630-11/32-INS
630-11/32-INS
    KLEINTOOLS
    11/32''NUTDRIVER
630-11/32-INS 数据手册
Insulated Tools Klein insulated tools combine excellent functionality along with reduction of risk of injury where a tool might make contact with an energized source with voltage up to 1000 volts. ~ Electrician's Insulated Tools Insulated Tools FORGED STEEL from Klein's US-made, proprietary blend Durable, three component molded insulation provides protection against electric shock Thick, exceptionally tough, high-dielectric white inner coating is bonded to the tool Induction hardened cutting knives for long life Forged steel handle Multi-color, sleek design with small thumb guards for ease of handling and storage Hot-riveted joint ensures smooth action and no handle wobble A flame retardant, impact-resistant, multi-color outer coating ~ Klein electrician's insulated tools meet or exceed IEC 60900: 2012, ASTM F1505, and VDE standards and are clearly marked with the official 1000-volt rating symbol. pliers available. Cuts ACSR, screws, nails, and most hardened wire The Electrician's line of insulated tools provides a multi-color, sleeker design than the Classic Lineman's insulated tools. 1000V rated and individually tested to conform to ASTM F1505, IEC 60900. EINS tools have passed VDE third party testing certification to the IEC 60900 standard. This line of tools provides the everyday protection the electrician needs in a compact, lightweight design. Catalog numbers for Klein electrician's insulated tools have the suffix "EINS" and are marked with the official international 1000-volt rating symbol. Not all tools with plastic coatings or plastic handles provide protection against electrical shock. Only use those tools that are marked with the official international 1000-volt rating symbol, as shown, if there is any chance that the tool will make contact with an energized source. Product numbers with the EINS suffix contain these warnings below and must be understood. WARNING: Only use tools that are marked with the official international 1000-volt rating symbol shown below, if there is any chance that the tools will make contact with an energized source. WARNING: Wear approved eye protection. Always inspect your tools before use. Do not use if orange coating cracks, breaks or becomes damaged. Destroy tool if white layer shows through orange layer. 46 www.kleintools.com WARNING: Do NOT touch uninsulated portion of the tool or any conductive object when either might contact an energized source. WARNING: Whenever possible, always de-energize lines and equipment prior to working on or around them. Klein insulated tools are designed only to reduce the chance of injury where the tool may make contact with an energized source. WARNING: Because moisture, films, or other surface contaminants are conductive, Klein insulated tools must be kept clean, dry, and free of any surface contaminants. See page 310 for additional information on warnings. Insulated Tools 3 R Y - 9NE E EY PROT N CT N S IO N 1 D2 A E W ~ Electrician's Insulated Pliers Electrician's Insulated High-Leverage Side-Cutting Pliers Additional Features: High-leverage design provides 46% greater cutting and gripping power than other plier designs Streamlined design with sure-gripping, cross-hatched knurled jaws 2000 Series cuts ACSR, screws, nails and most hardened wires • • • Cat. No. 213-8NE-EINS 213-9NE-EINS Nose Type New England New England Overall Length 8-13/16" (223.8 mm) 9-5/8" (244.5 mm) Jaw Length 1-7/16" (36.5 mm) 1-19/32" (40.5 mm) 213-9NE-EINS Jaw Width 1-7/64" (28.2 mm) 1-5/16" (33.3 mm) Jaw Thickness 5/8" (15.9 mm) 5/8" (15.9 mm) Knife Length 3/4" (19.1 mm) 25/32" (19.8 mm) Weight 1.0 lbs. (0.45 kg) 1.3 lbs. (0.59 kg) 5/8" (15.9 mm) 25/32" (19.8 mm) 1.3 lbs. (0.59 kg) 2000 Series* – Heavy-duty cutting knives 2000-9NE-EINS New England 9-5/8" (244.5 mm) 1-19/32" (40.5 mm) 1-5/16" (33.3 mm) *Cuts ACSR, screws, nails, and most hardened