32292
32292
    KLEINTOOLS
    Hex Socket Nut Driver Set 5 Pieces
32292 数据手册
STUBBY SCREWDRIVERS • Includes four different screwdriver bits and 1/4" and 5/16" nut drivers Cat. No. Tips 32593 #1 & #2 Phillips and 1/4" & 3/16" Slotted 32594 #1 & #2 Square, #2 Phillips & 3/16" Slotted Hex Sizes Overall Length 1/4" & 5/16" 3.5" (63.5 mm) SCREW, NUT, MULTI & ADJUSTABLE 15-in-1 Fixed shaft and internal storage compartment for the bits so they stay with the driver Description Tips 32290 15-in-1 Classic #0, #1, #2, #3 Phillips; #1 and #2 Square; #1 and #2 Combo; #10, #15, #20, #25 Torx; 4 and 6 MM Slotted; ¼” Hex 32291 15-in-1 Tamperproof #10, #15, #20, #25, #27, #30 Torx-Pins; 1/8”, 9/64”, 5/32”, 3/16” Hex-Pins; #6, #8, #10, #12 Spanners; ¼” Hex 32292 15-in-1 HVAC #0, #1, #2 and #3 Phillips; #1 and #2 Square; Schrader Valve Insertion and Core Removal Bits; #10, #15, #20 and #25 Torx; 4 and 6 MM Slotted; ¼” Hex Internal storage for screwdriver bits SCREWDRIVERS • These drivers include 14 different screwdriver tips plus a 1/4" nut driver Cat. No. Drivers 6-in-1 Ratcheting Ratcheting mechanism allows user to work faster and with more efficiency Overall Length 9" (229 mm) Adjustable Length Adjust to the length you need on the fly Carry fewer tools with a more versatile screwdriver. The shafts adjust anywhere from 4" to 8" (10 – 20 cm) for numerous length choices. SCREWDRIVERS • Removable and reversible shafts with a different tip on each end • Proprietary system securely holds the blade in place – as durable as a traditional Klein fixed blade screwdriver • Use on internet boxes, telecomm boxes, generators and more Cat. No. Description Tips 32708 Adjustable Length Screwdriver #1 & #2 Square 32751 Adjustable Length Screwdriver #2 Phillips & 1/4" Slotted Push up to retract or shorten the shaft Sets Replacement Blades 32618 Replacement Blades #2 Phillips and 1/4" Slotted 4" 8" 32709 Replacement Blades #1 & #2 Square 32713 Replacement Blades #1 Phillips & 3/16" Slotted 32715 Replacement Blades (3-Pack) #2 Phillips & 1/4" Slotted #1 Phillips & 3/16" Slotted #1 & #2 Square 32619 Handle only N/A Press down to extend or lengthen the shaft See our complete line of Drivers www.kleintools.com/catalog/drivers © 2016 Klein Tools, Inc. Lincolnshire, IL. 60069-1418 Rev. 10/17 96454 As the tradesperson’s needs change, so do Klein’s products. The latest additions to our line of drivers feature added functionality to increase productivity and decrease the number of tools on the belt or in the bag. 4-in-1 Electronics SCREWDRIVERS Heavy-Duty Completely hollow handle for unlimited threaded rod lengths NUT DRIVERS • Wrench assist for additional torque • Magnetic feature helps grab hex nuts securely Four different bits in one tool • Rotating cap for optimum and precise control • Heat-treated precision machined tip for greater strength Cat. No. Tips Overall Length 32581 #0 & #00 Phillips and 1/8" & 3/32" Slotted 6.5" (165 mm) 32585 T7, T8, T10 and T15 tamper-proof TORX® 6.5" (165 mm) Cat. No. Hex Sizes 635-1/4 1/4" 635-5/16 5/16" 635-3/8 3/8" 635-7/16 7/16" 635-1/2 1/2" 635-9/16 9/16" Color Code Overall Length 9" (229 mm) 9.4" (239 mm) Sets 635-4 4-Piece set includes 1/4", 5/16", 3/8" & 7/16" hex 635-6 6-Piece set includes 1/4", 5/16", 3/8", 7/16", 1/2" & 9/16" hex Multiple sizes in one convenient tool • Interchangeable hex sizes are available in two models • Heavy duty handles and shafts exceed the torque performance of regular nut drivers • Wrench assist feature for additional torque Cat. No. Hex Sizes Overall Length 32800 3/16", 1/4", 5/16", 3/8", 7/16" & 9/16" 9.5" (241 mm) 32801 3/16", 1/4", 5/16", 3/8" & 9/16" 9.1" (231 mm) Multi-Nut DRIVERS ench Assist Wr