Angle Position Sensors
AS500106
Magnet carrier for use with Angle Position Sensors
Features
PPS housing
Samarium Cobalt 28 magnet
RoHS compliant
Environmental Specifications
Vibration
Operation Temperature
Storage Temperature
Salt Spray
Immersion
15g sinusoidal, 9.26g RMS axial; 40 Hz – 2 kHz all 3 axes
-40 °C to 125 °C (-40 °F to 257 °F)
-40 °C to 150 °C (-40 °F to 302 °F)
SAEJ1455, Section 4.3.3
Tested per SAE J 1455, Section 4.4.1: Engine oil and additives,
Transmission oils, Water, Power steering fluid, Brake fluids, Washer
solvent, Gasoline, Diesel fuel, Alcohol, Antifreeze water mixture, Battery
acid, Salt water, Kerosene, Ammonia
Mechanical Specifications
Recommended Fastener
Recommended Torque
M4 Cap Screw
3 Nm (26.5 in lbs)
Products
Part Number
AS500106
CU103601
CU103602
CU103603
Description
Magnet only
Kit with AN820001 sensor
Kit with AN820002 sensor
Kit with AN820003 sensor
Dimensions mm (inches)
www.cherryswitches.com
Page 1 of 1, last update 2014-10-29, Specifications subject to change without notice.
Sensing Range
N/A
180°
360°
45°
很抱歉,暂时无法提供与“CU103603”相匹配的价格&库存,您可以联系我们找货
