1421.70
1421.70
    LAIRD(莱尔德)
    RECIRCULATINGCHILLERS
1421.70 数据手册
WLK Series WLK21 MFG Part Number: 1421.70 Legacy Product WLK Series Liquid Cooling System Note: This product is not recommended for new designs. Please use the recommended replacement: MFG Part Number: 385911-015 Description: NRC2400-A1-20-ST1 The WLK21 is a compressor-based recirculating chiller that offers dependable, compact performance by controlling the temperature of water or water with glycol (antifreeze) in a liquid circuit. The coolant is recirculated using a pump with high MTBF. Heat from the coolant is absorbed by a durable, compressor-based system and dissipated to the ambient environment. The unit is regulated with an easy-to-use digital temperature controller with push button interface. The unit is housed inside a rugged sheet metal casing. Standard cooling capacities range are available up to 3 KW. However, custom solutions have been designed to remove up to 200 KW of heat. Features ● ● ● ● ● ● Cooling to below ambient High heat pumping capacity Variable temperature control High temperature stability CFC free refrigerants Long life operation Applications ● ● ● Cooling Particle Accelerators: Linear Accelerators and Cyclotrons Semiconductor Fabrication Equipment Cooling X-ray Cooling in Industrial Scanners WLK Series WLK21 MFG Part Number: 1421.70 Legacy Product TECHNICAL SPECIFICATIONS Performance Nominal Cooling Capacity 2,000 Watts Nominal Operating Flowrate (60 Hz) 6.0 L/min @ 6.0 Bar Nominal Operating Flowrate (50 Hz) 6.0 L/min @ 6.0 Bar Operation Operating Temperature 5°C to 30°C Storage temperature range (w/o coolant) -25°C to 70°C Humidity range 20% to 80% Storage Humidity range 5% to 95%, non-condensing Input Voltage 230 VAC Frequency 50/60 Hz Physical Height 920 mm Length 590 mm Width 610 mm Weight 115 kg WLK Series WLK21 MFG Part Number: 1421.70 Legacy Product Any information furnished by Laird and its agents, whether in specifications, data sheets, product catalogues or otherwise, is believed to be (but is not warranted as being) accurate and reliable, is provided for information only and does not form part of any contract with Laird. All specifications are subject to change without notice. Laird assumes no responsibility and disclaims all liability for losses or damages resulting from use of or reliance on this information. All Laird products are sold subject to the Laird Terms and Conditions of sale (including Laird’s limited warranty) in effect from time to time, a copy of which will be furnished upon request. © Copyright 2019-2022 Laird Thermal Systems, Inc. All rights reserved. Laird™, the Laird Ring Logo, and Laird Thermal Systems™ are trademarks or registered trademarks of Laird Limited or its subsidiaries. Revision: 00 Date: 06-01-2022 Print Date: 06-16-2022
1421.70 价格&库存
很抱歉,暂时无法提供与“1421.70”相匹配的价格&库存,您可以联系我们找货
