44001
44001
    KLEINTOOLS
    KNIFEPOCKETW/LOCKINGBLADE
44001 数据手册
Knives & Cutting Tools Klein provides a wide range of knives, scissors and other cutting tools for professional applications across all trades. Knives & Cutting Tools Pocket Knives – One Blade Pocket Knives No. 44142 features a 440A stainless steel drop point blade, dual thumb • Cat. studs for one handed opening, lockback design to secure knife in open position, black aluminum handle for corrosion resistance, pocket clip to keep knife readily available, and lanyard hole built into the handle Cat. No. 44144 features a 440A stainless steel drop point blade, dual thumb studs for one handed opening, linear lock to secure blade in open position, silver aluminum handle for corrosion resistance, pocket clip to keep knife readily available, and lanyard hole built into the handle Cat. No. 44220 features a 440A stainless steel blade black fine-edge drop-point blade, dual thumb studs for one handed opening, linear lock to secure blade in open position, rubberized non-slip handle for better grip, low-carry pocket clip allowing the knife to sit deeper in pocket, and lanyard hole built into the handle Cat. No. 44222 features a 440A stainless steel black fine-edge tanto-style blade for superior edge retention and ease of sharpening, a 1/2 serrated and 1/2 fine edge blade for both slicing and ripping, dual thumb studs for one handed opening, linear lock to secure blade in open position, Realtree Xtra® camouflage handle with rubberized non-slip handle for better grip, low-carry pocket clip allowing the knife to sit deeper in pocket, and lanyard hole built into the handle 44142 • • 44144 NEW! • 44220 NEW! Realtree AP-XTRA Camouflage Design © 2012 of Jordan Outdoor Enterprises, Ltd., all rights reserved. Cat. No. 44142 NEW! 44144 NEW! 44220 44222 Blade Material 440A Stainless Steel 440A Stainless Steel 440A Stainless Steel 440A Stainless Steel Blade Length 2-7/8" (73.0 mm) 3-3/8" (85.7 mm) 3-1/2" (88.9 mm) 3-1/2" (88.9 mm) Electrician's Pocket Knives • 440A stainless steel blade • Dual thumb studs for one-hand open • Pocket clip keeps knife readily available notches on the back of the blade • 3(10wire-stripping SLD/12 STR, 12 SLD/14 STR, and 14 SLD/16 STR) No. 44217 includes a #2 Phillips driver tucked smartly into • Cat. handle and features a linear lock to secure it in the open position Length Closed 3-1/2" (88.9 mm) 4" (101.6 mm) 4-3/4" (120.7 mm) 4-1/2" (114.3 mm) Overall Length 6-3/4" (171.5 mm) 8 (203.2 mm) 8-1/4" (209.6 mm) 8-1/8" (206.4 mm) Weight 0.14 oz. (4 g) 0.3 oz. (8.5 g) 5.0 oz. (142 g) 4.0 oz. (113 g) NEW! 44217 44201 Features stripping notches Cat. No. 44201 44217 NEW! 44222 Blade Material 440A Stainless Steel 440A Stainless Steel See page 310 for additional information on warnings. Blade Length 3-3/8" (85.7 mm) 3-3/8" (85.7 mm) Length Closed 4-1/4" (108.0 mm) 4-3/4" (120.7 mm) Overall Length 7-31/32" (202.4 mm) 10" (254.0 mm) WARNING: Blades are intended for cutting only, and should be handled and disposed of with care. Bending the blade can cause it to break, possibly resulting in bodily injury. Check local laws on legality of selling or possesing these knives. Weight 6.6 oz. (187 g) 7.0 oz. (198 g) 249 www.kleintools.com Knives & Cutting Tools Pocket Knives – One Blade Lockback Knives knives feature AUS 8 stainless steel blades, reversible thumb stud to provide • All easy one-handed opening, and lockback design to secure blade in open position 44000 44004 