TAS-A1NH1-P11
TAS-A1NH1-P11
    FORMERICAOPTOELECTRONICSINC.(传承光电)
    TAS-A1NH1-P11
TAS-A1NH1-P11 数据手册
10GbE SFP+ SR Transceiver PRODUCT NUMBER: TAS-A1NH1-P11 Specification Small Form Factor Pluggable Duplex LC Receptacle – SFP+ Optical Transceivers 10 Gigabit Ethernet 10GBASE-SR Ordering Information TAS–A1NH1–P11 Voltage / Temperature 1 : 3.3V / 0 ℃ ~ +70 ℃ Model Name Voltage Category TAS-A1NH1-P11 3.3V Device type With DDMI 850 nm VCSEL Formerica OptoElectronics Inc . 5F-11, No.38, Taiyuan St.,Zhubei City, Hsinchu County 30265, Taiwan Ph: +886-3-5600286 Fax: +886-3-5600239 Interface AC / AC Coupling LOS Temperature LVTTL 0C~+70C Distance Latch Color 33m / 82m /300m Black (OM1/ OM2/OM3) Version 01 1 10GbE SFP+ SR Transceiver PRODUCT NUMBER: TAS-A1NH1-P11 Features             Optical interface compliant to IEEE 802.3ae 10GBASE-SR/SW Compliant with SFP+ MSA Data Rate 10.3125 Gbps 850nm VCSEL TOSA and PIN ROSA Maximum link length of 300m on 2000MHz-km MMF LC duplex receptacle Low power dissipation ( 4.25 GBd and when low input signal rate≦ 4.25 GBd. Receiver Loss of Signal Indication Rate Select 1, optionally controls SFP+ module transmitter. When high input signaling rate> 4.25 GBd and when low input signal rate≦ 4.25 GBd. Module Receiver Ground Module Receiver Ground Receiver Inverted Data Output Receiver Data Output Module Receiver Ground Module Receiver 3.3 V Supply Module Transmitter 3.3 V Supply Module Transmitter Ground Transmitter Non-Inverted Data Input Transmitter Inverted Data Input Module Transmitter Ground Note 1 2 3 2 2 1 1 1 1 1 Note: 1. Module ground pins are isolated from the module case and chassis ground within the module. 2. Shall be pulled up with 4.7k to 10k ohm to a voltage between 3.15V and 3.45V on the host board. 3. Shall be pulled up with 4.7k to 10k ohm to VccT in the module. Formerica OptoElectronics Inc . 5F-11, No.38, Taiyuan St.,Zhubei City, Hsinchu County 30265, Taiwan Ph: +886-3-5600286 Fax: +886-3-5600239 Version 01 6 10GbE SFP+ SR Transceiver PRODUCT NUMBER: TAS-A1NH1-P11 Absolute Maximum Ratings Parameters Power Supply Voltage Storage Temperature Relative Humidity Optical Receiver Power (Damage) Symbol VCC Tc RH Min. 0 -40 5 Max. 3.6 85 95 Unit V C % - 4 dBm Recommended Operating Environment Parameters Symbol Min. Typical Max Unit VCC 3.135 3.3 3.465 V TC 0 25 70 C Power Supply Voltage Operating Case Temperature Formerica OptoElectronics Inc . 5F-11, No.38, Taiyuan St.,Zhubei City, Hsinchu County 30265, Taiwan Ph: +886-3-5600286 Fax: +886-3-5600239 Version 01 7 10GbE SFP+ SR Transceiver PRODUCT NUMBER: TAS-A1NH1-P11 Optical Characteristics The following optical characteristics are defined over the Recommended Operating Environment unless otherwise specified. Parameter Symbol Center Wavelength RMS spectral width Average Optical Power Optical Power OMA Laser Off Power Extinction Ratio Transmitter Dispersion Penalty Relative Intensity Noise Optical Return Loss Tolerance λt Pm Center Wavelength Receiver Sensitivity (OMA) Stressed Sensitivity (OMA) Los Assert Los Dessert Los Hysteresis Overload Receiver Reflectance Max Unit 860 Note 1 nm nm -1 dBm Note 1 -30 dBm dBm dB TDP 3.9 dB Rin -128 dB/Hz 12 dB 860 nm -11.1 dBm -7.5 dBm Pavg Poma Poff ER λr Min. Typical Transmitter 840 850 -6.5 3.5 Receiver 840 850 Psens LosA LosD LosH Pin -30 -1 dBm dBm dB dBm -12 dB -12 0.5 Notes 12dB reflection Note: 1. Trade-offs are available between spectral width, center wavelength and minimum OMA, as shown in follow table. Formerica OptoElectronics Inc . 