VDV814-631
VDV814-631
    KLEINTOOLS
    CONNADAPTPLUGTOJACKFTYPE
VDV814-631 数据手册
VOICE/DATA/VIDEO CONNECTORS • Time Saving Innovations • Professional Grade For Professionals...Since 1857® Coax & Twisted Pair CONNECTORS Coax & Twisted Pair For more information including video, scan this code: For more than 150 years, Klein Tools has provided professionals with the quality and innovation they demand. Our voice/data/video products continue that tradition. Klein Tools’ comprehensive line of innovative connectors make them faster to install, more flexible and convenient to use. Klein's connectors feature the professional grade quality that today’s voice/data/video technicians depend on. VOICE/DATA/VIDEO 1 PREPARATION 2 CONNECTION 3 TESTING COAX COMPRESSION CONNECTORS Universal Sleeve Technology • Installs up to five times faster • One connector does it all: – – Fits all diameter variations within a cable series Fits difficult to work with multi-shield and plenum cables We have heard the frustration from coax installers about connecting thicker cables, plenum cables, or simply dealing with the variety of diameters within a single series of cable. Gone are the days of stocking three, four or even five special connectors just to have the right version on hand, or the need to drop everything and run around to find a connector that will work. Klein Tools' Universal sleeve coax compression connectors not only work in all these cable situations and minimize your inventory, they also install at lightning speeds—up to five times faster than ordinary coax compression connectors, saving installers time and money! This patented sleeve design still provides the excellent holding power and signal strength you require. Compact ferrule Full ferrule Open sleeve design Klein Tools' Universal sleeve compact ferrule compression connector Full ferrule compression connector Coax Cable Connectors Universal Compression Connectors • RG6 • RG6 Quad Shield • RG59 New Technology Universal Compression Connectors Installs Up To 5X • • Faster! Fit all diameter variations within a cable series • Fit difficult to work with multi-shield and plenum cables  remium quality, solid P brass construction • Elegant dark nickel-plated finish F • RG6-RG6Q BNC • RG6-RG6Q VDV812-606, VDV812-612 RCA • RG6-RG6Q VDV813-607, VDV813-613 F • RG59 VDV813-608, VDV813-614 BNC • RG59 VDV812-615, VDV812-618 RCA • RG59 VDV813-616, VDV813-619 VDV813-617, VDV813-620 SELECTION GUIDE Universal Standard Connector Type F-Connector BNC-Connector RCA-Connector F-Connector Crimping Type Cable Type: RG59 Compression Compression Compression Compression RG6 • • VDV812-615 VDV812-606 VDV812-618 VDV812-612 RG6 QUAD SHIELD Universal Sleeve * Outdoor Use Cat. Nos: Pack Size: 10 Pack Size: 35 Pack Size: 50 Klein Crimping Tools • • • • • • • • VDV813-616 VDV813-619 VDV813-607 VDV813-613 • • • • • • • VDV813-617 VDV813-620 VDV813-608 VDV813-614 VDV812-623 VDV211-063, VDV211-048, VDV211-007 • VDV812-624 VDV211-063, VDV211-048, VDV211-007, VDV212-008 * Cable diameters can vary within a series (eg. RG59, RG6 or RG6Q) across all major brands. Universal sleeve fits all cable diameter variations, multi-shield and plenum versions. Installs up to 5X faster than other compression connectors. Coax Cable Connectors Specialty Connectors • Accessories • Splitters