D511-6
D511-6
    KLEINTOOLS
    6''SLIP-JOINTPLIERS
D511-6 数据手册
Klein Pliers Klein specializes in the making of the world's finest pliers… pliers that professionals trust completely. Klein pliers feel right and work right. They are jobmatched for every kind of work you do; designed and built to exceptional quality standards in a tradition that dates back to 1857. Pliers Introduction – Pliers Klein Quality Klein pliers are made of the finest U.S. steel alloy. They are forged, precision machined, hardened, and carefully tempered for maximum strength. Klein pliers provide exceptional performance and durability. the hinge first and then meet at least one-half of the knife length. Diagonal-cutting pliers meet at the tip first and then meet at least one-half of the knife length. All pliers mating surfaces and dimensions are precision machined for faultless performance. Pliers halves are precision machined and hot riveted for uniformly smooth opening and closing action. Cutting knives are manufactured for long-lasting edges and perfect alignment. These precise knife-closing designs increase knife life and facilitate resharpening. Klein pliers are individually adjusted to meet performance standards far exceeding application requirements – ensuring that nothing less than outstanding quality ever carries the Klein name. The cutting knives on all Klein pliers are designed to meet according to the way each is used. Side-cutting and long-nose pliers with side cutters have knives that meet at Using Pliers A professional knows all the rules about using pliers, but a review of the following points may help you recall any you may have forgotten. edges. Cut wire at a right angle only. If it won't cut readily, the knives may need sharpening, or you may need pliers with greater leverage. 1. Never use pliers to do another tool's job. Pliers should not be used as a hammer or pry tool or a wrench. Using pliers instead of the proper tools risks damaging the work, damaging yourself, and losing time. 6. Never cut any wire or metal unless your eyes are protected. Goggles or other protective devices are an absolute must. Don't take shortcuts. Operate safely...the professional way. 2. Never push pliers beyond their capacity. Bending stiff wire with light pliers or the tip of needle-nose pliers can spring them or break them. Use a stronger, blunt-nose pliers. When you need greater leverage, use pliers with greater leverage. Don't extend the length of the ­pliers handles. Bolts should be cut with a bolt cutter, and large cable with a cable cutter. 3. Never expose pliers to excessive heat. Direct flame on metal can ruin the tool. Cutting pliers are ­especially vulnerable to high, direct heat. 4. Never cut hardened wire with ordinary pliers. Pliers should not be used for cutting hardened wire unless they are specifically recommended for this use. 7. Never cut any wire or metal unless your fellow workers' eyes are also protected. The wire that d­ oesn't get you may get someone else. Think about the "other guy" as well as yourself. 8. Never depend on plastic-dipped handles to insulate you from electricity. Plastic-dipped and JourneymanTM handles are intended for comfort and a firmer grip only. They are not intended for protection against electric shock. Never use any pliers or cutting tools on live electrical circuits. Only use insulated tools that are marked with the official inter­national 1000-volt rating symbol if there is any chance that the tool will make contact with an energized source. 5. Never rock pliers from side to side when cutting wire…and never bend the wire back and forth against the cutting knives. Either practice can dull or nick the cutting Pliers Catalog Number Prefixes/Suffixes "D" (Prefix) – Indicates the pliers have plastic-dipped handles. Plastic-dipped handles are for comfort, NOT for ­protection against electrical shock. "HD" (Prefix) – Indicates the pliers have heavy-duty plastic-dipped handles. Heavy-duty plastic-dipped handles p­ rovide an extra level of user comfort and are NOT for protection against electrical shock. "J" (Prefix) – Indicates the pliers have Journeyman™ handles. State-of-the-art dual material molding that allows for a softer, more comfortable grip on the outer surface and a harder, more durable grip on the inner surface and handle ends. "C" (Suffix) – Indicates the pliers have a coil spring in the handles for self-opening action. Pliers Cutting Edges Knife-edge descriptions refer to the angle of the outside cutting edges of the knives when fully closed. Standard Cutting Edges Semi-Flush Cutting Edges Cuts hard wire. Found on all Klein side cutters, long nose, and on most diagonal-cutting pliers. Closely cuts medium wire. Found on select Klein diagonal cutting pliers. Full-Flush Cutting Edges Close, flat cutting of soft wire only. Found on select diagonal-cutting pliers. 6 www.kleintools.com See page 310 for additional information on warnings. Pliers Introduction – Pliers Pliers Dimensions A – Overall Length D – Jaw Thickness All Klein pliers are listed with necessary dimensions in both inches and millimeters. The following drawings of six basic types of pliers are keyed by letter to the dimensions given for each pliers listed. All dimensions are subject to commercial tolerances. B – Jaw Length E – Knife Length C – Jaw Width F – Point Thickness 1. Side-Cutting Pliers 1. Side- Cutting Pliers 5. 