wire. Features combination polished and black-oxide finish. Electrician's Insulated High-Leverage Diagonal Cutting Pliers Additional Features: High-leverage design. Rivet is closer to the cutting edge for 36% greater cutting power than other pliers designs Cuts ACSR, screws, nails, and most hardened wire. Features combination polished and black-oxide finish 13° angled head for easier work in confined spaces (Cat. No. 2000-48-EINS) • • • Cat. No. 2000-28-EINS 2000-48-EINS Nose Type Tapered Angled Overall Length 8-1/4" (209.6 mm) 8-1/4" (209.6 mm) Jaw Length 13/16" (20.6 mm) 13/16" (20.6 mm) 2000-28-EINS Jaw Width 1-3/16" (30.2 mm) 1-3/16" (30.2 mm) Jaw Thickness 7/16" (11.1 mm) 7/16" (11.1 mm) Cutting Knives Standard Standard Weight 11.2 oz. (318 g) 11.2 oz. (318 g) Electrician's Insulated Long-Nose Pliers - Side-Cutting Additional Features: Induction-hardened cutting knives for long life Knurled jaws for sure wrapping and looping Cat. No. 203-8-EINS features heavier design for easier, more comfortable cutting and extended handle for added reach and leverage Cat. Nos. 203-6-EINS and 203-7-EINS has curved handles to provide greater tool control • • • • 203-8-EINS 203-7-EINS Cat. No. Overall Length Jaw Length Jaw Width Jaw Thickness Knife Length Point Thickness Weight 8-7/8" (225.4 mm) 2-5/16" (58.7 mm) 1" (25.4 mm) 1/2" (12.7 mm) 5/8" (15.9 mm) 1/8" (3.2 mm) 11.2 oz. (318 g) 6-7/8" (174.6 mm) 7-3/8" (187.3 mm) 1-15/16" (49.2 mm) 2-7/16" (61.9 mm) 11/16" (17.5 mm) 11/16" (17.5 mm) 3/8" (9.5 mm) 3/8" (9.5 mm) 1/2" (12.7 mm) 1/2" (12.7 mm) 3/32" (2.4 mm) 3/32" (2.4 mm) 4.8 oz. (136 g) 4.8 oz. (136 g) Heavier Design 203-8-EINS Standard Design 203-6-EINS 203-7-EINS See page 310 for additional information on warnings. 47 www.kleintools.com ~ Insulated Tools Electrician's Insulated Pliers Electrician's Insulated Combination Pliers Additional Features: Crimping die behind hinge for superior leverage crimping non-insulated connectors, lugs and terminals Toothed pipe-grip for greater power • • Cat. No. 12098-EINS 12098-EINS Nose Type Universal Overall Length 8-7/8" (225.4 mm) Jaw Length 1-25/32" (45.2 mm) Jaw Width 1-1/32" (26.2 mm) Jaw Thickness 1/2" (12.7 mm) Knife Length 3/4" (19.1 mm) Weight 1.0 lbs. (0.45 kg) Electrician’s Insulated Pump Pliers Additional Features: Secure tongue and groove design for non-slip grip - even with heavy pressure • 502-10-EINS Cat. No. 502-10-EINS Overall Length 10-1/4" (260.4 mm) Max. Jaw Capacity 1-3/4" (44.5 mm) Weight 1.0 lbs. (0.45 kg) Electrician's Insulated Cable Cutter Electrician's Insulated High-Leverage Cable Cutter Additional Features: High-leverage design for exceptional cutting capability Cable-gripping shear-type jaws Precision, one-hand shearing action Perfect for working in confined spaces Do NOT use to cut steel or ACSR • • • • • Cat. No. 63050-EINS Overall Length 9-5/8" (244.5 mm) 63050-EINS Maximum Cable Cutting Capacity 4/0 Aluminum, 2/0 Soft Copper, 100-Pair 24 AWG Communications Cable Weight 1.0 lbs. (0.45 kg) Electrician's Insulated Stripper/Cutter Electrician's Insulated Solid & Stranded Stripper/Cutter Additional Features: Cuts, strips, loops and gauges both solid and stranded wire Spring-loaded for self-opening Serrated nose for easy bending, shaping and pulling of wire Cleanly shears 6-32 and 8-32 screws Do not use for cutting steel wire • • • • • ® 8 −16 AWG 8 AWG 10 −1 11054-EINS Cat. No. 11054-EINS Overall Length 8" (203.2 mm) 48 www.kleintools.com Strips and Cuts 8 - 16 AWG Solid (8.4 mm² - 1.3 mm²), 10 - 18 AWG Stranded (5.3 mm² - 0.82 mm²) Weight 8.0 oz. (227 g) See page 310 for additional information on warnings. N CT N S IO N 3 R Y - 9NE E EY PROT Insulated Tools 1 D2 A E W Classic Insulated Tools FORGED STEEL from Klein's US-made, proprietary blend Integral guards help prevent hand contact with conductive parts Thick, exceptionally tough, high-dielectric white inner coating is bonded to the tool Induction hardened cutting knives