74HC174PW-Q100J
74HC174PW-Q100J
    NEXPERIA(安世)
    TSSOP16_5.1X4.5MM
    带复位的六角D型触发器;正边缘触发器
74HC174PW-Q100J 数据手册
74HC174-Q100; 74HCT174-Q100 Hex D-type flip-flop with reset; positive-edge trigger Rev. 2 — 26 February 2021 Product data sheet 1. General description The 74HC174-Q100; 74HCT174-Q100 are hex positive edge-triggered D-type flip-flops with individual data inputs (Dn) and outputs (Qn). The common clock (CP) and master reset (MR) inputs load and reset all flip-flops simultaneously. The D-input that meets the set-up and hold time requirements on the LOW-to-HIGH clock transition is stored in the flip-flop and appears at the Q output. A LOW on MR causes the flip-flops and outputs to be reset LOW. Inputs include clamp diodes. This enables the use of current limiting resistors to interface inputs to voltages in excess of VCC. This product has been qualified to the Automotive Electronics Council (AEC) standard Q100 (Grade 1) and is suitable for use in automotive applications. 2. Features and benefits • • • • • • • • • • Automotive product qualification in accordance with AEC-Q100 (Grade 1) • Specified from -40 °C to +85 °C and from -40 °C to +125 °C Wide supply voltage range from 2.0 to 6.0 V CMOS low power dissipation High noise immunity Input levels: • For 74HC174-Q100: CMOS level • For 74HCT174-Q100: TTL level Six edge-triggered D-type flip-flops Asynchronous master reset Complies with JEDEC standards • JESD8C (2.7 V to 3.6 V) • JESD7A (2.0 V to 6.0 V) Latch-up performance exceeds 100 mA per JESD 78 Class II Level B ESD protection: • MIL-STD-883, method 3015 exceeds 2000 V • HBM JESD22-A114F exceeds 2000 V • MM JESD22-A115-A exceeds 200 V (C = 200 pF, R = 0 Ω) 3. Ordering information Table 1. Ordering information Type number Package 74HC174D-Q100 Temperature range Name Description Version -40 °C to +125 °C SO16 plastic small outline package; 16 leads; body width 3.9 mm SOT109-1 -40 °C to +125 °C TSSOP16 plastic thin shrink small outline package; 16 leads; body width 4.4 mm SOT403-1 74HCT174D-Q100 74HC174PW-Q100 74HCT174PW-Q100 74HC174-Q100; 74HCT174-Q100 Nexperia Hex D-type flip-flop with reset; positive-edge trigger 4. Functional diagram 9 9 CP 3 4 6 11 13 14 D0 Q0 D1 Q1 D2 Q2 D3 Q3 D4 Q4 D5 Q5 2 5 Fig. 1. R 3 7 10 2 1D 4 5 6 12 15 MR 1 C1 1 7 11 10 13 12 14 15 aaa-007149 aaa-007150 Logic symbol Fig. 2. D0 D1 D Q D2 D Q IEC logic symbol D3 D Q D4 D Q D5 D Q D Q FF1 FF2 FF3 FF4 FF5 FF6 CP MR CP MR CP MR CP MR CP MR CP MR CP MR Q0 Q1 Q2 Q3 Q4 Q5 aaa-007151 Fig. 3. Logic diagram 5. Pinning information 5.1. Pinning 74HC174 74HCT174 MR 1 16 VCC Q0 2 15 Q5 D0 3 14 D5 D1 4 13 D4 Q1 5 12 Q4 D2 6 11 D3 Q2 7 10 Q3 GND 8 9 74HC174 74HCT174 CP MR 1 16 VCC Q0 2 15 Q5 D0 3 14 D5 D1 4 13 D4 Q1 5 12 Q4 D2 6 11 D3 Q2 7 10 Q3 GND 8 9 aaa-007152 Fig. 4. Pin configuration SOT109-1 (SO16) 74HC_HCT174_Q100 Product data sheet CP aaa-007154 Fig. 5. Pin configuration and SOT403-1 (TSSOP16) All information provided in this document is subject to legal disclaimers. Rev. 2 — 26 February 2021 © Nexperia B.V. 2021. All rights reserved 2 / 14 74HC174-Q100; 74HCT174-Q100 Nexperia Hex D-type flip-flop with reset; positive-edge trigger 5.2. Pin description Table 2. Pin