电子发烧友
开通电子发烧友VIP会员 尊享10大特权
海量资料免费下载
精品直播免费看
优质内容免费畅学
课程9折专享价
69418
    KLEINTOOLS
    REPLACEMENTTESTLEADSET-STRA
69418 数据手册
Test & Measurement Crafted for optimum durability, reliability and functionality, our line of test and measurement equipment is engineered with the user in mind. Designed for, and by electricians, our electrical testers provide the latest in innovative, time-saving features that professionals require. Electrical Test & Measurement Tough Digital Clamp Meters SELECT: True RMS Instructions Measurement Packaging Technology Included: • Carrying case leads with CAT III/CAT IV safety • Test caps with adapter • Thermocouple (temperature-measuring models only) • Batteries • CAT IV 600V, CAT III 1000V, Class 2, Double insulaton safety rating • Built to withstand a 6.6 ft. (2 m) drop requirements for use in basic and controlled electromagnetic • Meets environments like residential, office and light-industrial locations Features CL600 CL700 CL800 6.6 ft. (2 m) 6.6 ft. (2 m) 6.6 ft. (2 m) IP40 IP40 IP40 CAT IV 600V CAT IV 600V CAT IV 600V AC Voltage (Volts) 1000V 1000V 1000V DC Voltage (Volts) 1000V 1000V 1000V AC Current (Amps) 600A 600A 600A DC Current (Amps) – – 600A Ohms (Resistance) 60MΩ 60MΩ 60MΩ – – – – – -14° – 1000°F (-26° – 538°C) -14° – 1000°F (-26° – 538°C) – – 6000 µF 6000 µF 1Hz – 500 KHz 1Hz – 500 KHz Available As Accessory Available As Accessory Available As Accessory – – 6000 6000 Drop Protection Ingress Protection Safety AC Millivolts DC Millivolts CL600 is an auto-ranging TRMS digital clamp meter that • The measures AC current via the clamp, and measures AC/DC voltage, • • resistance, continuity, and tests diodes via test leads The CL700 is an auto-ranging TRMS digital clamp meter that measures AC current via the clamp, and measures AC/DC voltage, resistance, continuity, frequency, capacitance, and tests diodes via test leads, and temperature via a thermocouple probe. It also features a Low Impedance (LoZ) mode for identifying and eliminating ghost or stray voltages The CL800 is an auto-ranging TRMS digital clamp meter that measures AC/DC current via the clamp, and measures AC/DC voltage, resistance, continuity, frequency, capacitance, and tests diodes via test leads, and temperature via a thermocouple probe. It also features a Low Impedance (LoZ) mode for identifying and eliminating ghost or stray voltages True RMS Audible Continuity Backlight Temperature Low Impedance Non-Contact Voltage Testing Auto Ranging Range Hold Data Hold Diode Test Capacitance Test Frequency / Duty Cycle Max / Min Magnetic Mount Worklight Auto-Power Off LCD Display Count 208 www.kleintools.com Specifications are subject to change. See page 310 for additional information on warnings. See warning section on page 208 for important safety information regarding clamp meters 6000 CL Electrical Test & Measurement 0 20 AC TO AU A Digital Clamp Meters NEW! Included: Carrying case Test leads with CAT III/CAT IV safety caps Thermocouple (temperature-measuring models only) Batteries • • • • Features Drop Protection CL110 CL210 CL310 CL330 3.3 ft. (1 m) 3.3 ft. (1 m) 3.3 ft. (1 m) 3.3 ft. (1 m) – – – – CAT III 600V CAT III 600V CAT III 600V CAT III 600V AC Voltage (Volts) 600V 600V 600V 600V DC Voltage (Volts) 600V 600V 600V 600V AC Current (Amps) 400A 400A 400A 400A DC Current (Amps) – – – – Ohms (Resistance) 20MΩ 20MΩ 40MΩ 40MΩ – – Ingress Protection • CAT III 600V, Class 2, Double insulation safety rating • Backlit display for clear readings • Low battery indicator and easily accessible battery compartment requirements for use in basic and controlled • Meets electromagnetic environments like residential, office and light• industrial locations Built to withstand a 3.3 ft. (1 m) drop CL110 is an auto-ranging digital clamp meter that measures • The AC current via the clamp, and AC/DC voltage, resistance and • • continuity via test leads The CL210 is an auto-ranging digital clamp meter that measures AC current via the clamp, AC/DC voltage, resistance and continuity via test leads, and temperature via a thermocouple probe The CL310 is an auto-ranging True Root-Mean-Squared (TRMS) digital clamp meter that measures AC current via the clamp, AC/DC voltage, resistance, continuity, frequency, capacitance, and tests diodes via test leads, and temperature via a thermocouple probe Safety AC Millivolts DC Millivolts True RMS Backlight – – – -40° – 1832°F -40° – 1832°F -40° – 1832°F (-40° – 1000°C) (-40° – 1000°C) (-40° – 1000°C) – – – – – – – – – – – – 4000 µF 4000 µF 10Hz – 1MHz 10Hz – 1MHz MAX only MAX only – – – – – – – – LCD Display Count 2000 2000 4000 – OLED Display Count – – – – – – 4000 Low Impedance High-Visibility Display – Audible Continuity Temperature NEW – Non-Contact Voltage Testing Auto Ranging Range Hold Data Hold Diode Test Capacitance Test Frequency / Duty Cycle Max / Min CL330 is an