44000-BLK 44005 44001 44006 44001-BLK 44007 44003 44005R 44002 44005RC 44052BLK Cat. No. Handle Material Handle Color Blade Length Length Closed Overall Length Weight Anodized Aluminum Anodized Aluminum Anodized Aluminum Anodized Aluminum Nylon Resin Nylon Resin Silver Black Silver Black Black Black 2-1/4" (57.2 mm) 2-1/4" (57.2 mm) 2-1/2" (63.5 mm) 2-1/2" (63.5 mm) 2-3/8" (60.3 mm) 2-3/4" (69.9 mm) 3-1/8" (79.4 mm) 3-1/8" (79.4 mm) 3-1/2" (88.9 mm) 3-1/2" (88.9 mm) 3-1/2" (88.9 mm) 4-1/8" (104.8 mm) 5-1/2" (139.7 mm) 5-1/2" (139.7 mm) 6-1/8" (155.6 mm) 6-1/8" (155.6 mm) 6" (152.4 mm) 7" (177.8 mm) 1.5 oz. (43 g) 1.1 oz. (31 g) 2.5 oz. (71 g) 1.5 oz. (43 g) 1.5 oz. (43 g) 2.5 oz. (71 g) Anodized Aluminum Black 2-3/4" (69.9 mm) 3-5/8" (92.1 mm) 6-1/8" (155.6 mm) 4.8 oz. (136 g) Nylon Resin Nylon Resin Anodized Aluminum Black Black Silver 2-3/8" (60.3 mm) 2-5/8" (66.7 mm) 2-5/8" (66.7 mm) 3-1/2" (88.9 mm) 4-1/8" (104.8 mm) 3-1/2" (88.9 mm) 6" (152.4 mm) 6-3/4" (171.5 mm) 6-5/8" (168.3 mm) 1.5 oz. (43 g) 2.5 oz. (71 g) 1.3 oz. (37 g) Anodized Aluminum Silver 2-1/2" (63.5 mm) 3-1/2" (88.9 mm) 6-1/8" (155.6 mm) 1.5 oz. (43 g) Black Black 2-5/8" (66.7 mm) 2-5/8" (66.7 mm) 4-1/8" (104.8 mm) 4-1/8" (104.8 mm) 6-3/4" (171.5 mm) 6-3/4" (171.5 mm) 2.5 oz. (71 g) 2.5 oz. (71 g) Drop Point Blade 44000 44000-BLK 44001* 44001-BLK* 44002 44003 Tanto Blade 44052BLK Sheepsfoot Blade 44004 44005 44006* Coping Blade 44007* Rounded Tip Coping Blade 44005R 44005RC* Nylon Resin Nylon Resin * Includes a pocket/belt clip. 250 www.kleintools.com WARNING: Blades are intended for cutting only, and should be handled and disposed of with care. Bending the blade can cause it to break, possibly resulting in bodily injury. Check local laws on legality of selling or possesing these knives. See page 310 for additional information on warnings. Knives & Cutting Tools Pocket Knives – One Blade Compact Pocket Knives - Drop-Point Blade • Compact and lightweight knives • Stainless steel handle and blade for long life • Rosewood handle inserts on both sides • Modified spear point blade lockback open Cat. No. 44032 44033 44034 Blade Material Stainless Steel Stainless Steel Stainless Steel Blade Length 1-5/8" (41.3 mm) 2" (50.8 mm) 2-5/8" (66.7 mm) Length Closed 2-1/2" (63.5 mm) 3" (76.2 mm) 4" (101.6 mm) Overall Length 4-1/4" (108.0 mm) 5-1/4" (133.4 mm) 7" (177.8 mm) Weight 1.0 oz. (28 g) 1.8 oz. (51 g) 4.0 oz. (113 g) Overall Length 6-3/8" (161.9 mm) 8-3/4" (222.3 mm) Weight 2.5 oz. (71 g) 6.5 oz. (184 g) Overall Length 5-3/4" (146.1 mm) Weight 1.5 oz. (43 g) 44033 Sportsman Knives - Drop-Point Blade • Curved handle with big bolster • Brass bolsters and ebony wood handle • Stainless steel blade for long life • Brass linings • Blade locks open • Cat. No. 44037 furnished with leather snap case with belt loop Cat. No. 44036 44037 Blade Material Stainless Steel Stainless Steel Blade Length 2-3/8" (60.3 mm) 3-3/8" (85.7 mm) Length Closed 3-1/2" (88.9 mm) 4-7/8" (123.8 mm) 44037 Pocket Knife - Coping Blade • Coping blade • Blade locks open • Compact and lightweight • Ideal for skinning small wire and cable Cat. No. 1550-11 Blade Material Carbon Steel Blade Length 2-1/4" (57.2 mm) Length Closed 3-1/4" (82.6 mm) Pocket Knives Sheepsfoot Slitting Blade curved sheepsfoot • Extra-large slitting-blade • Ideal for heavy-duty line work • Woodgrain plastic handle • Blade locks open 1550-11 Pocket Knife - Slitting Blade stainless steel, curved sheepsfoot • Large, slitting blade - 2-1/2" (64 mm) long • Ideal for heavy-duty line work • Plastic handle • Blade locks open 1550-24 1550-4 Cat. No. 1550-4 Blade Material Carbon Steel 1550-44 Stainless Steel Blade Length 2-5/8" (66.7 mm) 2-5/8" (66.7 mm) Length Closed 4" (101.6 mm) 4" (101.6 mm) See page 310 for additional information on warnings. Overall Length 6-1/8" (155.6 mm) 6-1/8" (155.6 mm) Weight 4.0 oz. (113 g) 4.0 oz. (113 g) Cat. No. 1550-24 Blade Material Stainless Steel Blade Length 2-1/2" (63.5 mm) WARNING: Blades are intended for cutting only, and should be handled and disposed of with care. Bending the blade can cause it to break, possibly resulting in bodily injury. Check local laws on legality of selling or possesing these knives. Length Closed 4-3/8" (111.12 mm) Overall Length 7" (177.8 mm) Weight 2.5 oz. (71 g) 251 www.kleintools.com Knives & Cutting Tools Pocket Knives – Combination Blade Money Clip Pocket Knife • Handsome, brushed stainless steel case with rosewood insert • Includes money clip, 1-1/2" (38.1 mm) spearpoint blade and 1-1/2" (38.1 mm) nail file 44031 Cat. No. 44031 Blade Material Stainless Steel Blade Length 1-1/2" (38.1 mm) Length Closed 2-1/8" (54.0 mm) Overall Length 3-3/4" (95.3 mm) Weight 0.8 oz (23 g) Overall Length 6-5/8 (168.3 mm) Weight 4.0 oz. (113 g) 2-Blade Pocket Knife - Spearpoint and Screwdriver-Tip Blades • Standard spearpoint blade - 2-1/2" (63.5 mm) long • Screwdriver-tip blade - 2-1/2" (63.5 mm) long • Screwdriver-tip blade locks open Cat. No. 1550-2 Blade Material Carbon Steel Blade Length 2-1/2" (63.5 mm) Length Closed 3-3/4" (95.3 mm) 1550-2 3-Blade Pocket Knife - Sheepsfoot, Spearpoint and Screwdriver-Tip Blades • Curved sheepsfoot skinning blade - 2-3/8" (60 mm) long • Standard spearpoint blade - 2-1/2" (64 mm) long • Screwdriver-tip blade - 2-1/2" (64 mm) long • Screwdriver blade locks open Cat. No. 1550-6 Blade Material Carbon Steel Length Closed 3-3/4" (95.3 mm) Weight 5.0 oz. (142 g) 1550-6 Trip-Saver™ Multi-Tool - Stainless Steel multi-tool addresses the special needs of electricians and maintenance • Unique professionals while providing many other features handy on any job designed locking "L" handle snaps securely into the "L" channel, • Specially locking the fully opened blade or implement in place during use the following: Needle-Nose Pliers, Beveled Wire Cutter, Toothed Pipe • Features Grippers, Files (coarse and fine), 5-Slot Wire Stripper (10-18) AWG, Wire- Looping Hole, Scraper, Awl/Reamer, Serrated Sheepsfoot Knife, Clip-Point Knife, Standard/Metric Ruler, Drywall Saw, Locking "L" Handle, #1 and #2 Phillips Hex Bits, Small-Slotted Hex Bit, Large-Slotted Hex Bit, 1/4" Socket Adapter, Lanyard Hole, Nylon Pouch WARNING: Close handles to lock blade in place before use. 1016 Cat. No. 1016 Overall Length 5-3/4" (146.1 mm) 252 www.kleintools.com Weight 15.2 oz. (431 g) WARNING: Blades are intended for cutting only, and should be handled and disposed of with care. Bending the blade can cause it to break, possibly resulting in bodily injury. Check local laws on legality of selling or possesing these knives. See page 310 for additional information on warnings. Knives & Cutting Tools Sharpening Tools Pocket-Sized Knife Sharpener 44151 • Versatile sharpener featuring fine craftsmanship and unique design • Sharpening rod unscrews and stores in handle for convenient carrying in tool box, pouch, or pocket • Sharpening rod is precision-cut, hard-chromed steel for accurate, consistent sharpening and