description Symbol Pin Description MR 1 asynchronous master reset input (active LOW) Q0, Q1, Q2, Q3, Q4, Q5 2, 5, 7, 10, 12, 15 flip-flop output D0, D1, D2, D3, D4, D5 3, 4, 6, 11, 13, 14 data input GND 8 ground (0 V) CP 9 clock input (LOW-to-HIGH edge-triggered) VCC 16 positive supply voltage 6. Functional description Table 3. Function table H = HIGH voltage level; h = HIGH voltage level one set-up time prior to the LOW-to-HIGH clock transition; L = LOW voltage level; l = LOW voltage level one set-up time prior to the LOW-to-HIGH clock transition; X = don’t care; ↑ = LOW-to-HIGH clock transition. Operating modes Outputs Inputs MR CP Dn Qn reset (clear) L X X L load "1" H ↑ h H load "0" H ↑ l L 7. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V) Symbol Parameter Conditions Min Max Unit -0.5 +7 V VCC supply voltage IIK input clamping current VI < -0.5 V or VI > VCC + 0.5 V [1] - ±20 mA IOK output clamping current VO < -0.5 V or VO > VCC + 0.5 V [1] - ±20 mA IO output current -0.5 V < VO < VCC + 0.5 V - ±25 mA ICC supply current - 50 mA IGND ground current -50 - mA Tstg storage temperature -65 +150 °C Ptot total power dissipation - 500 mW [1] [2] Tamb = -40 °C to +125 °C [2] The input and output voltage ratings may be exceeded if the input and output current ratings are observed. For SOT109-1 (SO16) package: Ptot derates linearly with 12.4 mW/K above 110 °C. For SOT403-1 (TSSOP16) package: Ptot derates linearly with 8.5 mW/K above 91 °C. 74HC_HCT174_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 26 February 2021 © Nexperia B.V. 2021. All rights reserved 3 / 14 74HC174-Q100; 74HCT174-Q100 Nexperia Hex D-type flip-flop with reset; positive-edge trigger 8. Recommended operating conditions Table 5. Recommended operating conditions Voltages are referenced to GND (ground = 0 V) Symbol Parameter Conditions 74HC174-Q100 74HCT174-Q100 Unit Min Typ Max Min Typ Max 2.0 5.0 6.0 4.5 5.0 5.5 V VCC supply voltage VI input voltage 0 - VCC 0 - VCC V VO output voltage 0 - VCC 0 - VCC V Tamb ambient temperature -40 - +125 -40 - +125 °C Δt/ΔV input transition rise and fall rate VCC = 2.0 V - - 625 - - - ns/V VCC = 4.5 V - 1.67 139 - 1.67 139 ns/V VCC = 6.0 V - - 83 - - - ns/V 9. Static characteristics Table 6. Static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions 25 °C -40 °C to +85 °C -40 °C to +125 °C Unit Min Typ Max Min Max Min Max VCC = 2.0 V 1.5 1.2 - 1.5 - 1.5 - V VCC = 4.5 V 3.15 2.4 - 3.15 - 3.15 - V VCC = 6.0 V 4.2 3.2 - 4.2 - 4.2 - V VCC = 2.0 V - 0.8 0.5 - 0.5 - 0.5 V VCC = 4.5 V - 2.1 1.35 - 1.35 - 1.35 V VCC = 6.0 V - 2.8 1.8 - 1.8 - 1.8 V IO = -20 μA; VCC = 2.0 V 1.9 2.0 - 1.9 - 1.9 - V IO = -20 μA; VCC = 4.5 V 4.4 4.5 - 4.4 - 4.4 - V 74HC174-Q100 VIH VIL VOH VOL HIGH-level input voltage LOW-level input voltage HIGH-level output voltage LOW-level output voltage VI = VIH or VIL IO = -20 μA; VCC = 6.0 V 5.9 6.0 - 5.9 - 5.9 - V IO = -4.0 mA; VCC = 4.5 V 3.98 4.32 - 3.84 - 3.7 - V IO = -5.2 mA; VCC = 6.0 V 5.48 5.81 - 5.34 - 5.2 - V IO = 20 μA; VCC = 2.0 V - 0 0.1 - 0.1 - 0.1 V IO = 20 μA; VCC = 4.5 V - 0 0.1 - 0.1 - 0.1 V IO = 20 μA; VCC = 6.0 V - 0 0.1 - 0.1 - 0.1 V IO = 4.0 mA; VCC = 4.5 V - 0.15 0.26 - 0.33 - 0.4 V IO = 5.2 mA; VCC = 