for long life Forged steel handle Hot-riveted joint ensures smooth action and no handle wobble A flame retardant, impact-resistant, bright orange outer coating pliers available. Cuts ACSR, screws, nails, and most hardened wire All Classic Klein insulated tools comply with ASTM F-1505 and IEC 60900-2004 standards for insulated tools and are clearly marked with the official international 1000-volt rating symbol. Not all tools with plastic coatings or plastic handles provide protection against electrical shock. The large, bright orange handles make the tool comfortable to use all day and easy to identify in the field. Only use those tools that are marked with the official international 1000-volt rating symbol, as shown, if there is any chance that the tool will make contact with an energized source. Product numbers with the INS suffix contain WARNING: Do NOT touch uninsulated portion of the tool or any these warnings and must be understood. conductive object when either might contact an energized source. WARNING: Only use tools that are marked with the official international 1000-volt rating symbol shown below, if there is any chance that the tools will make contact with an energized source. WARNING: Whenever possible, always de-energize lines and equipment prior to working on or around them. Klein insulated tools are designed only to reduce the chance of injury where the tool may make contact with an energized source. WARNING: Wear approved eye protection. Always inspect your tools before use. Do not use if orange coating cracks, breaks or becomes damaged. Destroy tool if white layer shows through orange layer. WARNING: Because moisture, films, or other surface contaminants are conductive, Klein insulated tools must be kept clean, dry, and free of any surface contaminants. Insulated High-Leverage Side-Cutting Pliers Additional Features: High-leverage design provides 46% greater cutting and gripping power than other plier designs Streamlined design with sure-gripping, cross-hatched knurled jaws • • D213-9NE-INS Cat. No. D213-9NE-INS Nose Type New England Overall Length 9-5/8" (244.5 mm) Jaw Length 1-19/32" (40.5 mm) Jaw Width 1-5/16" (33.3 mm) Jaw Thickness 5/8" (15.9 mm) Knife Length 25/32" (19.8 mm) Weight 1.3 lbs. (0.59 kg) 5/8" (15.9 mm) 25/32" (19.8 mm) 25/32" (19.8 mm) 2000 Series* – Heavy-duty cutting knives D2000-9NE-INS New England 9-5/8" (244.5 mm) 1-19/32" (40.5 mm) 1-5/16" (33.3 mm) *Cuts ACSR, screws, nails, and most hardened wire. Features combination polished and black-oxide finish. Insulated High-Leverage Side-Cutting Pliers Connector Crimping Additional Features: Crimping die behind hinge for superior leverage crimping non-insulated connectors, lugs and terminals High-leverage design provides 46% greater cutting and gripping power than other plier designs Streamlined design with sure-gripping, cross-hatched knurled jaws • • • Cat. No. D213-9NE-CR-INS Nose Type New England Overall Length 9-5/8" (244.5 mm) See page 310 for additional information on warnings. Jaw Length 1-19/32" (40.5 mm) D213-9NECR-INS Jaw Width 1-5/16" (33.3 mm) Jaw Thickness 5/8" (15.9 mm) Knife Length 25/32" (19.8 mm) Weight 1.3 lbs. (0.59 kg) 49 www.kleintools.com Insulated Tools Insulated Pliers – Classic Insulated High-Leverage Universal Side-Cutting Pliers - Connector Crimping Additional Features: Crimping die behind hinge for superior leverage crimping non-insulated connectors, lugs and terminals Toothed pipe-grip for greater power • • Cat. No. 12098-INS Nose Type Universal Overall Length 8-7/8" (225.4 mm) 12098-INS Jaw Length 1-25/32" (45.2 mm) Jaw Width 1-1/32" (26.2 mm) Jaw Thickness 1/2" (12.7 mm) Knife Length 3/4" (19.1 mm) Weight 1.0 lbs. (0.45 kg) Insulated High-Leverage Diagonal-Cutting Pliers Additional Features: High-leverage design. Rivet is closer to the cutting edge for 36% greater cutting power than other pliers designs 13° angled head for easier work in confined spaces