VDV001-833
VDV001-833
    KLEINTOOLS
    VDVPROTECHDATA&COAXIALKIT
VDV001-833 数据手册
Voice/Data/Video Tools, Testors & Connectors Our comprehensive line of verification VDV products was created to prep, connect and test network, phone, CATV, home theater, satellite, and security cables for residential or commercial systems. Voice/Data/Video Tools, Testers & Connectors Coaxial Cutting Tool Coaxial Cable Cutter - CCS blade optimized to cut copper-clad steel (CCS) coaxial cable • Multi-functional and other common wires or cables from custom, US-made steel and through-hardened, the specialized • Forged notched blade is designed to withstand steel cable cutting blade section is optimized to easily cut common CCS coaxial cables • Notched such as RG-59, RG-6/6Q, RG-7 and RG-11 blade section is designed to cleanly cut and snip solid and stranded • Shears copper, aluminum, UTP/STP twisted pair wires and cables geometry ensures CCS coaxial cable retains form when cut to facilitate • Blade easy insertion into connectors and provide excellent terminations • High-leverage handles for genuine one-handed operation • Handles are plastic-coated for maximum comfort and grip Cat. No. VDV600-096 Handle Color Yellow Cutting Knives Custom Notch for CCS Coaxial Cable Standard Shears for General Purpose VDV600-096 Cuts RG59, RG6, RG6Q, RG7, RG11 Twisted Pair Handle Type Plastic Dipped Overall Length 7-5/8" (193.7 mm) Weight 8.4 oz. (238 g) Radial Strippers Radial Stripper UTP/STP • One-step outer jacket stripping, 1-level of category 3, 5, 5e, 6, and 6a cables • Durable high-carbon steel cutting blades are ground and honed for long life • Removes the outer jacket of twisted pair cable without damaging the conductors • Strip and slit lengths may be varied to accommodate different connector requirements • Recessed cutting surface slits long runs of twisted-pair cable • Multiple nest cavities allow the removal of a wide variety of jacket materials on twisted-pair cable • Tension loop can be disengaged for thin-jacket cable • One-piece construction ensures alignment for precise stripping • Large finger loop promotes rotation during use • Adjustable set-screw prevents twisted-pair conductor insulation scoring VDV120-006 Cat. No. Color Strips or Slits Levels Strip/Slit Dimensions Prepared Cable Overall Length Weight VDV120-006-SEN Yellow Unshielded Twisted Pair; Shielded Twisted Pair 1 Varies by application ​ 4-13/32" (111.9 mm) 1.3 oz. (37 g) Coax Cable Radial Strippers - 2-Level No. VDV110-095 features two stripping cavities: one for standard size cable and one for utility • Cat. size cables. Perfect for the data installer who works with utility cable as well standard cable No. VDV110-095 strips five different series of RG cable including: • Cat. RG6, RG6-QS, RG59, RG11 and RG7 • 2-level stripping in one step - 5/16" and 1/4" (7.9 mm and 6.4 mm) • Klein's sliding cable stop pre-measures cable for fast, accurate and repeatable strips • Durable high-carbon steel cutting blades automatically adjust to different cable diameters • Finger loop facilitates easy, controlled rotation • Easy debris clean-out VDV110-095 US Patent: D688927 Cat. No. Color Levels Cable VDV110-095 Yellow/Gray 2 VDV110-061 Yellow/Black 2 RG59, RG6, RG6-QS, RG7, RG11 RG59, RG6, RG6-QS 188 www.kleintools.com Cartridge Strip Dimensions 0.3125" and 0.250" (7.94 and 6.35 mm) 0.3125" and 0.250" (7.94 and 6.35 mm) VDV110-061 Prepared Cable Overall Length Weight ​ 5-1/4" (133.4 mm) 1.5 oz. (43 g) ​ 4-19/32" (116.7 mm) 1.2 oz. (34 g) See page 310 for additional information on warnings. Voice/Data/Video Tools, Testers & Connectors Radial Strippers and Cartridges Cartridge Radial Strippers • Designed for high-volume, multiple-type cable preparation environments • Includes storage cartridge-bay • One-piece construction ensures precise stripping and never requires adjustment • Large finger loop promotes rotation during use • F-Connector "nest" assists with cable insertion • Cartridges snap in from both sides for left or right-handed operation • Durable high-carbon steel cartridge cutting blades are ground and honed for long life • Additional and replacement cartridges available VDV100-801 VDV110-802 Cat. No. VDV100-801-SEN Cat. No. VDV110-802-SEN Set Contains Overall Length 5.6" (143 mm) Dual Cartridge Radial Stripper Cat. No. Cable Color Levels Cartridge Strip Dimensions Prepared Cable VDV110-003-SEN RG59/RG6/RG6 QS Coaxial Cable Black 2 0.3125" and 0.250" (7.94 and 6.35 mm) ​ VDV120-005-SEN UTP Cable (Category 3, 5, 5e and 6) Blue 1 Variable ​ Set Contains Overall Length 5.2" (133 mm) Radial Cartridge Stripper Cat. No. Cable Color Levels Cartridge Strip Dimensions Prepared Cable VDV110-003-SEN RG59/RG6/RG6 QS Coaxial Cable Black 2 ​ 0.3125" and 0.250" (7.94 and 6.35 mm) Weight 2.4 oz. (68 g) Weight 2.1 oz. (60 g) Radial Stripper Cartridges for use with: • Designed Dual Cartridge Radial Stripper (Cat. No. VDV100-801), • • • • • • Radial Cartridge Stripper (Cat. Nos. VDV110-802) Pre-set cutting blades for precise, accurate and efficient cable stripping Durable high-carbon steel cutting blades are ground and honed for long life Patented "V" notch eliminates scoring of the center conductor* Color-coded for easy identification Meets industry standards established by the SCTE (Society of Cable Telecommunication Engineers) Cartridges made from glass filled polycarbonate for superior strength and extended durability VDV110-004 VDV110-003 VDV113-022 VDV113-021 VDV110-020 VDV120-005 Cat. No. Cable Color Levels Cartridge Strip Dimensions Prepared Cable Weight VDV110-003-SEN RG59/RG6/RG6 QS Coaxial Cable Black 2 0.3125" and 0.250" (7.94 and 6.35 mm) ​ 0.1 oz. (2.8 g) VDV110-004-SEN RG7/RG11 Coaxial Cable Gray 2 0.3125" x 0.250" (7.94 x 6.35 mm) ​ 0.1 oz. (2.8 g) VDV120-005-SEN UTP Cable (Category 3, 5, 5e and 6) Blue 1 Variable ​ 0.1 oz. (2.8 g) VDV110-020 VDV113-021 Mini Coaxial Cable RG58/RG59/RG62 Coaxial Cable Green Green 2 3 ​ ​ 0.1 oz. (2.8 g) 0.1 oz. (2.8 g) VDV113-022 RG58/RG59/RG62 Coaxial Cable Brown 3 0.250" x 0.250" (6.35 x 6.35 mm) 0.234" x 0.234" x Variable (5.95 x 5.95 mm x Variable) 0.109" x 0.312" x Variable (2.76 mm x 7.92 mm x Variable) ​ 0.1 oz. (2.8 g) See page 310 for additional information on warnings. 