JO
JOURNEYMAN
TM
Klein’s Journeyman™ Pump Pliers…Get a Hold on Comfort and Durability
Introducing Klein’s new Journeyman pump pliers, designed with a difference you can see and feel every time you use
the tool. Six machined tongue and grooves provide smooth jaw adjustments up to a maximum of 1-3/4" (44 mm), robust
teeth for sure-gripping action, induction hardened jaws for long life and a tension-loaded joint that reduces handle wobble.
Also, the state-of-the-art handles are made from a dual material molding that allows for a softer, more comfortable grip
on the outer surface and a harder, more durable grip on the inner surface and handle ends.
See and feel the difference of a Klein Journeyman, and you will know why “professionals are known by the tools they own™”.
Features
Contoured thumb area
for additional comfort
and positive feel.
Tension-loaded joint
to reduce handle wobble
for sure gripping.
Induction hardened
jaws for long life.
Hard, black material for
toughness and durability.
Robust teeth for
sure-gripping action.
Six machined tongue
and grooves for
smooth adjustments.
Soft material on outer
surface for comfort
and a firm grip.
State-of-the-art dual
material molding process.
Color-coded yellow
handles allow quick
identification of tool.
WARNINGS:
• Always wear approved eye protection.
• NOT insulated. Plastic-dipped or slip-on plastic handles are
NOT intended for protection against electrical shock.
Ordering Information
Cat. No.
NEW! J502-10
Supplement M to Catalog 139.3
© 2002 Klein Tools, Inc.
Printed in U.S.A.
EDP No.
Description
Nominal Size
73015
Pump Pliers
10" (254 mm)
Chicago, IL 60659-9033
www.kleintools.com
98066
很抱歉,暂时无法提供与“J502-10”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+444.109091+57.43538
