AmPLink USB Adapter
AmPLink
Description
The AmPLink™ USB Adapter provides the
hardware interface between the AnDAPT
AmPDB1 Demonstration Board and a PC. It is
used in conjunction with AmPLink Control
software to program and control devices on the
demonstration board.
Key Features
AmP Device Control
SPI, I2C control
Memory Programmer
Program AmP and flash devices
New devices can easily be added to a
memory device database
Power
USB powered
5V and 3.3V outputs with current limiting
Software
Windows and Linux user interfaces
Connectors
USB type B
20 pin, male, keyed, 0.1” pitch
Accessories
USB type-B female to USB type-A male
3’ cable
20-way, female to female, IDC cable
assembly. Maximum length 4”/100mm.
Copyright © 2020, AnDAPT, Inc.
1
02/01/2020
AmPLink USB Adapter
AmPLink
Pin Out
GND – 1
AMP_SCLK – 3
AMP_SI – 5
CS3 – 7
AMP_Config – 9
AMP_SO – 11
3.3V – 13
FLASH_WP – 15
AMP_ALERT – 17
AMP_EN – 19
2 – CS2
4 – GND
6 – CS1
8 – CS4
10 – FLASH_RST
12 – GND
14 – AMP_SCL
16 – AMP_SDA
18 – AMP_CTRL
20 – VBUS
Functional Description
The AmPLink USB Adapter provides SPI, I2C and GPIO interfaces to the AmP evaluation board. The SPI bus is used to
control the AmP device and program both AmP and flash memory. The I2C bus provides control and monitoring of the
power supply functions of the AmP device. GPIO is used for evaluation board configuration and to support functions on
the SPI interface. All pins use 3.3V logic except where otherwise stated.
Pin Functional Description
SPI
AMP_SCLK
AMP_SI
AMP_SO
CS1, CS2, CS3, CS4
I2C
AMP_SCL
Clock output
Hi-Z when not in use
MOSI output when communicating with AmP devices
MISO input when programming flash devices
MISO input when communicating with AmP devices
MOSI output when programming flash devices
Chip select outputs
AMP_ALERT
AMP_CTRL
Clock output
Open drain with internal 2.2kΩ pull up resistor
Bidirectional data line
alert signal input
control signal output
Configuration
AMP_EN
AMP_Config
FLASH_WP
FLASH_RST
AmP device enable output
Configures AmP device (see AnDAPT_AmP_Platform datasheet)
Flash write protect output
Flash reset output
Power
GND
VBUS
3.3V
Connected to USB GND and shield
5V output with 0.5A to 0.7A current limiting
3.3V output with 0.5A current limiting
AMP_SDA
2
02/01/2020
AmPLink USB Adapter
AmPLink
AmPLink12 Adapter Extension
The AmPLink12 Adapter provides reduced pin counts for applications not requiring all the functionality of the 20-pin
interface. This enables the application to have a smaller footprint with fewer connections. Three Standard Interface
pinouts are recommended and supported as defined follows:
Standard Interface Total Pins
AmPLink12
12
AmPLink12 Basic
6
AmPLink12 Basic Edge
6
SPI
yes
yes
yes
I2C
yes
no
no
pin pitch
0.1 inch
0.1 inch
0.1 inch
cable length
4 inches
4 inches
4 inches
AmPLink Pinouts
AmPLink Images
3
02/01/2020
AmPLink USB Adapter
AmPLink
Electrical Characteristics
Description
VBUS (5V) output maximum current
3.3V output maximum current
Inputs and outputs
GPIO pin maximum output current
Adapter supply current
Condition
current limit with foldback current limiting
current limit with constant current limiting
logic levels
Assuming negligible current drawn from the IO
connector
Min
500
Typ
Max
700
500
3.3
80
8
100
Unit
mA
mA
V
mA
mA
Precautions for Use
The AmPLink USB Adapter features ESD protection, however, damage may occur at high ESD levels. Therefore, it is
recommended that static handling precautions be followed at all times.
Software
AmPLink software is only intended for use with AnDAPT products. It can be downloaded from https://www.andapt.com/
WebAmP AmPLink download.
Windows Driver Installation
The AmPLink Adapter drivers will normally be installed automatically when an Adapter is plugged into a USB port on a
PC. If this does not happen use the driver setup executable available from the FTDI website at
http://www.ftdichip.com/Drivers/D2XX.htm. Choose the latest version based on your operating system.
Windows AmPLink Control Installation
The control software is available at https://www.andapt.com/ WebAmP tools download page.
Download the zip file to your PC and unzip the AmPLink.zip folder onto your hard disk. Click on the executable to run the
Windows control interface.
Revision History
Date
2/1/2020
9/1/2016
8/1/2016
Revision
Added AmPLink12 Adapter Extension
5V output can limit at between 500mA and 700mA;
Initial
Trademarks
© 2020 AnDAPT, the AnDAPT logo, AmP, WebAmP, AmPLink, AmPScope and other designated brands included herein
are trademarks of AnDAPT in the United States and other countries. All other trademarks are the property of their
respective owners.
4
02/01/2020
很抱歉,暂时无法提供与“AMPLINK”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+2642.716531+343.54460