The Klein Tools' family of coax connectors also includes a variety of specialty connectors, accessories and splitters. These products have patented features for improved system performance, ease of installation, higher return loss, "higher shielding" (prevents ghosted and grainy images) and greater gripping strength of cable conductors (optimizes signal strength). Standard Compression Connectors Specialty Connectors & Accessories F • RG6 F Push-On Connector F to BNC Adapter VDV812-625, VDV812-626, VDV812-627 VDV814-629 VDV814-630 tool-less, • Patented, easy grip design F-connectors • Converts to BNC connectors F-connectors • Converts to RCA connectors VDV812-623, VDV812-624 • Full ferrule brass construction • Solid with nickel-plated finish • Best choice for outdoors • Great for satellite dishes F-Splice Adapter – 3 GHz F-Terminator VDV814-609 • Patented gripping mechanism for optimal signal strength F to RCA Adapter 90˚ F-Adapter – 3 GHz VDV814-610 VDV814-631 • Prevents extraneous signals from decreasing system performance Splitters for tight spaces in • Perfect a cabinet or against a wall Klein Tools’ splitters have lower insertion loss, higher shielding, a solder back cover and are hand-tuned for quality and performance. Digital Cable Splitters (5 MHz to 1 GHz) 2-way - VDV814-633 4-way - VDV814-634 Satellite / Digital Cable Splitters (5 MHz to 2.3 GHz) 8-way - VDV814-635 Diplexer or • Combines separates CATV and off-air signals with/from satellite signals 2-way - VDV814-636 4-way - VDV814-637 VDV814-638 Twisted Pair CAT3 • CAT5 • CAT5e • CAT6 Inferior Plating Professional Grade Gold Plating Klein’s line of data connectors, telephone plugs and IDC connectors deliver the high quality performance, durability and longevity you demand. So often today’s data and telephone connectors disappoint because of poor performance from “invisible” features such as thin, inferior plating on contact points causing erosion and connector failure, or weak spring clips and Thin, pitted, uneven plated surface leads to premature erosion of contact and causes connector failure. housings that break after minimal use. Klein Plating RJ45 CAT5e 8P8C Modular Data Plug Klein's data and telephone plugs are professional-grade and deliver consistent, reliable performance. They feature thick 50 micro-inch gold plating on the contact plates, three-pronged solid and stranded wire contacts, and durable connector housings. Expect a sure connection each and every time. Thick, consistent, evenly plated 50 micro-inch gold for reliable, long-lasting performance. Modular Data Plugs RJ45 8P8C CAT5e CAT6 3-piece VDV826-628, VDV826-602, VDV826-611 VDV826-603 Telephone Plugs RJ11 6P4C 6P6C VDV826-601 VDV826-600 Insulation Displacement Connectors Strain Relief Boot UY IDC RJ45 UR IDC VDV826-604 2-wire (26-22 AWG) VDV826-605 3-wire (26-19 AWG) VDV824-632 SELECTION GUIDE Connector Type Position & Contacts Connector Design Gold Plating Thickness (microinch) Cable Type: CAT 3 CAT 5 UY UR RJ11 RJ11 RJ45 2P2C 3P3C 6P4C 6P6C 8P8C 1-Piece 1-Piece 1-Piece 1-Piece 1-Piece 3-Piece 50μ" 50μ" 50μ" 50μ" • • • • • • • • Yellow Red Clear Clear VDV826-604 VDV826-605 VDV826-601 VDV826-600 • • CAT 5e CAT 6 Solid Conductor Wire Stranded Conductor Wire Connector Color • • Clear • • • Clear Cat. No. Pack Size: 10 Pack Size: 25 Pack