Ma gnetic Tip 4-in-1 Electronics SCREWDRIVERS Heavy-Duty Completely hollow handle for unlimited threaded rod lengths NUT DRIVERS • Wrench assist for additional torque • Magnetic feature helps grab hex nuts securely Four different bits in one tool • Rotating cap for optimum and precise control • Heat-treated precision machined tip for greater strength Cat. No. Tips Overall Length 32581 #0 & #00 Phillips and 1/8" & 3/32" Slotted 6.5" (165 mm) 32585 T7, T8, T10 and T15 tamper-proof TORX® 6.5" (165 mm) Cat. No. Hex Sizes 635-1/4 1/4" 635-5/16 5/16" 635-3/8 3/8" 635-7/16 7/16" 635-1/2 1/2" 635-9/16 9/16" Color Code Overall Length 9" (229 mm) 9.4" (239 mm) Sets 635-4 4-Piece set includes 1/4", 5/16", 3/8" & 7/16" hex 635-6 6-Piece set includes 1/4", 5/16", 3/8", 7/16", 1/2" & 9/16" hex Multiple sizes in one convenient tool • Interchangeable hex sizes are available in two models • Heavy duty handles and shafts exceed the torque performance of regular nut drivers • Wrench assist feature for additional torque Cat. No. Hex Sizes Overall Length 32800 3/16", 1/4", 5/16", 3/8", 7/16" & 9/16" 9.5" (241 mm) 32801 3/16", 1/4", 5/16", 3/8" & 9/16" 9.1" (231 mm) Multi-Nut DRIVERS ench Assist Wr Ma gnetic Tip STUBBY SCREWDRIVERS • Includes four different screwdriver bits and 1/4" and 5/16" nut drivers Cat. No. Tips 32593 #1 & #2 Phillips and 1/4" & 3/16" Slotted 32594 #1 & #2 Square, #2 Phillips & 3/16" Slotted Hex Sizes Overall Length 1/4" & 5/16" 3.5" (63.5 mm) SCREW, NUT, MULTI & ADJUSTABLE 15-in-1 Fixed shaft and internal storage compartment for the bits so they stay with the driver Description Tips 32290 15-in-1 Classic #0, #1, #2, #3 Phillips; #1 and #2 Square; #1 and #2 Combo; #10, #15, #20, #25 Torx; 4 and 6 MM Slotted; ¼” Hex 32291 15-in-1 Tamperproof #10, #15, #20, #25, #27, #30 Torx-Pins; 1/8”, 9/64”, 5/32”, 3/16” Hex-Pins; #6, #8, #10, #12 Spanners; ¼” Hex 32292 15-in-1 HVAC #0, #1, #2 and #3 Phillips; #1 and #2 Square; Schrader Valve Insertion and Core Removal Bits; #10, #15, #20 and #25 Torx; 4 and 6 MM Slotted; ¼” Hex Internal storage for screwdriver bits SCREWDRIVERS • These drivers include 14 different screwdriver tips plus a 1/4" nut driver Cat. No. Drivers 6-in-1 Ratcheting Ratcheting mechanism allows user to work faster and with more efficiency Overall Length 9" (229 mm) Adjustable Length Adjust to the length you need on the fly Carry fewer tools with a more versatile screwdriver. The shafts adjust anywhere from 4" to 8" (10 – 20 cm) for numerous length choices. SCREWDRIVERS • Removable and reversible shafts with a different tip on each end • Proprietary system securely holds the blade in place – as durable as a traditional Klein fixed blade screwdriver • Use on internet boxes, telecomm boxes, generators and more Cat. No. Description Tips 32708 Adjustable Length Screwdriver #1 & #2 Square 32751 Adjustable Length Screwdriver #2 Phillips & 1/4" Slotted Push up to retract or shorten the shaft Sets Replacement Blades 32618 Replacement Blades #2 Phillips and 1/4" Slotted 4" 8" 32709 Replacement Blades #1 & #2 Square 32713 Replacement Blades #1 Phillips & 3/16" Slotted 32715 Replacement Blades (3-Pack) #2 Phillips & 1/4" Slotted #1 Phillips & 3/16" Slotted #1 & #2 Square 32619 Handle only N/A Press down to extend or lengthen the shaft See our complete line of Drivers www.kleintools.com/catalog/drivers © 2016 Klein Tools, Inc. Lincolnshire, IL. 60069-1418 Rev. 10/17 96454 As the tradesperson’s needs change, so do Klein’s products. The latest additions to our line of drivers feature added functionality to increase productivity and decrease the number of tools on the belt or in the bag.
32292 价格&库存
很抱歉,暂时无法提供与“32292”相匹配的价格&库存,您可以联系我们找货