189 www.kleintools.com Voice/Data/Video Tools, Testers & Connectors Coaxial Connector Crimp Tools Compression Crimper - Lateral, Multi-Connector tool crimps most compression connectors to most coaxial cables • One Minicoax, RG58, RG59, RG62, RG6, RG6QS, RG7, and RG11 cable selection wheel eliminates the need to change plunger tips, • Unique saving time and avoids losing parts • Heavy-duty zinc die-cast chassis for durable, long lasting performance design with 180˚ capture mechanism provides easy insertion, • Open complete compression and simple removal F/BNC/RCA gauge markings on tool for accurate positioning • User-friendly and quick adjustments of the plunger • Integrated handle lock for easy storage • Spring loaded return increases user comfort and ease of use • Yellow and black contoured grips enhance comfort, visibility and allow quick identification Cat. No. VDV211-063 Color Yellow/Black Type Compression Crimper Cable Type Coaxial VDV211-063 Connector markings for quick adjustments. Connectors BNC, F, RCA Compression Crimper - Compact, Multi-Connector • Fast, reliable multiple-type compression connector installations • Crimps compression BNC, F and RCA connectors to coaxial cable • Adjustable universal plunger ensures accurate crimps on multiple types of connectors design with 180˚ capture mechanism provides easy insertion, complete • Open compression and simple removal of cable and connector F/BNC/RCA gauge markings on tool for accurate positioning and • User-friendly quick adjustments of the plunger • Compact tool with integrated handle lock for easy storage • Spring loaded return increases user comfort and ease of use • Yellow contoured grips enhance comfort, visibility and allow quick identification • Steel body with chrome finish resists corrosion and extends tool life Cat. No. VDV211-048 Color Yellow/Chrome Type Compression Crimper Cable Type Coaxial Overall Length 6-1/4" (158.8 mm) VDV211-048 Connector markings for quick adjustments. Connectors BNC, F and RCA Overall Length 5-19/32" (142.1 mm) Compact, F-Connector • Fast, reliable F-connector installation tool • Steel body with black-oxide finish for corrosion resistance and durability • Fixed plunger allows quick, easy insertion and removal of cable and connector • Fixed plunger accepts many common F-connector compression fittings • Compact tool with integrated handle lock • Yellow and black grips enhance comfort, visibility, and allow quick identification • Spring loaded return increases user comfort and ease of use Cat. No. VDV212-008-SEN Color Yellow/Black 190 www.kleintools.com Type Compression Crimper Cable Coaxial Weight 1.2 lbs. (0.54 kg) Weight 8.0 oz. (227 g) VDV212-008 Connectors Common F Connectors Overall Length 5-19/32" (142.1 mm) Weight 9.8 oz. (278 g) See page 310 for additional information on warnings. Voice/Data/Video Tools, Testers & Connectors Twisted Pair Crimp/Strip Tools Compact Ratcheting Modular Crimper • All-inclusive tool cuts, strips and crimps voice and data cables • Cuts and strips CAT6, CAT5e, CAT3 and flat-satin voice cables • Crimps 4, 6 and 8 position modular connectors • Heavy-duty ratchet ensures complete termination lateral crimp action provides more even, • Direct precise contact termination across all pins • Compact, ergonomic design for natural, single-hand operation • About 40% smaller than other crimpers for easy storage reference connector wiring diagrams provided on the tool • Quick and downloadable to your mobile device Cat. No. VDV226-107 Color Yellow/Black Cuts & Strips STP/UTP Data Cable Flat Satin Phone Cable 28 - 22 AWG (0.08 - 0.34 mm²) VDV226-107 Heavy-duty ratchet Crimps Connectors RJ11, RJ12 and RJ45 Position/Pair/Conductors 6-Position, 2 Pair/4-Conductor; 6-Position, 3-Pair/6-Conductor; 8-Position, 4-Pair/8-Conductor Overall Length 5-1/4" (133.4 mm) Weight 11.2 oz. (318 g) Ratcheting Modular Crimper/Stripper • Fast, reliable modular-crimp connector installation for voice and data applications tool, cuts, strips and crimps paired-conductor cables (round STP/UTP • All-in-one and flat-satin phone cable) • Crimps 4, 6, and 8 position modular connectors (RJ22, RJ11/RJ12 and RJ45) • Crimping dies are precision ground from high-carbon steel • Ratchet safety-release and a blade-guard on cutting and stripping knives reduce risk of injury • Full-cycle ratchet mechanism prevents the release of the connector prior to full compression • Yellow and black grips enhance comfort, visibility, and allow quick identification • Not for use with AMP connectors • Replacement blade set available (Cat. No. VDV999-064) VDV226-011 ® Cat. No. VDV226-011-SEN Color Yellow/Black Cuts & Strips STP/UTP, Flat Satin Phone Cable, and 22-28 AWG (0.08 - 0.34 mm²) Crimps Connectors RJ11, RJ12, RJ22, and RJ45 Position/Pair/Conductors 4-Position, 1-Pair/2-Conductor, 4-Position, 2-Pair/4-Conductor 6-Position, 2-Pair/4-Conductor, 6-Position, 3-Pair/6-Conductor, 8-Position, 4-Pair/8-Conductor Overall Length 7-1/2" (190.5 mm) Weight 11.3 oz. (320 g) AMP® is a registered trademark of TYCO, Inc. Long-Nose Pliers - Connector Crimping • Crimps UR/UY/UG insulation displacement connectors (IDC) - Scotchlok • Grooved jaws for wire wrapping, looping and twisting • Cleanly strips 23 AWG and 24 AWG wire • Hot-riveted joint ensures smooth action and no handle wobble • Induction-hardened cutting surface for long life ® type connectors VDV026-049 UR IDC Cat. No. VDV026-049 Overall Length 6-51/64" (172.6 mm) Jaw Length 2" (50.8 mm) Jaw Width 45/64" (17.9 mm) Jaw Thickness 3/8" (9.5 mm) Knife Length 7/16" (11.1 mm) UG IDC Point Diameter 0.095" x 0.125" (2.41 mm x 3.17 mm) UY IDC Handle Finish Plastic Dipped Handle Color Yellow Weight 4.5 oz. (128 g) Scotchlok® is a registered trademark of 3M Corporation. See page 310 for additional information on warnings. 