Angle Position Sensors
AN8 Sensors
Programmable, non-contact magnetic position
sensors capable of continuous rotation
Description
The AN8 Series sensors are non-contact, intrinsically linear contact angle position sensors. The sensors operate through the use
of Hall Effect technology with magnetic fields generated by permanent magnets. They provide a linear change in voltage output
(ratiometric to the input voltage) corresponding to an angular rotation of the input shaft.
Features
Typical Applications
Angular position sensor with high tolerance for misalignment
Non-contact angular position sensing and full 360° rotation
Custom programming available for: angle range, slope, PWM
output, custom magnets – contact factory
No mechanical interface means no parts to wear out or jam
Available with Delphi connector or 12” (305 mm) wire leads
RoHS compliant
IP67
Maximum air gap of 5.5 mm (0.22”)*
Implement (fork lift, agricultural trailer hitch,
etc.) position sensing
Steer, throttle by wire
Gear selection
Zero-contact encoder alternative
Replacement for smart bearings
Outboard trim sensing
Environmental Specifications
Vibration
Operating Temperature
Storage Temperature
Ingress Protection
6g sinusoidal, 8 g RMS axial; 40Hz – 2 kHz all 3 axes
-40 °C to 125 °C (-40 °F to 257 °F) with Delphi connectors,
-40 °C to 150 °C (-40 °F to 302 °F) with wire leads
IP67
Electrical Specifications
Input Voltage
Output Voltage
Input Current
Output Current
Output Accuarcy
Output Linearity
Maximum Overvoltage
Absolute Max. Output Current
Output Type
5.0 VDC ± 10%
10% to 90% of input (see graph for voltage vs. rotation angle
characteristics)
14 mA typ., 16 mA max.
-8 mA to 8 mA
±3.5%
±3.5%
16 VDC
±30 mA
Analog (PWM available)
Mechanical Specifications
Housing Material
Mechanical Travel
Mating Connector
Maximum Air Gap*
*with AS500106 magnet carrier
Maximum Center-To-Center Offset
Glass Reinforced Plastic
0° to 360° (continuous)
Delphi Metri-pak 150.2 12162185; Terminal 1214075 / 2047680
5.5 mm (0.22")
2 mm radial (magnet to center)
www.cherryswitches.com
Page 1 of 2, last update 2014-10-29, Specifications subject to change without notice.
Products
Part Number Sensor (incl.
(Sensor)
AS500106 magnet)
AN820001
CU103601
AN820002
CU103602
AN820003*
CU103603
AN820031
-------AN820032
-------AN820033*
-------*Not commonly stocked
Sensing
Range
180°
360°
45°
180°
360°
45°
Wires
Connectors
Terminals
N/A
N/A
N/A
18 AWG x 305 mm (12")
Packard Metri-pack
Packard Metri-pack
Packard Metri-pack
N/A
N/A
N/A
1214075 / 2047680
1214075 / 2047680
1214075 / 2047680
N/A
N/A
N/A
Sensor Output
These charts show the output voltage as a percentage of
the input voltage for a given angle of rotation.
Example: 180⁰ sensing range, magnet rotated 135⁰, output
voltage will be 70% of input voltage (see dashed lines in
graph above).
Dimensions mm (inches)
Page 2 of 2, last update 2014-10-29, Specifications subject to change without notice.
很抱歉,暂时无法提供与“AN820032”相匹配的价格&库存,您可以联系我们找货