Cat. Nos. D248-8-INS and D2000-48-INS series • • Cat. No. D228-8-INS D248-8-INS Nose Type Tapered Angled Overall Length 8-1/4" (209.6 mm) 8-1/4" (209.6 mm) Jaw Length 13/16" (20.6 mm) 13/16" (20.6 mm) D228-8-INS Jaw Width 1-3/16" (30.2 mm) 1-3/16" (30.2 mm) Jaw Thickness 7/16" (11.1 mm) 7/16" (11.1 mm) Cutting Knives Standard Standard Weight 11.2 oz. (318 g) 11.2 oz. (318 g) D2000-28-INS Tapered 8-1/4" (209.6 mm) 13/16" (20.6 mm) 1-3/16" (30.2 mm) D2000-48-INS Angled 8-1/4" (209.6 mm) 13/16" (20.6 mm) 1-3/16" (30.2 mm) *Cuts ACSR, screws, nails, and most hardened wire. Features combination polished and black-oxide finish. 7/16" (11.1 mm) 7/16" (11.1 mm) Standard Standard 11.2 oz. (318 g) 11.2 oz. (318 g) 2000 Series* – Heavy-duty cutting knives Insulated Heavy-Duty Diagonal-Cutting Pliers Tapered Nose Additional Features: Heavy-duty tapered nose design One-inch deep jaws easily reach into confined spaces • • Cat. No. D220-7-INS Nose Type Tapered Overall Length 7-7/8" (200.0 mm) D220-7-INS Jaw Length 1" (25.4 mm) Jaw Width 31/32" (24.6 mm) Jaw Thickness 1/2" (12.7 mm) Cutting Knives Standard Weight 11.2 oz. (318 g) Insulated Long-Nose Pliers - Side-Cutting Additional Features: Knurled jaws for sure wrapping and looping Cat. Nos. D203-8-INS and D203-8N has extended handles provide added reach and leverage Cat. Nos. D203-6-INS and D203-7-INS have curved handles to provide greater tool control Cat. No. D203-8N-INS has skinning hole for No. 12 AWG wire • • • • D203-8N-INS D203-7-INS Cat. No. Overall Length Jaw Length Jaw Width Jaw Thickness Cutting Knives Knife Length Weight 2-5/16" (58.7 mm) 2-5/16" (58.7 mm) 1" (25.4 mm) 1" (25.4 mm) 1/2" (12.7 mm) 1/2" (12.7 mm) Standard Standard 5/8" (15.9 mm) 5/8" (15.9 mm) 11.2 oz. (318 g) 11.2 oz. (318 g) 1-15/16" (49.2 mm) 2-7/16" (61.9 mm) 11/16" (17.5 mm) 11/16" (17.5 mm) 3/8" (9.5 mm) 3/8" (9.5 mm) Standard Standard 1/2" (12.7 mm) 1/2" (12.7 mm) 4.8 oz. (136 g) 4.8 oz. (136 g) Heavier Design D203-8-INS D203-8N-INS 8-7/8" (225.4 mm) 8-7/8" (225.4 mm) Standard Design D203-6-INS D203-7-INS 6-7/8" (174.6 mm) 7-3/8" (187.3 mm) 50 www.kleintools.com See page 310 for additional information on warnings. N CT N S IO N 3 R Y - 9NE E EY PROT Insulated Tools 1 D2 A E W Insulated Pliers – Classic Insulated Pump Pliers Additional Features: Secure tongue and groove design for non-slip grip - even with heavy pressure • Cat. No. D502-10-INS Overall Length 10-1/4" (260.4 mm) Max. Jaw Capacity 1-3/4" (44.5 mm) Weight 1.0 lbs. (0.45 kg) D502-10-INS Insulated Crimping/Cutting/Stripping Tools – Classic Insulated Crimping/Cutting Tool Additional Features: Tapered nose design for working in confined spaces Crimping dies marked for insulated and non-insulated solderless terminals and connectors Accommodates wire from No. 10 to 22 AWG Wire cutter in nose • • • • Cat. No. 1005-INS Overall Length 9-3/4" (247.7 mm) Crimps 10 - 22 AWG 1005-INS Weight 1.0 lbs. (0.45 kg) Insulated High-Leverage Cable Cutter Additional Features: Special, high-leverage design for exceptional cutting capability Cable-gripping shear-type jaws Precision, one-hand shearing action Perfect for working in confined spaces Do NOT use to cut steel or ACSR • • • • • Cat. No. 63050-INS Overall Length 9-5/8" (244.5 mm) Maximum Cable Cutting Capacity 4/0 Aluminum, 2/0 Soft Copper, 100-Pair 24 AWG Communications Cable 63050-INS Weight 1.0 lbs. (0.45 kg) Insulated Wire Stripper/Cutters Additional Features: Cuts, strips, loops and gauges wire Spring-loaded for self-opening Compact, lightweight wire-stripping and cutting tool Narrow nose fits into tight places Do not use for cutting steel wire or bolts Hardened spring steel with precision-ground stripping holes for easy removal of insulation Cat. No. 11055-INS cleanly shears 6-32 and 8-32 screws • • • • • • • Cat. No. 11045-INS Overall Length 7" (177.8 mm) 11049-INS 7" (177.8 mm) 11055-INS 8" (203.2 mm) Strips and Cuts 10, 12, 14, 16, 18 Solid AWG (4.0 mm², 2.5 mm², 1.5 mm², 1.0 mm², 0.75 mm²) 8, 10, 12, 14, 16 Stranded AWG (6.0 mm², 4.0 mm², 2.5 mm², 1.5 mm², 1.0 mm²) 10, 12, 14, 16, 18 AWG Solid (4.0 mm², 2.5 mm², 1.5 mm², 1.0 mm², 0.75 mm²) 12, 14, 16, 18, 20 AWG Stranded (2.5 mm², 1.5 mm², 1.0 mm², 0.82 mm², 0.50 mm²) See page 310 for additional information on warnings. 