COMBO-TIP
N
R
E A P P LICA
TI
FO
TH
T COMBI
ON
GH
I
R
ION
AT
T HE
D R I V E R S
COMBO-TIP D R I V E R S
FINALLY, A PERFECTLY SHAPED COMBO TIP.
The Combination-Tip Drivers are designed for maximum contact with combination-head screws
most commonly found on electrical devices and fittings.
Available in:
Fixed-Blade Screwdrivers
Impact Rated Power Drivers
11-in-1 Screwdriver
TCH
SWI
E
DRIV
• Custom heat-treated to withstand the torque needed to fasten all types of combination head screws.
• Made with quality steel for long-lasting bit shape and strength.
• Cushion-Grip handle for maximum comfort and torque.
• Made in the USA.
Cat. No.
UPC#
0-92644+
731-4
37375-1
732-4
Tips
Description
Length
#1
Fixed-Blade Combo-Tip Screwdriver
4" (102 mm)
32376-8
#2
4" (102 mm)
32378
32378-2
#1 and #2
Fixed-Blade Combo-Tip Screwdriver 2 Piece Set
4" (102 mm)
32505*
32505-2
11-in-1 Screwdriver with Double-Ended Combo Bit
8" (203 mm)
#1
#2
3/16"
1/4
#1
#2
#1
#2
1/4"
5/16"
3/8"
32752
32572-4
#1 and #2
Combo Replacement Bit for 32505 – 2 pack
1.26" (32 mm)
C1-1-5
32746-9
#1
#1 Combo-Tip Power Driver Bits x 1" (25 mm) – 5 pack
1" (25 mm)
C1-35-5
32748-3
#1
#1 Combo-Tip Power Driver Bits x 3.5" (89 mm) – 5 pack
3.5" (89 mm)
C2-1-5
32747-6
#2
#2 Combo-Tip Power Driver Bits x 1" (25 mm) – 5 pack
1" (25 mm)
C2-35-5
32749-0
#2
#2 Combo-Tip Power Driver Bits x 3.5” (89 mm) – 5 pack
3.5" (89 mm)
*assembled in the USA with imported and domestic components
See our complete line of Screwdrivers and Nut Drivers
www.kleintools.com
© 2014 Klein Tools, Inc.
Lincolnshire, IL 60069-1418
96252
很抱歉,暂时无法提供与“32378”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+296.902881+38.40892