191 www.kleintools.com Voice/Data/Video Tools, Testers & Connectors Punchdown Tools & Accesories Punchdown Screwdriver Multi-Tool and cut wire in one step with 110/66 combination cut-type punchdown • Terminate blade with precision ground cutting edge • Non-impact wire termination • Machine-tooled steel bits for superior strength • Heavy-duty blade barrel provides storage for bits • Bayonet-style (twist & lock) socket accepts most manufacturers' punchdown blades • Cushion-Grip handle for greater torque and enhanced comfort • Tip-Ident™ for quick identification of tool • Two Phillips screwdriver tips: #1 and #2 • Two slotted screwdriver tips: 3/16" and 1/4" • Two nut drivers: 1/4" and 3/8" • One hex key: 3/8" Cat. No. VDV001-081 Color Yellow/Black Included Bits/Blades 66/110 Terminate and Cut, #1 and #2 Phillips, 3/16" (4.8 mm) and 1/4" (6.4 mm) Slotted, 1/4" and 3/8" Nut Driver, 3/8" Hex-Key VDV001-081 #1 #2 3/16" 1/4" 3/8" 1/4" 3/8" US Patent: 8856994 Finish Chrome Overall Length 8" (203.2 mm) Weight 9.4 oz. (266 g) Cushion-Grip Impact Punchdown Tools • 4-piece tool kit for complete termination of 110/66 panels, cross-connect systems and wall jacks Impact Punchdown Tool (VDV427-821) includes a "Hi/Lo" impact functionality for • Cushion-Grip adjustable compression force on various wire gauges, blocks and jacks punchdown tool also has an integrated, extra-long shaft for reaching into bulky/crowded • The blocks and a heavy-duty metal collar for strength and longevity Cushion-Grip handle reduces hand fatigue and provides superior comfort when using • Atheunique punchdown tool separate or remove wires, small components, covers or debris from panels, blocks or • Pick-up, jacks with the Wire Pick (VDV327-103) Wire Pick body is made of non-conductive material to prevent shorts. It also has a metal • The hook end and a non conductive spudger end Dura-Blade 110/66 Cut Combination Punchdown Blade (VDV427-104) is manufactured • The using a metal injecting molding (MIM) technology for better quality, durability and performance blade has both 110 and 66 cut/terminate edges for clean, accurate wire insertion and • The trimming. It is compatible with most bayonet style (twist & lock) socket punchdown tools kit-exclusive Multi-Pocket Pouch has separate compartments to store tools, a metal belt clip • The and a reinforced puncture-resistant bottom VDV427-822 US Patent: D718585 Cat. No. VDV427-822 Set Contains Cat. No. Overall Length 9.125" (232 mm) Description Blade Configuration End 1 Blade Configuration End 2 VDV427-821 Cushion-Grip Impact Punchdown Tool w/Dura-Blade™ 110 Terminate and Cut VDV327-103 Wire Pick ​Hook VDV427-104 Dura-Blade™ 110/66 Cut Punchdown Blade 110 Terminate and Cut kit exclusive Multi-pocket pouch with reinforced puncture-resistant bottom *Items also sold separately 192 www.kleintools.com Weight 14.9 oz. (422 g) 66 Terminate and Cut ​Spudger 66 Terminate and Cut See page 310 for additional information on warnings. Voice/Data/Video Tools, Testers & Connectors Punchdown Tools & Accesories Punchdown Multi-Tool with 110/66 Blade locking impact mechanism allows non-impact operation and sure driving with a • Patented variety of optional WorkEnds™ driver bits • Terminate and cut wire in one step with included precision ground combination 110/66 blade • Integrated hook and spudger for fast, easy manipulation of wire and small components • Selectable (Hi/Low) impact-force settings • Spring loaded for fast, low effort seating and terminating • Dual material contoured chassis provides greater control and enhances comfort • Blade storage compartment with spring loaded locking mechanism • Color-coded yellow on the cut side of the tool • Hook and spudger neatly and compactly store in the chassis, out of the way when not in use • Induction-hardened high-carbon steel for durability and long life No. VDV427-807 Includes WorkEnds™ Kit with WorkEnds™ adapter, reach extension, and • Cat. 4 driver bits (#1 and #2 Phillips and 3/16" and 1/4" Slotted) in a convenient carrier • Replacement blades/accessories available Cat. No. VDV427-807 Set Contains Punchdown Multi-Tool with 110/66 Blade & WorkEnds Overall Length 7.88" (200 mm) Cat. No. Color Blade Configuration End 1 Blade Configuration End 2 VDV427-104 VDV770-050 Chrome ​— 110 Terminate and Cut Proprietary Magnetic Hex 66 Terminate and Cut 1/4" Female Hex Impact Punchdown Tools • Terminate cable in variety of cross-connect panels, blocks and keystone jacks • Spring loaded for fast, low effort seating and terminating • Selectable (Hi/Low) impact-force settings • Rubber finger grips and boot provide greater control and enhanced comfort • Blade storage compartment with spring loaded locking mechanism • Bayonet style (twist & lock) socket accepts most manufacturers' tools and blades • Induction-hardened high-carbon steel for durability and long life • Replacement blades available Cat. No. VDV427-800-SEN Color VDV427-104 Blade Configuration End 1 Blade Configuration End 2 VDV427-013 Yellow/Black VDV427-104 Chrome Set Contains Impact Punchdown Tool 110 Type — 110 Terminate and Cut — 66 Terminate and Cut Cat. No. Color Blade Configuration End 1 VDV427-013 VDV427-015-SEN Yellow/Black Black — 110 Terminate VDV427-015-SEN Overall Length 7" (177 mm) Weight 5.7 oz. (162 g) Overall Length 7.1" (180 mm) Weight 5.6 oz. (158.7 g) Blade Configuration End 2 — 110 Terminate and Cut Dura-Blade™ 110/66 Cut Combination Punchdown Blade • Dura-Blade™ is manufactured using metal injecting molding (MIM) technology for better quality, durability and performance • Precise cutting-edge for clean, accurate wire insertion, termination and trimming • Dual 110 and 66 cut and terminate ends for versatility • Easy blade insertion with bayonet-style (twist & lock) form factor • Compatible with most bayonet style (twist & lock) socket punchdown tools our Cushion-Grip Impact Punchdown Tool Kit (VDV427-822) for everything required to install and maintain 110 and 66 • See panels, cross-connect systems and wall jacks Cat. No. VDV427-104 Color Chrome See page 310 for additional information on warnings. Blade Configuration End 1 110 Terminate and Cut Weight 7.5 oz. (213 g) VDV427-800 Set Contains Impact Punchdown Tool, Combo 66/110 Type Cat. No. Cat. No. VDV427-805-SEN VDV427-807 Blade Configuration End 2 66 Terminate and Cut VDV427-104 Overall Length 2-13/64" (56.0 mm) Weight 0.6 oz. (17 g) 193 www.kleintools.com Voice/Data/Video Tools, Testers & Connectors Punchdown Tools & Accesories Punchdown Accessories compatible with Klein punchdown tools and • Blades other bayonet style (twist & lock) socket tools • Precision ground cutting-edge for clean, precise wire termination (depending on blade type) and adjust cable in variety of cross-connect panels, • Terminate, blocks and keystone jacks • Induction-hardened high-carbon steel blades for durability and long life blades with termination/cutting ends and • Reversible termination only ends (depending on blade type) Kit converts the Punchdown Multi-Tool chassis • WorkEnds™ (Cat. No. VDV427-047) into a multi-bit driver Pick (Cat. No. VDV327-103) is a professional • Wire pick/probe/spudger for precise maintenance of ® VDV427-015 VDV427-016 VDV770-050† wires on blocks or jacks Cat. No. VDV327-103 VDV427-015-SEN VDV427-016-SEN VDV427-104 VDV770-050 VDV327-103 Description Wire Pick Punchdown Tool Blade 110 Type Punchdown Tool Blade 66 Type Dura-Blade™ 110/66 Cut Punchdown Blade WorkEnds Kit Color Yellow Black Black Chrome — Blade Configuration End 1 ​hook 110 Terminate 66 Terminate 110 Terminate and Cut Proprietary Magnetic Hex Blade Configuration End 2 ​spudger 110 Terminate and Cut 66 Terminate and Cut 66 Terminate and Cut 1/4" Female Hex Overall Length 7-1/4" (184.2 mm) 2-3/32" (53.2 mm) 2-19/64" (58.3 mm) 2-13/64" (56.0 mm) 3013/64" (81.4 mm) Weight 0.1 oz. (2.8 g) 0.5 oz. (14 g) 0.6 oz. (17 g) 0.6 oz. (17 g) 1.4 lbs. (0.64 kg) WorkEnds™ Kit is only compatible with VDV427-047, VDV427-806 and VDV427-807. † Crimp Tool and Die Sets Ratcheting Crimper Frame CATV, electrical, home theater, satellite and security system ratcheting • Professional crimper frame with optional dies is perfect for fast, reliable connector installations • Full-cycle ratchet action assures a complete, precise crimp every cycle • Preset tension for optimum performance • Ratchet mechanism is designed to prevent the release of the connector prior to full compression VDV200-010 • Safety crimp release helps eliminate rejected terminations due to incorrect positioning • Steel body with black-oxide finish for corrosion resistance and durability Cat. No. Overall Length Weight • Thumb-screws secure die-sets for quick, easy changes VDV200-010 8-3/4" (222.3 mm) 1.2 lbs. (0.54 kg) • Optional, quick interchangeable die sets thumb and Phillips screw set available (see table) NOTE: Use caution when tightening thumb screws to prevent thread damage/stripping and hand tighten only; do not Coaxial Hex-Crimp Die Sets over-tighten the thumb screws. Over-tightening thumb-screws can damage the tool and/or die set. Cat. No. Die Set Nest Dimensions VDV999-033 Replacement N/A Screw Set (Thumb and Phillips) VDV212-034 CATV F Connectors RG59 RG6 VDV205-035 Insulated Terminals, AWG 10-22 VDV205-036 Non-Insulated Terminal or Open Barrel Terminal, AWG 10-20 0.255", 0.320", 0.350" 6.48 mm, 8.13 mm, 8.89 mm AWG 22 - 18/ 16 - 14/ 12 - 10 DIN 0.5 - 1.0/ 1.5 - 2.5/ 4 - 6 mm² AWG 20 - 18/ 16 - 14/ 12 - 10 DIN 0.5 1.5 - 2.5/ 4 - 6 mm² 194 www.kleintools.com Cat. No. Die Set VDV211-037 RG58 RG59 RG6 RG62 Nest Dimensions 0.256", 0.319", 0.068", 0.213" 6.50 mm, 8.10 mm, 1.73 mm, 5.41 mm VDV211-038 RG58 RG59 RG6 RG62 0.256", 0.068", 0.213" 6.50 mm, 1.73 mm, 5.41 mm VDV205-039 Pin Terminal Insulated or Non-Insulated Ferrules, AWG 12-22 AWG 22/20/ 18/16/14/12 DIN 0.5/0.75/ 1.0/ 1.5/2.5/ 4 mm² VDV201-040 RG58 RG59 RG62 RG174 Fiber Optic 0.043", 0.068", 0.100", 0.137", 0.213", 0.255", 1.09, 1.73, 2.54, 3.48, 5.41, 6.48 mm Cat. No. Die Set VDV211-041 RG58 RG59 RG6 RG62 VDV201-042 RG174 RG179 Belden 8218 and Fiber Optic VDV211-043 RG8 RG11 RG174 RG179 RG213 Nest Dimensions 0.255", 0.213", 0.098", 0.068", 0.321" 6.48 mm, 5.41 mm, 2.49 mm, 1.73 mm, 8.15 mm 0.042", 0.068", 0.078", 0.128", 0.151", 0.178", 1.07, 7.73, 1.98, 3.25, 3.84, 4.52 mm 0.100"/0.128"/ 0.429" 2.54/3.25/ 10.90 mm VDV205-044 Non-Insulated AWG 18 - 16/ Terminal, 14/ 12 - 10/ 8 AWG 8-18 DIN 0.75 - 1.5/ 2.54/ 4 - 6/ 10 mm² See page 310 for additional information on warnings. Voice/Data/Video Tools, Testers & Connectors Coaxial Cable Connectors Klein Tools' Universal Compression Connector Standard Compression Connector Installs up to 5x faster! Full ferrule Patented universal sleeve design provides excellent holding power and signal strength. Compact ferrule Universal Connector Type Crimping Type Cable Type: RG59 RG6 RG6 QUAD SHIELD Universal Sleeve Outdoor Use Cat. Nos: Pack Size: 10 Pack Size: 35 Pack Size: 50 • BNC-Connector Compression • • • • • VDV812-615 VDV812-606 VDV812-618 VDV812-612 Klein Crimping Tools plenum cables For indoor use only • • • • • VDV813-616 VDV813-619 VDV813-607 VDV813-613 VDV812-623 • VDV812-624 VDV812-615 F • RG6-RG6Q VDV812-606 BNC • RG59 VDV813-616 BNC • RG6-RG6Q Connector Type F-Connector F-Connector F-Connector F-Connector BNC Connector BNC Connector BNC Connector BNC Connector Cable Type RG59 RG59 RG6/6Q RG6/6Q RG59 RG59 RG6/6Q RG6/6Q See page 310 for additional information on warnings. VDV211-063, VDV211-048, VDV212-008-SEN Standard Compression Connectors • Full ferrule design brass construction with • Solid nickel-plated finish • Best choice for outdoors • Great for satellite dishes Cat. No. VDV812-623 VDV812-624 Package Quantity 10 50 10 50 10 35 10 35 Connector Type F-Connector F-Connector Cable Type RG6 RG6 VDV812-627 Connector Type F-Connector Crimping Type Push-on VDV812-623 Package Quantity 10 50 Push-On Connectors • Patented, tool-less, easy grip design • Fits most major brands • For indoor use only Cat. No. VDV813-607 Cat. No. VDV812-615 VDV812-618 VDV812-606 VDV812-612 VDV813-616 VDV813-619 VDV813-607 VDV813-613 F-Connector Compression VDV211-063, VDV211-048 Universal Compression Connectors all manufacturers' • Fit diameter variations F • RG59 within a cable series difficult to work • Fit with multi-shield and • Standard F-Connector Compression VDV812-627 Cable Type RG6/6Q Package Quantity 10 F-Splice Adapter 3 GHz gripping mechanism for • Patented optimal signal strength VDV814-609 Cat. No. VDV814-609 Description F-Splice Adapter 3 GHz Package Quantity 10 195 www.kleintools.com Voice/Data/Video Tools, Testers & Connectors Twisted Pair Connectors Klein's data and telephone plugs are professional-grade and deliver consistent, reliable performance. They feature thick 50 micro-inch gold plating on the contact