8 −16 AWG 11049-INS Weight 9.6 lbs. (4.35 kg) 9.6 lbs. (4.35 kg) 12.0 lbs. (5.44 kg) 8 AWG 10 −1 0 AWG 12 − 2 ® 11055-INS 51 www.kleintools.com Insulated Tools Insulated Screwdrivers FORGED STEEL from Klein's US-made, proprietary blend Klein insulated tools meet or exceed the IEC 60900 and ASTM F1505 standards, for insulated tools, and are clearly marked with the official 1000-volt rating symbol Durable, two layer, molded insulation Cushion-Grip handles for greater torque and comfort Bright orange outer coating is flame and impact resistant Thick, exceptionally tough, high-dielectric white inner coating is bonded to the tool Tip-Ident® quickly identifies driver size WARNING: Only use tools that are marked with the official international 1000-volt rating symbol shown below, if there is any chance that the tools will make contact with an energized source. WARNING: Wear approved eye protection. Always inspect your tools before use. Do not use if orange coating cracks, breaks or becomes damaged. Destroy tool if white layer shows through orange layer. Product numbers with the INS suffix contain these warnings and must be understood. WARNING: Do NOT touch uninsulated portion of the tool or any conductive object when either might contact an energized source. WARNING: Whenever possible, always de-energize lines and equipment prior to working on or around them. Klein insulated tools are designed only to reduce the chance of injury where the tool may make contact with an energized source. WARNING: Because moisture, films, or other surface contaminants are conductive, Klein insulated tools must be kept clean, dry, and free of any surface contaminants. Insulated Screwdrivers - Round-Shank Additional Features: Profilated Phillips-tip provides a more consistent geometric symmetry than conventional Phillips-tip screwdrivers Square-Recess tips are perfect for electrical, telephone and work in recessed holes and other tight spaces • • 603-7-INS 661-7-INS Cat. No. 6334INS 603-4-INS 6037INS 6337INS 607-3-INS 612-4-INS 601-4-INS 601-7-INS 602-4-INS 605-7-INS 602-7-INS 602-8-INS 661-4-INS 661-7-INS 662-4-INS 662-7-INS Tip Type Phillips Phillips Phillips Phillips Cabinet Tip Cabinet Tip Cabinet Tip Cabinet Tip Cabinet Tip Cabinet Tip Cabinet Tip Cabinet Tip Square Square Square Square 52 www.kleintools.com Tip Size #1 #2 #2 #1 3/32" (2.4 mm) 1/8" (3.2 mm) 3/16" (4.8 mm) 3/16" (4.8 mm) 1/4" (6.4 mm) 1/4" (6.4 mm) 5/16" (7.9 mm) 3/8" (9.5 mm) #1 #1 #2 #2 Shank Length 4" (101.6 mm) 4" (101.6 mm) 7" (177.8 mm) 7" (177.8 mm) 3" (76.2 mm) 4" (101.6 mm) 4" (101.6 mm) 7" (177.8 mm) 4" (101.6 mm) 7" (177.8 mm) 7" (177.8 mm) 8" (203.2 mm) 4" (101.6 mm) 7" (177.8 mm) 4" (101.6 mm) 7" (177.8 mm) Overall Length 7-3/4" (196.9 mm) 8-5/16" (211.1 mm) 11-5/16" (287.3 mm) 12-3/8" (314.3 mm) 6-3/4" (171.5 mm) 7-3/4" (196.9 mm) 7-3/4" (196.9 mm) 10-3/4" (273.1 mm) 8-5/16" (211.1 mm) 11-5/16" (287.3 mm) 12-3/8" (314.3 mm) 13-3/8" (339.7 mm) 8-5/16" (211.1 mm) 11-5/16" (287.3 mm) 8-5/16" (211.1 mm) 11-5/16" (287.3 mm) Weight 2.1 oz. (60 g) 3.2 lbs. (1.45 kg) 4.0 lbs. (1.81 kg) 6.4 lbs. (2.90 kg) 1.9 lbs. (0.86 kg) 2.1 oz. (60 g) 2.1 oz. (60 g) 2.7 lbs. (1.22 kg) 3.2 lbs. (1.45 kg) 4.0 lbs. (1.81 kg) 6.4 lbs. (2.90 kg) 8.0 oz. (227 g) 3.2 lbs. (1.45 kg) 3.2 lbs. (1.45 kg) 3.2 lbs. (1.45 kg) 3.2 lbs. (1.45 kg) See page 310 for additional information on warnings. N CT N S IO N 3 R Y - 9NE E EY PROT Insulated Tools 1 D2 A E W 2-Piece Insulated 4" (102 mm) Screwdriver Set - Round Shanks Additional Features: Includes one 1/4" (6 mm) cabinet-tip and one #2 Phillips-tip • 33532-INS Cat. No. 33532-INS Set Contains Weight 9.6 