TAS-A1NL1-Q11
TAS-A1NL1-Q11
    FORMERICAOPTOELECTRONICSINC.(传承光电)
    TAS-A1NL1-Q11
TAS-A1NL1-Q11 数据手册
10GbE SFP+ ZR Transceiver PRODUCT NUMBER: TAS-A1NL1-Q11 Specification Small Form Factor Pluggable Duplex LC Receptacle – SFP+ Optical Transceivers 10 Gigabit Ethernet 10GBASE-ZR/ZW Ordering Information TAS–A1NL1–Q11 Voltage / Temperature 1. 3.3V / +0℃ ~ +70℃ Model Name Voltage Category Device type Interface LOS Temperature Distance TAS-A1NL1-Q11 3.3V With DDMI 1550 nm EML AC/AC LVTTL 0°C~+70°C 80Km Formerica Optoelectronics Inc . 4F, No.31, Xintai Rd, Zhubei City, Hsinchu County 302, Taiwan Ph: +886-3-5512858 Fax: +886-3-5537118 Latch Color White Version 03 Page 1 10GbE SFP+ ZR Transceiver PRODUCT NUMBER: TAS-A1NL1-Q11 Features          Compliant to SFF-8431 specifications for enhanced 8.5 and 10 Gigabit small form factor pluggable module “SFP+” 1550nm cooled EML transmitter with TEC, APD photo-detector 2-Wire Interface for Management Specifications Compliant with SFF 8472 Digital Diagnostic Monitoring Interface for Optical Transceivers Operating Case Temperature: 0 to 70 °C All-Metal Housing for Superior EMI Performance Low power consumption, less than 1.8w Advanced Firmware Allow Customer System Encryption Information to Be Stored in Transceiver Cost Effective SFP+ Solution, Enables Higher Port Densities and Greater Bandwidth ROHS compliant Applications    10GBASE-ZR/ZW 10GBASE-ZR/ZW + FEC 10G Storage system Figure1: Application in System Formerica Optoelectronics Inc . 4F, No.31, Xintai Rd, Zhubei City, Hsinchu County 302, Taiwan Ph: +886-3-5512858 Fax: +886-3-5537118 Version 03 Page 2 10GbE SFP+ ZR Transceiver PRODUCT NUMBER: TAS-A1NL1-Q11 General Description This 1550nm cooled EML laser based 10Gigabit SFP+ transceiver is designed to transmit and receive optical data over single mode optical fiber for link length up to 80km. The SFP+ ZR module electrical interface is compliant to SFI electrical specifications. The transmitter input and receiver output impedance is 100 Ohms differential. Data lines are internally AC coupled. The module provides differential termination and reduce differential to common mode conversion for quality signal termination and low EMI. SFI typically operates over 200 mm of improved FR4 material or up to about 150mmof standard FR4 with one connector. The transmitter converts 10Gbit/s serial PECL or CML electrical data into serial optical data compliant with the 10GBASE-ZR standard. An open collector compatible Transmit Disable (Tx_Dis) is provided. A logic “1,” or no connection on this pin will disable the laser from transmitting. A logic “0” on this pin provides normal operation. The transmitter has an internal automatic power control loop (APC) to ensure constant optical power output across supply voltage and temperature variations. An open collector compatible Transmit Fault (Tx_Fault) is provided. TX_Fault is a module output contact that when high, indicates that the module transmitter has detected a fault condition related to laser operation or safety. The TX_Fault output contact is an open drain/collector and shall be pulled up to the Vcc_Host in the host with a resistor in the range 4.7-10 kΩ. TX_Disable is a module input contact. When TX_Disable is asserted high or left open, the SFP+ module transmitter output shall be turned off. This contact shall be pulled up to VccT with a 4.7 kΩ to 10 kΩ resistor The receiver converts 