TAS-A5NB1-FAH
TAS-A5NB1-FAH
    FORMERICAOPTOELECTRONICSINC.(传承光电)
    TAS-A5NB1-FAH
TAS-A5NB1-FAH 数据手册
10GbE SFP+ LR Transceiver PRODUCT NUMBER: TAS-A5NB1-FAH Specification Small Form Factor Pluggable Duplex LC Receptacle – SFP+ Optical Transceivers 10 Gigabit Ethernet 10GBASE-LR Ordering Information TAS–A5NB1–FAH Model Name Voltage Category TAS-A5NB1-FAH 3.3V With DDMI Device type Interface LOS Temperature Distance 1310 nm DFB AC / AC Coupling LVTTL -5C~+70C 10km Formerica OptoElectronics Inc . 5F-11, No.38, Taiyuan St.,Zhubei City , Hsinchu County 30265, Taiwan Ph: +886-3-5600286 Fax: +886-3-56002398 Latch Color Blue Version 01 Page 1 10GbE SFP+ LR Transceiver PRODUCT NUMBER: TAS-A5NB1-FAH Features            Optical Interface compliant to IEEE 802.3ae 10GBASE-LR/LW Compliant with SFP+ MSA Data Rate 10.3125Gbps 1310nm DFB TOSA and PIN ROSA Applicable for 10 km SMF connection LC duplex receptacle Low power dissipation (< 1W) Hot Pluggable All-metal housing for superior EMI performance Built in digital diagnostic Functions ROHS Compliant Applications     10GBASE-LR 10Gigabit Ethernet High-speed storage area networks Computer cluster cross-connect Custom high-speed data pipes Transceiver Block Diagram Formerica OptoElectronics Inc . 5F-11, No.38, Taiyuan St.,Zhubei City , Hsinchu County 30265, Taiwan Ph: +886-3-5600286 Fax: +886-3-56002398 Version 01 Page 2 10GbE SFP+ LR Transceiver PRODUCT NUMBER: TAS-A5NB1-FAH Proposed Applications Schematics Formerica OptoElectronics Inc . 5F-11, No.38, Taiyuan St.,Zhubei City , Hsinchu County 30265, Taiwan Ph: +886-3-5600286 Fax: +886-3-56002398 Version 01 Page 3 10GbE SFP+ LR Transceiver PRODUCT NUMBER: TAS-A5NB1-FAH Pin Definition and Descriptions Formerica OptoElectronics Inc . 5F-11, No.38, Taiyuan St.,Zhubei City , Hsinchu County 30265, Taiwan Ph: +886-3-5600286 Fax: +886-3-56002398 Version 01 Page 4 10GbE SFP+ LR Transceiver PRODUCT NUMBER: TAS-A5NB1-FAH PIN Logic 1 2 LVTTL-O Symbol VeeT TX_Fault 3 LVTTL-I TX_Dis 4 5 LVTTL-I/O LVTTL-I SDA SCL 6 Mod_ABS 7 LVTTL-I RS0 8 LVTTL-O RX_LOS 9 LVTTL-I RS1 10 11 12 13 14 15 16 17 18 19 20 CML-O CML-O CML-I CML-I VeeR VeeR RDRD+ VeeR VccR VccT VeeT TD+ TDVeeT Name / Description Module Transmitter Ground Module Transmitter Fault Transmitter Disable; Turns off transmitter laser output 2-Wire Serial Interface Data Line 2-Wire Serial Interface Clock Module Absent, connected to VeeT or VeeR in the module Rate Select 0, optionally controls SFP+ module receiver. When high input signaling rate> 4.25 GBd and when low input signal rate≦ 4.25 GBd. Receiver Loss of Signal Indication Rate Select 1, optionally controls SFP+ module transmitter. When high input signaling rate> 4.25 GBd and when low input signal rate≦ 4.25 GBd. Module Receiver Ground Module Receiver Ground Receiver Inverted Data Output Receiver Data Output Module Receiver Ground Module Receiver 3.3 V Supply Module Transmitter 3.3 V Supply Module Transmitter Ground Transmitter Non-Inverted Data Input Transmitter Inverted Data Input Module Transmitter Ground Note 1 2 3 1 1 1 1 1 Note: 1. Module ground pins are isolated from the module case and chassis ground within the module. 2. Shall be pulled up with 4.7k to 10k ohm to a voltage between 3.15V and 3.45V on the host board. 3. Shall be pulled up with 4.7k to 10k ohm to VccT in the module. Formerica OptoElectronics Inc . 5F-11, No.38, Taiyuan St.,Zhubei City , Hsinchu County 30265, Taiwan Ph: +886-3-5600286 Fax: +886-3-56002398 Version 01 Page 5 10GbE SFP+ LR Transceiver PRODUCT NUMBER: TAS-A5NB1-FAH Absolute Maximum Ratings Parameters Power Supply Voltage Storage Temperature Relative Humidity Optical Receiver Power (Damage) Symbol VCC Tc RH Pmax Min. 0 -40 5 Max. 3.6 85 95 1.5 Unit V C % dBm Recommended Operating Environment Parameters Symbol Min. Typical Max Unit Power Supply Voltage Operating Case Temperature Power Supply Current VCC 3.135 3.3 3.465 V TC -5 70 C 300 mA 1000 mW Icc Power Consumption Data rate Formerica OptoElectronics Inc . 