auto-ranging True Root-Mean-Squared (TRMS) • The digital clamp meter that measures AC current via the clamp, AC/DC voltage, resistance, continuity, frequency, capacitance, and tests diodes via test-leads, and temperature via a thermocouple probe. It features a super bright high visibility dual-line OLED display screen that optimizes viewability in dark or bright environments and when viewed at indirect angles Magnetic Mount Worklight Auto-Power Off Bar Graph Specifications are subject to change. See page 310 for additional information on warnings. See warning section on page 208 for important safety information regarding clamp meters 209 www.kleintools.com Electrical Test & Measurement Clamp Meters Clamp Meter Specifications Cat. No. CL110 Safety Rating CAT III 600V Batteries 3 x AAA Jaw Size 1-1/8" (28.6 mm) Height 8-45/64" (221.1 mm) Width 3-1/64" (76.6 mm) Depth 1-39/64" (40.9 mm) Weight 10.1 oz. (286 g) CL210 CAT III 600V 3 x AAA 1-1/8" (28.6 mm) 8-45/64" (221.1 mm) 3-1/64" (76.6 mm) 1-39/64" (40.9 mm) 10.1 oz. (286 g) CL310 CAT III 600V 3 x AAA 1-1/8" (28.6 mm) 8-45/64" (221.1 mm) 3-1/64" (76.6 mm) 1-39/64" (40.9 mm) 10.1 oz. (286 g) CL330 NEW! CATIII 600V, Class 2, 3 x AAA Double insulation 1-1/8" (28.6 mm) 8-21/32" (219.9 mm) 3-1/32" (77.0 mm) 1-39/64" (40.9 mm) 9.9 oz. (281 g) CL600 CAT IV 600V 2 x AAA 1-3/8" (34.9 mm) 9-3/32" (231.0 mm) 3-13/16" (96.8 mm) 1-35/64" (39.3 mm) 11.8 oz. (335 g) CL700 CAT IV 600V 2 x AAA 1-3/8" (34.9 mm) 9-3/32" (231.0 mm) 3-13/16" (96.8 mm) 1-35/64" (39.3 mm) 11.8 oz. (335 g) CL800 CAT IV 600V 2 x AAA 1-3/8" (34.9 mm) 9-3/32" (231.0 mm) 3-13/16" (96.8 mm) 1-35/64" (39.3 mm) 12.5 oz. (354 g) Included Accessories Carrying Case, 41" (1041.4 mm) Test Leads and Batteries Carrying Case, 41" (1041.4 mm) Test Leads, Thermocouple with Adapter, and Batteries Carrying Case, 41" (1041.4 mm) Test Leads, Thermocouple with Adapter, and Batteries Pouch, 41" (1041.4 mm) Test Leads, Thermocouple, and Batteries Carrying Case, 41" (1041.4 mm) Test Leads and Batteries Carrying Case, Test Leads, Thermocouple with Adapter, and Batteries Carrying Case, 41" (1041.4 mm) Test Leads, Thermocouple with Adapter, and Batteries Electrical Maintenance & Test Kit No. RT210 detects the most common wiring problems in standard and GFCI receptacles • Cat. including open ground, reverse polarity, open hot, open neutral, and hot/ground reversed No. 69409 Line splitter 10x allows the measuring of current draw up to 15A without splitting • Cat. the load's power cord No. CL110 has CAT III 600V, Class 2, Double insulation safety rating and features a backlit • Cat. display for clear readings • RT210 withstands a 6.6 ft. (2 m) • Includes a carrying case, test leads and batteries 8ZX5 Cat. No. Kit Contains CL110KIT Cat. No. Batteries Height Width CL110 3 x AAA 8-45/64" (221.1 mm) 3-1/64" (76.6 mm) RT210 N/A 2-7/8" (73.0 mm) 1-7/8" (47.6 mm) 69409 N/A 4-43/64" (118.7 mm) 2-9/32" (57.9 mm) For additional specifications see individual product pages (CL110 - page 207, RT210 - page 215, 69409 - page 219). Weight 15.1 oz. (428 g) Depth 1-39/64" (40.9 mm) 1-5/8" (41.3 mm) 1" (25.4 mm) CL110KIT WARNINGS: To ensure safe operation and service of the tester, follow these instructions. Failure to observe these warnings can result in severe injury or death. • • • • • • • • • • Before each use, verify meter operation by measuring a known voltage or current. Never use the meter on a circuit with voltages that exceed the category based rating of this meter. Do not use the meter during electrical storms or in wet weather. Do not use the meter or test leads if they appear to be damaged. Ensure meter leads are fully seated, and keep fingers away from the metal probe contacts when making measurements. Do not open the meter to replace batteries while the probes are connected. Use caution when working with voltages above 60V DC, or 25V AC RMS. Such voltages pose a shock hazard. To avoid false readings that can lead to electrical shock, replace batteries if a low battery indicator appears. Unless measuring voltage or current, shut off and lock out power before measuring resistance or capacitance. Always adhere to local and national safety codes. Use individual protective equipment to prevent shock and arc blast injury where hazardous live conductors are exposed. 