WLK Series WLK31
MFG Part Number: 1432.49
Legacy Product
WLK Series Liquid Cooling System
Note: This product is not recommended for new designs.
Please use the recommended replacement:
MFG Part Number: 385912-029
Description: NRC5000-A1-20-ST1
The WLK31 is a compressor-based recirculating chiller that offers
dependable, compact performance by controlling the temperature of
water or water with glycol (antifreeze) in a liquid circuit. The coolant is
recirculated using a pump with high MTBF. Heat from the coolant is
absorbed by a durable, compressor-based system and dissipated to the
ambient environment. The unit is regulated with an easy-to-use digital
temperature controller with push button interface. The unit is housed
inside a rugged sheet metal casing. Standard cooling capacities range
are available up to 3 KW. However, custom solutions have been designed
to remove up to 200 KW of heat.
Features
Cooling to below ambient
High heat pumping capacity
Variable temperature control
High temperature stability
CFC free refrigerants
Long life operation
Applications
Cooling Particle Accelerators: Linear Accelerators and
Cyclotrons
Semiconductor Fabrication Equipment Cooling
X-ray Cooling in Industrial Scanners
WLK Series WLK31
Legacy Product
TECHNICAL SPECIFICATIONS
Performance
Nominal Cooling Capacity
3,000 Watts
Nominal Operating Flowrate (60 Hz)
6.0 L/min @ 4.0 Bar
Nominal Operating Flowrate (50 Hz)
6.0 L/min @ 4.0 Bar
Operation
Operating Temperature
5°C to 35°C
Storage temperature range (w/o coolant)
-25°C to 70°C
Humidity range
20% to 80%
Storage Humidity range
5% to 95%, non-condensing
Input Voltage
230 VAC
Frequency
50/60 Hz
Physical
Height
920 mm
Length
590 mm
Width
610 mm
Weight
115 kg
WLK Series WLK31
Legacy Product
Any information furnished by Laird and its agents, whether in specifications, data sheets, product catalogues or otherwise, is believed to be (but is not warranted as
being) accurate and reliable, is provided for information only and does not form part of any contract with Laird. All specifications are subject to change without notice.
Laird assumes no responsibility and disclaims all liability for losses or damages resulting from use of or reliance on this information. All Laird products are sold
subject to the Laird Terms and Conditions of sale (including Laird’s limited warranty) in effect from time to time, a copy of which will be furnished upon request.
© Copyright 2019-2022 Laird Thermal Systems, Inc. All rights reserved. Laird™, the Laird Ring Logo, and Laird Thermal Systems™ are trademarks or registered
trademarks of Laird Limited or its subsidiaries.
Revision: 00 Date: 06-01-2022
Print Date: 06-16-2022
很抱歉,暂时无法提供与“1432.49”相匹配的价格&库存,您可以联系我们找货