6.0 V - 0.16 0.26 - 0.33 - 0.4 V VI = VIH or VIL II input leakage current VI = VCC or GND; VCC = 6.0 V - - ±0.1 - ±1 - ±1 μA ICC supply current VI = VCC or GND; IO = 0 A; VCC = 6.0 V - - 8.0 - 80 - 160 μA CI input capacitance - 3.5 - - - - - pF 74HC_HCT174_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 26 February 2021 © Nexperia B.V. 2021. All rights reserved 4 / 14 74HC174-Q100; 74HCT174-Q100 Nexperia Hex D-type flip-flop with reset; positive-edge trigger Symbol Parameter Conditions 25 °C -40 °C to +85 °C -40 °C to +125 °C Unit Min Typ Max Min Max Min Max 74HCT174-Q100 VIH HIGH-level input voltage VCC = 4.5 V to 5.5 V 2.0 1.6 - 2.0 - 2.0 - V VIL LOW-level input voltage VCC = 4.5 V to 5.5 V - 1.2 0.8 - 0.8 - 0.8 V VOH HIGH-level output voltage VI = VIH or VIL; VCC = 4.5 V IO = -20 μA 4.4 4.5 - 4.4 - 4.4 - V IO = -4.0 mA 3.98 4.32 - 3.84 - 3.7 - V IO = 20 μA; VCC = 4.5 V - 0 0.1 - 0.1 - 0.1 V IO = 5.2 mA; VCC = 5.5 V LOW-level output voltage VI = VIH or VIL; VCC = 4.5 V - 0.15 0.26 - 0.33 - 0.4 V II input leakage current VI = VCC or GND; VCC = 5.5 V - - ±0.1 - ±1 - ±1 μA ICC supply current VI = VCC or GND; IO = 0 A; VCC = 5.5 V - - 8.0 - 80 - 160 μA ΔICC additional supply current per input pin; VI = VCC - 2.1 V; other inputs at VCC or GND; VCC = 4.5 V to 5.5 V Dn input - 25 90 - 112.5 - 122.5 μA CP input - 130 468 - 585 - 637 μA MR input - 125 450 - 562.5 - 612.5 μA - 3.5 - - - - - pF VOL CI input capacitance 74HC_HCT174_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 26 February 2021 © Nexperia B.V. 2021. All rights reserved 5 / 14 74HC174-Q100; 74HCT174-Q100 Nexperia Hex D-type flip-flop with reset; positive-edge trigger 10. Dynamic characteristics Table 7. Dynamic characteristics GND (ground = 0 V); CL = 50 pF unless otherwise specified; for test circuit, see Fig. 8 Symbol Parameter Conditions 25 °C Min -40 °C to +85 °C -40 °C to +125 °C Unit Typ Max Min Max Min Max 74HC174-Q100 tpd tPHL tt tW propagation delay HIGH to LOW propagation delay transition time pulse width CP to Qn; see Fig. 6 [1] VCC = 2.0 V - 55 165 - 205 - 250 ns VCC = 4.5 V - 20 33 - 41 - 50 ns VCC = 5.0 V; CL = 15 pF - 17 - - - - - ns VCC = 6.0 V - 16 28 - 35 - 43 ns VCC = 2.0 V - 44 150 - 190 - 225 ns VCC = 4.5 V - 16 30 - 38 - 45 ns VCC = 5.0 V; CL = 15 pF - 13 - - - - - ns VCC = 6.0 V - 13 26 - 33 - 38 ns VCC = 2.0 V - 19 75 - 95 - 110 ns VCC = 4.5 V - 7 15 - 19 - 22 ns VCC = 6.0 V - 6 13 - 16 - 19 ns VCC = 2.0 V 80 17 - 100 - 120 - ns VCC = 4.5 V 16 6 - 20 - 24 - ns VCC = 6.0 V 14 5 - 17 - 20 - ns VCC = 2.0 V 80 12 - 100 - 120 - ns VCC = 4.5 V 16 4 - 20 - 24 - ns VCC = 6.0 V 14 3 - 17 - 20 - ns VCC = 2.0 V 5 -11 - 5 - 5 - ns VCC = 4.5 V 5 -4 - 5 - 5 - ns VCC = 6.0 V 5 -3 - 5 - 5 - ns VCC = 2.0 V 60 6 - 75 - 90 - ns VCC = 4.5 V 12 2 - 15 - 18 - ns VCC = 6.0 V 10 2 - 13 - 15 - ns VCC = 2.0 V 3 -6 - 3 - 3 - ns VCC = 4.5 V 3 -2 - 3 - 3 - ns VCC = 6.0 V 3 -2 - 3 - 3 - ns MR to Qn; see Fig. 7 Qn output; see Fig. 6 [2] CP input HIGH or LOW; see Fig. 6 MR input LOW; see Fig. 7 trec tsu th recovery time set-up time hold time 74HC_HCT174_Q100 Product data sheet MR to CP; see Fig. 7 Dn to CP; see Fig. 6 Dn to CP; see Fig. 6 All information provided in this document is