5F-11, No.38, Taiyuan St.,Zhubei City, Hsinchu County 30265, Taiwan Ph: +886-3-5600286 Fax: +886-3-5600239 Version 01 8 10GbE SFP+ SR Transceiver PRODUCT NUMBER: TAS-A1NH1-P11 Center Wavelength (nm) 840 to 842 842 to 844 844 to 846 846 to 848 848 to 850 850 to 852 852 to 854 854 to 856 856 to 858 858 to 860 RMS Spectral width (nm) Up to 0.05 0.05 to 0.1 0.1 to 0.15 0.15 to 0.2 0.2 to 0.25 0.25 to 0.3 0.3 to 0.35 0.35 to 0.4 0.4 to 0.45 -4.2 -4.2 -4.2 -4.3 -4.3 -4.3 -4.3 -4.3 -4.3 -4.3 -4.2 -4.2 -4.2 -4.2 -4.2 -4.2 -4.2 -4.3 -4.3 -4.3 -4.1 -4.2 -4.2 -4.2 -4.2 -4.2 -4.2 -4.2 -4.2 -4.2 -4.1 -4.1 -4.1 -4.1 -4.1 -4.1 -4.1 -4.1 -4.1 -4.2 -3.9 -3.9 -4.0 -4.0 -4.0 -4.0 -4.0 -4.0 -4.0 -4.1 -3.8 -3.8 -3.8 -3.8 -3.8 -3.8 -3.9 -3.9 -3.9 -3.9 -3.5 -3.6 -3.6 -3.6 -3.6 -3.6 -3.7 -3.7 -3.7 -3.7 -3.2 -3.3 -3.3 -3.3 -3.3 -3.4 -3.4 -3.4 -3.5 -3.5 -2.8 -2.9 -2.9 -2.9 -3.0 -3.0 -3.1 -3.1 -3.1 -3.2 Digital Diagnostic Functions The following digital diagnostic characteristics are defined over the Recommended Operating Environment unless otherwise specified. It is compliant to SFF8472 Rev10.2 with internal calibration mode. For external calibration mode please contact our sales stuff. Parameter Temperature monitor absolute error Laser power monitor absolute error RX power monitor absolute error Supply voltage monitor absolute error Bias current monitor Symbol Min. Max Unit DMI_Temp -3 3 degC DMI_TX -3 3 dB DMI_RX -3 3 dB DMI_VCC -0.08 0.08 V DMI_Ibias -10% 10% mA Formerica OptoElectronics Inc . 5F-11, No.38, Taiyuan St.,Zhubei City, Hsinchu County 30265, Taiwan Ph: +886-3-5600286 Fax: +886-3-5600239 Notes Over operating temp -1dBm to -12dBm range Full operating range Version 01 9 10GbE SFP+ SR Transceiver PRODUCT NUMBER: TAS-A1NH1-P11 Electrical Characteristics The following electrical characteristics are defined over the Recommended Operating Environment unless otherwise specified. Parameter Data Rate Power Consumption Single Ended Output Voltage Tolerance C common mode voltage tolerance Tx Input Diff Voltage Tx Fault Data Dependent Input Jitter Data Input Total Jitter Symbol Min. Typical 10.3125 600 Transmitter -0.3 Max 800 Unit Gbps mW 4 V 15 Notes mV VI 180 700 mV VoL -0.3 0.4 V DDJ 0.1 UI TJ 0.28 UI -0.3 4 V Vo 300 850 mV Tr/Tf 30 At 0.7mA Receiver Single Ended Output Voltage Tolerance Rx Output Diff Voltage Rx Output Rise and Fall Time Total Jitter Deterministic Jitter TJ DJ Formerica OptoElectronics Inc . 5F-11, No.38, Taiyuan St.,Zhubei City, Hsinchu County 30265, Taiwan Ph: +886-3-5600286 Fax: +886-3-5600239 ps 0.7 0.42 20% to 80% UI UI Version 01 10 10GbE SFP+ SR Transceiver PRODUCT NUMBER: TAS-A1NH1-P11 Control And Status I/O Timing Characteristics Timing characteristics of control and status I/O are included in Table 9, which is also defined in SFF-8431. Formerica OptoElectronics Inc . 5F-11, No.38, Taiyuan St.,Zhubei City, Hsinchu County 30265, Taiwan Ph: +886-3-5600286 Fax: +886-3-5600239 Version 01 11 10GbE SFP+ SR Transceiver PRODUCT NUMBER: TAS-A1NH1-P11 Content in 2-Wire Address A0H Address 00 01 02 03 04 05 06 07 08 09 10 11 12 13 14 15 16 17 18 19 20 ~ 35 36 37 ~ 39 40 ~ 55 56 ~ 59 60 ~ 61 62 63 64 65 66 67 68 ~ 83 84 ~ 89 90 ~ 91 92 HEX 03 04 07 10 00 00 00 00 00 00 00 06 67 00 00 00 08 03 00 1E 46,4F,52,4D,45,52,49,43 ,41,4F,45,20,20,20,20,20 00 00,00,00 54,41,53,2D,41,31,4E,48,31, 2D,50,31,31,20,20,20 00,00,00,00 03,52 00 00 1A 00 00 Serial Number yy/mm/dd 20,20 68 F0 93 03 94 95 96~127 Name of Field Identifier Extended Identifier Connector type 10G Ethernet Compliance Codes SONET Compliance Codes SONET Compliance Codes Ethernet Compliance Codes Fiber Channel link length Fiber Channel transmitter technology Fiber Channel transmission media Fiber Channel