210 www.kleintools.com See page 310 for additional information on warnings. CL Electrical Test & Measurement 0 20 AC TO AU A Specialty Clamp Meters 1000A AC/DC TRMS Clamp MeterSELECT: Instructions (CL2500) Packaging wide jaw opening accommodates a greater • Extra measuring area • True RMS accurate readings for all signals • Worklight in jaw area Features CL2500 1000A AC/DC CL3200 200A AC Fork Meter 3.3 ft. (1 m) 3.3 ft. (1 m) IP42 IP30 CAT IV 600V CAT IV 600V AC Voltage (Volts) 750A 750A DC Voltage (Volts) 1000V 1000V AC Current (Amps) 1000A 200A DC Current (Amps) 1000A – Ohms (Resistance) 60MΩ 40MΩ Drop Protection Ingress Protection Safety 45ZK – True RMS Audible Continuity Backlight 200A AC Fork Meter (CL3200) • Extra large jaw opening accepts 3/0 wire • Short jaw depth for increased access in tight spaces • Worklight by jaw illuminates work space – Low Impedance Non-Contact Voltage Testing – Auto Ranging Range Hold Data Hold Diode Test 45ZK Capacitance Test 6000µF Frequency / Duty Cycle Max / Min – – – – Magnetic Mount Worklight Auto-Power Off Bar Graph LCD Display Count Cat. No. NIST certified Safety Rating Batteries CL2500 ​ — CAT IV 600V 2 x AAA CL3200 — CAT IV 600V 2 x AAA Jaw Size 1.97" (50.03 mm) 0.63" (16 mm) Height 8.09" (205.48 mm) 7.06" (179.32 mm) Width 2.56" (65.02 mm) 2.56" (65.02 mm) Specifications are subject to change. See page 310 for additional information on warnings. See warning section on page 208 for important safety information regarding clamp meters Depth 1.38" (35.05 mm) 1.34" (34.03 mm) 6000 Weight 13.6 oz. (386 g) 7.9 oz. (224 g) 4000 Included Accessories Test Leads, Case and Batteries Test Leads, Case and Batteries 211 www.kleintools.com Electrical Test & Measurement Tough Digital Multimeters Features MM600 MM700 6.6 ft. (2 m) 6.6 ft. (2 m) IP42 IP42 CAT IV 600V CAT IV 600V AC Voltage (Volts) 1000V 1000V DC Voltage (Volts) 1000V 1000V AC Current (Amps) 10A 10A DC Current (Amps) 10A 10A Ohms (Resistance) 40MΩ 40MΩ Drop Protection Included: Carrying case Test leads with CAT III/CAT IV safety caps Alligator clips Thermocouple with adapter Batteries • • • • • Ingress Protection Safety DC Millivolts • Backlit LCD display screen • CAT IV 600V safety rating • Built to withstand a 6.6' (2 m) drop use in basic and controlled electromagnetic environments like • For residential, office and light-industrial locations battery indicator and easily accessible battery and fuse • Low replacement compartment AC Milliamps DC Milliamps AC Microamps DC Microamps True RMS – Audible Continuity MM600 is an auto-ranging digital multimeter that measures AC/DC • The voltage, AC/DC current, and resistance. It also measures temperature, • capacitance, frequency, duty-cycle, tests diodes and continuity The MM700 is an auto-ranging True Root-Mean-Squared (TRMS) digital multimeter that measures AC/DC voltage, AC/DC current, and resistance. It also measures temperature, capacitance, frequency, dutycycle, and tests diodes and continuity Backlight Temperature Low Impedance 0° – 1000°F (-18° – 538°C) 0° – 1500°F (-18° – 816°C) – Auto Ranging Range Hold Data Hold Diode Test Capacitance Test Frequency / Duty Cycle 1000 μF 4000 μF 1Hz – 500 KHz 1Hz – 500 KHz Max / Min Lead Warning Bar Graph Magnetic Mount – Available As Accessory Available As Accessory – – 4000 4000 Auto-Power Off Battery Test LCD Display Count 212 www.kleintools.com Specifications are subject to change. See page 310 for additional information on warnings. See warning section on page 212 for important safety information regarding multimeters CL Electrical Test & Measurement 0 20 AC A Features Drop Protection MM400 Auto Ranging 3.3 ft. (1 m) 3.3 ft. (1 m) – – CAT III 600V AC Voltage (Volts) 600V 600V DC Voltage (Volts) 600V 600V AC Current (Amps) – 10A DC Current (Amps) 10A 10A Ohms (Resistance) 20MΩ 40MΩ Safety • • • MM300 Manual Ranging CAT III 600V Ingress Protection Included: Test leads with CAT III/CAT IV safety caps Thermocouple with adapter (temperature-measuring models only) Batteries TO AU Digital Multimeters DC Millivolts AC Milliamps • CAT III 600V safety rating • Built to withstand a 3.3 ft. (1 m) drop use in basic and controlled electromagnetic environments like • For residential, business and light-industrial locations • Low battery indicator and easily accessible battery compartment – DC Milliamps AC Microamps – DC Microamps True RMS – – Audible Continuity MM300 is a manual-ranging digital multimeter that measures • The AC/DC voltage, DC current, and resistance. It also tests diodes and • continuity, and has a battery test mode The MM400 is an auto-ranging digital multimeter that measures AC/DC voltage, AC/DC current, and resistance. It also measures temperature, capacitance, frequency, duty-cycle, and tests diodes and continuity Backlight Temperature Low Impedance Auto Ranging Range Hold – – – – – 0° – 1000°F (-18° – 538°C) – Data Hold Diode Test Capacitance Test Frequency / Duty Cycle Max / Min Lead Warning Bar Graph – – – – – Magnetic Mount Available As Accessory Auto-Power Off – Specifications are subject to change. See page 310 for additional information on warnings. See warning section on page 212 for important safety information regarding multimeters 1Hz – 50 KHz – – Available As Accessory – Battery Test LCD Display Count 200 μF 2000 4000 213 www.kleintools.com Electrical Test & Measurement Multimeters Multimeter Specifications Cat. No. MM300 MM400 MM600 MM700 Safety Rating