910A704HV
910A704HV
    WINCHESTER(温彻斯特)
    SMA(DO-214AC)
    SMA
910A704HV 数据手册
900 Series SMA Product Description 50 Ohm Cable and PCB Connectors Winchester’s Bomar brand 900 Series 50 Ohm SMA Connectors can be used in a wide range of applications including Test and Measurement, Mil-Aero, Satellite, and Wireless Communication Equipment. Our 900 Series 50 Ohm SMA Connectors are designed in accordance with MIL-STD 348 and feature a .250-36 threaded coupling interface designed or a frequency range of DC to 18 GHz. Male cable plug connectors are available in straight and right-angle designs for popular flexible and semi-rigid cables. Printed Circuit Board (PCB) connectors are available in straight and right-angle through-hole solder, and also in our unique E-Snap® Edge-Mount design. • Threaded coupling ensures connector will not decouple in vibration-intensive applications • Straight crimp plug center contact features a retention barb which snaps into the insulator to prevent the pin contact from backing out of the connector. • E-Snap® Edge-Mount connectors provide superior RF performance versus traditional right-angle connects, as a straight contact provides the best transmission path CONNECTING INNOVATION TO APPLICATION® Specifications Electrical Mechanical Impedance: Polarity: Frequency (GHz): Flexible Cable Semi-Rigid VSWR: Straight Right-Angle Dielectric Withstanding Voltage: Flexible Semi-Rigid Contact Resistance: 50 Ohms Standard Coupling Mating Torque: Cable Retention: Flexible Semi-Rigid Center Contact: Connector Durability: 0 to 12.5 GHz 0 to 18 GHz 1.15 Max 1.2 Max 7-15 in-lbs. 60 lbs. Min 80 lbs. Min Solder / Crimp 500 Cycles Min Material 1000 VRMS 1500 VRMS Center ≤ 2 mΩ Outer ≤ 2 mΩ 5000 mΩ Min -65˚C to +165˚C Insulation Resistance: Temperature Range: Insulator Material: Body Material: Body Finish: Contact Material: PTFE Brass Nickel or Gold Male Brass Female BECU Gold Yes Contact Finish: RoHS Compliant: Part Numbering Bomar Part Number Straight and Right-Angle Cable Plugs Crimp Tool Hex Size 910A204M Straight Plug for RG174, RG316, LMR100 BDHD200 Solder / .128 910A204F Straight Plug for RG58, RG58A, RG141, LMR195 BDHD200 Solder / .213 910A204P Straight Plug for RG55, RG142, RG223, RG400 BDHD200 Solder / .213 910A704HV Straight Plug RG402 (use cable for center contact) Solder Solder 910A704B Straight Plug RG402 Cable (with center contact supplied) Solder Solder 910A704A Straight Plug RG405 Cable (with center contact supplied) Solder Solder 913A204M Right-Angle Plug for RG174, RG316, LMR100 BDND200 Solder / .128 913A204F Right-Angle Plug for RG58, RG58A, RG141, LMR195 BDHD200 Solder / .213 913A204P Right-Angle Plug for RG55, RG142, RG223, RG400 BDHD200 Solder / .213 913A704B Right-Angle Plug for RG402 Solder Solder 913A704A Right-Angle Plug for RG405 Solder Solder Bomar Part Number Printed Circuit Board Connectors PCB Thickness Packaging 961A514 Vertical, SMA, Jack, 0.155’’ Solder Tail 0.062” Single 964A595 Right-Angle, SMA, Jack, 0.155’’ Solder Tail 0.062” Single 960A514 Vertical, SMA, Plug, 0.155’’ Solder Tail 0.062” Single 963A595 Right-Angle, SMA, Plug, 0.155’’ Solder Tail 0.062” Single 961E504 E-Snap® Edge-Mount, SMA, Jack 0.062” Single 962E504 E-Snap® Edge-Mount, SMA, Plug 0.062” Single 961E504HF E-Snap® 0.062” Single Winchester Electronics 199 Park Road Extension, Suite 104 Middlebury, Connecticut 06762 203.741.5400 Phone 203.741.5500 Fax www.winchesterelectronics.com High Frequency Jack (26.5 GHz) April 2014
910A704HV 价格&库存
很抱歉,暂时无法提供与“910A704HV”相匹配的价格&库存,您可以联系我们找货