oz. (272 g) Cat. No. Tip Type Tip Size Shank Length Overall Length 602-4-INS 603-4-INS Cabinet Tip Phillips 1/4" (6.4 mm) #2 4" (101.6 mm) 4" (101.6 mm) 8-5/16" (211.1 mm) 8-5/16" (211.1 mm) 9-Piece Insulated Cushion-Grip Screwdriver Set • Features three sizes of each tip style: cabinet, keystone, and Phillips durable, black nylon case features: nylon-zipper closure, polypropylene • Highly handles, custom-fitted tool pockets; extra pocket is provided for storage of papers • • or other items Overall dimensions: 15-1/2" W x 11" D x 2-1/2" H (394 mm x 279 mm x 64 mm) Replacement case (Cat. No. 33538) available 33528 Cat. No. 33528 Set Contains Weight 5.4 lbs. (2.45 kg) Cat. No. Tip Type Tip Size Shank Length Overall Length 601-4-INS 601-7-INS 612-4-INS 602-4-INS 602-7-INS 602-8-INS 6334INS 603-4-INS 6337INS 33538 Cabinet Tip Cabinet Tip Cabinet Tip Cabinet Tip Cabinet Tip Cabinet Tip Phillips Phillips Phillips heavy-duty polyester case 3/16" (4.8 mm) 3/16" (4.8 mm) 1/8" (3.2 mm) 1/4" (6.4 mm) 5/16" (7.9 mm) 3/8" (9.5 mm) #1 #2 #1 4" (101.6 mm) 7" (177.8 mm) 4" (101.6 mm) 4" (101.6 mm) 7" (177.8 mm) 8" (203.2 mm) 4" (101.6 mm) 4" (101.6 mm) 7" (177.8 mm) 7-3/4" (196.9 mm) 10-3/4" (273.1 mm) 7-3/4" (196.9 mm) 8-5/16" (211.1 mm) 12-3/8" (314.3 mm) 13-3/8" (339.7 mm) 7-3/4" (196.9 mm) 8-5/16" (211.1 mm) 12-3/8" (314.3 mm) See page 310 for additional information on warnings. 53 www.kleintools.com Insulated Tools Insulated Nut Drivers FORGED STEEL from Klein's US-made, proprietary blend Klein insulated tools meet or exceed the IEC 60900 and ASTM F1505 standards, for insulated tools, and are clearly marked with the official 1000-volt rating symbol Cushion-Grip handles for greater torque and comfort Thick, exceptionally tough, high-dielectric white inner coating is bonded to the tool Durable, two layer, molded insulation Bright orange outer coating is flame and impact resistant Hollow shafts make it possible to work on stacked circuit boards or other long bolt applications WARNING: Only use tools that are marked with the official international 1000-volt rating symbol shown below, if there is any chance that the tools will make contact with an energized source. WARNING: Wear approved eye protection. Always inspect your tools before use. Do not use if orange coating cracks, breaks or becomes damaged. Destroy tool if white layer shows through orange layer. Product numbers with the INS suffix contain these warnings and must be understood. Tip-Ident® quickly identifies nut driver size WARNING: Do NOT touch uninsulated portion of the tool or any conductive object when either might contact an energized source. WARNING: Whenever possible, always de-energize lines and equipment prior to working on or around them. Klein insulated tools are designed only to reduce the chance of injury where the tool may make contact with an energized source. WARNING: Because moisture, films, or other surface contaminants are conductive, Klein insulated tools must be kept clean, dry, and free of any surface contaminants. 6" (152 mm) Insulated Hollow-Shaft Nut Drivers Additional Features: Slimmer molded insulation with increased durability • Cat. No. 646-3/16-INS* 646-1/4-INS 646-5/16-INS 646-11/32-INS 646-3/8-INS 646-7/16-INS 646-1/2-INS 646-9/16-INS 646-5/8-INS Color Code Black Red Yellow Green Blue Brown Red Orange Yellow 646-5/8-INS Hex Size 3/16" 1/4" 5/16" 11/32" 3/8" 7/16" 1/2" 9/16" 5/8" Overall Length 9-3/4" (247.7 mm) 9-3/4" (247.7 mm) 9-3/4" (247.7 mm) 9-3/4" (247.7 mm) 10-5/16" (261.9 mm) 10-5/16" (261.9 mm) 11-3/8" (288.9 mm) 11-3/8" (288.9 mm) 11-3/8" (288.9 mm) Weight 2.4 lbs. (1.09 kg) 3.2 lbs. (1.45 kg) 3.2 lbs. (1.45 kg) 3.2 lbs. (1.45 kg) 4.0 lbs. (1.81 kg) 4.0 lbs. (1.81 kg) 5.6 oz. (159 g) 6.4 lbs. (2.90 kg) 6.4 lbs. (2.90 kg) *3/16" magnetic nut driver does not have hollow shaft 54 www.kleintools.com See page 310 for additional information on warnings. N CT N S IO N 3 R Y - 9NE E EY PROT Insulated Tools 