plates, three-pronged solid and stranded wire contacts, and durable connector housings. Expect a sure connection each and every time. Connector Type Position & Contacts Connector Design Gold Plating Thickness (micro-inch) Cable Type: CAT 3 UY UR RJ11 RJ11 RJ45 2P2C 1-Piece 3P3C 1-Piece 6P4C 1-Piece 50μ" 6P6C 1-Piece 50μ" 8P8C • • • • 1-Piece 50μ" • • CAT 5 CAT 5e • • • • • • • • • Yellow Red Clear Clear Clear Clear VDV826-604 VDV826-605 VDV826-601 VDV826-600 CAT 6 Solid Conductor Wire Stranded Conductor Wire Connector Color Cat. No. Pack Size: 10 Pack Size: 25 Pack Size: 50 Pack Size: 100 Crimping Type Klein Crimping Tools 3-Piece 50μ" VDV826-628 VDV826-603 VDV826-602 VDV826-611 Modular Plug Connector VDV226-011-SEN, VDV226-107 IDC D234-6, D234-6C, VDV026-049 RJ45 Modular Data Plugs • 8 position 8 contact • For solid or stranded conductors Cat. No. VDV826-628 VDV826-602 VDV826-611 VDV826-603 Connector Type RJ45 RJ45 RJ45 RJ45 Cable Type CAT 5/CAT 5e CAT 5/CAT 5e CAT 5/CAT 5e CAT 6 Connector Color Clear Clear Clear Clear Package Quantity 10 50 100 25 RJ11 Telephone Plugs • 6 position 4 contact for 1 or 2 line telephones • 6 position 6 contact for 1, 2 or 3 line telephones 6P4C Cat. No. VDV826-601 VDV826-600 Position & Contacts 6P4C 6P6C 196 www.kleintools.com Connector Color Clear Clear VDV826-603 (CAT 6) Insulation Displacement Connectors • Insulation displacement connector to add or terminate a telephone line • Gel-filled for moisture resistance Package Quantity 25 25 VDV826-605 3 wire (26-19 AWG) VDV826-604 2 wire (26-22 AWG) VDV826-600 6P6C Connector Type RJ11 RJ11 VDV826-628 (CAT 5 / CAT 5e) Cat. No. VDV826-604 VDV826-605 Connector Type UY UR Position & Contacts 2P2C 3P3C Connector Color Yellow Red Package Quantity 25 25 See page 310 for additional information on warnings. Voice/Data/Video Tools, Testers & Connectors Voice/Data/Video Tool Kits VDV ProTech™ Kits data and coaxial • For cable installations VDV026-831 Cat No. Product VDV011-832 Description VDV001-833 VDV026-831 VDV011-832 VDV001-833 ● ● ● VDV000-133 VDV ProTechTM Transport Lightweight tool case with 12 organizational compartments for small parts and a large, open section to hold hand tools VDV826-600 Telephone Plug RJ11 - 6P6C Thick 50 micro-inch gold-plated and 3-pronged contacts with durable housing – for 1, 2 or 3 line telephones VDV826-603 Modular Data Plug – RJ45 - CAT6 Thick 50 micro-inch gold-plated and 3-pronged contacts with durable housing – 8 position, 8 contact 3-piece design for solid and stranded wire VDV826-628 Modular Data Plug – RJ45 - CAT5e Thick 50 micro-inch gold-plated and 3-pronged contacts with durable housing – 8 position, 8 contact for solid or stranded wire VDV812-606 Universal F Compression Connector – RG6/6Q Patented universal sleeve technology installs up to 5X faster and fits all diameter variations of RG6/6Q cable VDV812-615 Universal F Compression Connector – RG59 Patented universal sleeve technology installs up to 2X faster and fits all diameter variations of RG59 cable VDV812-623 F Compression Connector – RG6 All metal construction with dual O-ring to seal out moisture – satellite provider approved VDV813-607 Universal BNC Compression Connector – RG6/6Q Patented universal sleeve technology installs up to 5X faster and fits all diameter variations of RG6/6Q cable 10 pack VDV813-616 Universal BNC Compression Connector - RG59 Patented universal sleeve technology installs up to 2X faster and fits all diameter variations of RG59 cable 10 pack 2100-8 Free-Fall Snip – Stainless Steel Stainless steel blades maintain blade durability and sharpness when cutting 19 and 23 AWG wire ● ● VDV226-107 Compact Ratcheting Modular Crimper All inclusive tool cuts, strips and crimps data cables and modular data plugs ● ● VDV211-048 Compression Crimper – Compact, Multi-Connector Crimps compression (F, BNC, RCA) connectors to coaxial cable VDV211-063 Compression Crimper-Lateral, Multi-Connector One tool crimps most compression (F, BNC, RCA) connectors to most coaxial cables including Mini-Coax, RG58, RG59, RG62, RG6Q, RG7 and RG11 VDV110-061 Coax Cable Stripper – 2-Level, Radial Provides one step, two-level stripping: 5/16" (7.9 mm) and 1/4" (6.4 mm) ● 63020 Multi-Cable Cutter Klein-KurveTM Cutter has a wide range of blades designed to cut various types of cable including solid and stranded copper wire, RG-59, RG6Q and RG-62 coaxial cable as well as other conductors ● VDV600-096 Coaxial Cable Cutter – CCS Cutter features a custom notch for CCS coaxial cable and standard shears for general purpose of cable including RG59, RG6, RG6Q RG7, RG11 and Twisted pair copper wire. See page 310 for additional information on warnings. ● ● 25 pack 25 pack ● ● 25 pack 25 pack ● ● 10 pack (x2) 10 pack (x2) ● ● 10 pack (x2) 10 pack (x2) ● 10 pack ● 10 pack ● ● 10 pack (x2) 10 pack (x2) ● ● ● 10 pack ● 10 pack ● ● ● ● 197 www.kleintools.com Voice/Data/Video Tools, Testers & Connectors Voice/Data/Video Tool Kits Coax Installer Starter Kit-F-Connectors • Includes the tools needed to prepare and connect F-connectors nylon tool pouch designed specifically for • Durable F-connector installation tools pocket holds a screwdriver or • Additional common AA battery flashlights includes a closeable pocket that will hold up to 25 • Pouch compression F-connectors (F-connectors not included) • Tunnel-loop accommodates up to 2" belt Cat. No. VDV012-811 Kit Contains Weight 1.4 lbs. (0.64 kg) Cat. No. Description 63020 VDV110-802-SEN VDV212-008-SEN kit exclusive Multi-Cable Cutter Klein-Kurve® Radial Cartridge Stripper Compression Crimper Compact, F-Connector 5-pocket nylon tool pouch plus closeable consumables pocket VDV012-811 LAN Installer Starter Kit - Modular the tools needed to prepare, • Includes connect and test modular cables nylon tool pouch designed specifically • Durable for modular plug installation tools additional pockets hold a screwdriver and common AA • Two battery flashlights includes a closeable pocket that will hold up to • Pouch 25 RJ45 plugs (RJ45 plugs not included) • Tunnel-loop accommodates up to 2" belt Cat. No. VDV026-812 Kit Contains Weight 1.5 lbs. (0.68 kg) Cat. No. Description 2100-8 VDV226-011-SEN VDV526-052 98554 kit exclusive Free-Fall