HL CONNECTOR
3.96mm pitch/Disconnectable Crimp style Wire-to-wire connectors
Specifications –––––––––––––––––––
• Current rating: 7A AC, DC max.
• Voltage rating: 300V AC, DC max.
• Temperature range: -25˚C to +90˚C
(including temperature rise in applying
electrical current)
• Contact resistance: Initial value/7m Ω max.
After environmental testing/10m Ω max.
• Insulation resistance: 1,000M Ω min.
• Withstanding voltage: 1,500V AC/minute
• Applicable wire: AWG #22 to #18
0.3 to 0.75mm2
• Applicable panel thickness: 0.7 to 2.0mm
* Compliant with RoHS.
* Refer to "General Instruction and Notice when using
Terminals and Connectors" at the end of this catalog.
* Contact JST for details.
• Low insertion force contact
• Housing lance
• Inner-housing lock
• Secondary retainers
• Panel lock construction
Note: The current rating varies depending on the number of circuits and the
wire size used in each connector. The table below lists the current rating
as a function of the number of circuits and wire size.
Current unit: A
Circuits
2
3
4
8
9
12
Standards ––––––––––––––––––––
Recognized E60389
1 Certified LR20812
2 R50171609
Wire size (AWG)
#20
7
6
6
4
4
3
5
4
4
3
3
2
#22
4
4
4
3
3
2
Panel layout and Assembly layout
4 circuits : 15.0
8 to 12 circuits : 15.1
(including retainer)
(4, 8 and 12 circuits)
9.5
(2 and 3 circuits)
31.6
31.6
34.2 (including retainer)
7.5
7.5
Shape II
E
0.7
C
D
14.7
C
D
9.8
Shape I
E
3.0
A
B
A
B
Circuits
Receptacle housing
Panel hole
shape
Panel hole dimensions (mm)
A ±0.13
B ±0.13
General tolerance
C ±0.1
D ±0.13
E ±0.1
2
6.4
1.0
3
6.4
1.0
12.0
3.2
12.0
3.2
12.0
3.2
4.4
15.7
1
9.5
HLR-02V
4.4
19.7
1
13.5
HLR-03V
5.6
15.7
4
2
9.5
HLR-04V
5.6
23.6
8
2
17.4
HLR-08V
5.6
31.6
12
2
25.3
HLR-12V
Note: 1. Punch holes in the panel according to the figures and table shown above. Burrs must be removed.
2. The strength of the panel must be considered when punching two or more holes.
3. The connector must be inserted from the same side as the hole is punched.
Applicable panel
thickness (mm)
0.7∼2.0
1
HL CONNECTOR
Contact
Applicable wire
Model No.
Pin contact
Socket contact
mm2
AWG #
SSM-21T-P1.4
SSF-21T-P1.4
0.3∼0.75
22∼18
Insulation O.D. Q´ty /
reel
(mm)
1.4
Pin contact
6,000
Material and Finish
17.6
3.8
Phosphor bronze, tin-plated (reflow treatment)
0.5
4.3
1.5∼2.2
RoHS compliance
Note: Contact JST for special products.
Crimping
machine Crimp applicator
Contact
Socket contact
SSM-21T-P1.4
AP-K2N
2.2
SSF-21T-P1.4
12.6
1.0
MKS-L
Applicator
Dies
Crimp applicator with dies
MK/SSF/M-21-14 APLMK SSF/M21-14
1.9
4.3
Contact position location numbers
Contact position numbers are stamped
Retainer
Retainer
Receptacle housing
Plug housing
2
1
3
1
3
L JST
1
3
L JST
4
7
3
L JST
4 10
3
9
5
1
7
1
1
9
6
5
1
8
4
4
7
7
2
2
3
5
1
2
4
7
6
8
3
7
3
8
5
9
5 11
3
6
9
2
5
8
1
4
7
2
8
1
7
8
7
2
2
12
6
5
4
8
2
8
3
6 12
11
6
10
2
9
7
1
3
9
1
6
9
2
4
1
8
8
3
1 5
10 4
9
6
2
11 5
4
10
5 1
5
L JST
2
L JST
2
6
6
5
11
3
4
6
12
7
12 6
3
7
4
2
1
1
4
8
L JST
8
4
3
2
2
1
2
1
2
3
1
L JST
2
1
3
1
1
4
L JST
2
L JST
2
L JST
2
4
3
3
L JST
2
2
1
Plug housing
3
Receptacle housing
HL CONNECTOR
Housing
Material: Housing...PA 66, UL94V-0, white
Retainer...Glass-filled PA 66, UL94V-0, ivory
Circuits
Voltage Current
rating
rating
Receptacle housing(for pin contact)
HLR-02V
Plug housing(for socket contact)
3.0
Q´ty /
bag
Q´ty /
bag
L JST
2
9.16
HLP-02V
Retainer
HLS-02V
(commonly used for
2-circuit housing and
4-circuit housing)
Q´ty /
bag
7.16
24.1
9.16
2.5
7A
1
1,000
11.6
7.5
6.1
2.5
1,000
3.8
7.1
1,000
L JST
2
2.6 3.96 2.6
HLR-02VF
1
6.1
2.5
24.1
HLR-03V
HLP-03V
Q´ty /
bag
HLS-03V
Q´ty /
bag
3
3.0
Q´ty /
bag
11.12
300V
L JST
2
3.0
1
6.1
2
1
500
11.6
3.0
L JST
13.12
1,000
7.1
3.8
7.5
2.5
6.1
1,000
1
13.12
2
6A
L JST
300V
2
3
3
6.1
24.1
2.5
HLR-04V
3.0
Q´ty /
bag
HLP-04V
Q´ty /
bag
2
4
9.16
HLS-02V
(commonly used for
4-circuit housing)
Q´ty /
bag
3
11.6
L JST
7.5
500
2.5
HLP-08V
1
3.0
1
11.6
17.28
L JST
17.08
13.12
500
16.75
2.5
HLP-12V
Q´ty /
bag
HLS-12V
Q´ty /
bag
12
2
8
23.0
25.0
500
1,000
3.0
1
1
7
7
L JST
11
10
9
3
8
9
6
4
5
10
4
5
11.6
24.1
11.7
3
11
500
2
6
3A
12
300V
L JST
12
25.0
3.0
Q´ty /
bag
7.5
Q´ty /
bag
9
6
2
4
HLR-12V
1
2
7
3
2.6
3
8
5
7.92
8
5
2
1
17.08
5
6
24.1
8
2
7.1
Q´ty /
bag
7
6
7
3
HLP-09V
500
2.5
16.75
1,000
3.8
24.1
Q´ty /
bag
9
2.6
Q´ty /
bag
500
11.7
5
7
2.5
HLR-09VF
4A
HLS-08V
7.5
4
4
3
8
11.6
2.5
11.7
300V
6
4
3.0
Q´ty /
bag
500
L JST
9
1,000
24.1
Q´ty /
bag
L JST
4A
7.1
1
2.5
HLR-08V
300V
3.8
3
L JST
11.7
8
500
11.7
2
4
2.6 3.96 2.6
HLR-04VF
7.16
3
24.1
2.5
6A
1
300V
9.16
2
3.0
4
4
1
L JST
11.7
7.5
3.8
2.5
7.1
11.7
2.5
RoHS compliance
3
很抱歉,暂时无法提供与“HLR-03V”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.12234
- 50+0.89100
- 150+0.79186
- 500+0.66809
- 2500+0.61301