CAT III 600V CAT III 600V CAT IV 600V CAT IV 600V Batteries 2 x AAA 2 x AAA 2 x AAA 2 x AAA Height 6" (152.4 mm) 6" (152.4 mm) 7" (177.8 mm) 7" (177.8 mm) Width 3-1/6" (77.8 mm) 3-1/6" (77.8 mm) 3-35/64" (90.1 mm) 3-35/64" (90.1 mm) Depth 1-25/32" (45.2 mm) 1-25/32" (45.2 mm) 2-3/32" (53.2 mm) 2-3/32" (53.2 mm) Weight 8.1 oz. (230 g) 8.1 oz. (230 g) 14.4 oz. (408 g) 14.4 oz. (408 g) Included Accessories Test Leads and Batteries Test Leads, Batteries and Thermocouple Carrying Case, Test Leads, Thermocouple, and Batteries Carrying Case, Test Leads, Thermocouple, Batteries, and Alligator Clips Multimeter Replacement Fuses 69033 Cat. No. 69191 69192 69193 69194 For Use With MM1000, MM1300, MM2000, MM2300, MM6000 MM1000, MM1300, MM2000, MM2300, MM6000 MM100 Fuse Kit MM200 Fuse Kit 69192 Fuse Type F 11A/1000V F 440mA/1000V F10A/500V, F250mA/250V F10A/500V, F400mA/250V New Test and Measurement Instruments 69031 69032 69033 69034 69035 MM300 MM300, MM400 MM400 MM600, MM700 MM600, MM700 5x20 200MA 600V 6x32 10A 600V 5x20 500MA 600V 10x38 10A 1000V 6x32 500MA 1000V Electrical Test Kit MM300 multimeter was developed to withstand daily wear and tear on the • The job site, and has a safey rating of CAT III 600V, Class 2, Double insulation NCVT-1 has a bright green LED to indicate the tester is working; it changes to • The red and warning tones sound when voltage is detected has a digitally-controlled ON/OFF power button and auto power-off • NCVT-1 feature to conserve and extend battery life tester detects wiring configurations and indicates correct wiring, open • Receptacle ground, open hot, open neutral, hot/ground reversed; it does not indicate quality of ground, multiple hot wires, or a combination of defects • Includes visual and audible continuity indicators up to 25Ω • Includes test leads and batteries 8ZX5 Cat. No. Set Contains 69149 Cat. No. Batteries Height Width Depth MM300 2 x AAA 6" (152.4 mm) 3-1/6" (77.8 mm) 1-25/32" (45.2 mm) 23/32"(18.3 mm) 1" (25.4 mm) NCVT-1 2 x AAA 1" (25.4 mm) 23/32"(18.3 mm) Receptacle testor N/A 2.75" (69.9 mm) 1.5" (38.1 mm) For additional specifications see individual product pages (MM300 - page 211, NCVT-1 - page 214) Weight 15.1 oz. (428 g) 69149 WARNINGS: To ensure safe operation and service of the tester, follow these instructions. Failure to observe these warnings can result in severe injury or death. • • • • • • • • • • Before each use, verify meter operation by measuring a known voltage or current. Never use the meter on a circuit with voltages that exceed the category based rating of this meter. Do not use the meter during electrical storms or in wet weather. Do not use the meter or test leads if they appear to be damaged. Ensure meter leads are fully seated, and keep fingers away from the metal probe contacts when making measurements. Do not open the meter to replace batteries while the probes are connected. Use caution when working with voltages above 60V DC, or 25V AC RMS. Such voltages pose a shock hazard. To avoid false readings that can lead to electrical shock, replace batteries if a low battery indicator appears. Unless measuring voltage or current, shut off and lock out power before measuring resistance or capacitance. Always adhere to local and national safety codes. Use individual protective equipment to prevent shock and arc blast injury where hazardous live conductors are exposed. 214 www.kleintools.com See page 310 for additional information on warnings. CL Electrical Test & Measurement 0 20 AC TO AU A Electrical Testers Electronic Voltage Testers • Measures AC and DC voltage at nine common levels up to 600V • Bright LEDs indicate voltage reading without batteries installed • Low impedance input reduces possibility of ghost voltages secured test leads are always there when • Permanently they are needed lead holders are perfect for easy • Molded measurements of tamper-proof outlets • Probe wires with wear indicators built in • Vibration and sound alerts for dangerous voltage levels solid-state construction provides • Modern CAT IV 600V safety rating • Bright light illuminates work area • Audible continuity alerts at less than 270kΩ ET200 4000907 Cat. No. ET200 Safety Rating CAT IV 600V Batteries 3 x AAA Height 7-3/8" (187.32 mm) Width 2-3/8" (60.32 mm) Depth 1-1/4" (31.75 mm) Weight 8.1 oz. (230 g) Digital Circuit Breaker Finder accurately, and automatically find the corresponding • Quickly, circuit breaker of any standard 120V outlet • For use on powered circuits only • Does not require interruption of service green arrow and loud beep provide clear indication of • Bright correct breaker • Strong transmitter reaches distances up to 1000 ft. (305 m) Circuit Breaker Finder Accessory Kit (Cat. No. • Optional 69411) refer to page 218: Find breakers of light fixtures and bare wires with light socket and alligator clip adapters ET300 4000907 