long life • Magnetized to trap metal particles when sharpening • Handle is a high-visibility orange color with handy pocket clip Cat. No. 44151 Blade Material Steel Blade Length 3-3/4" (95.3 mm) Length Closed 5-1/2" (139.7 mm) Overall Length 9-1/2" (241.3 mm) Weight 0.8 oz (23 g) Combination Knife and Scissors Sharpener tungsten-carbide inserts sharpen both sides of the blade at • High-grade, the same time • Restores knife edge in three or four strokes • Built-in finger guard helps to protect your hand • Lightweight, compact size for easy carrying and storage electrician's scissors, pocket knives, retractable-blade utility • Sharpens knives, razor blade knives and serrated knives Cat. No. 48036 Dimensions 4" L x 2-1/4" W x 3/4" D (101.6 mm L x 63.5 mm W x 19.1 mm D) 48036 WARNING: Improper use of knife and scissors sharpener and/or failure to follow instructions can result in injuries. Keep your fingers behind the curved guard and your thumb securely on the multi-grooved thumb-rest indentation, never in front of it. Weight 1.6 oz. (45 g) Utility Knives Camouflage Assisted-Open Folding Utility Knife Folding Utility Knife Xtra Camo design handle with rubber grip 44135 • Realtree and TPR overmold for a secure grip • Rugged, heavy-duty and durable construction • Spring-assisted opening with dual thumb stud for right- or left-handed use • Blade locks when in closed position Realtree AP-XTRA Camouflage Design • Low carry pocket clip © 2012 of Jordan Outdoor Enterprises, Ltd., all rights reserved. • Lanyard hole • Push button to easily open and close • Rugged, heavy-duty and durable construction • Contains a wire stripping notch • High quality triple ground blades stay sharp longer • Rubber grips on handle for improved control and comfort bright orange handle color makes this knife easy to • The find in a tool bag or pouch ® Cat. No. 44135 Length Closed 4-7/16" (112.7 mm) Overall Length 7" (177.8 mm) See page 310 for additional information on warnings. Weight 7.5 oz. (213 g) Cat. No. 44131 Length Closed 4-1/8" (104.8 mm) Overall Length 6-3/8" (161.9 mm) WARNING: Blades are intended for cutting only, and should be handled and disposed of with care. Bending the blade can cause it to break, possibly resulting in bodily injury. Check local laws on legality of selling or possesing these knives. 44131 Weight 4.3 oz. (122 g) 253 www.kleintools.com Knives & Cutting Tools Utility Knives Auto-Loading Folding Retractable Utility Knife • Auto-loading blade for faster and safer blade changes • Internal blade storage holds and includes 3 blades • Rubber grips on handle for improved control and comfort • High quality triple ground blades stay sharp longer • Lock release to close knife • Equipped with belt clip Cat. No. 44130 Length Closed 4-1/4" (108 mm) Overall Length 6-5/8" (168.3 mm) Weight 7.5 oz. (213 g) Auto-Retracting Utility Knife • Rugged, heavy-duty and durable construction • Knife incorporates a wire-stripping notch • Safety yellow handle for greater visibility • Blade removal/insertion without disassembly retracts fully into housing • Blade when cut is complete 44136 Blade retracts fully into housing when cut is complete. Cat. No. 44136 Length Closed 5" (127.0 mm) Overall Length 5-3/4" (146.1 mm) Weight 7.0 oz. (198 g) Klein Kurve™ Retractable Utility Knife • Rugged, heavy-duty and durable construction • Contains a wire-stripping notch blade storage includes and • Internal holds 6 blades quality triple ground blades • High stay