DC-ES-BKT
DC-ES-BKT
    DIGIINTERNATIONAL
    BRACKET MOUNTING
DC-ES-BKT 数据手册
8 COPYRIGHT C 2014 DIGI INTERNATIONAL, 7 6 BALLOON DESIGNATION SYMBOL 14 UNPUBLISHED WORK - ALL RIGHTS RESERVED. 3 5 4 3 THIS DOCUMENT CONTAINS PROPRIETARY INFORMATION AND, EXCEPT WITH WRITTEN PERMISSION OF DIGI, SUCH INFORMATION SHALL NOT BE PUBLISHED OR DISCLOSED TO OTHERS, OR USED FOR ANY PURPOSE AND THE DOCUMENT SHALL NOT BE COPIED IN WHOLE OR IN PART ITEM NUMBER ITEM QUANTITY B NOTES: UNLESS OTHERWISE SPECIFIED INITIAL RELEASE NPRO 103254 DATE DRW/CHK 28OCT14 TJM/MJL 31MAR05 005558 UPDATE DIMENSION SCHEME AND TITLE BLOCK TJM/TJM NO PAINT ALLOWED. 5. DIMENSIONS OF FORM AND LOCATION APPLY TO PART IN THE UNRESTRAINED CONDITION. .0 2X .500 1.000 6. ALL BENDS R.063" MIN. ALL BENDS ARE 90 $ NOTED. 2X 2.39 7 UNLESS OTHERWISE .0 .655 .405 POWDER COAT: 4. REMOVE BURRS AND SHARP EDGES PER STANDARD COMMERCIAL PRACTICE PRIOR TO COATING. R.120 (TYP) R.060 (TYP) 2X .492 STAMP, ETCH, OR ENGRAVE PART NUMBER, REVISION AND DATE CODE (YYWW) WITH .125" MINIMUM TALL CHARACTERS. LOCATE APPROXIMATELY AS SHOWN. PART MARKING SHALL BE CLEARLY VISIBLE AFTER FINISHING. C 2X 3.445 2X 3.937 8. FINISHED PART SHALL BE ROHS COMPLIANT PER 2011/65/EU. THE FACILITY PERFORMING THIS WORK SHALL PERFORM TESTS OR OBTAIN TESTING INFORMATION THAT CONFIRMS COMPLIANCE. TEST RECORDS SHALL BE MADE AVAILABLE UPON REQUEST. 7 9. ALL COMPONENT SHIPMENTS TO INCLUDE CERTIFICATE OF CONFORMANCE. COC MUST STATE PARTS ARE BUILT TO DRAWING SPECIFICATIONS. 3 10X M4 x 0.7 PITCH THREADED HOLES 2X 9.20 9.56 6.00 4.688 3.813 2.188 1.313 .0 3X 9.30 FRONT VIEW SCALE B - PRO/ENGINEER GENERATED DRAWING - DESCRIPTION D 2X 4.476 3X 4.969 2. PAINT ALL EXTERIOR SURFACES UNLESS OTHERWISE SPECIFIED WITH THE FOLLOWING COLOR: WHITE RAL 9002 CHEMISTRY: URETHANE PARTICLE SIZE: 45-60% THROUGH 325 MESH RECOMMENDED FILM THICKNESS: 2.0 - 3.0 MILS FINISHED TEXTURE SHALL BE LIGHT POWDER COAT CHIP WILL BE SUPPLIED UPON REQUEST 3 C ECO 1. MATERIAL: 0.1015" 10 GAUGE 5052-H32 ALUMINUM PER ASTM B209. CLEAR CHROMATE ELECTROPLATE .0002 THRU .0004 THICK. 3X 1.032 2X 1.524 D REVISION HISTORY REV A 1 2 0.500 UNLESS OTHERWISE SPECIFIED ISOMETRIC VIEW FOR REFERENCE ONLY A SCALE B ALL DIMENSIONS AND TOLERANCES ARE IN INCHES AND SHALL BE INTERPRETED PER ASME Y14.5M - 1994. 0.500 DRAWING TOLERANCES ARE AS FOLLOWS: FRACTIONS # 1/64 DECIMALS ANGLES .X # .1 # 1 $ .XX # .02 .XXX # .010 THIS DWG AND SPECIFICATION ARE THE PROPERTY OF DIGI INTERNATIONAL AND SHALL NOT BE REPRODUCED OR COPIED WITHOUT THEIR WRITTEN PERMISSION. 8 7 6 5 4 3 DESIGNER/ENGINEER: DATE: T.MILLER 27-Oct-14 HW ENGINEER: MFG/OPS: 27-Oct-14 TITLE DATE: 27-Oct-14 T.MILLER 27-Oct-14 PRODUCT MANAGER 11001 BREN ROAD EAST, MINNETONKA, MN 55343 DATE: R.OLSEN DRAFTER: DIGI INTERNATIONAL A BRACKET, CONNECT ES DATE: DATE: 27-Oct-14 2 SIZE CAGE CODE D O8TP3 SCALE 1.000 DWG NO 60001099-01 DO NOT SCALE DRAWING 1 SHEET REV B 1 OF 1
DC-ES-BKT 价格&库存
很抱歉,暂时无法提供与“DC-ES-BKT”相匹配的价格&库存,您可以联系我们找货
DC-ES-BKT
  • 5+871.125955+112.66027
