1.15105.0010000
1.15105.0010000
    RAFI
    SWITCHPUSHDPST-NC2.5A240V
1.15105.0010000 数据手册
10.10.2016 LUMOTAST 22 Emergency stop pushbutton, non-illuminated, 2 NC, reset by rotation 1.15.105.001/0000 General information Form of lens Color of lens Form of collar conical mushroom form red round Dimensions Mushroom Diameter Overall height Mounting depth Mounting hole 30 mm 25.9 mm 17.6 mm 22.3 mm Mechanical design Mounting Terminals Torque for nut ring Contact function Contact arrangement Illuminability Reset ring nut quick connector 2.8 x 0.8 mm, solderable 1.9 Nm latching 2 NC no by rotation Mechanical characteristics Robustness max. 100 N Electrical characteristics acc. to IEC/EN 60947-5-1 (VDE 0660 Part 200) Application category AC15/DC13 Rated insulation voltage Ui 250V (AC/DC) Rated operating voltage Ue 250V AC, 240V DC {Term. Dauerstrom} 2.5A (AC/DC) Other specifications Ambient temp. operating min. Ambient temp. operating max. Robustness Operating life (operations) / B10 Degree of protection from front side Storage temperature min. Storage temperature max. Environmental restistance Salt spray Solder techniques -25 °C +70 °C acc. to IEC 600 68-2-3 und 2-30 15,000 cycle IP65 (DIN EN 60529) -40 °C +80 °C acc. to IEC 60068-2-14, -30, -33 and -78 IEC 600 68-2-11 manual soldering, lead-free Technical data are approximate and intended solely for general orientation in the selection of a product. Subject to modifications and errors. Images and other graphics may only be similar. For more information, refer to www.rafi.de chapter Imprint / Data Protection. 10.10.2016 Soldering temperature max. Soldering time max. ROHS compliant REACH compliant 350 °C 5s yes yes Panel cut-out to IEC 60947-5-1 Technical data are approximate and intended solely for general orientation in the selection of a product. Subject to modifications and errors. Images and other graphics may only be similar. For more information, refer to www.rafi.de chapter Imprint / Data Protection.
1.15105.0010000 价格&库存
很抱歉,暂时无法提供与“1.15105.0010000”相匹配的价格&库存,您可以联系我们找货
