1664
1664
    ADAFRUIT
    ROUND SPACER #10 BRASS 1/2"
1664 数据手册
5-pin JST SM Plug + Receptacle Cable Set PRODUCT ID: 1664  Description These 5-wire cables are 168mm (6.6") long and come as a set. One cable has a JST SM type connector plug on the end. The other cable has a matching JST SM type receptacle connector. They are good for whenever you have 5 wires you want to be able to plug and unplug. We like the solid and compact nature of these connectors and the latch that keeps the cable from coming apart easily. For more information, check the JST SM connector datasheet Each order receives one of each connector. Wires are 22 American wire gauge.  Technical Details o o o JST SM plug + receptacle connector: JST SM connector datasheet Length: 168mm / 6.6" Weight (female / male): 4.3g / 4.7g                                  Engineered in NYC Adafruit ® https://www.adafruit.com/product/1664 5‐5‐17
很抱歉,暂时无法提供与“1664”相匹配的价格&库存,您可以联系我们找货
