B383904
B383904
    EATON(伊顿)
    接线端子 间距P=11.10mm 4Pin(1x4P)
B383904 数据手册
Single Row Terminal Blocks A38 & B38 Dimensions Inches (Millimeters) Specifications A38 A38: 30A, 600V B38: 50A, 300V Center Spacing: 0.437” (11.10mm) Wire Range: A38: #10-22 AWG Cu; B38: #8-16 AWG Screw Size: #8-32 zinc-plated steel A389306 Torque Rating: A38: 9 lb-in; B38: 15 lb-in for #8, 9 lb-in for #6 Base: A38 Only: Standoffs standard for easy flux washing Distance Between Barriers: 0.378” (9.60mm) Recommended PCB Hole Diameter (A38): 0.076” (1.93mm) Operating Temperature: 105°C (221°F) max to -40°C (-40°F) Molded Material: Black, UL Rated 94V0 Thermoplastic Breakdown Voltage: 5000V Agency Information: UL File E62622, CSA File 47235; CE Certified B38 B384404 MOUNTING ENDS ONLY BARRIER ENDS ONLY Poles A Mounting Centers “A” Dimension Length “A” Dimension Length 02 03 04 05 06 07 08 09 10 11 12 13 14 15 16 1.31 1.75 2.19 2.62 3.06 3.50 3.93 4.37 4.81 5.24 5.68 6.12 6.56 6.99 7.43 1.67 2.10 2.54 2.98 3.41 3.85 4.29 4.72 5.16 5.60 6.04 6.47 6.91 7.35 7.78 0.93 1.37 1.81 2.25 2.68 3.12 3.56 3.99 4.43 4.87 5.30 5.74 6.18 6.61 7.05 Dimensions in inches. To convert to millimeters, multiply by 25.4. A38 & B38   Single Row Terminal Blocks  Part Numbering System Family A 3 Terminal Style Base/End Poles Screw Options 1 - handwired* 1 - flat base, mount end 02 to 16 Blank - standard screw (steel zincplated, philslot BHMS) 8 2 - printed circuit 7 - extended wire wrap 9 - 0.250” QC* 2 - flat base, barrier end 04 - brass, nickelplated, philslot BHMS 3 - insulator base** mount end Family 3 Covers - (pg 26) Terminal Style Base/End Poles Screw Options Options 3 - screw terminal (#6-32 screw top & bottom) 4 - insulator base, barrier end 02 to 16 4 - stud (#8-32 screw top, #6-32 stud bottom) 9 - insulator base, mount end Blank - standard L1 to L6 marking screw (steel zincoptions (pg 25) plated, philslot BHMS) Covers - (pg 26) 34** - #6-32 nickelplated brass philslot BHMS 8 5* - double stud (#6-32 stud top & bottom) *C360 Copper Alloy (bright tim plate) A38 Terminal Styles Inches (Millimeters) Wire ready screws standard B38 Terminal Styles Screw Options (Bulk ordering part numbers are in parentheses) 22 L1 to L6 marking options (pg 25) 07 - steel, SEMS zincplated philslot screw 4 - insulator base** barrier end B Options EATON www.eaton.com **Note: 34 screws only available with “3” terminal style Effective November 2019 Supersedes December 2017 Single Row Terminal Blocks Tools & resources • • • • Webpage Terminal block selector tool Terminal block cross reference Conatct us Eaton Electronics Division 1000 Eaton Boulevard Cleveland, OH 44122 United States Eaton.com/electronics © 2019 Eaton All Rights Reserved Printed in USA Publication No. 10682 — BU-MC19146 November 2019 Eaton is a registered trademark. All other trademarks are property of their respective owners. Follow us on social media to get the latest product and support information.
B383904
1. 物料型号: - A38: 30A, 600V - B38: 50A, 300V
2. 器件简介: - A38和B38是单排端子台,具有不同的电流和电压规格。
3. 引脚分配: - 中心间距为0.437英寸(11.10mm)。
4. 参数特性: - 电线范围:A38适用于#10-22 AWG铜线;B38适用于#8-16 AWG。 - 螺丝尺寸:#8-32镀锌钢螺丝。 - 扭矩等级:A38为9磅-英寸(对于#8),B38为15磅-英寸(对于#8),9磅-英寸(对于#6)。 - 基座:A38专用,标准间隔为0.378英寸(9.60mm)。 - 推荐PCB孔径(A38):0.076英寸(1.93mm)。 - 工作温度范围:最高105°C(221°F)至最低-40°C(-40°F)。 - 成型材料:黑色,UL等级94V0热塑性材料。 - 击穿电压:5000V。
5. 功能详解: - 提供了详细的安装端和带屏障端的尺寸数据。 - 描述了不同的端子样式和螺丝选项。
6. 应用信息: - 适用于多种接线需求,包括手焊、印刷电路板接线等。
7. 封装信息: - 提供了端子台的物理尺寸和安装数据。
8. 其他信息: - 包括Eaton的联系信息、社交媒体链接和版权声明。
B383904 价格&库存
很抱歉,暂时无法提供与“B383904”相匹配的价格&库存,您可以联系我们找货