Snip Stainless Steel Ratcheting Modular Crimper/Stripper LAN Scout Jr. Tester Fine Point Permanent Markers 5-pocket nylon tool pouch plus closeable consumables pocket VDV026-812 LAN Installer Starter Kit - Punchdown the tools needed to prepare and connect • Includes 66 type and 110 type punchdown terminal blocks nylon tool pouch designed specifically for • Durable punchdown installation tools additional pockets hold a screwdriver and • Two common AA battery flashlights • Tunnel-loop accommodates up to 2" belt Cat. No. VDV027-813 Kit Contains Weight 14.1 oz. (399 g) Cat. No. Description 2100-8 VDV427047 VDV427-015-SEN VDV427-104 98554 kit exclusive Free-Fall Snip Stainless Steel PUNCHDOWN MULTI-TOOL CHASSIS Punchdown Tool Blade 110 Type Dura-Blade™ 110/66 Cut Punchdown Blade Fine Point Permanent Markers 4-pocket nylon tool pouch 198 www.kleintools.com VDV027-813 See page 310 for additional information on warnings. WARNING: Do NOT use on energized circuits or cabling systems. Voice/Data/Video Tools, Testers & Connectors Voice/Data/Video Tool Kits Coax Installation & Test Kit • Includes tools needed to prepare, connect and test coax cables • Coax Cable Stripper 2-Level, Radial: Designed for easy single operation cable preparations Crimper Compact F-Connector: Crimps compression F-connectors to coaxial • Compression cable quickly and reliably Explorer™ Tester: Compact tool tests and verifies coaxial cable connections • Coax (good/open/short) F-Compression Connectors - RG6 / RG6-QS: Patented universal sleeve • Universal connectors install up to 5X faster Cat. No. VDV002-818 Kit Contains Weight 1.1 lbs. (0.50 kg) Cat. No. Description VDV212-008-SEN VDV110-061 VDV512-057 VDV812-606 Compression Crimper Compact, F-Connector Coax Cable Stripper 2-Level, Radial Coax Explorer Tester Universal F Compression Connector RG6/6Q Pk 10 VDV002-818 Coax Push-On Connector Installation & Test Kit • Includes tools needed to prepare, connect and test push-on coax cables • Coax Cable Stripper 2-Level, Radial: Designed for easy single operation cable preparations Explorer™ Tester: Compact tool tests and verifies coaxial cable connections • Coax (good/open/short) F-Connectors - RG6 / RG6-QS: Tool-less, patented cable grip design for easy • Push-On installation and strong hold Cat. No. VDV002-820 Kit Contains Weight 4.5 oz. (128 g) VDV002-820 Cat. No. Description VDV110-061 VDV512-057 VDV812-627 Coax Cable Stripper 2-Level, Radial Coax Explorer Tester F Connector RG6/6Q Male Pk 10 Modular Installation Kit • Includes tools needed to prepare and connect modular cables Modular Crimper/Stripper: All-in-one tool cuts, strips and crimps • Ratcheting paired-conductor cables (RJ11 / RJ12, RJ22, RJ45) Data Plug - RJ45 - CAT5e: Thick 50 micro-inch gold plating and • Modular 3-pronged contacts with durable housing - 8 position, 8 contact for data cables Plug - RJ11 - 6P6C: Thick 50 micro-inch gold plating and 3-pronged • Telephone contacts with durable housing - for 1, 2 or 3 line telephones Cat. No. VDV226-817 Kit Contains Weight 12.2 oz. (345 g) Cat. No. Description VDV226-011-SEN VDV826-628 kit exclusive Ratcheting Modular Crimper/Stripper Modular Data Plug, RJ45, CAT5e 10 Pk Telephone Plug - Rj11 - 6P6C (10 pack) VDV226-817 199 See page 310 for additional information on warnings. WARNING: Do NOT use on energized circuits or cabling systems. www.kleintools.com Voice/Data/Video Tools, Testers & Connectors Voice/Data/Video Test & Measurement VDV Commander™ Commander™ Series locates, tests and measures • VDV coaxial, data (RJ45) and telephone (RJ11) cables cable length and distance to a fault with • Measure Time Domain Reflectometry (TDR) technology and identify cables with location ID remotes, • Locate Test-n-Map™ remotes, Link Light and Tone Generator* • Detect, identify and test Power over Ethernet (PoE) • Perform active network (Ethernet) testing • Save up to 256 cable or network tests and export to print reports No. VDV501-828: 1 Commander™ tester • Test-n-Map™ Remote #1 • 5 LanMap™ • Cat. ID Remotes • 5 CoaxMap™ ID remotes • 1 test cable each for USB, RJ12 and Features RJ-45 8-Wire Cables F-connector Coaxial Cables Telephone Cables Wiremap ● ● with adapter ● Open Fault ● Short Fault ● Miswire Fault ● Split-Pair Fault ● ● RJ45 • 1 coax adapter • carrying case TIA-568A/B & Crossover/Uplink Active Ethernet remotes • 1 test cable each for USB, RJ12 and RJ45 • 1 coax adapter • carrying case Single-End Cable Testing Test-n-Map™ Remote (Two End Testing) Pass Detects link speed and capabilities to 1 Gbps No. VDV501-829: 1 Commander™ tester • Test-n-Map™ Remote #1 • 1 • Cat. PROBEplus Tone Tracing Probe • 20 LanMap™ ID Remotes • 20 CoaxMap™ ID Test and Indentify location in one step with remote PoE TDR Power Over Ethernet Testing ● ● Length Measurement Method ±(5% + 1 Ft.) Accuracy/ Measurement Resolution ±(5% + 0.3 m) Link Light ID S Cat. No. VDV501-828 Batteries Battery Life Height Width 6 AA Alkaline 20 Hours Active 6-51/64" 3-19/32" Included 10 Years Standby (172.6 mm) (91.3 mm) Commander: VDV501-829 Commander: 6-51/64" 3-19/32" 6 AA Alkaline 20 Hours Active (172.6 mm) (91.3 mm) 10 Years Standby, Included; Probe: 25 Hours Active Probe: 4 Years Standby 1 9V Alkaline Included *Functionality requires analog probe VDV500-060 (included with Cat. No. VDV501-829) Depth 1-27/32" (46.9 mm) 1-27/32" (46.9 mm) Weight 12.0 oz. (340 g) 12.0 oz. (340 g) Ft./m Apo 1500 ft. / 457 m ● ● Cable Identification supports up to 20 Shield Detection ● Voltage Warning ● Low Battery Indicator ● Store Test Results 256 Print / Export Custom Reports ● Multiple-style Tone Generator* 4 Down to Single Conductor/Pair/Cable VDV501-829 ● supports up to 8 Time Domain Reflectometry Measures Cable Length VDV501-828 ● Color LCD Display 2.7" Multiple Languages ENG · ESP · FRA Imperial or Metric Results Auto Power Off ● ● Customizable Setup ● USB interface (for PC connection) Upgradable Firmware (via internet download & pc connection) MICRO ● VDV Commander™ Test-n-Map™ Remote Kit • Maximize your VDV Commander™ with single-step Test-n-Map™ Remotes • Test, map and identify a location in a single step • Cuts testing and identification time in half • Test and identify up to eight locations at