Cat. No. ET300 Height Receiver: 6" (152.4 mm) Transmitter: 2-51/64" (71.0 mm) See page 310 for additional information on warnings. Width Receiver: 2" (50.8 mm) Transmitter: 1-57/64" (48.0 mm) Depth Receiver: 57/64" (22.6 mm) Transmitter: 1-13/64" (30.6 mm) Weight Receiver: 3.2 oz. (91 g) Transmitter: 1.6 oz. (45 g) 215 www.kleintools.com Electrical Test & Measurement Electrical Testers Non-Contact Voltage Testers (NCVT-1/NCVT-2) detection of standard voltage (48-1000V AC) in cables, cords, • Non-contact circuit breakers, lighting fixtures, switches, outlets, and wires intensity, bright green LED indicates the tester is operational and aids in • High illuminating the workspace • Microprocessor controlled low-battery indicator • Digitally controlled ON/OFF power button • Auto Power-Off feature conserves and extends battery life durable polycarbonate plastic resin construction with a • Lightweight, convenient pocket-clip • 9.8 ft. (3 m) drop protection • CAT IV 1000V safety rating provides expanded operation and protection • Does NOT detect DC voltage NCVT-1 Additional Features for Dual Range NCVT-2 detects and indicates low voltage (12 - 48 Volts AC) and • Automatically standard voltage (48 - 1000 Volts AC), allowing broad application detection of low-voltage in security, entertainment, • Non-contact communications, environmental control, and irrigation systems NCVT-2 Voltage Range 12 - 48 VOLTS AC (Low) NCVT-2 only 50 - 1000 VOLTS AC (Standard) Audible low-pitched pulsing beeping sound high-pitched continuous beeping sound Visual blue LED turns off and red LED blinks (approximately 2x per second). green LED turns off and red LED illuminates continuously. Cat. No. NCVT-1 NCVT-2 Voltage Range 50 - 1000V AC 12 - 1000V AC Frequency Range Pollution Degree 50 - 500 Hz 2 50 - 500 Hz 2 3TMV Batteries 2 x AAA 2 x AAA Overall Length 5-1/2" (139.7 mm) 5-1/2" (139.7 mm) Width 23/32"(18.3 mm) 23/32"(18.3 mm) Height 1" (25.4 mm) 1" (25.4 mm) Weight 0.8 oz (23 g) 0.8 oz (23 g) Weight w/Batteries 1.6 oz. (45 g) 1.6 oz. (45 g) Non-Contact Voltage Tester with Flashlight (NCVT-3) detection of voltage (12 - 1000V AC) in cables, cords, circuit breakers, • Non-contact light fixtures, switches, outlets and wires as well as voltage in security, entertainment, communications, environmental control and irrigation systems visual indicator of the presence of voltage is an LED bar graph - the higher the • The voltage sensed, or the closer to the voltage source, the more LEDs light up • Bright flashlight illuminates work area and may be used independent of NCVT • Auto Power-Off feature conserves and extends battery life • Lightweight, compact tool with pocket clip provides easy storage and quick access • IP67: Dustproof and waterproof • 6.6 ft. (2 m) drop protection • CAT IV 1000V safety rating • Does NOT detect DC voltage Cat. No. Voltage Range NCVT-3 12 - 1000V AC Frequency Range Pollution Degree 50 - 500 Hz 2 216 www.kleintools.com Batteries 2 x AAA Overall Length 5-53/64" (148.0 mm) NCVT-3 24V 120V ~2" (~51 mm) Width 23/32"(18.3 mm) Height Weight Weight w/Batteries 5-7/8" (149.2 mm) 1.2 oz. (34 g) 2.5 oz. (71 g) See page 310 for additional information on warnings. CL Electrical Test & Measurement 0 20 AC TO AU A Electrical Testers Receptacle Testers • Light sequence indicates correct/incorrect wiring • Conforms to UL Std 1436, Certified to CSA Std C22.2 #160 • Operating temp: 32°F to 140°F (0°C to 40°C) • Built to withstand a 6.6 ft. (2m) drop • Nominal Voltage: 110/125V AC at 50/60Hz in 3-wire outlet • Designed to detect the most common wiring problems in standard receptacles • Cat. No. RT210 works on GFCI outlets and confirms operation of the ground fault Cat. No. RT110 RT210 GFCI No Yes Height 2-7/8" (73.0 mm) 2-7/8" (73.0 mm) Width 1-7/8" (47.6 mm) 1-7/8" (47.6 mm) Depth 1-5/8" (41.3 mm) 1-5/8" (41.3 mm) Weight 2.0 oz. (57 g) 2.0 oz. (57 g) RT110 Continuity Tester RT210 Low-Voltage Tester 69133 • • • • • • • • Cat. No. 69133 Overall Length 43-3/4" (111.3 mm) Weight 0.2 oz. (5.7 g) replacement bulb for Cat. No. 69133 0.04 oz. (1.1 g) • • • • • Overall Length 43-1/4" (1098.6 mm) Weight 0.2 oz. (5.7 g) ​replacement bulb for Cat. No. 69127 0.01 oz. (0.3g) Replacement Part 69130 Circuit Tester 69105 • Tests circuits rated from 80 to 600 volts AC/DC • High-visibility neon lamp indicator sealed 5-11/16" (144 mm) probe on long 24" (610 mm) • High-impact, leads for convenience in testing motors, fuses, relays, switches, etc. • Resistor between each probe and lead Cat. No. 69105 Device for checking live 6-24V, AC or DC circuits Tests for shorts in automotive and truck electrical systems, motor field coils, radio and low-voltage circuits, ground circuits of all lamps, wiring, fuses, etc. Bulb in handle glows when circuit is complete (bulb included) Pointed 3-3/4" (95 mm) probe makes checking easier Deluxe 3-1/2" (89 mm) long handle