4. Long-N Pliers 3.Cutting End Cutting Pliersose 2. D iagonalPliers 4. Long-N ose Pliers D D C C D A A B D D F F F C C C C E B E B D D E D 6. Curved-N ose Pliers Flat-Nose and Duck-Bill Pliers E E B B B F C C B A A A E 2. D iagonal- Cutting Pliers 5. Flat-N ose and D uck-B ill Pliers 2. Diagonal-Cutting 5. Flat-N 6. Curved-Nose Pliers Pliersose and D uck-B ill Pliers 4. Long-Nose tting Pliers 3. E ndCutting Pliers D D A D D E D C C C A Pliers A D D F F F C B B A B B E C C A B B F E E A A A A C B B osePliers Pliers l- Cutting Pliers 5. Flat-N ose andCurved-N D uck-B ill A 6. A 6. Curved-N ose Pliers 3. E nd- Cutting Pliers 3. E ndCutting Pliers Pliers dimensions shown are accurate within accepted commercial tolerances, which allow slight variations that n­ ormally result from forging and grinding operations. Side-Cutting Pliers FORGED STEEL from Klein's US-made, proprietary blend "Handform" handles for full gripping and cutting power Plastic-dipped handles† for comfort and ease of identification Unique handle tempering helps absorb the "snap" when cutting wire Hot-riveted joint ensures smooth action and no handle wobble Induction hardened cutting knives for long life Precisionhardened plier head for on-the-job toughness Sure-gripping cross-hatched knurled jaws pliers available. Cuts ACSR, screws, nails, and most hardened wire JourneymanTM pliers available. State-of-the-art, dual-material handles provide a better grip without sacrificing tool strength or durability † See page 310 for additional information on warnings. 7 www.kleintools.com Pliers Side-Cutting Pliers High-Leverage Side-Cutting Pliers - Heavy-Duty Cutting Additional Features: • Cuts ACSR, screws, nails and most hardened wire • High-leverage design. Rivet is closer to the cutting edge for 46% greater cutting and gripping power than other pliers designs • Streamlined design • Features combination polished and black-oxide finish • Cat. No. D2000-9NEGLW feature glow in the dark grips to easily locate your tool in dark or low lit areas D2000-9NE Glow in the Dark Grips Cat. No. D2000-7 D2000-8 D2000-9NE D20009NEGLW Nose Type New England New England New England New England Overall Length 7-7/8" (200.0 mm) 8-11/16" (220.7 mm) 9-3/8" (238.1 mm) 9-3/8" (238.1 mm) HD2000-9NE New England 9-1/2" (241.3 mm) Jaw Length 1-9/32" (32.5 mm) 1-7/16" (36.5 mm) 1-19/32" (40.5 mm) 1-19/32" (40.5 mm) Jaw Width 1-1/32" (26.2 mm) 1-7/64" (28.2 mm) 1-1/4" (31.8 mm) 1-1/4" (31.8 mm) Jaw Thickness 1/2" (12.7 mm) 5/8" (15.9 mm) 5/8" (15.9 mm) 5/8" (15.9 mm) Knife Length 3/4" (19.1 mm) 3/4" (19.1 mm) 25/32" (19.8 mm) 25/32" (19.8 mm) 1-19/32" (40.5 mm) 1-1/4" (31.8 mm) 5/8" (15.9 mm) 25/32" (19.8 mm) 1-7/16" (36.5 mm) 1-7/64" (28.2 mm) 5/8" (15.9 mm) 3/4" (19.1 mm) 1-19/32" (40.5 mm) 1-1/4" (31.8 mm) 5/8" (15.9 mm) 25/32" (19.8 mm) Journeyman D2000-9NEGLW Handle Finish Plastic-Dipped Plastic-Dipped Plastic-Dipped Plastic-Dipped Heavy-Duty, Oversized, Plastic-Dipped Handle Color Royal Blue Royal Blue Royal Blue Glow Weight 10.6 oz. (299 g) 13.6 oz. (386 g) 1.1 lbs. (0.50 kg) 1.1 lbs. (0.50 kg) Light Red 1.2 lbs. (0.54 kg) Journeyman Light Blue/Black 14.9 oz. (422 g) JourneymanTM 2000 Series – Dual-material handles New England 8-13/16" (223.8 mm) Tapered New England 9-1/2" (241.3 mm) J20008 J2000-9NE Light Blue/Black 1.1 lbs. (0.50 kg) Refer to the insulated section for insulated pliers. High-Leverage Side-Cutting Pliers Additional Features: • High-leverage design. Rivet is closer to the cutting edge for 46% greater cutting and gripping power than other pliers designs • Streamlined design • D213-9NETT has split tether ring for use with tether device D213-9NE NEW! D213-9 Cat. No. 213-9NE D213-9 D213-8NE D213-9NE D213-9NETT NEW! Nose Type New England Square New England New England New England Overall Length 9-1/4" (235.0 mm) 9-3/8" (238.1 mm) 8-11/16" (220.7 mm) 9-3/8" (238.1 mm) 9-3/8" (238.1 mm) HD213-9NE New England 9-1/2" (241.3 mm) Jaw Length 1-19/32" (40.5 mm) 1-19/32" (40.5 mm) 1-7/16" (36.5 mm) 1-19/32" (40.5 mm) 1-19/32" (40.5 mm) Jaw Width 1-1/4" (31.8 mm) 1-1/4" (31.8 mm) 1-3/16" (30.2 mm) 1-1/4" (31.8 mm) 1-1/4" (31.8 mm) 1-19/32" (40.5 mm) 1-1/4" (31.8 mm) Jaw Thickness 5/8" (15.9 mm) 5/8" (15.9 mm) 5/8" (15.9 mm) 5/8" (15.9 mm) 5/8" (15.9 mm) Knife Length 25/32" (19.8 mm) 25/32" (19.8 mm) 23/32" (18.3 mm) 25/32" (19.8 mm) 25/32" (19.8 mm) 5/8" (15.9 mm) 25/32" (19.8 mm) Handle Finish Plain Plastic-Dipped Plastic-Dipped Plastic Dipped Plastic Dipped Heavy-Duty, Oversized, Plastic-Dipped Handle Color ​— Dark Blue Dark Blue Dark Blue Dark Blue Weight 1.1 lbs. (0.50 kg) 1.1 lbs. (0.50 kg) 14.4 oz. (408 g) 1.1 lbs. (0.50 kg) 1.1 lbs. (0.50 kg) Light Red 1.2 lbs. (0.54 kg) Journeyman Series – Dual-material handles TM J2138NE J213-9NE New England 8-13/16" (223.8 mm) New England 9-1/2" (241.3 mm) 1-7/16" (36.5 mm) 1-3/16" (30.2 mm) 5/8" (15.9 mm) 1-19/32" (40.5 mm) 1-1/4" (31.8 mm) 5/8" (15.9 mm) 23/32" (18.3 mm) Journeyman 25/32" (19.8 mm) Journeyman Dark Blue/Black 15.5 oz. (439 g) Dark Blue/Black 1.1 lbs. (0.50 kg) Refer to the insulated section for insulated pliers. 