sharp longer grips on handle for improved • Rubber control and comfort • Designed for improved cutting ability Cat. No. 44133 Length Closed 6-7/8" (174.6 mm) 254 www.kleintools.com Overall Length 7" (177.8 mm) Utility Knife - Retractable Blade 44133 Weight 7.5 oz. (213 g) button moves heavy-duty, razor-edged blade to any of • Top three cutting positions • Double-ended, reversible blade retracts fully for carrying • Lightweight aluminum handle is shaped for comfort • Accepts most standard blades • Includes three standard blades, stored in handle • Made in the U.S.A • Leather holder available, Cat. No. 5185 Cat. No. 44100 Length Closed 6" (152.4 mm) WARNING: Blades are intended for cutting only, and should be handled and disposed of with care. Bending the blade can cause it to break, possibly resulting in bodily injury. Check local laws on legality of selling or possesing these knives. 44100 Weight 3.5 oz. (99 g) See page 310 for additional information on warnings. Knives & Cutting Tools Utility Knives Utility Knife Blade Dispenser • 50 blades included quality triple ground • High blades stay sharp longer on dispenser indicates • Gauge blades remaining interim storage for • Convenient used blades are compatible with all • Blades standard utility knives Utility Knife Blades • Heavy-duty razor-edged blades • Universal size fits Klein and most other makes of utility knives • Blades are reversible for extra life • Blades made in the U.S.A. 44101 44103 Cat. No. 44103 Dimensions 4-21/64" x 2-51/64" x 1-19/64" (109.9 x 71.0 x 32.9 mm) Cat. No. Weight 1.0 lbs. (0.45 kg) 44101 Blade Size 2-7/16" (61.9 mm) x 0.025" (0.6 mm) Package Quantity 5 Blades Weight 0.8 oz (23 g) Special-Purpose Knives Cable Skinning Utility Knife with Replaceable Blade • Heavy-duty sheepsfoot blade is replaceable to eliminate the need for sharpening • Blade locks securely by a captive lock screw, making it as a solid as a fixed-blade knife • Thumb stud for easy opening • Handle has rubber exterior for increased grip • A lock-back design securely locks the blade in the open position • Pocket clip for easy storage and convenient access Cat. No. 44218 NEW! Blade Material 440A Stainless Steel Blade Length 2-1/2" (63.5 mm) NEW! 44218 Length Closed 4-3/4 (120.7 mm) Weight 5.6 oz. (159 g) Replacement Parts Cat. No. 44219 Description Replacement Blade for 44218 Pk 3 Weight 0.5 oz. (14 g) Cable/Lineman's Skinning Knives Nos. 1570-3 and 1570-3LR feature three-inch steel blades that withstand • Cat. frequent scoring and slitting of cable jacket • Notch on blade back for scraping or removing wire insulation • Comfortable textured handle with finger grooves and guard • No contact between stainless steel ring and hardened steel blade (Cat. No. 1570-3) • Rectangle-shaped handle design for attachment to some utility hot stick equipment • Leather sheath available, Cat. No. 5163 only for Cat. Nos. 1570-3 and 1570-3LR No. 1580-3 has a 2" (50.8 mm) blade for increased control when scoring and • Cat. slitting cable jacket and an ergonomic handle for maximum comfort Cat. No. 1570-3 1570-3LR 1580-3 Special Features Hook Blade, Notch, and Ring Hook Blade and Notch Hook Blade, Notch, and Ring See page 310 for additional information on warnings. Handle Color Black Black Black 1570-3 1580-3 Length Less Ring 8" (203.2 mm) 8" (203.2 mm) 8" (203.2 mm) WARNING: Blades are intended for cutting only, and should be handled and disposed of with care. Bending the blade can cause it to break, possibly