subject to legal disclaimers. Rev. 2 — 26 February 2021 © Nexperia B.V. 2021. All rights reserved 6 / 14 74HC174-Q100; 74HCT174-Q100 Nexperia Hex D-type flip-flop with reset; positive-edge trigger Symbol Parameter Conditions 25 °C Min fmax maximum frequency power dissipation capacitance Typ Max Min Max Min Max CP input; see Fig. 6 VCC = 2.0 V 6 30 - 5 - 4 - MHz VCC = 4.5 V 30 90 - 24 - 20 - MHz VCC = 6.0 V 35 107 - 28 - 24 - MHz - 99 - - - - - MHz - 17 - - - - - pF VCC = 4.5 V - 21 35 - 44 - 53 ns VCC = 5.0 V; CL = 15 pF - 18 - - - - - ns VCC = 4.5 V - 20 35 - 44 - 53 ns VCC = 5.0 V; CL = 15 pF - 17 - - - - - ns - 7 15 - 19 - 22 ns 16 7 - 20 - 24 - ns 20 7 - 25 - 30 - ns 12 -3 - 15 - 18 - ns 16 4 - 20 - 24 - ns 5 -3 - 5 - 5 - ns 30 63 - 24 - 20 - MHz - 69 - - - - - MHz - 17 - - - - - pF VCC = 5.0 V; CL = 15 pF CPD -40 °C to +85 °C -40 °C to +125 °C Unit per package; VI = GND to VCC [3] CP to Qn; see Fig. 6 [1] 74HCT174-Q100 tpd tPHL tt propagation delay HIGH to LOW propagation delay MR to Qn; see Fig. 7 transition time Qn output; see Fig. 6 [2] VCC = 4.5 V tW pulse width CP input; see Fig. 6 VCC = 4.5 V MR input LOW; see Fig. 7 VCC = 4.5 V trec recovery time MR to CP; see Fig. 7 VCC = 4.5 V tsu set-up time Dn to CP; see Fig. 6 VCC = 4.5 V th hold time Dn to CP; see Fig. 6 VCC = 4.5 V fmax maximum frequency CP input; see Fig. 6 VCC = 4.5 V VCC = 5.0 V; CL = 15 pF CPD [1] [2] [3] power dissipation capacitance per package; VI = GND to VCC - 1.5 V [3] tpd is the same as tPHL and tPLH. tt is the same as tTHL and tTLH. CPD is used to determine the dynamic power dissipation (PD in μW). 2 2 PD = CPD × VCC × fi + Σ (CL × VCC × fo) where: fi = input frequency in MHz; fo = output frequency in MHz; 2 Σ (CL × VCC × fo) = sum of outputs; CL = output load capacitance in pF; VCC = supply voltage in V. 74HC_HCT174_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 26 February 2021 © Nexperia B.V. 2021. All rights reserved 7 / 14 74HC174-Q100; 74HCT174-Q100 Nexperia Hex D-type flip-flop with reset; positive-edge trigger 10.1. Waveforms and test circuit VI Dn input VM GND th th tsu tsu 1/fmax VI CP input VM GND tW tPHL VOH tPLH 90 % 90 % Qn output VM VM 10 % VOL 10 % tTHL tTLH aaa-007155 Measurement points are given in Table 8. The shaded areas indicate when the input is permitted to change for predictable output performance. VOL and VOH are typical voltage output levels that occur with the output load. Fig. 6. Input to output propagation delay, output transition time, clock input pulse width, set-up and hold times for data input and maximum frequency VI VM CP input GND t rec tW VI VM MR input VM GND tPHL VOH Qn output VM VOL aaa-007156 Measurement points are given in Table 8. VOL and VOH are typical voltage output levels that occur with the output load. Fig. 7. Master reset to output propagation delays, master reset pulse width and master reset to clock recovery time Table 8. Measurement points Type Input Output VI VM VM 74HC174-Q100 VCC 0.5VCC 0.5VCC 74HCT174-Q100 3V 1.3 V 1.3 V 74HC_HCT174_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 26 February 2021 © Nexperia B.V. 2021. All rights reserved 8 / 14 74HC174-Q100; 74HCT174-Q100 Nexperia Hex D-type flip-flop