8 www.kleintools.com See page 310 for additional information on warnings. Pliers Side-Cutting Pliers High-Leverage Side-Cutting Pliers - Fish Tape Pulling Additional Features: • Easily pulls 1/8" or 1/4" flat steel fish tape without damaging the tape • High-leverage design. Rivet is closer to the cutting edge for 46% greater cutting and gripping power than other pliers designs • Streamlined design • Cat. No. J2000-9NECRTP crimps non-insulated connectors, lugs, and terminals Cat. No. D213-9NETP Nose Type Overall Length New England 9-3/8" (238.1 mm) D213-9NETP Jaw Length 1-19/32" (40.5 mm) Jaw Width 1-1/4" (31.8 mm) Jaw Thickness Knife Length 5/8" (15.9 mm) 25/32" (19.8 mm) Handle Finish Handle Color Plastic-Dipped Dark Blue Weight 1.1 lbs. (0.50 kg) 1-19/32" (40.5 mm) 1-1/4" (31.8 mm) 5/8" (15.9 mm) 25/32" (19.8 mm) Journeyman Dark Blue/Black 1.1 lbs. (0.50 kg) 1-19/32" (40.5 mm) 1-1/4" (31.8 mm) 5/8" (15.9 mm) 25/32" (19.8 mm) Royal Blue 1.1 lbs. (0.50 kg) 1-1/4" (31.8 mm) 1-1/4" (31.8 mm) 5/8" (15.9 mm) 5/8" (15.9 mm) 25/32" (19.8 mm) Journeyman 25/32" (19.8 mm) Journeyman Light Blue/Black Blue/Black 1.1 lbs. (0.50 kg) 1.1 lbs. (0.50 kg) JourneymanTM Series – Dual-material handles J213-9NETP New England 9-1/2" (241.3 mm) 2000 Series* – Heavy-duty cutting knives D2000-9NETP New England 9-3/8" (238.1 mm) Plastic-Dipped JourneymanTM 2000 Series* – Dual-material handles J2000-9NETP New England 9-1/2" (241.3 mm) J2000-9NECRTP New England 9-1/2" (241.3 mm) 1-19/32" (40.5 mm) 1-19/32" (40.5 mm) *Cuts ACSR, screws, nails, and most hardened wire. Features combination polished and black-oxide finish. High-Leverage Side-Cutting Pliers - Lineman's Bolt-Thread Holding Additional Features: • Hinge opening holds and cleans 5/8" pole line and hardware bolts or threaded rods • High-leverage design. Rivet is closer to the cutting edge for 46% greater cutting and gripping power than other pliers designs • Streamlined design D213-9NETH Cat. No. D213-9NETH Nose Type Overall Length New England 9-3/8" (238.1 mm) Jaw Length 1-19/32" (40.5 mm) Jaw Width 1-1/4" (31.8 mm) Jaw Thickness Knife Length 5/8" (15.9 mm) 25/32" (19.8 mm) HD213-9NETH New England 9-1/2" (241.3 mm) 1-19/32" (40.5 mm) 1-1/4" (31.8 mm) 5/8" (15.9 mm) 25/32" (19.8 mm) 1-19/32" (40.5 mm) 1-1/4" (31.8 mm) 5/8" (15.9 mm) 25/32" (19.8 mm) Handle Finish Handle Color Plastic-Dipped Dark Blue Heavy-Duty, Oversized, Light Red Plastic-Dipped Weight 1.1 lbs. (0.50 kg) 1.2 lbs. (0.54 kg) 2000 Series* – Heavy-duty cutting knives D2000-9NETH New England 9-3/8" (238.1 mm) Plastic-Dipped Royal Blue 1.2 lbs. (0.54 kg) *Cuts ACSR, screws, nails, and most hardened wire. Features combination polished and black-oxide finish. High-Leverage Side-Cutting Pliers Connector Crimping Additional Features: • Crimping die behind hinge for superior leverage crimping noninsulated connectors, lugs and terminals • Cat. No. J213-9NECRN cleanly strips 10 and 12 solid AWG wire and 12 and 14 stranded wire • High-leverage design. Rivet is closer to the cutting edge for 46% greater cutting and gripping power than other pliers designs • Streamlined design Cat. No. D213-9NE-CR Nose Type Overall Length New England 9-3/8" (238.1 mm) D213-9NECR 2 AWG 10 – 1 4 AWG 12 – 1 J213-9NECRN Jaw Length 1-19/32" (40.5 mm) Jaw Width 1-1/4" (31.8 mm) Jaw Thickness Knife Length 5/8" (15.9 mm) 25/32" (19.8 mm) Handle Finish Handle Color Plastic-Dipped Yellow Weight 1.0 lbs. (0.45 kg) 1-19/32" (40.5 mm) 1-19/32" (40.5 mm) 1-1/4" (31.8 mm) 1-1/4" (31.8 mm) 5/8" (15.9 mm) 5/8" (15.9 mm) 25/32" (19.8 mm) Journeyman 25/32" (19.8 mm) Journeyman Yellow/Black Yellow/Black 1.1 lbs. (0.50 kg) 1.1 lbs. (0.50 kg) 1-19/32" (40.5 mm) 1-1/4" (31.8 mm) 5/8" (15.9 mm) 25/32" (19.8 mm) Royal Blue 1.1 lbs. (0.50 kg) 1-1/4" (31.8 mm) 5/8" (15.9 mm) 25/32" (19.8 mm) Journeyman Light Blue/Black 1.1 lbs. (0.50 kg) JourneymanTM Series – Dual-material handles J213-9NECR J2139NECRN New England 9-1/2" (241.3 mm) New England 9-1/2" (241.3 mm) 2000 Series* – Heavy-duty cutting knives D2000-9NECR New England 9-3/8" (238.1 mm) Plastic-Dipped JourneymanTM 2000 Series* – Dual-material handles J2000-9NECR New England 9-1/2" (241.3 mm) 1-19/32" (40.5 mm) *Cuts ACSR, screws, nails, and most hardened wire. Features combination polished and black-oxide finish. Refer to the insulated section for insulated pliers. See page 310 for additional information on warnings. 9 www.kleintools.com Pliers Side-Cutting Pliers Side-Cutting Pliers Additional Features: • Streamlined design D201-9NE Cat. No. Nose Type Overall Length Jaw Length Jaw Width Jaw Thickness Knife Length Handle Finish Handle Color Weight Streamlined Design D201-7NE D201-8NE D201-9NE New England 7-7/16" (188.9 mm) New England 8-11/16" (220.7 mm) New England 9-3/8" (238.1 mm) 1-9/32" (32.5 mm) 1-1/16" (27.0 mm) 1-7/16" (36.5 mm) 1-3/16" (30.2 mm) 1-19/32" (40.5 mm) 1-5/16" (33.3 mm) 1/2" (12.7 mm) 5/8" (15.9 mm) 5/8" (15.9 mm) 5/8" (15.9 mm) 23/32" (18.3 mm) 25/32" (19.8 mm) Plastic-Dipped Plastic-Dipped Plastic-Dipped Dark Blue Dark Blue Dark Blue 8.8 oz. (249 g) 14.7 oz. (417 g) 1.1 lbs. (0.50 kg) Square Square 1-7/16" (36.5 mm) 1-7/32" (31.0 mm) 1-19/32" (40.5 mm) 1-5/16" (33.3 mm) 5/8" (15.9 mm) 5/8" (15.9 mm) 23/32" (18.3 mm) 25/32" (19.8 mm) Plastic-Dipped Plastic-Dipped Dark Blue Dark Blue 14.9 oz. (422 g) 1.1 lbs. (0.50 kg) Square Nose D201-8 D201-9 8-11/16" (220.7 mm) 9-3/8" (238.1 mm) High-Leverage Universal Combination Pliers Additional Features: • Crimping die behind hinge for superior leverage crimping non-insulated connectors, lugs and terminals • High-leverage design. Rivet is closer to the cutting edge for 46% greater cutting and gripping power than other pliers designs • Toothed pipe-grip for greater gripping power Cat. No. 12098 Nose Type Universal Overall Length 8-5/8" (219.1 mm) Jaw Length 1-25/32" (45.2 mm) 12098 Jaw Width 1-1/32" (26.2 mm) Jaw Thickness Knife Length 17/32" (13.5 mm) 3/4" (19.1 mm) Handle Finish Plastic-Dipped Handle Color Weight Dark Blue 11.5 oz. (327 g) 1-25/32" (45.2 mm) 1-1/32" (26.2 mm) 17/32" (13.5 mm) 3/4" (19.1 mm) Journeyman