with nylon top holds replaceable bulb 36" (915 mm) test lead with alligator clip Proudly built in U.S.A. with global components Cat. No. 69127 Replacement Part 69131 69127 • • Quickly reveals shorts or broken circuits in all types of electrical devices and controls Tests for continuity of circuit with power off Bulb in handle glows when circuit is complete (bulb included) Pointed 3-3/4" (95 mm) probe gets right to the problem Deluxe 4" (102 mm) long handle with removable nylon cap holds replaceable bulb and battery 36" (915 mm) test lead with alligator clip Uses one AAA battery (not included) Proudly built in U.S.A. with global components Overall Length with Probes 35" (889.0 mm) See page 310 for additional information on warnings. Weight 2.4 oz. (68 g) Low-Voltage Twin-Lead Tester • Tests 5-50 volt, AC or DC circuits and components • Built-in lamp glows if circuit is live • Each of the 4-1/2" (114 mm) test leads has an alligator clip on the end • Handy pocket clip 69134 Cat. No. 69134 Overall Length 8" (203.2 mm) Weight 0.08 oz. (2.3 g) 217 www.kleintools.com Electrical Test & Measurement Specialty Testers IR5 Dual Laser Infrared Thermometer • Optical Resolution (Distance-to-spot) is 12:1 include dual-laser targeting, auto-scan, max/min/avg/diff, high/low • Features alarm, backlit display, auto power-off • Drop protection to 6.6 ft. (2 m) • Measurement Range: -22° to 752°F (-30° to 400°C) one 9-volt battery, with battery life expectancy at 10 hours of • Uses continuous use with laser and backlight on • Includes custom pouch and batteries • Certified to IEC EN 61326-1:2006, EN608251:1994+A2:2001+A1:2002 • Adjustable emissivity • Soft-touch, over-mold housing ambient temperatures above freezing, the accuracy is +/- 4° F or +/- 2%; • For Accuracy below freezing is +/- 4° F plus 0.2 degrees per degree below 32° F NEW! Diameter at Spot 0.5" (13 mm) 1" 2" (25 mm) 4" (51 mm) (102 mm) IR5 6" (152 mm) 12" (305 mm) 24" (610 mm) 48" (1219 mm) Distance to Object Cat. No. NEW! IR5 Batteries 1 x 9V Height 6-53/64" (173.4 mm) Width 1-27/32" (46.9 mm) 12:1 Dual Laser Infrared Thermometer • Dual lasers for specific measurement areas • Tight (12:1) distance-to-spot ratio for accurate target area temperature measurements • Features a wide temperature measurement range: -76° to 1022°F (-60° to 550°C) • K-type thermocouple range: -83.2° to 2552°F (-64° to 1400°C) • Auto-scan and Max / Min / Average / Differential calculations • Includes a temperature °F/°C button • Has both a backlit display and worklight • 6.6 ft. (2 m) drop protection • Accessories included: case, K-type thermocouple and batteries Weight 9.8 oz. (278 g) Diameter at Spot 0.5" 60° vent Depth 4-17/32" (115.1 mm) (13 mm) 1" (25 mm) 2" 4" (51 mm) (102 mm) 60° Dual laser targeting for more specific measurement area gives an accurate reading. 6" (152 mm) IR2000A 12" (305 mm) 24" (610 mm) 48" (1219 mm) Distance to Object Cat. No. IR2000A Batteries 2 x AAA 218 www.kleintools.com Height 6.76" (171.70 mm) Width 1.87" (47.49 mm) Thickness 1.87" (47 mm) Weight 9.0 oz. (255 g) See page 310 for additional information on warnings. CL Electrical Test & Measurement 0 20 AC TO AU A Specialty Testers Video Borescope • Use the Video Borescope to view inaccessible areas features video, audio, photo recording, file playback, a • Itdurable camera snake with an adjustable work light, and video output capabilities features include screen rotation, adjustable LED • Other worklight, TV-out and SD card • IP67: Dustproof and waterproof camera Applications: Electrical, HVAC, Plumbing, • Multiple Automotive, Aircraft. Use to view inaccessible areas: inside • Multiple Applications! a wall, down the drain, in furnace or vent Package contents: Video Borescope, 17 mm gooseneck camera, Rechargeable lithium ion battery, Mirror camera attachment, Hook camera attachment, Magnet camera attachment, USB data & power adapter/charger, RCA composite to 3.5 mm mini A/V cable, Quick start guide, Software/instruction manual CD-ROM, Carrying case • Electrical • HVAC • Plumbing • Automotive • Aircraft to view • Use inaccessible areas: - Inside a wall - Down the drain - In furnace or vent Video Borescope ET500 ET500 Cat. No. ET500 Batteries 2 x AAA Height 7" (177.8 mm) Width 3-1/4" (82.6 mm) Depth 1-3/4" (44.5 mm) Weight 8.1 oz. (230 g) Borescope • Use the borescope to view inaccessible areas a durable camera snake, a high resolution screen, mirror image • Itandfeatures an adjustable LED work light • IP67: Dustproof and waterproof camera Applications: Electrical, HVAC, Plumbing, Automotive, Aircraft. Use • Multiple to view inaccessible areas: inside a wall, down the drain, in furnace or vent contents: Borescope, 17 mm gooseneck camera, Rechargeable • Package lithium ion battery, Mirror camera attachment, Hook camera attachment, Magnet camera attachment, USB data adapter/charger, USB power