Angle Position Sensors
AN9 Sensors
Thin, programmable, non-contact magnetic position sensors
capable of continuous rotation with dual outputs
Description
The AN9 Series sensors are non-contact, intrinsically linear angle position sensors with two independent outputs. The sensors
operate through the use of Hall Effect technology with magnetic fields generated by permanent magnets. They provide a linear
change in voltage output (ratiometric to the input voltage) corresponding to an angular rotation of the input shaft.
Features
Typical Applications
Angular position sensor with high tolerance for misalignment
Non-contact angular position sensing and full 360° rotation
Dual independent (fully redundant) outputs assure high reliability
Custom programming available for: angle range, slope, PWM
output, custom magnets – contact factory
No mechanical interface means no parts to wear out or jam
Comes with 18 AWG 305 mm (12”) wire leads
RoHS Compliant
IP68*
Maximum air gap of 5.5 mm (0.22”)**
Implement (fork lift, agricultural trailer hitch,
etc.) position sensing
Steer, throttle by wire
Gear selection
Zero-contact encoder alternative
Replacement for smart bearings
Outboard trim sensing
Environmental Specifications
Vibration
15g sinusoidal, 9.26g RMS axial; 40 Hz – 2 kHz all 3 axes
Operating Temperature
-40 °C to 125 °C (-40 °F to 257 °F)
Storage Temperature
-40 °C to 150 °C (-40 °F to 302 °F)
Ingress Protection
IP68*
*submerged in 22±3 °C water for 1 hour at 2 m depth
Electrical Specifications
Input Voltage
Output Voltage
Input Current
Output Current
Output Accuracy
Output Linearity
Maximum Overvoltage
Absolute Max. Output Current
Output Type
5.0 VDC ± 10%
10% to 90% of input (see graph for voltage vs. rotation angle
characteristics)
14 mA typ., 16 mA max.
-8 mA to 8 mA
±3.5%
±3.5%
16 VDC
±30 mA
Analog (PWM available)
Mechanical Specifications
Housing Material
Mechanical Travel
Maximum Air Gap**
**with AS500106 magnet carrier
Maximum Center-To Center Offset
Glass Reinforced Plastic
0° to 360° (continuous)
5.5 mm (0.22")
2 mm radial (magnet to center)
Note: When used with AS500106 Magnet Carrier; user is responsible for determining characteristics when using other magnets.
Products
Sensing Range
Wires
www.switches-sensors.zf.com
Page 1 of 2, last update 2017-01-05, Specifications subject to change without notice.
#NP#_ TY9vb4IwEM a/CumrLZ PZFlDwHZ 2dY Q7E P5vD NCGV 4mxGqKHVLDF+ 95Xt zS655 O65 3+XuuYKqApMr 6A6JABOAI ILgNr Bi3 7HhlJv6 DvmhF+ARRgGE8MEmvG dDMA BC9 pvcgt8 2rLDv 61RWndLqYJyt6kS PJVMrkyLYZ XHw Qe cLCItiNQtf3ndpE WbYIoe TJYoJY1 /ae L49 wJhs hbxI ceY NY+StTGg 5a9SeN+Wa N7 Uuk1a ctelkL6jmb KRqNWN5v nJeN5kTr4ijj7yr GbM OuD7 WtbHj dd1 q1 dmCtp+ N1M d/0zLOopJmj0JVvZPT3 9PPGU7jfI bHI zyaL3 O4 2KKlV+B0E1rG /CI heYr INCKuhyh2fRqN3Z hQ6BLohcj HEbYJ brcf_# NP#
Part Number (Sensor)
AN920031
AN920032
AN920035
AN920036
180°
360°
45°
90°
18 AWG x 305 mm (12")
Sensor Output
Dimensions mm (inches)
Page 2 of 2, last update 2017-01-05, Specifications subject to change without notice.
很抱歉,暂时无法提供与“AN920031”相匹配的价格&库存,您可以联系我们找货