Dark Blue/Black 13.1 oz. (371 g) JourneymanTM Series – Dual-material handles J12098 Universal 8-3/4" (222.3 mm) Refer to the insulated section for insulated pliers. Ironworker's Work Pliers D201-7CST -9ST NEW! D213-9ST 13 Additional Features: • Twists and cuts soft annealed rebar tie wire • Cat. Nos. 213-9ST, D213-9ST and D20009ST feature high-leverage design. Rivet is closer to the cutting edge for 46% greater cutting and gripping power than other pliers designs • Hook bend handle • Spring-loaded action for self-opening • Cat. Nos. 213-9ST, D213-9ST and D2000-9ST feature heavy-duty knurled jaws • D201-7CSTT and D213-9STT has split tether ring for use with tether device D2 Cat. No. 201-7CST D201-7CST D201-7CSTT NEW! 213-9ST D213-9ST D213-9STT NEW! Nose Type Square Square Square Square Square Square Overall Length 9-1/8" (231.8 mm) 9-1/4" (235.0 mm) 9" (228.6 mm) 9-1/4" (235.0 mm) 9-3/8" (238.1 mm) 9-3/8" (238.1 mm) Jaw Length 1-9/32" (32.5 mm) 1-9/32" (32.5 mm) 1-1/2" (38.1 mm) 1-19/32" (40.5 mm) 1-19/32" (40.5 mm) 2" (50.8 mm) Jaw Width 1-5/32" (29.4 mm) 1-5/32" (29.4 mm) 1-1/4" (31.8 mm) 1-1/4" (31.8 mm) 1-1/4" (31.8 mm) 1-1/4" (31.8 mm) Jaw Thickness 1/2" (12.7 mm) 1/2" (12.7 mm) 1/2" (12.7 mm) 5/8" (15.9 mm) 5/8" (15.9 mm) 5/8" (15.9 mm) Knife Length 5/8" (15.9 mm) 5/8" (15.9 mm) 5/8" (15.9 mm) 25/32" (19.8 mm) 25/32" (19.8 mm) 25/32" (19.8 mm) Handle Finish Plain Plastic Plastic Plain Plastic Plastic Handle Color ​— Blue Blue ​— Blue Blue Weight 10.4 oz. (295 g) 12.0 oz. (340 g) 10.9 oz (308 g) 1.0 lbs. (0.45 kg) 1.1 lbs. (0.50 kg) 1.1 lbs. (0.50 kg) 1-9/32" (32.5 mm) 1-19/32" (40.5 mm) 1-5/32" (29.4 mm) 1-1/4" (31.8 mm) 1/2" (12.7 mm) 5/8" (15.9 mm) 5/8" (15.9 mm) 25/32" (19.8 mm) Plastic Plastic Blue Blue 11.2 oz. (318 g) 1.1 lbs. (0.50 kg) 2000 Series* – Heavy-duty cutting knives D2000-7CST D2000-9ST Square Square 9-1/4" (235.0 mm) 9-3/8" (238.1 mm) *Cuts ACSR, screws, nails, and most hardened wire. Features combination polished and black-oxide finish. 10 www.kleintools.com See page 310 for additional information on warnings. Pliers Diagonal-Cutting Pliers FORGED STEEL from Klein's US-made, proprietary blend Plastic-dipped handles† for comfort and ease of identification Hot-riveted joint ensures smooth action and no handle wobble Induction-hardened cutting knives for long life Short jaws and beveled cutting edges permit close cutting of wire pliers available. Cuts ACSR, screws, nails, and most hardened wire JourneymanTM pliers available. State-of-the-art, dual-material handles provide a better grip without sacrificing tool strength or durability † High-Leverage Diagonal-Cutting Pliers Additional Features: • High-leverage design. Rivet is closer to the cutting edge for 36% greater cutting power than other pliers design • Cat. No. D2000-28GLW and D248-8GLW feature glow in the dark grips to easily locate your tool in dark or low lit areas • D228-8TT has split tether ring for use with tether device D2000-28 Glow in the Dark Grips D2000-28GLW NEW! D228-8TT Cat. No. D228-7 D228-8 D228-8TT NEW! Overall Length 7-1/8" (181.0 mm) 8-1/16" (204.8 mm) 8" (203.2 mm) Jaw Length 13/16" (20.6 mm) 13/16" (20.6 mm) 1" (25.4 mm) Jaw Width 1-3/16" (30.2 mm) 1-3/16" (30.2 mm) 1-1/4" (31.8 mm) Jaw Thickness 7/16" (11.1 mm) 7/16" (11.1 mm) 1/2" (12.7 mm) Cutting Knives Standard Standard Standard Handle Finish Plastic Dipped Plastic Dipped Plastic Dipped Handle Color Red Red Red Weight 8.6 oz. (244 g) 9.6 oz. (272 g) 10.9 oz. (309 g) 1-3/16" (30.2 mm) 7/16" (11.1 mm) Standard Journeyman Red/Black 10.7 oz. (303 g) 1-3/16" (30.2 mm) 1-3/16" (30.2 mm) 7/16" (11.1 mm) 7/16" (11.1 mm) Standard Standard Plastic Dipped Plastic Dipped Royal Blue Glow 9.6 oz. (272 g) 9.6 oz. (272 g) 1-3/16" (30.2 mm) 7/16" (11.1 mm) Standard Journeyman Light Blue/Black 10.7 oz. (303 g) JourneymanTM Series – Dual-material handles J228-8 8-1/8" (206.4 mm) 13/16" (20.6 mm) 2000 Series* – Heavy-duty cutting knives D2000-28 D200028GLW 8-1/16" (204.8 mm) 8-1/16" (204.8 mm) 13/16" (20.6 mm) 13/16" (20.6 mm) JourneymanTM 2000 Series* – Dual-material handles J2000-28 8-1/8" (206.4 mm) 13/16" (20.6 mm) *Cuts ACSR, screws, nails, and most hardened wire. Features combination polished and black-oxide finish. Refer to the insulated section for insulated pliers. See page 310 for additional information on warnings. 11 www.kleintools.com Pliers Diagonal-Cutting Pliers NEW! High-Leverage Diagonal-Cutting Pliers - Angled Head Additional Features: • Angled head design for easy work in confined spaces • High-leverage design. Rivet is closer to the cutting edge for 36% greater cutting and gripping power than other plier designs • Cat. No. D248-8GLW feature glow in the dark grips to easily locate your tool in dark or low lit areas Angled Head Profile Cat. No. D248-8 D248-8-GLW D238-8 Overall Length 8-1/16" (204.8 mm) 8-1/16" (204.8 mm) 8-1/16" (204.8 mm) D2000-49 Glow in the Dark Grips Jaw Length 13/16" (20.6 mm) 13/16" (20.6 mm) 13/16" (20.6 mm) D248-8GLW Jaw Width 1-3/16" (30.2 mm) 1-3/16" (30.2 mm) 1-3/16" (30.2 mm) Jaw Thickness 7/16" (11.1 mm) 7/16" (11.1 mm) 7/16" (11.1 mm) Cutting Knives Standard Standard Semi-Flush** Handle Finish Plastic-Dipped Plastic-Dipped Plastic-Dipped Handle Color Red Glow Red Weight 9.6 oz. (272 g) 9.6 oz. (272 g) 9.4 oz. (266 g) 1-3/16" (30.2 mm) 7/16" (11.1 mm) Standard Journeyman Red/Black 9.8 oz. (278 g) 1-3/16" (30.2 mm) 1-1/4" (31.8 mm) 7/16" (11.1 mm) 7/16" (11.1 mm) Standard Standard Plastic Dipped Plastic Dipped Blue Blue 9.6 oz. (272 g) 10.3 oz. (292 