once Tester sold separately Cat. No. VDV770-834 Test-n-Map™ Coax Remotes F-Adapters 7 8 RJ45 jumper test cable (8) 9” (228.6 mm) RJ11/RJ12 jumper Verification Weight cable Cables (2) 9" (228.6 mm) 1 23.0 oz. (652 g) 200 www.kleintools.com VDV770-834 See page 310 for additional information on warnings. WARNING: Do NOT use on energized circuits or cabling systems. Voice/Data/Video Tools, Testers & Connectors Voice/Data/Video Test & Measurement VDV Scout Pro 2 Series TM VDV ScoutTM VDV ScoutTM Pro 2 Pro 2 LT VDV501-823 VDV501-824 VDV501-825 VDV501-826 ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● Measures cable length – ● Test-n-MapTM Remotes Supports up to 8 Supports up to 8 Supports up to 19 Supports up to 19 Supports up to 19 Supports up to 19 4 Tones 4 Tones ● ● ● ● ● ● ● ● Features Tests RJ45 8-wire cables Tests RJ11/12 6-wire cables Tests F-connector coaxial cables Pass Continuity testing TIA-568A/B & crossover/uplink Wiremap Detects open faults Detects short faults Detects miswires Detects split pairs Twisted-pair (RJ45) cable ID location remotes Coaxial F-connector cable ID location remotes ID Multiple-style Tone Generator Low battery indicator S Apo Voltage warning Shield detection Auto power off VDV501-823 VDV501-824 VDV501-825 VDV501-826 VDV501-823 Self Storing Remote Top View: RJ45, RJ11/12 and F-connector ports VDV501-824, VDV501-825 and VDV501-826 Test-n-MapTM Self Storing Remote Maximize your VDV Scout Pro TM with Test-n-Map TM Remotes • Test, map and identify a location in a single step • Cuts testing and identification time in half • Test and identify up to eight locations at once Test-n-Map™ Remote Kit Compatibility Chart Cat. No. Description Kit No. VDV501-098 VDV Scout™ Pro 2 Tester VDV501-823, VDV501-824 Button Color Compatibility YES VDV501-108 VDV Scout™ Pro 2 LT Tester VDV501-825, VDV501-826 YES VDV501-053 VDV Scout™ Pro Tester VDV501-809 NO 201 See page 310 for additional information on warnings. WARNING: Do NOT use on energized circuits or cabling systems. www.kleintools.com Voice/Data/Video Tools, Testers & Connectors Voice/Data/Video Test & Measurement VDV Scout™ Pro 2 Series • Tests continuity on voice (RJ11/12), data (RJ45) and video (F-connector) connections • Locates cable runs to wall outlets with location ID remotes • Compatible with single-step Test-n-Map™ Remotes • Supports multiple tones and control of pins carrying tone with integrated tone generator Measures cable length in feet or meters (LT models only) Requires analog tone probe — sold • separately † † VDV501-825 VDV501-824 VDV501-823 VDV501-826 Items Included Cat.No. VDV Scout™ Pro 2 Tester VDV Scout™ Pro 2 LT Tester Test-n-Map™ Remotes LanMap™ Cable Identification Location Remotes CoaxMap™ Cable Identification Location Remotes Coax barrel F adapter (female to female) Coax push-on F adapter (threaded male to push-on female) VDV770-827 VDV ScoutTM Pro 2 Tester Kit VDV ScoutTM Pro 2 Tester & Test-n-MapTM Remote Kit VDV ScoutTM Pro 2 LT Tester & Remote Kit VDV ScoutTM Pro 2 LT Tester & Test-n-MapTM Remote Kit VDV ScoutTM Pro 2 Test-n-MapTM Remote Kit VDV501-823 VDV501-824 VDV501-825 VDV501-826 VDV770-827 VDV501-098 VDV501-098 – – – – – – 8 VDV501-108 VDV501-108 1 8 – 8 5 – 19 – – 5 – 19 – – 1 1 1 1 – – 8 – 8 8 8 RJ45 jumper test cable (9") – 8 – 8 9V battery ● ● ● ● Carrying case – ● ● ● ● 2.75" (70 mm) 6.3" (160 mm) 1.38" (35 mm) 13 oz. (369 g) 9" (229 mm) 13" (330 mm) 4.375" (111 mm) 63 oz. (1786 g) 9" (229 mm) 11.5" (292 mm) 2" (51 mm) 34 oz. (964 g) 9" (229 mm) 13" (330 mm) 4.375" (111 mm) 63 oz. (1786 g) 9" (229 mm) 13" (330 mm) 4.375" (111 mm) 56 oz. (1588 g) Dimensions Height Width Depth Weight 202 www.kleintools.com See page 310 for additional information on warnings. WARNING: Do NOT use on energized circuits or cabling systems. Voice/Data/Video Tools, Testers & Connectors Voice/Data/Video Test & Measurement LanMap™ Kit for VDV Scout™ Pro Series Tester • Identify and map twisted-pair (RJ45) infrastructure, up to 19 locations • For use with VDV Scout™ Pro Series and VDV Commander™ testers • Heavy-duty design for long life and repeated connections • Remotes numbered 1 through 19 for fast and accurate identification Cat. No. VDV526-055 Height 3" (76.2 mm) Width 3-19/64" (83.7 mm) Depth 1-13/32" (35.6 mm) Weight 1.9 oz. (54 g) VDV526-055 CoaxMap™ Kit for VDV Scout™ Pro Series Tester • Identify and map coaxial (F-connector) cable infrastructure, up to 19 locations • For use with VDV Scout™ Pro Series and VDV Commander™ testers • Heavy-duty design for long life and repeated connections • Remotes numbered 1 through 19 for fast and accurate identification Cat. No. VDV512-056 Height 3" (76.2 mm) Width 3-19/64" (83.7 mm) Depth 1" (25.4 mm) Weight 5.2 oz. (147 g) VDV512-056 VDV Scout™ Pro Series Carrying Case • Custom designed compartments hold tester and accessories securely • Dual zipper-pulls for quick access and EVA foam to cushion and protect • Flexible case can accommodate various products and configurations • Designed for use with VDV Scout™ Pro Series, LanMap™ and CoaxMap™ Kits VDV770-080 Products not included Cat. No. VDV770-080 Height 11-1/2" (292.1 mm) Width 8-3/4" (222.3 mm) Depth 2-1/4" (57.2 mm) Weight 15.0 oz. (425 g) 203 See page 310 for additional information on warnings. WARNING: Do NOT use on energized circuits or cabling systems. www.kleintools.com Voice/Data/Video Tools, Testers & Connectors Voice/Data/Video Test & Measurement LAN Scout™ Jr. Tester • Tests continuity on twisted pair data wiring (RJ45) connections • Integrated tone generator supports multiple tones and control of individual wires carrying tone • Heavy-duty ports are designed for long life and repeated connections • Large display for easy identification • Compact, contoured dual-material chassis fits comfortably in your hand Features Pass Apo S VDV526-052 RJ45 8-wire Cables ● Continuity Testing TIA-568A/B & Crossover/Uplink LCD Display ● Wiremap ● Open Fault ● Short Fault ● Miswire Fault ● Split Pair Fault ● Multiple Style Tone Generator 4 Self-Storing Remote ● Low Battery Auto Power Off ● ● Voltage Warning ● Shield Detection ● ● RJ45 Port ● VDV526-052 Self Storing Remote Cat. No. VDV526-052 Batteries 6V to 4 x Lr44 Alkaline Height 