10Gbit/s serial optical data into serial PECL/CML electrical data. An open collector compatible Loss of Signal is provided. Rx_LOS when high indicates an optical signal level below that specified in the relevant standard. The Rx_LOS contact is an open drain/collector output and shall be pulled up to Vcc_Host in the host with a resistor in the range 4.7-10 kΩ, or with an active termination. Power supply filtering is recommended for both the transmitter and receiver. The Rx_LOS signal is intended as a preliminary indication to the system in which the SFP+ is installed that the received signal strength is below the specified range. Such an indication typically points to non-installed cables, broken cables, or a disabled, failing or a powered off transmitter at the far end of the cable. Formerica Optoelectronics Inc . 4F, No.31, Xintai Rd, Zhubei City, Hsinchu County 302, Taiwan Ph: +886-3-5512858 Fax: +886-3-5537118 Version 03 Page 3 10GbE SFP+ ZR Transceiver PRODUCT NUMBER: TAS-A1NL1-Q11 Proposed Applications Schematics Formerica Optoelectronics Inc . 4F, No.31, Xintai Rd, Zhubei City, Hsinchu County 302, Taiwan Ph: +886-3-5512858 Fax: +886-3-5537118 Version 03 Page 4 10GbE SFP+ ZR Transceiver PRODUCT NUMBER: TAS-A1NL1-Q11 Pin Definition and Descriptions The SFP+ modules are hot-pluggable. Hot pluggable refers to plugging in or unplugging a module while the host board is powered. The SFP+ host connector is a 0.8 mm pitch 20 position right angle improved connector specified by SFF8083, or stacked connector with equivalent with equivalent electrical performance. Host PCB contact assignment is shown in Figure 2 and contact definitions are given in Table 2. SFP+ module contacts mates with the host in the order of ground, power, followed by signal as illustrated by Figure 3 and the contact sequence order listed in the PIN description table. Figure 2: Module Interface to Host Figure 3: Module Contact Assignment Formerica Optoelectronics Inc . 4F, No.31, Xintai Rd, Zhubei City, Hsinchu County 302, Taiwan Ph: +886-3-5512858 Fax: +886-3-5537118 Version 03 Page 5 10GbE SFP+ ZR Transceiver PRODUCT NUMBER: TAS-A1NL1-Q11 PIN Logic 1 Symbol VeeT 2 LVTTL-O TX_Fault 3 LVTTL-I TX_Dis 4 LVTTL-I/O 5 LVTTL-I 6 Name / Description Note Module Transmitter Ground 1 Module Transmitter Fault 3 Transmitter Disable; Turns off transmitter laser output 4 SDA 2-Wire Serial Interface Data Line 2 SCL 2-Wire Serial Interface Clock 2 MOD_ABS 7 LVTTL-I RS0 8 LVTTL-O RX_LOS 9 LVTTL-I RS1 Module Absent, Grounded in the module Receiver Rate Select-Not used Receiver Loss of Signal Indication Active LOW 3 Transmitter Rate Select-Not used 10 VeeR Module Receiver Ground 1 11 VeeR Module Receiver Ground 1 12 CML-O RD- Receiver Inverted Data Output 13 CML-O RD+ Receiver Data Output 14 VeeR Module Receiver Ground 15 VccR Module Receiver 3.3 V Supply 16 VccT Module Receiver 3.3 V Supply 17 VeeT Module Transmitter Ground 18 CML-I TD+ Transmitter Non-Inverted Data Input 19 CML-I TD- Transmitter Inverted Data Input VeeT Module Transmitter Ground 20 1 1 1 Table 1: SFP+ Module PIN Definition Note: 1. Module ground pins GND are isolated from the module case. 2. Shall be pulled up with 4.7K-10 kΩ to a voltage between 3.15V and 3.45V on the host board. 3. This contact is an open collector/drain output contact and shall be pulled up on the host board. 4. Tx_Disable is an input contact with a 4.7 kΩ to 10 kΩ pull up to VccT inside the module. Formerica Optoelectronics Inc . 