g) 1-3/16" (30.2 mm) 7/16" (11.1 mm) Standard Journeyman Light Blue/Black 9.8 oz. (278 g) JourneymanTM Series – Dual-material handles J248-8 8-1/8" (206.4 mm) 13/16" (20.6 mm) 2000 Series* – Heavy-duty cutting knives D2000-48 8" (203.2 mm) D2000-49 NEW! 9" (228.6 mm) 13/16" (20.6 mm) 13/16" (20.6 mm) JourneymanTM 2000 Series* – Dual-material handles J2000-48 8-1/8" (206.4 mm) 13/16" (20.6 mm) *Cuts ACSR, screws, nails, and most hardened wire. Features combination polished and black-oxide finish. Refer to the insulated section for insulated pliers. **Semi-flush cutting knives cut Cherry Burrel rivets. For use on non-ferrous wire only. High-Leverage Diagonal-Cutting Pliers - Stripping Holes Additional Features: • Cleanly strips 12 and 14 solid AWG wire • High-leverage design. Rivet is closer to the cutting edge for 36% greater cutting power than other pliers designs 4 AWG D243-8 12 – 1 Cat. No. D243-8 Overall Length 8-1/16" (204.8 mm) Jaw Length 13/16" (20.6 mm) Jaw Width 1-3/16" (30.2 mm) Jaw Thickness 7/16" (11.1 mm) Cutting Knives Standard Handle Finish Plastic-Dipped Handle Color Red Weight 9.6 oz. (272 g) High-Leverage Diagonal-Cutting Pliers - Ironworker's Additional Features: • Angled head design for easy working in confined spaces • Hooked handle for improved grip • High-leverage design. Rivet is closer to the cutting edge for 36% greater cutting power than other pliers designs • Cat. No. D248-9STT has split tether ring for use with tether device NEW! D248-9STT Angled Head Profile Cat. No. Overall Length D248-9ST 9-3/16" (233.4 mm) D248-9STT NEW! 9" (228.6 mm) 12 www.kleintools.com Jaw Length 13/16" (20.6 mm) 1" (25.4 mm) Jaw Width 1-3/16" (30.2 mm) 1-1/4" (31.8 mm) Jaw Thickness 7/16" (11.1 mm) 1/2" (12.7 mm) Cutting Knives Standard Standard Handle Finish Plastic Dipped Plastic Dipped Handle Color Red Red Weight 10.9 oz. (309 g) 10.9 oz. (309 g) See page 310 for additional information on warnings. Pliers Diagonal-Cutting Pliers Heavy-Duty Diagonal-Cutting Pliers - Tapered Nose Additional Features: • Heavier design for all-purpose use • Tapered nose for easy working in confined areas D220-7 D252-6 Cat. No. D220-7 D252-6 Overall Length 7-11/16" (195.3 mm) 6-1/8" (155.6 mm) Jaw Length 1" (25.4 mm) 13/16" (20.6 mm) Jaw Width 31/32" (24.6 mm) 3/4" (19.1 mm) Jaw Thickness 1/2" (12.7 mm) 7/16" (11.1 mm) Cutting Knives Standard Standard Handle Finish Plastic-Dipped Plastic-Dipped Handle Color Red Red Weight 8.6 oz. (244 g) 6.1 oz. (173 g) 3/4" (19.1 mm) 7/16" (11.1 mm) Standard Plastic-Dipped Red 5.3 oz. (150 g) Bell System Type "W" Notches – Slit insulation cleanly D252-6SW 6-1/8" (155.6 mm) 13/16" (20.6 mm) Standard Diagonal-Cutting Pliers - Tapered Nose Additional Features: • Tapered nose for easy working in confined areas and close tip cutting • Spring-loaded action for self-opening (Cat. No. D245-5C) D245-5 Cat. No. D202-6 D202-6C D245-5 D245-5C Overall Length 6-1/8" (155.6 mm) 6-1/8" (155.6 mm) 5-1/16" (128.6 mm) 5-1/16" (128.58 mm) Jaw Length 13/16" (20.6 mm) 13/16" (20.6 mm) 11/16" (17.5 mm) 11/16" (17.46 mm) Jaw Width 11/16" (17.5 mm) 11/16" (17.5 mm) 9/16" (14.3 mm) 9/16" (14.28 mm) Jaw Thickness 7/16" (11.1 mm) 7/16" (11.1 mm) 3/8" (9.5 mm) 3/8" (9.52 mm) Cutting Knives Standard Standard Standard Standard Handle Finish Plastic-Dipped Plastic-Dipped Plastic-Dipped Plastic-Dipped Handle Color Red Red Red Red Weight 4.6 oz. (130 g) 5.0 oz. (142 g) 3.2 oz. (91 g) 0.20 lbs. (0.09 kg) Standard Diagonal-Cutting Pliers - Semi-Flush Cutting Additional Features: • Trims plastic or printed circuit boards • Spring-loaded for self-opening action D210-6C Cat. No. D210-6C Overall Length 6-1/8" (155.6 mm) Jaw Length 13/16" (20.6 mm) Jaw Width 11/16" (17.5 mm) Jaw Thickness 7/16" (11.1 mm) Cutting Knives Semi-Flush Handle Finish Plastic-Dipped Handle Color Red Weight 4.6 oz. (130 g) Standard Diagonal-Cutting Pliers - Stripping Hole Additional Features: • Cleanly strips 16 AWG (1.0 mm) solid wire • Tapered nose for easy working in confined areas G 16 AW D240-6 Cat. No. D240-6 Overall Length 6-1/8" (155.6 mm) Jaw Length 13/16" (20.6 mm) See page 310 for additional information on warnings. Jaw Width 11/16" (17.5 mm) Jaw Thickness 7/16" (11.1 mm) Cutting Knives Standard Handle Finish Plastic-Dipped Handle Color Red Weight 4.8 oz. (136 g) 13 www.kleintools.com Pliers Diagonal-Cutting Electronics Pliers Midget Diagonal-Cutting Pliers Additional Features: • Sharp pointed nose for precise tip cutting • Tapered nose for easy working in confined areas and close tip cutting (Cat No. D295-4C, D257-4 & D257-4C) • Spring loaded for self-opening action (Not available on Cat. No. D257-4) • Narrow jaw and hinge for delicate work in tight areas (Cat. No. D259-4C & D2445C) • Miniature jaw for close-quarter work with maximum visibility (Cat. No. D295-4C) D257-4C D295-4C Cat. No. D209-4C D209-5C D244-5C D257-4 D257-4C D259-4C D295-4C Nose Type Pointed Pointed Pointed Tapered Tapered Pointed Tapered D259-4C Jaw Type Standard Standard Narrow Standard Standard Extra Narrow Mini D209-5C Overall Length 4-1/4" (108.0 mm) 5-1/16" (128.6 mm) 5-1/16" (128.6 mm) 4-1/4" (108.0 mm) 4-1/4" (108.0 mm) 4-1/4" (108.0 mm) 4-1/4" (108.0 mm) Jaw Length 1/2" (12.7 mm) 11/16" (17.5 mm) 11/16" (17.5 mm) 1/2" (12.7 mm) 1/2" (12.7 mm) 1/2" (12.7 mm) 1/2" (12.7 mm) D244-5C Jaw Width 7/16" (11.1 mm) 9/16" (14.3 mm) 1/2" (12.7 mm) 7/16" (11.1 mm) 7/16" (11.1 mm) 13/32" (10.3 mm) 3/8" (9.5 mm) Jaw Thickness 1/4" (6.4 mm) 3/8" (9.5 mm) 5/16" (7.9 mm) 1/4" (6.4 mm) 1/4" (6.4 mm) 