements up to 65 ft. (19.8 m) in distance, at an accuracy of + or - 1/16" (1.6 mm) • Quickly calculates length, area, volume, and indirect measurements with large, easy-to-read buttons • Offers the option of one-touch, single-distance measurement and continuous measurement • Depth gauge stick flips out to measure from inside corners or channels • Highly visible backlit display • Provides both fractional (imperial) and metric readings • Memory stores last 20 measurements • Includes handy carrying pouch to keep until safe when not in use Cat. No. 93LDM65 NEW! Batteries 2 x AAA Height 4-1/2" (114.3 mm) See page 310 for additional information on warnings. Width 2" (50.8 mm) Depth 1-3/8" (34.9 mm) Weight 5.1 oz. (145 g) NEW! 93LDM65 119 www.kleintools.com Levels and Measuring Tools Folding Rulers Wood Folding Rules • Strong, 6' (183 cm) long hardwood rules with clear abrasion-resistant coating • Black markings on yellow, with red stud center markings every 16 inches • Measurements are marked on both sides and both edges, graduated to 1/16th inch • Riveted lock joints are designed for long wear and maintained accuracy • Extension slide moves under friction in a T-slot with stops at each end. (Cat. No. 905-6) Cat. No. 900-6 901-6 905-6 Reading Inside Outside Outside Length 6 ft. (1.8 m) 6 ft. (1.8 m) 6 ft. (1.8 m) Weight 5.3 oz. (150 g) 5.3 oz. (150 g) 5.3 oz. (150 g) 901-6 Non-Conductive Fiberglass Folding Rules of tough nylon, reinforced with glass fibers for added durability, and • Constructed resistance to weather, abrasion and most chemicals • Positive locking joints and stainless steel spring hinges for added strength • Measurements are marked on both sides and both edges, graduated to 1/16th inch • Black markings on yellow, with red stud center markings every 16 inches • Engraved graduations on both sides Cat. No. 910-6 911-6 Reading Inside Outside Length 6 ft. (1.8 m) 6 ft. (1.8 m) Weight 5.3 oz. (150 g) 5.3 oz. (150 g) 910-6 Fiberglass Tapes Woven Fiberglass Tapes fiberglass tape with moisture-proof coating of polyvinyl chloride • Woven assures durability and protects against oil or chemicals • Can be immersed in water without adverse effects • All metal parts are nickel-plated for protection against rust • End-hooks are permanently attached to a reinforced strip • Case and reel are ruggedly built, yet lightweight and comfortable to use • Tape line is graduated in feet and inches to 8ths • Black graduating numbers and red foot markings on yellow background carrying case on Cat. Nos. 946-50 and 946-100 encloses • Protective tape completely • Tape rings tuck neatly into case opening for storage No. 946-150 is contained in an open reel and • Cat. is easy to handle and rewind Cat. No. 946-50 946-100 946-150 Description 50' Woven Fiberglass Tape Case 100' Woven Fiberglass Tape Case 150' Woven Fiberglass Tape Open-Reel 120 www.kleintools.com 946-100 Length 50 ft. (15.2 m) 100 ft. (30 m) 150 ft. (45.7 m) 946-150 Width 1/2" (12.7 mm) 1/2" (12.7 mm) 1/2" (12.7 mm) Weight 12.8 oz. (363 g) 1.2 lbs. (0.54 kg) 1.7 lbs. (0.77 kg) See page 310 for additional information on warnings.
93225 价格&库存
很抱歉,暂时无法提供与“93225”相匹配的价格&库存,您可以联系我们找货