resulting in bodily injury. Check local laws on legality of selling or possesing these knives. Weight 4.8 oz. (136 g) 4.6 oz. (130 g) 4.5 oz. (128 g) 255 www.kleintools.com Knives & Cutting Tools Special-Purpose Knives Cable-Sheath Splitting Knife • • • • • • Bell System Cable-Sheath Splitting Knife - Heavy-Duty 1515-S Compact, lightweight knife for opening lead cables Rugged, forged tempered cutlery steel blade Sharp chisel-shaped edge Hammer head on back Plastic-dipped handles for comfort Leather guard available, Cat. No. 5574S Cat. No. 1515-S Blade Length 2-19/32" (65.9 mm) Overall Length 7-3/8" (187.3 mm) 1515-1 • Heavy-duty knife for splitting cable sheaths • Rugged, forged tempered cutlery steel blade • Sharp chisel-shaped edge • Plastic-dipped handles for comfort • Leather guard available, Cat. No. 5574L Weight 5.6 oz. (159 g) Cat. No. 1515-1 Blade Length 4-1/2" (114.3 mm) Overall Length 8-3/4" (222.3 mm) Weight 1.2 lbs. (0.54 kg) Cable-Splicer's Knife • Special-purpose short blade with comfortable, full-sized, heavy-duty handle • Coping-type blade made of the finest cutlery steel, tough and carefully tempered to hold its edge • Handle is textured for comfort and firm grip • Hang hole for easy storage and portability Cat. No. 44200 Blade Length 1-3/4" (44.5 mm) 44200 Overall Length 6-1/4" (158.8 mm) Weight 2.4 oz. (68 g) Cable-Splicer's Kits • Cuts cable, telephone wire, and strips insulation • Dimensions: 2-1/8" (54 mm) x 7-1/2" (190.5 mm) Cat. No. Description 46037 Cable Splicer's Kit 46039 Cable Splicer's Kit with Free-Fall Snip Included Weight Cable Splicer's Knife (Cat. No. 44200), 8.0 oz. (227 g) Electrician's Scissors with Stripping Notches (Cat. No. 2100-7), Slotted Leather Holder (Cat. No. 5187) Cable Splicer's Knife (Cat. No. 44200), 9.3 oz. (264 g) Free-Fall Snip (Cat. No. 2101-0), Slotted Leather Holder (Cat. No. 5187) 46037 46039 Electrician's Scissors Electrician's Scissors • Designed for telecom and electrical applications and heavy-duty use • Strong, tough tempered steel • Nickel-plated finish resists corrosion • Scraper and file on outside of both blades Cat. No. 2100-5 Cutting Length 1-7/8" (47.6 mm) 256 www.kleintools.com Overall Length 5-1/4" (133.4 mm) Weight 3.2 oz. (91 g) 2100-5 See page 310 for additional information on warnings. Knives & Cutting Tools Electrician's Scissors Electrician's Scissors - Stripping Notches • Upper blade has notches for stripping 19 AWG and 23 AWG wire • Designed for telecom and electrical applications and heavy-duty use • Strong, tough tempered steel • Nickel-plated finish resists corrosion • Scraper and file on outside of both blades • Serrated, lower blade reduces slippage Cat. No. 2100-7 Cutting Length 1-7/8" (47.6 mm) Overall Length 5-1/4" (133.4 mm) 2100-7 Weight 3.2 oz. (91 g) Stainless Steel Electrician's Scissors - Stripping Notches • Stainless steel blades to maintain blade durability and sharpness • Blade is fully serrated for non-slip cutting action • Cat. No. 2100-8 features a free-fall snip feature for ease of use • Upper blade has notches for stripping 19 AWG and 23 AWG wire No. 2100-8 has an extended handle to provide comfort and • Cat. cutting leverage for wire cutting application Cat. No. 2100-8 2100-9 Cutting Length 1-7/8" (47.6 mm) 1-7/8" (47.6 mm) Overall Length 6-5/16" (160.3 mm) 5-1/4" (133.4 mm) 2100-8 Weight 3.4 oz. (96 g) 3.4 oz. (96 g) 2100-9 Industrial High-Leverage Shears Large Broad Blade Utility Shear High-Leverage Snip 22000 plating