1/4" (6.4 mm) 1/4" (6.4 mm) Cutting Knives Semi-Flush Semi-Flush Flush Semi-Flush Semi-Flush Flush Flush Handle Finish Plastic-Dipped Plastic-Dipped Plastic-Dipped Plastic-Dipped Plastic-Dipped Plastic-Dipped Plastic-Dipped Handle Color Royal Blue Royal Blue Royal Blue Royal Blue Royal Blue Royal Blue Royal Blue Weight 2.1 oz. (60 g) 3.0 oz. (85 g) 2.9 oz. (82 g) 1.9 oz. (54 g) 1.9 oz. (54 g) 1.9 oz. (54 g) 1.8 oz. (51 g) Midget Diagonal-Cutting Pliers - Nickel Ribbon Wire Cutters Additional Features: • Designed to cut nickel ribbon wire • Nose tip is only 1/32" (0.8 mm) for precise work in confined areas • Cutting knife tip is 3/16" (5 mm) long for precise cutting • Spring-loaded action for self-opening D230-4C Cat. No. D230-4C Overall Length 4-1/4" (108.0 mm) Jaw Length 1/2" (12.7 mm) Jaw Width 7/16" (11.1 mm) Jaw Thickness 1/4" (6.4 mm) Cutting Knives Semi-Flush Handle Finish Plastic-Dipped Handle Color Royal Blue Weight 1.9 oz. (54 g) Lightweight Flush Cutter • Shears wire up to 18 AWG producing a flat, flush cut • Shear cutting greatly reduces cutting effort and minimizes fly-off • Cushioned grips and steel return spring for increased comfort during repetitive cutting • Ultra slim profile increases access in confined areas • Heat treated for increased durability Cat. No. D275-5 Overall Length 5" (127.0 mm) 14 www.kleintools.com Cutting Knives Flush Handle Finish Plastic Handle Color Red Weight 1.8 oz. (51 g) D275-5 See page 310 for additional information on warnings. Pliers Long-Nose Pliers Hot-riveted joint ensures smooth action and no ­handle wobble FORGED STEEL from Klein's US-made, proprietary blend Slim head design for working in­ confined areas. Plastic-dipped handles† for comfort and ease of identification JourneymanTM pliers available. State-of-the-art, dual-material handles provide a better grip without sacrificing tool strength or durability † All-Purpose Pliers Additional Features: • Cat. No. J206-8C strips 8-16 AWG solid and 10-18 AWG stranded wire • Cat. No. J207-8CR strips 10-18 AWG solid and 12-20 AWG stranded wire and crimps non-insulated connectors, lugs and terminals • Induction-hardened cutting knives for increased wire cutting performance, including hard wire • Long nose for grabbing and looping wire • 6-32 and 8-32 screw shearing J206-8C WG 0-18 A WG 8-16 A 1 J207-8CR 8 AWG 10 – 1 Cat. No. J206-8C J207-8CR Overall Length 8-5/8" (219.1 mm) 8-5/8" (219.1 mm) Jaw Length 2-3/16" (55.6 mm) 2-3/16" (55.6 mm) See page 310 for additional information on warnings. Jaw Width 1" (25.4 mm) 1" (25.4 mm) Jaw Thickness 1/2" (12.7 mm) 1/2" (12.7 mm) Knife Length 1/2" (12.7 mm) 1/2" (12.7 mm) 0 AWG 12 – 2 Point Thickness Handle Finish 1/8" (3.2 mm) Journeyman 1/8" (3.2 mm) Journeyman Handle Color Yellow/Black Yellow/Black Weight 9.6 oz. (272 g) 9.6 oz. (272 g) 15 www.kleintools.com Pliers Long-Nose Pliers Heavy-Duty Long-Nose Pliers - Side-Cutting Additional Features: • Induction-hardened cutting knives for long life • Heavier design for greater cutting power • Extended handles provide added reach and greater leverage • Cat. No. D203-8GLW features glow in the dark grips to easily locate your tool in dark or low lit areas D203-8NCR G 12 AW Glow in the Dark Pliers Cat. No. D203-8 D203-8GLW Overall Length Jaw Length 8-7/16" (214.3 mm) 2-5/16" (58.7 mm) Jaw Width 1" (25.4 mm) Jaw Thickness Knife Length 1/2" (12.7 mm) 5/8" (15.9 mm) Point Thickness Handle Finish 1/8" (3.2 mm) Plastic-Dipped D203-8-GLW 8-7/16" (214.3 mm) 2-5/16" (58.7 mm) 1" (25.4 mm) 1/2" (12.7 mm) 5/8" (15.9 mm) 1/8" (3.2 mm) Plastic-Dipped Handle Color Weight Yellow 9.6 oz. (272 g) High-Visibility, Glow in. The Dark 9.6 oz. (272 g) 1" (25.4 mm) 1/2" (12.7 mm) 5/8" (15.9 mm) 1/8" (3.2 mm) Journeyman Yellow/Black 10.1 oz. (286 g) 1" (25.4 mm) 1/2" (12.7 mm) 5/8" (15.9 mm) 1/8" (3.2 mm) Plastic-Dipped Yellow 9.4 oz. (266 g) 1" (25.4 mm) 1/2" (12.7 mm) 5/8" (15.9 mm) 1/8" (3.2 mm) Journeyman Yellow/Black 10.2 oz. (289 g) 1/8" (3.2 mm) Plastic-Dipped Yellow 9.8 oz. (278 g) JourneymanTM Series – Dual-material handles J203-8 8-9/16" (217.5 mm) 2-5/16" (58.7 mm) Wire Stripping – Cleanly strips 12 AWG wire D203-8N 8-7/16" (214.3 mm) 2-5/16" (58.7 mm) JourneymanTM Series – Dual-material handles J203-8N 8-9/16" (217.5 mm) 2-5/16" (58.7 mm) Wire Stripping & Crimping – Cleanly strips 12 AWG wire; crimps connectors, lugs & terminals D203-8NCR 8-7/16" (214.3 mm) 2-5/16" (58.7 mm) 1" (25.4 mm) 1/2" (12.7 mm) 5/8" (15.9 mm) Refer to the insulated section for insulated pliers. Standard Long-Nose Pliers - Side-Cutting Additional Features: • Induction-hardened, long-lasting cutting knives • Knurled jaws for sure wrapping and looping • Curved handles provide greater tool control • Spring-loaded action for self-opening (Cat. Nos. D203-6C, D203-7C) D203-6C Cat. No. Overall Length Jaw Length Jaw Width Jaw Thickness Knife Length D203-6 D203-6C D203-7 D203-7C 6-5/8" (168.3 mm) 6-5/8" (168.3 mm) 7-3/16" (182.6 mm) 7-3/16" (182.6 mm) 1-7/8" (47.6 mm) 1-7/8" (47.6 mm) 2-7/16" (61.9 mm) 2-7/16" (61.9 mm) 11/16" 11/16" 11/16" 11/16" 3/8" 3/8" 3/8" 3/8" Point Thickness Handle Finish Handle Color Weight (9.5 mm) (9.5 mm) (9.5 mm) (9.5 mm) 1/2" (12.7 mm) 1/2" (12.7 mm) 1/2" (12.7 mm) 1/2" (12.7 mm) 3/32" (2.4 mm) 3/32" (2.4 mm) 3/32" (2.4 mm) 3/32" (2.4 mm) Plastic-Dipped Plastic-Dipped Plastic-Dipped Plastic-Dipped Yellow Yellow Yellow Yellow 4.3 oz. (122 g) 4.3 oz. (122 g) 4.6 oz. (130 g) 4.6 oz. (130 g) 11/16" (17.5 mm) 3/8" (9.5 mm) 11/16" (17.5 mm) 3/8" (9.5 mm) 1/2" (12.7 mm) 1/2" (12.7 mm) 3/32" (2.4 mm) 3/32" (2.4 mm) Journeyman Journeyman Yellow/Black Yellow/Black 4.8 oz. (136 g) 5.3 oz. (150 g) 1/2" (12.7 mm) 3/32" (2.4 mm) Plastic-Dipped Yellow 4.2 oz. (119 g) (17.5 mm) (17.5 mm) (17.5 mm) (17.5 mm) JourneymanTM Series – Dual-material handles J203-6 J203-7 6-3/4" (171.5 mm) 7-5/16 (185.7 mm) 1-7/8" (47.6 mm) 2-7/16" (61.9 mm) Switchboard Work – Cleanly strips 19 & 22 AWG wire D203-6H2 6-5/8" (168.3 mm) 1-7/8" (47.6 mm) 11/16" (17.5 mm) 3/8" (9.5 mm) Refer to the insulated section for insulated pliers. 