BU-60 Series
(Uninsulated Steel Alligator Clips)
Mueller Electric’s BU-60 is the most common and versatile alligator clip. Compatible
with BU-62 and BU-62S high-temperature PVC insulators.
Overall length 1.96” (50.1mm), overall width 0.31” (7.9mm), maximum jaw spread =
0.31” (7.9mm)
Can be attached to wire via solder or crimp connection.
Ratings:
Current
10 Amps
The BU-60 is sold under the following models:
BU-60
Nickel-plated steel clip, compatible with 4mm banana plugs
BU-60HT
Zinc-plated steel BU-60, rated to 1100°F (593°C)
BU-60X
Stainless-steel BU-60 (including hardware)
BU-60BLACK
Black BU-60
BU-60G
Gold-plated steel BU-60
BU-60U
BU-60 with U-shaped barrel
BU-60TBO
BU-60 with 8-32 threaded barrel
BU-60PR2
BU-60 with phone tip/test prod tip connection
BU-60S
BU-60 with #6 screw for wire attachment
BU-60-ZZZN
Same as BU-60 with no screw hole, no wire strap
RoHS 3 compliant
Mueller Electric Company
2850 Gilchrist Rd. Bld 5A
Akron, OH 44305
www.muellerelectric.com
Toll Free: 800.955.2629
Phone: 330.780.2525
Fax: 330.780.2524
很抱歉,暂时无法提供与“JP-33699-L”相匹配的价格&库存,您可以联系我们找货