5F-11, No.38, Taiyuan St.,Zhubei City , Hsinchu County 30265, Taiwan Ph: +886-3-5600286 Fax: +886-3-56002398 800 10.3125 Gbps Version 01 Page 6 10GbE SFP+ LR Transceiver PRODUCT NUMBER: TAS-A5NB1-FAH Optical Characteristics Parameter Symbol Min. Transmitter Typ. Max Unit Average Launch Power Po -8.2 --- 0.5 dBm Center wavelength λc 1260 --- 1355 nm SMSR 30 --- --- nm ER 3.5 --- --- dB TDP --- --- 3.2 dB POMA -5.2 --- --- dBm POMA-TDP -6.2 --- --- dBm Poff --- --- -30 dBm RIN --- --- -128 dB/Hz 12 --- --- dB Side Mode Suppression Ratio Extinction ratio Transmitter and dispersion penalty(max) Optical power OMA OMA-TDP Average launch power of OFF transmitted RIN12OMA Optical Return Loss Tolerance Notes Compliant with IEEE802.3ae eye mask Output eye Receiver λc Center wavelength Average receiver power(max) Pmax Average receiver power(min) Pmin Receiver Reflectance Rrx 1260 1355 nm 0.5 dBm -14.4 dBm -12 dB Receiver Sensitivity in OMA -12.6 dBm Stressed Sensitivity in OMA -10.3 dBm 1 2.2 dB 2 0.3 UIp-p 1 -30 dBm Vertical eye closure penalty Stressed eye jitter LOS Assert LOSA Deassert LOSD LOS Hysteresis LOSH -12 0.5 dBm dB Note: 1. Receiver sensitivity is informative. Stressed receiver sensitivity shall be measured with conformance test signal for BER =1x 10-12. 2. Vertical eye closure penalty and stressed eye jitter are the test conditions for measuring stressed receiver sensitivity. They are not the required characteristic of the receiver. Formerica OptoElectronics Inc . 5F-11, No.38, Taiyuan St.,Zhubei City , Hsinchu County 30265, Taiwan Ph: +886-3-5600286 Fax: +886-3-56002398 Version 01 Page 7 10GbE SFP+ LR Transceiver PRODUCT NUMBER: TAS-A5NB1-FAH Electrical Characteristics Parameter Symbol Data Rate Min. Typical Max Unit - 10.3125 - Gbps 700 mV Notes Transmitter Transmitter Differential Input Voltage VIN Transmitter Disable (TXDisable) 180 - VIH 2 Vcc VIL Vee Vee+0.8 V Receiver Receiver Differential Output Voltage VO 300 VOH 2 Vcc VOL Vee Vee+0.8 Tr/Tf 30 Loss of Signal (LOS) Rx Output Rise and Fall Time - 850 mV V ps 20% to 80% Control And Status I/O Timing Characteristics Formerica OptoElectronics Inc . 5F-11, No.38, Taiyuan St.,Zhubei City , Hsinchu County 30265, Taiwan Ph: +886-3-5600286 Fax: +886-3-56002398 Version 01 Page 8 10GbE SFP+ LR Transceiver PRODUCT NUMBER: TAS-A5NB1-FAH Digital Diagnostic Functions Parameter Symbol Min. Max Unit Notes Temperature monitor absolute error DMI_Temp -3 3 degC Over operating temp Laser power monitor absolute error DMI_TX -3 3 dB RX power monitor absolute error DMI_RX -3 3 dB -1dBm to -12dBm range Supply voltage monitor absolute error DMI_VCC -0.08 0.08 V Full operating range Bias current monitor DMI_Ibias -10% 10% mA Digital Diagnostic Memory Map Formerica OptoElectronics Inc . 5F-11, No.38, Taiyuan St.,Zhubei City , Hsinchu County 30265, Taiwan Ph: +886-3-5600286 Fax: +886-3-56002398 Version 01 Page 9 10GbE SFP+ LR Transceiver PRODUCT NUMBER: TAS-A5NB1-FAH Content in 2-Wire Address A0H Address 00 01 02 03 04 05 06 07 08 09 10 11 12 13 14 15 16 17 18 19 20 ~ 35 36 37 ~ 39 40 ~ 55 56 ~ 59 60 ~ 61 62 63 64 65 66 67 68 ~ 83 84 ~ 89 90 ~ 91 92 93 HEX 03 04 07 20 00 00 00 00 00 00 00 06 67 00 0A 64 00 00 00 00 46,4F,52,4D,45,52,49,43 ,41,4F,45,20,20,20,20,20 00 00,00,00 54,41,53,2D,41,35,4E,42,31, 2D,46,41,48,20,20,20 00,00,00,00 05,1E 00 Name of Field Identifier Extended Identifier Connector type 10G Ethernet Compliance Codes SONET Compliance Codes SONET Compliance Codes Ethernet Compliance Codes Fiber Channel link length Fiber Channel transmitter technology Fiber Channel