16 www.kleintools.com See page 310 for additional information on warnings. Pliers Long-Nose Pliers Standard Long-Nose Pliers Additional Features: • Knurled jaws for sure wrapping and looping • Curved handles provide greater tool control • Spring-loaded action for self-opening (Cat. No. D301-6C) D301-6 Cat. No. D301-6 D301-6C Overall Length 6-5/8" (168.3 mm) 6-5/8" (168.3 mm) Jaw Length 1-7/8" (47.6 mm) 1-7/8" (47.6 mm) Jaw Width 11/16" (17.5 mm) 11/16" (17.5 mm) Jaw Thickness 3/8" (9.5 mm) 3/8" (9.5 mm) Point Thickness 3/32" (2.4 mm) 3/32" (2.4 mm) Handle Finish Plastic-Dipped Plastic-Dipped Handle Color Yellow Yellow Weight 4.6 oz. (130 g) 4.5 oz. (128 g) Slim Long-Nose Pliers Additional Features: • Longer nose and handles for deeper reach into work • Spring-loaded for self-opening action • Curved handles provide greater tool control D307-5 1/2C Cat. No. D307-51/2C D327-51/2C Overall Length 5-5/8" (142.9 mm) 5-5/8" (142.9 mm) Jaw Length Jaw Width 1-11/16" (42.9 mm) 1/2" (12.7 mm) 1-11/16" (42.9 mm) 1/2" (12.7 mm) Jaw Thickness 5/16" (7.9 mm) 5/16" (7.9 mm) Point Thickness 1/32" (0.8 mm) 1/16" (1.59 mm) Handle Finish Plastic-Dipped Plastic-Dipped Handle Color Yellow Dark Blue Weight 2.4 oz. (68 g) 2.4 oz. (68 g) Electronics Long-Nose Pliers Midget Long-Nose Pliers - Slim-Nose Additional Features: • Lightweight, slim-nose pliers for precision subminiature assembly work • Knurled jaws for sure wrapping and looping • Curved handles provide greater tool control • Spring-loaded action for self-opening D322-4 1/2C Cat. No. D321-41/2C Overall Length Jaw Length Jaw Width Jaw Thickness Point Thickness 4-13/16" (122.2 mm) 1-1/16" (27.0 mm) 7/16" (11.1 mm) 1/4" (6.4 mm) 1/32" x 1/16" (0.8 x 1.6 mm) Handle Finish Plastic-Dipped Handle Color Royal Blue Weight 2.1 oz. (60 g) Plastic-Dipped Plastic-Dipped Royal Blue Royal Blue 2.1 oz. (60 g) 0.13 lbs. (0.058 kg) Smooth Inside Jaws – Radiused jaw edges help prevent nicking wire D322-41/2C D323-41/2C 4-13/16" (122.2 mm) 1-1/16" (27.0 mm) 7/16" (11.1 mm) 1/4" (6.4 mm) 4-13/16" (122 mm) 1-1/16" (27 mm) 7/16" (11 mm) 1/4" (6 mm) 1/32" x 1/16" (0.8 x 1.6 mm) 1/8" x 1/16" (3mm x 2 mm) Tapered Long-Nose Pliers Additional Features: • Larger and sturdier yet tapered design allows access into tight areas • Knurled jaws for sure wrapping and looping • Spring-loaded for self-opening action • Curved handles provide greater tool control D310-6C Cat. No. D310-6C Overall Length 6-5/8" (168.3 mm) Jaw Length 1-7/8" (47.6 mm) See page 310 for additional information on warnings. Jaw Width 11/16" (17.5 mm) Jaw Thickness 3/8" (9.5 mm) Point Thickness 1/16" (1.59 mm) Handle Finish Plastic-Dipped Handle Color Yellow Weight 4.3 oz. (122 g) 17 www.kleintools.com Pliers Electronics Long-Nose Pliers Long-Nose Pliers - Chain-Nose Additional Features: • Knurled jaws for sure gripping, bending and forming of medium-gauge wire • Spring-loaded for self-opening action • Curved handles provide greater tool control D317-5C Cat. No. D317-5C Overall Length Jaw Length 5-1/16" (128.58 mm) 1-1/8" (28.57 mm) Jaw Width 1/2" (12.7 mm) Jaw Thickness 5/16" (7.93 mm) Point Thickness 1/16" (1.58 mm) Handle Finish Plastic-Dipped Handle Color Yellow Weight 0.14 lbs. (0.064 kg) Long Needle-Nose Pliers Additional Features: • Designed for accurate work in hard-to-reach areas • Knurled jaws for sure wrapping and looping • Spring-loaded for self-opening action • Curved handles provide greater tool control D318-5 1/2C Cat. No. D318-51/2C Overall Length 5-5/8" (142.9 mm) Jaw Length Jaw Width 1-11/16" (42.9 mm) 1/2" (12.7 mm) Jaw Thickness 5/16" (7.9 mm) Point Thickness 1/16" (1.59 mm) Handle Finish Plastic-Dipped Handle Color Yellow Weight 2.1 oz. (60 g) Long Needle-Nose Pliers - Extra-Slim Additional Features: • Long, narrow nose and slim hinge for extremely close quarter work • Finely knurled jaws grip thin wire without damaging it • Spring-loaded for self-opening action • Curved handles provide greater tool control D335-5 1/2C Cat. No. D335-51/2C Overall Length 5-5/8" (142.9 mm) Jaw Length Jaw Width 1-11/16" (42.9 mm) 15/32" (11.9 mm) Jaw Thickness 1/4" (6.4 mm) Point Thickness 1/16" (1.59 mm) Handle Finish Plastic-Dipped Handle Color Royal Blue Weight 2.1 oz. (60 g) Curved Long-Nose Pliers Additional Features: • 70° bent nose for maximum work visibility in confined areas • Knurled jaws for sure wrapping and looping • Curved handles provide greater tool control D302-6 Cat. No. D302-6 Overall Length 6-3/8" (161.9 mm) 18 www.kleintools.com Jaw Length 1-1/2" (38.1 mm) Jaw Width 11/16" (17.5 mm) Jaw Thickness 3/8" (9.5 mm) Point Thickness 3/32" (2.4 mm) Handle Finish Plastic Dipped Handle Color Yellow Weight 4.8 oz. (136 g) See page 310 for additional information on warnings. Pliers Electronics Long-Nose Pliers Midget Curved Chain-Nose Pliers Additional Features: • 60° bent nose for maximum work visibility in confined areas • Easily bends and forms fine wire • Polished inside jaws and radiused jaw edges prevent nicking wire • Spring-loaded for self-opening action • Curved handles provide greater tool control D320-4 1/2C Cat. No. D320-41/2C Overall Length 4-3/4" (120.7 mm) Jaw Length 1" (25.4 mm) Jaw Width 13/32" (10.3 mm) Jaw Thickness 1/4" (6.4 mm) Point Thickness 1/16" (1.59 mm) Handle Finish Plastic-Dipped Handle Color Royal Blue Weight 2.1 oz. (60 g) Special Use Pliers Conduit Locknut and Reaming Pliers • Tightens 1/2" (13 mm) and 3/4" (19 mm) EMT or 1/2" (13 mm) rigid locknuts • Fits liquid tight fittings and caps • Reams and deburrs both inside and outside of conduit • Knurled jaws at nose tip pull wire or fish tape • Machined nose fits snugly into locknut wings Cat. No. D333-8 Overall Length 7-3/4" (196.9 mm) Jaw Length 1-5/8" (41.3 mm) Jaw Width 15/16" (23.8 mm) Tightens Bodies & Caps Jaw Thickness Cuchillas Couteaux 1/2" (12.7 mm) D333-8 Tightens Locknuts Point Thickness Cuchillas Couteaux 3/16" (4.8 mm) Handle Finish Plastic-Dipped Handle Color Yellow Weight 8.8 oz. (249 g) End-Cutting Pliers • Wide throat clearance for clean, even cutting of wire or nails at close range • High-leverage design provides greater cutting power at the knives than other plier designs • Extended handles for longer reach and increased leverage D232-8 Cat. No. D232-8 Overall Length 8-1/2" (215.9 mm) Jaw Length 3/8" (9.5 mm) Jaw Width 1-3/16" (30.2 mm) Jaw Thickness 19/32" (15.1 mm) Knife Length 1-3/16" (30.2 mm) Handle Finish Plastic-Dipped Handle Color Red Weight 11.4 oz. (323 g) Plastic-Cutting Pliers • Precisely cuts injection mold sprues, gates and other plastic • Adjustable 1/16" hollow-head screw keeps knife-edges from damaging each other (not designed for use on metal) • Spring-loaded for self-opening action D227-7C Cat. No. D227-7C Overall Length 7-11/16" (195.3 mm) Jaw Length 1" (25.4 mm) See page 310 for additional information on warnings. Jaw Width 31/32" (24.6 mm) Jaw Thickness 1/2" (12.7 mm) Cutting Knives Flush Handle Finish Plastic-Dipped Handle Color Red Weight 8.8 oz. (249 g) 19 www.kleintools.com Pliers Slip-Joint Pliers Slip-Joint Pliers • Shear-type cutter for precision wire cutting • Two versatile jaw positions • Serrated jaws provide sure-gripping power • Nickel-chrome plated for long life Cat. No. D511-6 D511-8 D511-10 Overall Length 6-9/16" (166.7 mm) 8-1/16" (204.8 mm) 9-7/8" (250.8 mm) Jaw Length 1-3/16" (30.2 mm) 1-3/8" (34.9 mm) 1-3/4" (44.5 mm) D511-6 Jaw Width 1-3/16" (30.2 mm) 1-1/4" (31.8 mm) 1-3/8" (34.9 mm) Jaw Thickness 3/8" (9.5 mm) 7/16" (11.1 mm) 15/32" (11.9 mm) Handle Finish Plastic-Dipped Plastic-Dipped Plastic-Dipped Handle Color Blue Blue Blue Weight 6.2 oz. (176 g) 9.9 oz. (281 g) 13.3 oz. (377 g) Slip-Joint Pliers - Hose Clamp • Quickly installs and removes spring-tension hose clamps • Grips with either end or side of jaws for work in confined areas • Nickel-chrome plated for long life D514-8 Cat. No. D514-8 Overall Length 8-1/16" (204.8 mm) Jaw Length 1-3/8" (34.9 mm) Jaw Width 1-1/4" (31.8 mm) Jaw Thickness 7/16" (11.1 mm) Handle Finish Plastic-Dipped Handle Color Blue Weight 9.8 oz. (278 g) Pump Pliers Klaw™ Pump Pliers • Push button and quick ratchet feature allows for fast and easy adjustment to any position. (Cat. Nos. D504-10B, D504-12B) • Compact, narrow design for easy work in small or hard to reach spaces • Gripping surfaces with specially hardened teeth for reduced wear and D504-10 positive gripping • Extended grips for added comfort • Quick-Adjust Pump Pliers: Push button feature allows for fast and easy adjustment to any position. Cat. Nos. D504-10B, D504-12B) Cat. No. Overall Length Max. Jaw Capacity Handle Finish Handle Color Weight 10-1/8" (257.2 mm) 12-1/2" (317.5 mm) 2-1/8" (54.0 mm) 2-3/4" (69.9 mm) Plastic-Dipped Plastic-Dipped Yellow Yellow 12.6 oz. (357 g) 1.2 lbs. (0.54 kg) 7-3/8" (187.3 mm) 9-7/8" (250.8 mm) 12" (304.8 mm) 1-3/8" (34.9 mm) 2-1/8" (54.0 mm) 2-3/4" (69.9 mm) Plastic-Dipped Plastic-Dipped Plastic-Dipped Yellow Yellow Yellow 5.4 oz. (153 g) 13.0 oz. (369 g) 1.4 lbs. (0.64 kg) Quick-Adjust KlawTM Pump Pliers D504-10B D504-12B Classic KlawTM Pump Pliers D504-7 D504-10 D504-12 20 www.kleintools.com See page 310 for additional information on warnings. Pliers Pump Pliers Pump Pliers • Secure tongue and groove design for non-slip grip - even with heavy pressure • Wide range of versatile jaw positions D502-6 Cat. No. D502-6 D502-10 D502-12 D502-16 Overall Length 6-1/2" (165.1 mm) 10" (254.0 mm) 12-1/4" (311.2 mm) 16-1/4" (412.8 mm) Max. Jaw Capacity 7/8" (22.2 mm) 1-3/4" (44.5 mm) 2-3/8" (60.3 mm) 4-1/4" (108.0 mm) Handle Finish Plastic-Dipped Plastic-Dipped Plastic-Dipped Plastic-Dipped Handle Color Yellow Yellow Yellow Yellow Weight 6.6 oz. (187 g) 15.5 oz. (439 g) 1.4 lbs. (0.64 kg) 3.2 lbs. (1.45 kg) 1-3/4" (44.5 mm) Journeyman Yellow/Black 1.0 lbs. (0.45 kg) Journeyman™ Series – Dual-material handles J502-10 10-1/4" (260.4 mm) Pliers Handles Replacement Klein-Koat™ Pliers Handles • Plastic material for slip-resistant grip and comfort Cat. No. 60 70 89 Size to Fit Pliers 6" (152.4 mm) Long 7" (177.8 mm) Long 8" to 9" (203.2 to 228.6 mm) Long Color Maroon Maroon Maroon Weight 0.8 oz (23 g) 1.6 oz. (45 g) 1.6 oz. (45 g) 70 Replacement Comfort-Grip Pliers Handles • Klein exclusive slip-reducing pliers handles • Aerated plastic construction provides firm and resilient cushion 55 Cat. No. 55 Size to Fit Pliers 5" x 6-1/2" (127.0 x 165.1 mm) See page 310 for additional information on warnings. Color Red Weight 0.8 oz. (23 g) 21 www.kleintools.com
D511-6 价格&库存
很抱歉,暂时无法提供与“D511-6”相匹配的价格&库存,您可以联系我们找货
