3050532E-SAG
3050532E-SAG
    LAIRD(莱尔德)
    FAB NICU NRSE CPSA RL
3050532E-SAG 数据手册
Nickel/Copper Nylon Ripstop With Conductive Adhesive Product No: 3050-532 Flectron® Nickel/Copper Nylon Ripstop with Conductive Adhesive is a unique fabric, manufactured using a patented, proprietary technology. Nylon Ripstop fabric is plated with highly conductive copper and corrosion resistant nickel. An anti-fray coating is applied to the fabric, then a conductive pressure sensitive adhesive (CPSA) is laminated to one side. Electrical Properties Physical Properties Property Units Substrate Nylon Ripstop Metal Weight Thickness, (nominal) Max Short Duration Temperature Value Ni/Cu oz./yd. 2 g/m. 2 Inches microns Advantage Property Strong, Flexible, Conformable Surface Resistivity (ASTM F390) Highly Conductive, Corrosion Resistant 200 MHz to 18 GHz 2.3 – 3.0 78 – 119 Light Weight 0.006 152 Thin and Flexible 200 C Allows Thermal Processing Far-field Shielding Units Value ohms/square < 0.07 Effectiveness (typical) dB >60 Mechanical Properties Property Tensile Strength, MD* (ASTM D5035) 180° Peel Strength (ASTM D3330) Units Value Lb./in 50 oz/inch width 30 * Machine Direction FLECTRON® Nickel/Copper Nylon Ripstop with CPSA can be used in many different configurations to protect against EMI/RFI and ESD in a variety of applications. Typical applications include: enclosures, cables, tapes, and grounding. NOTICE: Although the information and recommendations set forth herein (hereinafter "Information") are presented in good faith and believed to be correct as of the date hereof, Laird Technologies makes no representations as to the completeness or accuracy thereof. Information is supplied upon the condition that the persons receiving same will make their own determination as to its suitability for their purposes prior to use. In no event will Laird Technologies be responsible for damages of any nature whatsoever resulting from the use of or reliance upon information. Nothing contained herein is to be construed as a recommendation to use any product, process equipment or formulation in conflict with any patent, and Laird Technologies makes no representation or warrant y, express or implied, that the use there-of will not infringe any patent. NO REPRESENTATIONS OR WARRANTIES, EITHER EXPRESS OR IMPLIED, OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE OR OF ANY OTHER NATURE ARE MADE HEREUNDER WITH RESPECT TO INFORMATION OR THE PRODUCT TO WHICH INFORMATION REFERS.
3050532E-SAG 价格&库存
很抱歉,暂时无法提供与“3050532E-SAG”相匹配的价格&库存,您可以联系我们找货