1 D2 A E W Insulated Nut Driver Sets 9-Piece Insulated Cushion-Grip Hollow-Shaft Nut Driver Set - 6" (152 mm) Shafts Additional Features: Features assortment of popular sized nut drivers Highly durable, black nylon case features: nylon-zipper closure, polypropylene handles, custom-fitted tool pockets; extra pocket is provided for storage of papers or other items Overall case dimensions are: 15" W x 12-3/4" L x 3-1/2" D (381 mm x 324 mm x 89 mm) Replacement case available Cat. No. 33534 • • • • 33524 Cat. No. 33524 Set Contains Weight 6.0 lbs. (2.72 kg) Cat. No. Color Code 646-3/16-INS 646-1/4-INS 646-5/16-INS 646-11/32-INS 646-3/8-INS 646-7/16-INS 646-1/2-INS 646-9/16-INS 646-5/8-INS 33534 Black 3/16" Red 1/4" Yellow 5/16" Green 11/32" Blue 3/8" Brown 7/16" Red 1/2" Orange 9/16" Yellow 5/8" Custom heavy-duty Cordura® case Hex Size Overall Length 9-3/4" (247.7 mm) 9-3/4" (247.7 mm) 9-3/4" (247.7 mm) 9-3/4" (247.7 mm) 10-5/16" (261.9 mm) 10-5/16" (261.9 mm) 11-3/8" (288.9 mm) 11-3/8" (288.9 mm) 11-3/8" (288.9 mm) Cordura® is a registered trademark of INVISTA for durable fabrics. *3/16" magnetic nut driver does not have hollow shaft Insulated Skinning Knife Insulated Lineman's Skinning Knife • Molded measuring marks on back of handle to help measure stripping length of wire • Large molded handle for an easier, more comfortable grip tempered steel blade provides maximum sharpness and durability to • Tough, withstand frequent cable scoring 1571-INS Cat. No. 1571INS Blade Length 2-3/8" (60.3 mm) See page 310 for additional information on warnings. Handle Color Orange Overall Length 8-3/4" (222.3 mm) Weight 5.6 oz. (159 g) 55 www.kleintools.com Insulated Tools Insulated Tool Kits General-Purpose Insulated 22-Piece Tool Kit includes three pallets with custom-fitted pockets for each tool, piano• Case hinged cover has both a combination lock and two key-locked latches for • • • security, storage space behind the pallets to keep important papers and accessory items Inside dimensions: 7-3/4" W x 14-1/4" D x 8" H (197 mm x 362 mm x 203 mm) Overall dimensions: 18-7/8" W x 15-3/8" D x 8-1/4" H (479 mm x 391 mm x 210 mm) Replacement case (Cat. No. 33537) available Cat. No. 33527 Kit Contains Weight 24.3 lbs. (11.0 2kg) Cat. No. ​Description D2000-9NE-INS 12098-INS D2000-28-INS D2000-48-INS D203-8N-INS D220-7-INS D203-6-INS D203-7-INS 601-4-INS 601-7-INS 612-4-INS 602-4-INS 602-7-INS 602-8-INS 6334INS 603-4-INS 6337INS D502-10-INS 11045-INS 63050-INS 1571INS 1005-INS 33537 9" Side Cutting Pliers Heavy Duty Side Cutting Pliers Crimping Insulated 8" Insulated Diagonal Cutting Pliers 8" Insulated HD Diagonal Cutting Pliers 8" Insulated HD Long Nose Pliers 7" Insulated Diagonal Cutting Pliers 6" Insulated Long Nose Cutting Pliers 7" Long Nose Pliers Side Cutting Insulated 3/16" Cabinet - 4" Screwdriver Insulated 3/16" Cabinet - 7" Screwdriver Insulated 1/8" Slotted - 4" Screwdriver Insulated 1/4" Cabinet - 4" Screwdriver Insulated 5/16" Cabinet - 7" Screwdriver Insulated 3/8" Cabinet - 8" Screwdriver Insulated #1 Phillips - 4" Screwdriver Insulated #2 Phillips - 4" Screwdriver Insulated #1 Phillips - 7" Screwdriver 10" Pump Pliers, Insulated Insulated Wire Stripper and Cutter Cable Cutter, Insulated, High Leverage Lineman's Skinning Knife, Insulated Insulated Crimping/Cutting Tool Case for Insulated Tool Kit 33527 56 www.kleintools.com 33527 See page 310 for additional information on warnings. N CT N S IO N 3 R Y - 9NE E EY PROT Insulated Tools 1 D2 A E W Insulated Tool Kits Utility Insulated 13-Piece Tool Kit custom case includes two pallets with custom-fitted • The pockets for each tool, piano-hinged case cover has both • • • a combination lock and two key-locked latches for security, storage space behind the pallets to keep important papers and accessory items Inside dimensions: 17-3/4" W x 14-1/4" D x 8" H (451 mm x 362 mm x 203 mm) Overall dimensions: 18-7/8" W x 15-3/8" D x 8-1/4" H (79 mm x 391 