with reset; positive-edge trigger VI negative pulse tW 90 % VM 0V VI positive pulse 0V VM 10 % tf tr tr tf 90 % VM VM 10 % tW VCC G VI VCC VO DUT RT RL S1 open CL 001aad983 Test data is given in Table 9. Definitions for test circuit: RT = Termination resistance should be equal to output impedance Zo of the pulse generator. CL = Load capacitance including jig and probe capacitance. RL = Load resistance. S1 = Test selection switch Fig. 8. Test circuit for measuring switching times Table 9. Test data Type Input S1 position Load VI tr, tf CL RL tPHL, tPLH 74HC174-Q100 VCC 6 ns 15 pF, 50 pF 1 kΩ open 74HCT174-Q100 3V 6 ns 15 pF, 50 pF 1 kΩ open 74HC_HCT174_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 26 February 2021 © Nexperia B.V. 2021. All rights reserved 9 / 14 74HC174-Q100; 74HCT174-Q100 Nexperia Hex D-type flip-flop with reset; positive-edge trigger 11. Package outline SO16: plastic small outline package; 16 leads; body width 3.9 mm SOT109-1 D E A X c y HE v M A Z 16 9 Q A2 A (A 3) A1 pin 1 index θ Lp 1 L 8 e w M bp 0 2.5 detail X 5 mm scale DIMENSIONS (inch dimensions are derived from the original mm dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y Z (1) mm 1.75 0.25 0.10 1.45 1.25 0.25 0.49 0.36 0.25 0.19 10.0 9.8 4.0 3.8 1.27 6.2 5.8 1.05 1.0 0.4 0.7 0.6 0.25 0.25 0.1 0.7 0.3 inches 0.069 0.010 0.057 0.004 0.049 0.01 0.019 0.0100 0.39 0.014 0.0075 0.38 0.16 0.15 0.05 0.039 0.016 0.028 0.020 0.01 0.01 0.004 0.028 0.012 0.244 0.041 0.228 θ o 8 o 0 Note 1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included. Fig. 9. REFERENCES OUTLINE VERSION IEC JEDEC SOT109-1 076E07 MS-012 JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 Package outline SOT109-1 (SO16) 74HC_HCT174_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 26 February 2021 © Nexperia B.V. 2021. All rights reserved 10 / 14 74HC174-Q100; 74HCT174-Q100 Nexperia Hex D-type flip-flop with reset; positive-edge trigger TSSOP16: plastic thin shrink small outline package; 16 leads; body width 4.4 mm D SOT403-1 E A X c y HE v M A Z 9 16 Q A2 pin 1 index (A 3 ) A1 A θ Lp 1 L 8 detail X w M bp e 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (2) e HE L Lp Q v w y Z (1) θ mm 1.1 0.15 0.05 0.95 0.80 0.25 0.30 0.19 0.2 0.1 5.1 4.9 4.5 4.3 0.65 6.6 6.2 1 0.75 0.50 0.4 0.3 0.2 0.13 0.1 0.40 0.06 8o 0o Notes 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic interlead protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT403-1 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-18 MO-153 Fig. 10. Package outline SOT403-1 (TSSOP16) 74HC_HCT174_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 26 February 2021 © Nexperia B.V. 2021. All rights reserved 11 / 14 74HC174-Q100; 74HCT174-Q100 Nexperia Hex D-type flip-flop with reset; positive-edge trigger 12. Abbreviations Table 10. Abbreviations Acronym Description CMOS Complementary Metal-Oxide Semiconductor DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MIL Military MM Machine Model TTL Transistor-Transistor Logic 13. Revision history Table 11. Revision history Document ID Release date Data sheet status Change notice Supersedes 74HC_HCT174_Q100 v.2 20210226 Product data sheet - Modifications: • • • • 74HC_HCT174_Q100 v.1 74HC_HCT174_Q100 Product data sheet 74HC_HCT174_Q100 v.1 The format of this data sheet has been redesigned to comply with the identity guidelines of Nexperia. Legal texts have been adapted to the new company name where appropriate. Section 2 updated. Section 7: Derating values for Ptot total power dissipation updated. 