76000904
76000904
    DIGIINTERNATIONAL
    ACPOWERSUPPLY18VDC
76000904 数据手册
bec http://www.bobbintron.com BOBBINTRON ELECTRICAL CORPORATION SPECIFICATION FOR PRELIMINARY APPROVAL SIGNATURE DATE : CUSTOMER : Digi International PART NO : 24000112 DESCRIPTION : AC to DC 18Watt Desktop SMPS PLEASE SIGN AND RETURN ONE COPY. ALL PRODUCTION UNITS WILL BE BUILT ACCORDING TO THIS SPECIFICATIONS. MODEL NO: AGENCY APPROVAL: PRESENTED BY: CHECKED BY: APPROVED BY: REV. AP0181-18E Ben Yang NO. Ben Yang Johnson Lin DATE : 05/30/2012 19F, NO.102, HSIN TAI WU ROAD SEC.1, HSIH-JR CITY, TAIPEI HSIEN, TAIWAN TEL# (886)2-2696-0007 WEBSITE: www.bobbintron.com FAX# (886)2-2696-8786 EMAIL: sales@bobbintron.com bec http://www.bobbintron.com BOBBINTRON ELECTRICAL CORPORATION BOBBINTRON ELECTRICAL CORPORATION SWITCHING POWER SUPPLY SPECIFICATION MODEL : AP0181-18E DWG NO : ISSUED : 05/30/2012 REV. A 1. Input 1.1 AC input voltage range : 90VAC ~ 254VAC (universal) 1.2 AC input voltage rating : 100VAC~240VAC 1.3 AC input Frequency : 47Hz to 63Hz 1.4 AC input current : 0.50 A (rms) max. for 115VAC 0.30 A (rms) max. for 230VAC 1.5 MAX. In-rush current : 25A MAX. @ 115VAC 50 A max. @ 230Vac at 25℃ ambient cold start. 1.6 Leakage current : 3.5 mA max. 2. Output characteristics: 2.1 Output voltage : 18V 2.2 Max. load current : 1A 2.3 Min load current : 0A 2.4 Tolerance : ±5 % 2.5 Output Ripple & Noise : Output Voltage 1% * Ripple & Noise test conditions : (1) Measured by-pass capacitors 0.1uF / 10uF at output connector terminal And oscilloscope set at 20 Mhz. ( tested by oscilloscope ) bec 3. http://www.bobbintron.com BOBBINTRON ELECTRICAL CORPORATION General characteristics : 3.1 Max. output power : 18 watts continuous. 3.2 Efficiency : 78% ( Minimum ) at max load & 220VAC. 3.3 Turn no delay : 3 second max. at 100VAC 3.4 Hold up time : 3.5 Transient response : 10ms Min. at max load 120VAC output return within ±10% tolerance of nominal voltage within 1m sec. for 50% load change, 120Hz 50% duty cycle. 3.6 Short circuit protection : protection against short circuit for output Note : The output can be shorted permanently without damage. 3.6.1 (1) Any protect condition shall cause no damage and no component fail. (2) Automatic recovery when removal of protect condition. 3.7 Temperature coefficient : 0.2% per ℃ maximum over entire operating temperature range for Va output . 4. Environmental : 4.1 Operating temperature : -40℃ to 75 ℃ 4.2 Storage temperature : -40℃ to 85℃ 4.3 Operating relative humidity : 10% to 85% 4.4 Storage relative humidity : 5. Safety requirement :(Meet) 5% to 95% (1) UL 1950 (2) CE bec http://www.bobbintron.com BOBBINTRON ELECTRICAL CORPORATION 6. EMI requirement : CISPR EN55022 class B rules. 7. Hi-pot test : 7.1 Primary to secondary : 4242VDC for 1 sec. 10mA 8. Insulation resistance 8.1 Input to output : > 7Mohm. 500VDC 9. Reliability 9.1 MTBF : 50K hours min. @ full load at 25℃ ambient temperature. 9.2 Burn in : 4hrs. 40 ±5℃, 115VAC or 230VAC ON/OFF cycling 70% ~ full load nominal line . 9.3 Vibration : Frequency range : 5-200Hz. Vibration amplitude 0.5g ±10% over entire frequency range. A complete sweep of the frequencies from 5-200Hz at 0.4 decades per mins. duration, if insufficient resonant point are established to provide for 30 minutes input per axis, then a constant acceleration continuous sweep at one octave per minute ( 0.3 decade / min. ) shall be applied for the duration. 9.4 Altitude : will operate properly at any altitude between 0 to 10000ft. 10. Mechanical : 10.1 Dimensions : 150mm long 90mmwidth bec http://www.bobbintron.com BOBBINTRON ELECTRICAL CORPORATION 52mm height Color : Black 10.2 Weight : 840g(Ref.). 10.3 Input connector : AC Cord EU Model 1830mm 10.4 Output connector : DC CABLE : 1220mm XTW 20AWG PLUG : Molex #39-01-2040 or EQUIV. 10.5 Pin Out configuration : Location : Pin4 18VDC Pin1 RTN REVISION HISTORY Rev# Date Was Is bec http://www.bobbintron.com BOBBINTRON ELECTRICAL CORPORATION bec http://www.bobbintron.com BOBBINTRON ELECTRICAL CORPORATION bec http://www.bobbintron.com BOBBINTRON ELECTRICAL CORPORATION
76000904 价格&库存
很抱歉,暂时无法提供与“76000904”相匹配的价格&库存,您可以联系我们找货
