DISTANCE
MEASURER
Easy Measurements
• Length • Area
• Volume
• Indirect
• Continuous (Max/Min)
Excellent Accuracy
65' ±1/16"
(20 m) (1,6 mm)
93LDM65
Easily take single,
continuous
and cumulative
measurements
DISTANCE
MEASURER
The Klein Tools 93LDM65 Laser Distance Measurer easily calculates distance, area,
perimeter and volume up to 65 feet (20 m) using direct and indirect measurements
with an accuracy of +/- 1/16" (1.6 mm). It provides both imperial and metric
readings and takes single, continuous (Max/Min) and cumulative measurements.
Backlit Display
IP54
for easy viewing
in low light
LENGTH
Continuous
measurement
shows maximum and
minimum distance values
(when moving around)
Add/subtract
measurements
Measurement options
Length
Area
Volume
Pythagoras 2-Point
Pythagoras 3-Point
AREA
Power On/
Measurement
Memory storage
Device reference
point, Sound on/off
The last 20
measurements
will be displayed
toggles the measurement
reference point between
the top, bottom, and
depth gauge stick of
the tester
Backlight/
Unit of measure
toggle between
“ft+in” (feet and inches),
“in” (inches), “ft” (feet),
and “m” (meters)
Clear/Power Off
VOLUME
Depth gauge stick
(flips out)
to measure from inside
corners or channels
Included Accessories:
INDIRECT
(2 POINT/3 POINT)
Pouch & Batteries
Cat. No.
93LDM65
UPC# 0-92644+
93003-4
Batteries
2 x AAA
Height
4.5" (115 mm)
Width
2.0" (52 mm)
Depth
1.4" (32 mm)
Weight (oz.)
4.5 oz (118 g)
CAUTION: Laser radiation-Do NOT stare into beam. Class 2 laser product.
See our complete line of Measurement products
www.kleintools.com
© 2016 Klein Tools, Inc.
Lincolnshire, IL 60069-1418
96465 Rev. 09/16 A
很抱歉,暂时无法提供与“93LDM65”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+614.403441+79.84330