20130417 Product data sheet - All information provided in this document is subject to legal disclaimers. Rev. 2 — 26 February 2021 - © Nexperia B.V. 2021. All rights reserved 12 / 14 74HC174-Q100; 74HCT174-Q100 Nexperia Hex D-type flip-flop with reset; positive-edge trigger equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer's own risk. 14. Legal information Data sheet status Document status [1][2] Product status [3] Definition Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the internet at https://www.nexperia.com. Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use in automotive applications — This Nexperia product has been qualified for use in automotive applications. Unless otherwise agreed in writing, the product is not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or 74HC_HCT174_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 26 February 2021 © Nexperia B.V. 2021. All rights reserved 13 / 14 74HC174-Q100; 74HCT174-Q100 Nexperia Hex D-type flip-flop with reset; positive-edge trigger Contents 1. General description...................................................... 1 2. Features and benefits.................................................. 1 3. Ordering information....................................................1 4. Functional diagram.......................................................2 5. Pinning information......................................................2 5.1. Pinning.........................................................................2 5.2. Pin description............................................................. 3 6. Functional description................................................. 3 7. Limiting values............................................................. 3 8. Recommended operating conditions..........................4 9. Static characteristics....................................................4 10. Dynamic characteristics............................................ 6 10.1. Waveforms and test circuit........................................ 8 11. Package outline........................................................ 10 12. Abbreviations............................................................ 12 13. Revision history........................................................12 14. Legal information......................................................13 © Nexperia B.V. 2021. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 26 February 2021 74HC_HCT174_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 26 February 2021 © Nexperia B.V. 2021. All rights reserved 14 / 14
74HC174PW-Q100J 价格&库存
很抱歉,暂时无法提供与“74HC174PW-Q100J”相匹配的价格&库存,您可以联系我们找货
74HC174PW-Q100J
  • 2500+2.048792500+0.25639
  • 5000+1.991955000+0.24927
  • 7500+1.963497500+0.24571
  • 12500+1.9319412500+0.24176
  • 17500+1.9135017500+0.23946
  • 25000+1.8957825000+0.23724