Size: 50 Pack Size: 100 Crimping Type Klein Crimping Tools VDV826-628 VDV826-603 IDC VDV826-602 VDV826-611 Modular Plug Connector D234-6, D234-6C, VDV026-049 VDV226-011 VOICE/DATA/VIDEO 1 PREPARATION Coax Crimping Tools: 2 CONNECTION 3 TESTING Coax Connectors Compression Crimper - Lateral, Multi-Connector VDV211-063 Compression Crimper Compact, Multi-Connector VDV211-048 Compression Crimper - Compact, F-Connector VDV212-008 Twisted Pair Crimping Tools: Ratcheting Modular Crimper/Stripper Cat. No. UPC #0-92644+ Description VDV812-615 VDV812-618 VDV812-606 VDV812-612 VDV813-616 VDV813-619 VDV813-607 VDV813-613 VDV813-617 VDV813-620 VDV813-608 VDV813-614 VDV812-623 VDV812-624 VDV812-625 VDV812-626 VDV812-627 58155-7 58158-8 58142-7 58148-9 58156-4 58159-5 58143-4 58149-6 58157-1 58160-1 58144-1 58150-2 58163-2 58164-9 58165-6 58166-3 58167-0 Universal F Compression Connector – RG59 Universal F Compression Connector – RG59 Universal F Compression Connector – RG6 - RG6Q Universal F Compression Connector – RG6 - RG6Q Universal BNC Compression Connector – RG59 Universal BNC Compression Connector – RG59 Universal BNC Compression Connector – RG6 - RG6Q Universal BNC Compression Connector – RG6 - RG6Q Universal RCA Compression Connector – RG59 Universal RCA Compression Connector – RG59 Universal RCA Compression Connector – RG6 - RG6Q Universal RCA Compression Connector – RG6 - RG6Q Standard F Compression Connector – RG6 Standard F Compression Connector – RG6 F Push-On Connector – RG59 F Push-On Connector – RG6 - 6Q F Push-On Connector – RG6 - 6Q Pack Qty. 10 50 10 50 10 35 10 35 10 35 10 35 10 50 4 4 10 Coax Splitters Cat. No. UPC #0-92644+ Description VDV814-633 VDV814-634 VDV814-635 VDV814-636 VDV814-637 VDV814-638 58173-1 58174-8 58175-5 58176-2 58177-9 58178-6 2-Way Digital Cable Splitter – 5 MHz - 1 GHz 4-Way Digital Cable Splitter – 5 MHz - 1 GHz 8-Way Digital Cable Splitter – 5 MHz - 1 GHz 2-Way Satellite/Digital Cable Splitter – 5 MHz - 2.3 GHz 4-Way Satellite/Digital Cable Splitter – 5 MHz - 2.3 GHz Satellite/TV Diplexer – 5 MHz - 2.3 GHz Pack Qty. 1 1 1 1 1 1 Coax Accessories Cat. No. UPC #0-92644+ Description VDV814-629 VDV814-630 VDV814-609 VDV814-631 VDV814-610 58169-4 58170-0 58145-8 58171-7 58146-5 F to BNC Adapter F to RCA Adapter F-Splice Adapter – 3 GHz 90˚ F-Adapter – 3 GHz F-Terminator Pack Qty. 2 2 10 2 10 Twisted Pair Connectors VDV226-011 Connector Crimping Long-Nose Pliers VDV026-049 Cat. No. UPC #0-92644+ Description Pack Qty. VDV826-604 VDV826-605 VDV826-601 VDV826-600 VDV826-628 VDV826-602 VDV826-611 VDV826-603 VDV824-632 58140-3 58141-0 58137-3 58136-6 58168-7 58138-0 58147-2 58139-7 58172-4 UY IDC Connector – UY-26-22 AWG - 2-wire UR IDC Connector – UR-26-19 AWG - 3-wire Telephone Plug – RJ11 - 6P4C Telephone Plug – RJ11 - 6P6C Modular Data Plug – RJ45 - CAT5e Modular Data Plug – RJ45 - CAT5e Modular Data Plug – RJ45 - CAT5e Modular Data Plug – RJ45 - CAT6 Strain Relief Boot for Modular Data Plug – RJ45 25 25 25 25 10 50 100 25 10 See our complete line of Voice/Data/Video Tools, Testers & Connectors www.kleintools.com Klein Tools, Inc. • 450 Bond Street • Lincolnshire • IL 60069-1418 • phone: 847-821-5500 • fax: 800-553-4876 © 2012 Klein Tools, Inc. All right reserved. Printed in U.S.A. 96895
VDV814-631 价格&库存
很抱歉,暂时无法提供与“VDV814-631”相匹配的价格&库存,您可以联系我们找货