4-39/64" (117.1 mm) Width 2-19/64" (58.3 mm) Depth 1-7/64" (28.2 mm) Weight 4.0 oz. (113 g) Coax Explorer™ Testers • Tests and verifies coaxial cable continuity • Compact size fits easily into pocket or pouch • Bright LED indicates cable status (good/open/short) • Simple push-button operation No. VDV512-058 includes color coded remotes and a • Cat. convenient remote holder to test up to 4 locations at once VDV512-058 Cat. No. VDV512-058 VDV512-057 Location ID 4 1 Batteries Lithium Non-Replaceable Lithium Non-Replaceable Height 5-39/64" (142.5 mm) 2-45/645" (68.7 mm) Width 1-3/32" (27.8 mm) 1-3/32" (27.8 mm) Depth 1-1/4" (44.5 mm) 45/64" (17.9 mm) Weight 3.3 oz. (95 g) 1.3 oz. (37 g) VDV512-057 204 www.kleintools.com See page 310 for additional information on warnings. WARNING: Do NOT use on energized circuits or cabling systems. Voice/Data/Video Tools, Testers & Connectors Voice/Data/Video Test & Measurement PROBEplus-Tone Tracing Probe • Trace wire paths and identify cables in common wiring systems • Amplifier overload LED improves accuracy, warning against misreads • Dual mode power button with Power-On LED indicator - tap or hold • Recessed buttons prevent accidental operation • Works with other manufacturers' analog tone generators • Replacement tips available (Cat. No. VDV999-065) Features Apo VDV500-060 Amplifier Overload Indication Adjustable Digital Volume Control ● ● Tap-Mode Operation ● Hold-Mode Operation ● Power-On LED Indicator ● Visual Notification Auto Power-Off Low Battery Indicator Replaceable Tip ● ● ● ● Lanyard Attachment Loop ● VDV500-060 Cat. No. VDV500-060 Battery 9V Not Included Battery Life 25 Hours Active 4 Years Standby Height 9-29/32" (251.6 mm) TONEcube-Tone Generator wire paths and identify cables in • Trace common wiring systems • Five discrete tracing tones selected by tone switch • Constant output level over useful battery life • Momentary slide switches prevent accidental operation leads with rugged dual-mode modular plug • Heavy-duty for direct connection to RJ11/RJ12 and RJ45 jacks via • Battery 9V Not Included Depth 1-9/64" (29.0 mm) Features VDV500-051 Battery Life 120 Hours Active 4 Years Standby Height 2-45/645" (68.7 mm) Apo Width 2-1/2" (63.5 mm) Weight 6.0 oz. (170 g) VDV500-051 Tones 5 Heavy-Duty Leads ● Rugged Universal RJ11/RJ12/RJ45 Modular Plug Continuity Testing Voltage Overload Protection Line Status & Polarity RJ12 plug Works with other manufacturers' analog tone probes Cat. No. VDV500-051 Width 2" (50.8 mm) ● ● ● ● Power-On Flashing LED Indicator ● Auto Power-Off Low Battery Indicator ● ● Lanyard Attachment Loop ● Depth 1-27/64" (36.1 mm) Weight 5.0 oz. (142 g) TONEcube & PROBEplus Kit • Trace wire paths and identify cables in common wiring systems • Batteries not included Cat. No. VDV500-808 Kit Contains Weight 16.0 oz. (454 g) Cat. No. Description VDV500-051 VDV500-060 kit exclusive TONEcube Tone Generator PROBEplus Tone Tracing Probe nylon pouch VDV500-808 205 See page 310 for additional information on warnings. WARNING: Do NOT use on energized circuits or cabling systems. www.kleintools.com Voice/Data/Video Tools, Testers & Connectors Voice/Data/Video Test & Measurement TraceAll™ Tone & Probe • Trace wire paths and identify cables in common wiring systems • Heavy-duty RJ11 jack on tone generator for long life and repeated connections • Includes RJ11 adapter to convert tone generator to an alligator-clip configuration • Dual material chassis fits comfortably in your hand • Replacement tips available (Cat. No. VDV999-059) Features Apo VDV526-054 VDV526-054 Tone Generator 2 Adjustable Volume ● Self-Storing Remote ● Auto Power-Off ● Replaceable Tip ● Self Storing Remote Cat. No. VDV526-054 Batteries 6V 4 x LR44 Alkaline Included Battery Life Tracer: 10 Hours, Generator: 50 Hours Adapter Height 8-57/64" (225.8 mm) Width 1-45/64 (43.3 mm) Depth 1-13/64" (30.6 mm) Weight 5.0 oz. (142 g) VDV Ranger™ TDR Kit • Test and measure cable with the latest technology Domain Reflectometry Spread Spectrum (TDR-SS) Technology provides superior • Time accuracy up to +/-(1% + 3 ft.) by eliminating interference when measuring cable technology broadens TDR environments by operating in Safety Extra Low Voltage (SELV) rated • TDR-SS environments as defined by IEC. (SELV is 60 volts DC or Peak AC - 45 volts RMS) paired-conductor cable length up to 3,000 ft. (914 m) including voice, data, video, • Measure doorbell, siamese, lamp-wire and NM cables • Determine if cable run is broken or damaged • Ensure compliance and identify cable runs outside specification • The Tone Generator traces and identifies cables. Four tone cadences available • Measure cable remaining in box or on a reel • Simplify cable estimating and bill jobs more accurately cord set includes BNC to F-connector adapter, F-connector adapter, insulated push-on F-connector to • Adapter alligator clips, insulated BNC connector to alligator clips and insulated push-on F-connector to RJ45 modular plug † Features VDV501-815 Multi-Adapter Set Interface Measures Cable Length Length Measurement Method VDV501-815 ● TDR-SS Spread Spectrum Time Domain Reflectometry Accuracy & Resolution Measurement ±(1% + 3 ft.) ± (1% + 1 m) Maximum Cable Length ● ● 3,000 ft. / 914 m Common Cable Length Ranges Must be paired conductors RJ45 8-Cables 0 - 1,500 Ft. (457 m) Coaxial Cable 0 - 2,000 Ft. (609 m) Electrical Cable 0 - 1,000 Ft. (305 m) Imperial & Metric Results Ft./m On-Board Calibration Memory ● 2 Storage Locations Open Fault ● Short Fault ● 4 2.25" (57 mm) Backlit LCD Multiple Style Tone Generator† Display Voltage Warning Low Battery Auto Power Off ● Apo ● ● Includes custom designed polyester carrying case. Requires analog tone probe: VDV526-054 or VDV500-060 – both sold separately.) † Cat. No. VDV501-815 Batteries Battery Life Height Four AA 15 Hours Active, 6-51/64" Alkaline 4 Years Standby (172.6 mm) Batteries Included 206 www.kleintools.com Width 3-5/32" (80.2 mm) Depth 1-19/64" (32.9 mm) Weight 12.0 oz. (340 g) See page 310 for additional information on warnings. WARNING: Do NOT use on energized circuits or cabling systems.
VDV001-833 价格&库存
很抱歉,暂时无法提供与“VDV001-833”相匹配的价格&库存,您可以联系我们找货
VDV001-833
    • 1+3976.472051+497.52841
    库存:1