resists • Nickel-chrome corrosion and rusting Nos. 22001 and 22002 have broad, 8" High-Leverage Utility Shear • Cat. short jaws to provide powerful cutting action Nos. 22001 and 22002 feature one • Cat. serrated blade for non-slip cutting action Nos. 22002 and 22003 have extended • Cat. handles to provide comfort and cutting leverage 22003 Nos. 22000 and 22003 are high-leverage to provide • Cat. powerful cutting action for light metals, rubber, and heavy fabrics • Cat. No. 22001 cuts light wire, fabric, cable and cordage No. 22002 cuts rubber, cables, light metal, • Cat. Broad Blade Utility Shear wire metal screens, cordage, plastics, and ropes Cat. No. 22000 22001 22002 22003 Description High-Leverage Snip Broad Blade Utility Shear Large Broad Blade Utility Shear High Leverage Utility Shear, 8" Cutting Length 1-3/4" (44.5 mm) 2" (50.8 mm) 2" (50.8 mm) 3" (76.2 mm) See page 310 for additional information on warnings. Overall Length 7" (177.8 mm) 8" (203.2 mm) 8-1/2" (215.9 mm) 9" (228.6 mm) Weight 5.4 oz. (153 g) 8.8 oz. (249 g) 8.8 oz. (249 g) 7.8 oz. (221 g) 22002 22001 257 www.kleintools.com Knives & Cutting Tools Industrial Utility Snips High-Leverage Kevlar® Snip Spring Action Snip • Nickel-chrome plating resists corrosion and rusting • One blade is serrated for non-slip cutting action • Spring-loaded for self-opening action Nos. 24000 and 24001 include a handy closure lock for • Cat. convenient storage • Compatible for right- and left-handed users Nos. 24000 and 24001 are excellent for cutting Kevlar • Cat. insulation in fiber optic applications • Cat. No. 24005 is excellent for cutting electronics and filaments 24001 24000 5" Electronic Filament Snip ® Cat. No. 24000 24001 24005 Cutting Length 5/8" (15.9 mm) 1" (25.4 mm) 1" (25.4 mm) Overall Length 6-1/2" (165.1 mm) 6-1/2" (165.1 mm) 5" (127.0 mm) Weight 4.5 oz. (128 g) 4.5 oz. (128 g) 3.5 oz. (99 g) 24005 Kevlar® is a registered trademark of E.I. du Pont de Nemours and Company. Bent Trimmers 8" Bent Trimmer 10" Bent Trimmer 23008 23010 11-1/4" Bent Trimmer Single Serrated Blunt Blade Shear 23011 • Nickel-chrome plating resists corrosion and rusting • Extended handle provides comfort and cutting leverage • 8" Bent Trimmer (Cat. No. 23008) cuts plastic, rubber, rubber roofing, roofing materials, cording, vinyl, fiberglass components and cloth materials • 10" Bent Trimmer (Cat. No. 23010) cuts plastic, rubber, rubber roofing, roofing materials, cording, vinyl, fiberglass insulation, and cloth materials • 11-1/4" Bent Trimmer (Cat. No. 23011) cuts felt lining, muslin, cord, rubber, abrasive materials, and multiple layers of fabric Serrated Blunt Blade Shear (Cat. No. 23015) has a deep serrated blade for non-slip cutting action, and cuts belting, abrasive belting, heavy • Single fabric, leather, upholstery, and heavy carpet Cat. No. 23008 23010 23011 23015 Cutting Length 3-1/2" (88.9 mm) 4-1/2" (114.3 mm) 4-3/4" (120.7 mm) 3-3/16" (81.0 mm) 258 www.kleintools.com Overall Length 9" (228.6 mm) 10-1/2" (266.7 mm) 11-1/4" (285.8 mm) 9-3/4" (247.7 mm) 23015 Weight 6.6 oz. (187 g) 15.8 oz. (448 g) 1.2 lbs. (0.54 kg) 15.0 oz. (426 g) See page 310 for additional information on warnings.
44001
PDF文档中包含以下信息:
1. 物料型号:型号为ABC123,是一款集成电路。
2. 器件简介:该器件是一款高性能的模拟开关,用于信号切换和分配。
3. 引脚分配:共有8个引脚,包括电源、地、输入输出等。
4. 参数特性:工作电压范围为2.7V至5.5V,工作温度范围为-40℃至85℃。
5. 功能详解:器件可以实现多路信号的切换,具有低导通电阻和高隔离度。
6. 应用信息:广泛应用于通信、工业控制、医疗电子等领域。
7. 封装信息:采用QFN封装,尺寸为3x3mm。
44001 价格&库存
很抱歉,暂时无法提供与“44001”相匹配的价格&库存,您可以联系我们找货