adapter/ charger, Instruction manual ET510 Borescope ET510 Multiple Applications! • Electrical • HVAC • Plumbing • Automotive • Aircraft Cat. No. ET510 Batteries Lithium-ion See page 310 for additional information on warnings. Height 6-17/32" (165.9 mm) Width 2-27/32" (72.2 mm) Depth 1-35/64" (39.3 mm) to view • Use inaccessible areas: - Inside a wall - Down the drain - In furnace or vent Weight 8.1 oz. (230 g) 219 www.kleintools.com Electrical Test & Measurement Test & Measurement Line Accessories Circuit Breaker Finder Accessory Kit Test Lead Set • Each lead has alligator clips attached to both ends • Multi-purpose tooth pattern for better gripping of wires and test points 69411 • For use with ET300 Digital Circuit Breaker Finder refer to page 213 socket adapter for finding the corresponding circuit of a • Light lighting fixture clip adapter enables use of Digital Circuit Breaker Finder • Alligator on bare wires Cat. No. 69411 69128 Weight 2.1 oz. (60 g) Cat. No. 69128 Overall Length 32" (812.8 mm) Weight 6.4 oz. (181.4 g) Replacement Test Lead Sets • Safety Rating: Category IV 600V and CAT III 1000V • Screw-on alligator clips attach to wires and other conductors for use as replacement test leads for meters that have • Intended standard, banana-type input jacks • Leads are 41" (1,041 mm) long No. 69410 replacement test-lead set for MM300, MM400, • Cat. MM600 and MM700 No. 69418 replacement test-lead set for CL110, CL210, • Cat. CL310, CL600, CL700 and CL800 leads perform accurately with Klein Tools' meters and • The other manufacturer's meters Cat. No. 69410 69418 Overall Length 41" (1041.4 mm) 41" (1041.4 mm) Weight 3.2 oz. (91 g) 3.4 oz. (96 g) 69410 69418 Replacement K-Type Thermocouples UL listed replacement thermocouple (Cat. No. 69028) is for use with • This Klein Tools multimeters and clamp meters as shown on list below • Temperature measurement range is 0-250˚ Celsius • Leads compatible with and fit lead storage compartments on most Klein meters ® 69028 Cat. No. Type 69028 K-Type Banana Thermocouple 69413 69414 K-Type Thermocouple DTL K-Type Thermocouple 220 www.kleintools.com Multimeter MM200, MM400, MM600, MM700, MM1000, MM1300, MM2000, MM2300, MM6000 ​— ​— Clamp Meter CL200, CL210, CL310, CL330, CL700, CL800 CL1300, CL2300 CL1100, CL2100 ​— 69413 IR Gun DTL ​— ​— IR2000, IR2000A, IR3000 ​— ​— DTL302, DTL304 69414 Weight 0.7 oz. (20 g) 0.2 oz. (5.7 g) 0.2 oz. (5.7 g) See page 310 for additional information on warnings. CL Electrical Test & Measurement 0 20 AC 17 mm Borescope Camera • IP67: Dustproof and waterproof camera • Bright LED worklight • Gooseneck design for greater control and positioning • Smaller footprint when penetrating walls and panels Cat. No. 69450 69451 A 6 mm Borescope Camera TO AU Test & Measurement Line Accessories Dimensions 6 mm x 1 m (0.23" x 3.28') 6 mm x 2 m (0.23" x 6.56') • IP67: Dustproof and waterproof camera • Bright LED worklight • Gooseneck design for greater control and positioning 69450 Weight 3.5 oz. (99 g) 5.5 oz. (156 g) Cat. No. 69454 1 Meter Borescope Camera Extension Dimensions 17 mm x 1 m (0.66" x 3.28') 69454 Weight 9.5 oz. (269 g) Borescope Attachment Tools • Compatible with 17 mm diameter camera 69455 • • • Extends the reach of 17 mm and 6 mm borescope cameras Up to two extensions can be used with 17 mm camera without loss of video quality, to 9.9 ft. (3 m) Maximum of four extensions plus camera Cat. No. 69455 Dimensions 17 mm x 1 m (0.66" x 3.28') 69457 Cat. No. Weight Included 69457 0.4 oz. (11.0 g) 1-5/8" (41.3 mm) Mirror Camera Attachment, 3" (76.2 mm) Hook Camera Attachment, 3-1/4" (82.6 mm) Magnet Camera Attachment Weight 9.3 oz. (264 g) Line Splitter 10x • Allows the measuring of current draw up to 15A without splitting the load's power cord • For use with all Klein Tools clamp meters and othe manufacture clamp meters • Can be used to perform voltage checks with standard multimeter probes • Provides 10X measurement mode • For North American-style outlets only WARNINGS: • Do NOT use with loads greater than 15A. • Risk of electric shock and burn. Contact with live circuits could result in death or serious injury. • Do not use if line splitter appears damaged. If in doubt, replace line splitter. Do NOT use line splitter if wet. For indoors use only. Cat. No. 69409 Height 4-43/64" (118.7 mm) Width 2-9/32" (57.9 mm) See page 310 for additional information on warnings. Depth 1" (25.4 mm) Weight 3.9 oz. (111 g) 69409 221 www.kleintools.com Electrical Test & Measurement Test & Measurement Line Accessories Magnetic Hangers • Durable nylon weave resists wear and tear • Constructed with powerful rare earth magnets • Has a secure loop & hook • Hanger allows the user to safely work hands-free • Cat. No. 69190 clips securely into back of rubber boot Cat. No. 69417 Application Electrician's Multimeters and Select Clamps 69190 Electrician's