transmission media Fiber Channel speed Encoding codes: Nominal Bit Rate (units of 100Mbps) Rate identifier Link length supported for 9um fiber Link length supported for 9um fiber Link length supported for 50um,OM2 Link length supported for 62.5um,OM1 Link length supported for copper Link length supported for 50um,OM3 Description SFP SFP LC 10G Base LR Not compliant Not compliant Not compliant Not compliant Not compliant Not compliant Not compliant 64B/66B 10.3Gbps Unspecified 10km (units of km) 10km (units of 100m) N/A (units of 10m) N/A (units of 10m) N/A (units of 1m) N/A (units of 10m) Vendor Name FORMERICAOE Unallocated Vendor OUI Unspecified Part Number TAS-A5NB1-FAH Unspecified 1310nm 00 1A 00 00 Serial Number yy/mm/dd 20,20 68 Vendor Revision number Laser Wavelength Unallocated CC_BASE: Options Options Bit Rate, max. Bit Rate, min. Serial Number Date Code Vendor specific lot code Diagnostic Monitoring Type F0 Enhanced Options (soft) 94 03 95 96~127 SFF-8472 Compliance CC_EXT Vendor specific Formerica OptoElectronics Inc . 5F-11, No.38, Taiyuan St.,Zhubei City , Hsinchu County 30265, Taiwan Ph: +886-3-5600286 Fax: +886-3-56002398 Check sum of byte 0 ~ 62 TX-DIS, TX_FAULT, RX-LOS Unspecified Unspecified Unspecified Internal calibration Alarm/Warning flags, Soft TxDisable, Soft TxFault, Soft RxLOS implemented Rev10.2 Check sum of byte 64 ~ 94 Version 01 Page 10 10GbE SFP+ LR Transceiver PRODUCT NUMBER: TAS-A5NB1-FAH Content in 2-Wire Address A2H Add Bytes Name Hex Real Value 00-01 02-03 04-05 06-07 08-09 10-11 12-13 14-15 16-17 18-19 20-21 22-23 24-25 26-27 28-29 30-31 32-33 34-35 36-37 38-39 40-55 56-59 60-63 64-67 68-71 72-75 76-77 78-79 80-81 82-83 84-85 86-87 88-89 90-91 92-94 95 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 16 4 4 4 4 4 2 2 2 2 2 2 2 2 3 1 Temp High Alarm Temp Low Alarm Temp High Warning Temp Low Warning Voltage High Alarm Voltage Low Alarm Voltage High Warning Voltage Low Warning Bias High Alarm Bias Low Alarm Bias High Warning Bias Low Warning TX Power High Alarm TX Power Low Alarm TX Power High Warning TX Power Low Warning RX Power High Alarm RX Power Low Alarm RX Power High Warning RX Power Low Warning Reserved RX_PWR(4) RX_PWR(3) RX_PWR(2) RX_PWR(1) RX_PWR(0) TX_I(Slope) TX_I(Offset) TX_PWR(Slope) TX_PWR(Offset) T(Slope) T(Offset) V(Slope) V(Offset) Reserved Checksum 5500 F100 5000 F600 9470 6D60 9088 7148 AFC8 03E8 9C40 05DC 576C 02F8 4574 03B6 576C 00E6 4574 016B FF 00000000 00000000 00000000 3F800000 00000000 0100 0000 0100 0000 0100 0000 0100 0000 00 85℃ -15℃ 80℃ -10℃ 3.8V 2.8V 3.7V 2.9V 90mA 2mA 80mA 3mA 3.5dBm -11.2dBm 2.5dBm -10.2dBm 3.5dBm -16.4dBm 2.5dBm -14.4dBm 0 0 0 1 0 1 0 1 0 1 0 1 0 - Formerica OptoElectronics Inc . 5F-11, No.38, Taiyuan St.,Zhubei City , Hsinchu County 30265, Taiwan Ph: +886-3-5600286 Fax: +886-3-56002398 Version 01 Page 11 10GbE SFP+ LR Transceiver PRODUCT NUMBER: TAS-A5NB1-FAH Mechanical (mm) ESD This transceiver is specified as ESD threshold 2kV for all electrical input pins, tested per MIL-STD-883, Method 3015.4 /JESD22-A114-A (HBM). However, normal ESD precautions are still required during the handling of this module. This transceiver is shipped in ESD protective packaging. It should be removed from the packaging and handled only in an ESD protected environment. LASER Safety This is a Class 1 Laser Product according to IEC 608251:1993:+A1:1997+A2:2001. This product complies with 21 CFR 1040.10 and 1040.11 except for deviations pursuant to Laser Notice No. 50, dated (July 26, 2001) Formerica OptoElectronics Inc . 5F-11, No.38, Taiyuan St.,Zhubei City , Hsinchu County 30265, Taiwan Ph: +886-3-5600286 Fax: +886-3-56002398 Version 01 Page 12
TAS-A5NB1-FAH 价格&库存
很抱歉,暂时无法提供与“TAS-A5NB1-FAH”相匹配的价格&库存,您可以联系我们找货
TAS-A5NB1-FAH
  • 1+864.427511+112.21675