mm x 210 mm) Replacement case (Cat. No. 33535) available Cat. No. Kit Contains 33525 Weight 20.1 lbs. (9.12 kg) Cat. No. ​Description D2000-9NE-INS D2000-28-INS D2000-48-INS D203-8-INS 602-4-INS 602-7-INS 602-8-INS 6334INS 603-4-INS 6337INS 63050-INS D502-10-INS 1571INS 33535 9" Side Cutting Pliers Heavy Duty 8" Insulated Diagonal Cutting Pliers 8" Insulated HD Diagonal Cutting Pliers 8" Insulated Long Nose Cutting Pliers Insulated 1/4" Cabinet - 4" Screwdriver Insulated 5/16" Cabinet - 7" Screwdriver Insulated 3/8" Cabinet - 8" Screwdriver Insulated #1 Phillips - 4" Screwdriver Insulated #2 Phillips - 4" Screwdriver Insulated #1 Phillips - 7" Screwdriver Cable Cutter, Insulated, High Leverage 10" Pump Pliers, Insulated Lineman's Skinning Knife, Insulated Case for Utility Tool Kit 33525 33525 Utility Insulated 13-Piece Tool Kit with Roll-up Case light, compact, soft roll-up carry case provides protective • The storage with custom-fitted pockets for each tool • Kit includes a padded, adjustable shoulder strap dimensions: Opened 24-1/2" x 24-1/2" (622 mm x 622 • Case mm), Closed 24-1/2" x 5-1/2" (622 mm x 140 mm) • Replacement roll-up case (Cat. No. 33535SC) available Cat. No. Kit Contains 33525SC Weight 9.8 lbs. (4.45 kg) Cat. No. ​Description D2000-9NE-INS D2000-28-INS D2000-48-INS D203-8-INS 602-4-INS 602-7-INS 602-8-INS 6334INS 603-4-INS 6337INS 63050-INS D502-10-INS 1571INS 33535SC 9" Side Cutting Pliers Heavy Duty 8" Insulated Diagonal Cutting Pliers 8" Insulated HD Diagonal Cutting Pliers 8" Insulated Long Nose Cutting Pliers Insulated 1/4" Cabinet - 4" Screwdriver Insulated 5/16" Cabinet - 7" Screwdriver Insulated 3/8" Cabinet - 8" Screwdriver Insulated #1 Phillips - 4" Screwdriver Insulated #2 Phillips - 4" Screwdriver Insulated #1 Phillips - 7" Screwdriver Cable Cutter, Insulated, High Leverage 10" Pump Pliers, Insulated Lineman's Skinning Knife, Insulated Case for Utility Tool Kit 33525SC See page 310 for additional information on warnings. 33525SC 57 www.kleintools.com Insulated Tools Insulated Tool Kits Premium Insulated 8-Piece Tool Kit No. D2000-9NE-INS and D2000-48-INS cut ACSR, screws, • Cat. nails and most hardened wire durable, black nylon case features: nylon-zipper closure, • Highly polypropylene handles, custom-fitted tool pockets case dimensions are: 15-1/2" W x 11" D x 2-1/2" H (394 • Overall mm x 279 mm x 64 mm) • Replacement case (Cat. No. 33536) available Cat. No. 33529 Kit Contains Weight 6.9 lbs. (3.13 kg) Cat. No. ​Description D2000-9NE-INS D2000-48-INS D203-8N-INS 601-6-INS 602-4-INS 603-4-INS 63050-INS 11055-INS 33536 9" Side Cutting Pliers Heavy Duty 8" Insulated HD Diagonal Cutting Pliers 8" Insulated HD Long Nose Pliers Insulated 3/16" Cabinet - 6" Screwdriver Insulated 1/4" Cabinet - 4" Screwdriver Insulated #2 Phillips - 4" Screwdriver Cable Cutter, Insulated, High Leverage Klein-Kurve® Wire Stripper Insulated Case for Insulated Tool Kit 33529 See individual tool listings for more details. 33529 Basic Insulated 8-Piece Tool Kit durable, black nylon case features: nylon-zipper closure, • Highly polypropylene handles, custom-fitted tool pockets case dimensions are: 15-1/2" W x 11" D x 2-1/2" H (394 • Overall mm x 279 mm x 64 mm) • Replacement case (Cat. No. 33536) available Cat. No. 33526 Kit Contains Weight 6.9 lbs. (3.13 kg) Cat. No. Description D213-9NE-INS D228-8-INS D203-8N-INS 601-6-INS 602-4-INS 603-4-INS 63050-INS 11045-INS 33536 9" Insulated Side Cutting Pliers 8" Insulated, Diagonal-Cutters 8" Insulated HD Long Nose Pliers Insulated 3/16" Cabinet - 6" Screwdriver Insulated 1/4" Cabinet - 4" Screwdriver Insulated #2 Phillips - 4" Screwdriver Cable Cutter, Insulated, High Leverage Insulated Wire Stripper and Cutter Case for Insulated Tool Kit 33529 See individual tool listings for more details. 33526 58 www.kleintools.com See page 310 for additional information on warnings.
630-11/32-INS 价格&库存
很抱歉,暂时无法提供与“630-11/32-INS”相匹配的价格&库存,您可以联系我们找货