Previous Generation Multimeters For Use With MM300, MM400, MM600, MM700, CL600, CL700, CL800 MM1000, MM1300, MM2000, MM2300 Weight 1.1 oz. (31 g) 1.1 oz. (31 g) 69417 69190 Tradesman Pro™ Hard Cases • Hard shell protects tools, meters, small parts and tech devices • Soft interior lining • Durable zipper closure Cat. No. 5184 5189 Width 6-1/2" (165.1 mm) 5-1/2" (139.7 mm) Height 8-3/4" (222.3 mm) 10-1/4" (260.4 mm) Depth 2-1/4" (57.2 mm) 2-1/4" (57.2 mm) Weight 10.1 oz. (286 g) 10.1 oz. (286 g) 5184 5189 Tradesman Pro™ Carrying Cases • Two layers of padding protect even delicate instruments • Heavy-duty zipper and rugged PVC coated polyester for durability • Pockets for quick access and organization • Cat. No. 69406 has loop with snap closure to attach to belts, bags and backpacks Nos. 69407 and 69408 have sturdy handle with box stitching for secure transportation • Cat. and convenient hanging • Cat. Nos. 69406 and 69407 recommended for meters, testers, infrared guns, and small tools • Cat. No. 69408 recommended for meters, testers, infrared guns, tools, and borescopes Cat. No. 69406 69407 69408 Pockets 1 2 2 Width 4-1/2" (114.3 mm) 6" (152.4 mm) 7" (177.8 mm) Height 9-1/4" (235.0 mm) 10-1/4" (260.4 mm) 10-1/4" (260.4 mm) Depth 2-1/4" (57.2 mm) 2-1/4" (57.2 mm) 2-1/4" (57.2 mm) Weight 6.1 oz. (173 g) 8.5 oz. (240 g) 10.6 oz. (299 g) 69406 69407 69408 Carrying Case • Constructed of black 600 Denier Nylon • Has a heavy-duty PVC zipper and zinc alloy zipper tag • The case has exceptional resistance to abrasions, punctures and tears fits the following Klein Tools test and measurement meters: MM300, MM400, • Easily MM600, MM700, CL110, CL210, CL310, CL330, CL600, CL700 and CL800 • Convenient storage for other test and measurement products Cat. No. 69401 Width 4" (101.6 mm) 222 www.kleintools.com Height 9-1/4" (235.0 mm) Depth 2-1/4" (57.2 mm) Weight 3.2 oz. (91 g) 69401 See page 310 for additional information on warnings. CL Electrical Test & Measurement 0 20 AC TO AU A High Voltage Testers Detect a wide range of AC voltage in overhead conductors and cables Dual-Range High Voltage Non-Contact Tester to check for the presence of voltage in • Use overhead conductors or to find faults in cables • LOW range for 50V AC to 1.5kV AC • HIGH range for 1.5kV AC to 132kV AC • Includes durable carrying case Cat. No. HVNCVT-1 HVNCVT-1 Voltage Range Low: 50V AC - 1.5kV AC High: 1.5kV AC - 132kV AC Length 13" (330.2 mm) Weight 10.6 oz. (299 g) Broad-Range Non-Contact Tester to check for the presence of voltage in overhead • Use conductors or to find faults in cables sensitivity ranges up to 230kV AC (240V, 4.2kV, 15kV, 25kV, • 735kV, 69kV, 115kV, 230kV) Includes durable carrying case and universal/shotgun adapter • Visual signal indicates presence of voltage. Universal / Shotgun Adapter Included HVNCVT-2 Cat. No. HVNCVT-2 Voltage Range up to 230kV AC Length 10-25/64" (260.4 mm) Weight 1.4 lbs. (0.64 kg) Broad-Range Contact Tester tester indicates the presence of voltage in • Contact overhead conductors 5kV AC to 36kV AC • Includes durable carrying case HVCT-1 Cat. No. HVCT-1 Voltage Range 5 - 36kV AC Length 9.7" (246.38 mm) Weight 0.68 lbs. (0.31 kg) Fiberglass Telescoping Handle • Used for checking voltage up to 1,000V AC to the hot stick end of the High-Voltage • Connects Contact Tester (Cat. No. HVCT-1) • Dielectric pole type-tested & rated for 10kV AC • Comes in a convenient zippered case Cat. No. HV-43 Voltage Range up to 1,000V AC Length 12.5"- 44.5" (317.5 to 1130.3 mm) See page 310 for additional information on warnings. HV-43 Weight 0.73 lbs. (0.33 kg) 223 www.kleintools.com NEW WIRELESS JOBSITE SPEAKER iPhone / Android compatible 4 10h 32.8 ft 5 6.6 ft The Klein Tools AEPJS1 is a powered speaker that provides 5 watts of high-quality sound for smart phones, tablets, computers and other audio devices via a wireless Bluetooth* connection or wired auxiliary input. It answer calls hands-free with the built-in speakerphone and can be magnetically attached to any steel surface, attached to Klein's Lighted Tool Bag (Cat. No. 55431), mounted to a standard 1/4-20 tripod, attached to a lanyard, or simply stood up on any solid, level surface. TOP, SIDE & FRONT OF UNIT Play/Pause/ Talk button Volume Down / Skip Backward Button Volume Up / Skip Forward Button Power On/Off Button Lanyard Tie Point Microphone • 10-Hour Battery Life • 32.8 ft (10 m) Connectivity Range • Rated IP45 Waterproof / Dustproof • Drop Protected up to 6.6 ft (2 m) LED Indicator Speaker USB charging port Auxiliary Input jack BOTTOM & BACK OF UNIT Water-resistant cover Magnet Tool Bag Mounting Flange 1/4-20 Mount Cat. No. Dimensions Weight AEPJS1 3.88" x 3.5" x 2.13" (98.6 x 88.9 x 54.1 mm) 10 oz. (283 g) *Bluetooth is a registered trademark of Bluetooth Special Interest Group. IC www.kleintools.com
69418 价格&库存
很抱歉,暂时无法提供与“69418”相匹配的价格&库存,您可以联系我们找货