speed Encoding codes: Nominal Bit Rate (units of 100Mbps) Rate identifier Link length supported for 9um fiber Link length supported for 9um fiber Link length supported for 50um,OM2 Link length supported for 62.5um,OM1 Link length supported for copper Link length supported for 50um,OM3 Description SFP SFP LC 10G Base SR Not compliant Not compliant Not compliant Not compliant Not compliant Not compliant Not compliant 64B/66B 10.3Gbps Unspecified N/A (units of km) N/A (units of 100m) 82m (units of 10m) 33m (units of 10m) N/A (units of 1m) 300m (units of 10m) Vendor Name FORMERICAOE Unallocated Vendor OUI Unspecified Part Number TAS-A1NH1-P11 Vendor Revision number Laser Wavelength Unallocated CC_BASE: Options Options Bit Rate, max. Bit Rate, min. Serial Number Date Code Vendor specific lot code Diagnostic Monitoring Type Unspecified 850nm Enhanced Options (soft) SFF-8472 Compliance CC_EXT Vendor specific Formerica OptoElectronics Inc . 5F-11, No.38, Taiyuan St.,Zhubei City, Hsinchu County 30265, Taiwan Ph: +886-3-5600286 Fax: +886-3-5600239 Check sum of byte 0 ~ 62 TX-DIS, TX_FAULT, RX-LOS Unspecified Unspecified Unspecified Internal calibration Alarm/Warning flags, Soft TxDisable, Soft TxFault, Soft RxLOS implemented Rev10.2 Check sum of byte 64 ~ 94 Version 01 12 10GbE SFP+ SR Transceiver PRODUCT NUMBER: TAS-A1NH1-P11 Content in 2-Wire Address A2H Add Bytes Name Hex Real Value 00-01 02-03 04-05 06-07 08-09 10-11 12-13 14-15 16-17 18-19 20-21 22-23 24-25 26-27 28-29 30-31 32-33 34-35 36-37 38-39 40-55 56-59 60-63 64-67 68-71 72-75 76-77 78-79 80-81 82-83 84-85 86-87 88-89 90-91 92-94 95 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 16 4 4 4 4 4 2 2 2 2 2 2 2 2 3 1 Temp High Alarm Temp Low Alarm Temp High Warning Temp Low Warning Voltage High Alarm Voltage Low Alarm Voltage High Warning Voltage Low Warning Bias High Alarm Bias Low Alarm Bias High Warning Bias Low Warning TX Power High Alarm TX Power Low Alarm TX Power High Warning TX Power Low Warning RX Power High Alarm RX Power Low Alarm RX Power High Warning RX Power Low Warning Reserved RX_PWR(4) RX_PWR(3) RX_PWR(2) RX_PWR(1) RX_PWR(0) TX_I(Slope) TX_I(Offset) TX_PWR(Slope) TX_PWR(Offset) T(Slope) T(Offset) V(Slope) V(Offset) Reserved Checksum 5A00 EC00 5500 F100 9470 6D60 9088 7148 2710 00FA 2328 01F4 3E1C 0640 3138 07D0 3138 0064 2710 007E FF 00000000 00000000 00000000 3F800000 00000000 0100 0000 0100 0000 0100 0000 0100 0000 00 90℃ -20℃ 85℃ -15℃ 3.8V 2.8V 3.7V 2.9V 20mA 0.5mA 18mA 1mA 2.01dBm -7.96dBm 1dBm -6.99dBm 1dBm -20dBm 0dBm -19dBm 0 0 0 1 0 1 0 1 0 1 0 1 0 - Formerica OptoElectronics Inc . 5F-11, No.38, Taiyuan St.,Zhubei City, Hsinchu County 30265, Taiwan Ph: +886-3-5600286 Fax: +886-3-5600239 Version 01 13 10GbE SFP+ SR Transceiver PRODUCT NUMBER: TAS-A1NH1-P11 Mechanical (mm) ESD This transceiver is specified as ESD threshold 2kV for all electrical input pins, tested per MIL-STD-883, Method 3015.4 /JESD22-A114-A (HBM). However, normal ESD precautions are still required during the handling of this module. This transceiver is shipped in ESD protective packaging. It should be removed from the packaging and handled only in an ESD protected environment. LASER Safety This is a Class 1 Laser Product according to IEC 608251:1993:+A1:1997+A2:2001. This product complies with 21 CFR 1040.10 and 1040.11 except for deviations pursuant to Laser Notice No. 50, dated (July 26, 2001) Formerica OptoElectronics Inc . 5F-11, No.38, Taiyuan St.,Zhubei City, Hsinchu County 30265, Taiwan Ph: +886-3-5600286 Fax: +886-3-5600239 Version 01 14
TAS-A1NH1-P11 价格&库存
很抱歉,暂时无法提供与“TAS-A1NH1-P11”相匹配的价格&库存,您可以联系我们找货
