HEF4051B-Q100
8-channel analog multiplexer/demultiplexer
Rev. 2 — 11 September 2014
Product data sheet
1. General description
The HEF4051B-Q100 is an 8-channel analog multiplexer/demultiplexer with three
address inputs (S1 to S3), an active LOW enable input (E), eight independent
inputs/outputs (Y0 to Y7) and a common input/output (Z). The device contains eight
bidirectional analog switches, each with one side connected to an independent
input/output (Y0 to Y7) and the other side connected to a common input/output (Z). With
E LOW, one of the eight switches is selected (low-impedance ON-state) by S1 to S3. With
E HIGH, all switches are in the high-impedance OFF-state, independent of S1 to S3. If
break before make is needed, then it is necessary to use the enable input.
VDD and VSS are the supply voltage connections for the digital control inputs (S1 to S3,
and E). The VDD to VSS range is 3 V to 15 V. The analog inputs/outputs (Y0 to Y7, and Z)
can swing between VDD as a positive limit and VEE as a negative limit. VDD VEE may not
exceed 15 V. Unused inputs must be connected to VDD, VSS, or another input. For
operation as a digital multiplexer/demultiplexer, VEE is connected to VSS (typically
ground). VEE and VSS are the supply voltage connections for the switches.
This product has been qualified to the Automotive Electronics Council (AEC) standard
Q100 (Grade 1) and is suitable for use in automotive applications.
2. Features and benefits
Automotive product qualification in accordance with AEC-Q100 (Grade 1)
Specified from 40 C to +85 C and from 40 C to +125 C
Fully static operation
5 V, 10 V, and 15 V parametric ratings
Standardized symmetrical output characteristics
ESD protection:
MIL-STD-833, method 3015 exceeds 2000V
HBM JESD22-A114F exceeds 2000 V
MM JESD22-A115-A exceeds 200 V (C = 200 pf, R = 0 )
Complies with JEDEC standard JESD 13-B
3. Applications
Analog multiplexing and demultiplexing
Digital multiplexing and demultiplexing
Signal gating
HEF4051B-Q100
Nexperia
4. Ordering information
Table 1.
All types operate from 40 C to +125 C.
Type number
Package
Name
Description
Version
HEF4051BT-Q100
SO16
plastic small outline package; 16 leads; body width 3.9 mm
SOT109-1
HEF4051BTT-Q100
TSSOP16
plastic thin shrink small outline package; 16 leads; body width 4.4 mm
SOT403-1
5. Functional diagram
VDD
16
13 Y0
S1 11
14 Y1
15 Y2
S2 10
12 Y3
LOGIC
LEVEL
CONVERSION
1 − OF − 8
DECODER
1 Y4
S3 9
5 Y5
2 Y6
4 Y7
E 6
3 Z
8
VSS
Fig 1.
7
VEE
001aac277
Functional diagram
HEF4051B_Q100
Product data sheet
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2017. All rights reserved
2 of 21
HEF4051B-Q100
Nexperia
Yn
VDD
VDD
Z
VEE
001aac281
Fig 2.
Schematic diagram (one switch)
11
10
9
13
S1
S2
S3
11
14
10
15
9
12
1
5
2
E
6
4
3
Y0
6
Y1
1
X
3
EN
Y2
MUX/DMUX
Y3
Y4
1
Y5
2
Y6
3
3
4
Y7
5
Z
6
001aac278
7
13
14
15
12
1
5
2
4
001aac279
Fig 3.
Logic symbol
HEF4051B_Q100
Product data sheet
Fig 4.
IEC logic symbol
3 of 21
HEF4051B-Q100
Nexperia
Y0
Y1
S1
S2
S3
E
LEVEL
CONVERTER
Y2
LEVEL
CONVERTER
Y3
LEVEL
CONVERTER
Y4
LEVEL
CONVERTER
Y5
Y6
Y7
Z
001aac280
Fig 5.
Logic diagram
HEF4051B_Q100
Product data sheet
4 of 21
HEF4051B-Q100
Nexperia
6. Pinning information
6.1 Pinning
+()%4
很抱歉,暂时无法提供与“HEF4051BT-Q100,118”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 2500+1.516962500+0.18343
- 5000+1.509875000+0.18258
- 7500+1.509837500+0.18257
- 12500+1.5098012500+0.18257
- 25000+1.5097725000+0.18256