4F, No.31, Xintai Rd, Zhubei City, Hsinchu County 302, Taiwan Ph: +886-3-5512858 Fax: +886-3-5537118 Version 03 Page 6 10GbE SFP+ ZR Transceiver PRODUCT NUMBER: TAS-A1NL1-Q11 Transceiver Block Diagram Absolute Maximum Ratings These values represent the damage threshold of the module. Stress in excess of any of the individual Absolute Maximum Ratings can cause immediate catastrophic damage to the module even if all other parameters are within Recommended Operating Conditions. Parameters Power Supply Voltage Storage Temperature Operating Case Temperature Relative Humidity RX Input Average Power Symbol VCC Tc Tc RH Pmax Min. 0 -40 0 5 - Max. 3.6 85 70 95 -1 Unit V °C °C % dBm Table 2: Absolute Maximum Rating Formerica Optoelectronics Inc . 4F, No.31, Xintai Rd, Zhubei City, Hsinchu County 302, Taiwan Ph: +886-3-5512858 Fax: +886-3-5537118 Version 03 Page 7 10GbE SFP+ ZR Transceiver PRODUCT NUMBER: TAS-A1NL1-Q11 Recommended Operating Environment Recommended Operating Environment specifies parameters for which the electrical and optical characteristics hold unless otherwise noted. Parameters Symbol Min. Typical Max Unit VCC 3.135 3.3 3.465 V 400 520 mA 25 70 °C Power Supply Voltage Power Supply Currwnt Operating Case Temperature lcc TC 0 Table 3: Recommended Operating Environment Formerica Optoelectronics Inc . 4F, No.31, Xintai Rd, Zhubei City, Hsinchu County 302, Taiwan Ph: +886-3-5512858 Fax: +886-3-5537118 Version 03 Page 8 10GbE SFP+ ZR Transceiver PRODUCT NUMBER: TAS-A1NL1-Q11 Optical Characteristics The following optical characteristics are defined over the Recommended Operating Environment unless otherwise specified. Parameters Unit Values km 80 Center wavelength (range) nm 1530 -1565 Side Mode Suppression Ratio (min) dB 30 – maximum (Average) dBm 4.0 – minimum (Average) dBm 0 OMA(Minimum) dBm -2.1 Transmitter and dispersion penalty (max)(note 3) dB 3.0 Average launch power of OFF transmitter (max) dBm -30 dB 9 dB/Hz -128 dB 21 nm 1260-1620 Receive overload (max) in average power(note 1) dBm -7.0 Receive sensitivity (min) in average power(note 1) dBm -24.0 Receiver Reflectance (max) dBm -26 LOS Assert(min) dBm -40 Los Dessert(max) dBm -24 dB 0.5 Stressed eye jitter (min)(note 2) UIp-p 0.3 Receive electrical 3dB upper cutoff frequency (max) GHz 12.3 Receiver power (damage, Max) dBm 1.0 Operating Reach(SMF) Transmitter Launched power Extinction ratio (min) RIN12 OMA (max) Optical Return Loss Tolerance (min) Receiver Center wavelength (range) Los Hysteresis(min) Table 4: Optical Characteristics Note: 1. Average optical power shall be measured using the methods specified in TIA/EIA455-95. 2. Receiver sensitivity is informative. Stressed receiver sensitivity shall be measured with conformance test signal for BER =1x 10-12 . 3. Path penalty is intended as the power penalty of the interface between back-to-back and the maximum applied dispersion. Formerica Optoelectronics Inc . 4F, No.31, Xintai Rd, Zhubei City, Hsinchu County 302, Taiwan Ph: +886-3-5512858 Fax: +886-3-5537118 Version 03 Page 9 10GbE SFP+ ZR Transceiver PRODUCT NUMBER: TAS-A1NL1-Q11 Digital Diagnostic Functions The following digital diagnostic characteristics are defined over the Recommended Operating Environment unless otherwise specified. It is compliant to SFF8472 Rev10.2 with internal calibration mode. For external calibration mode please contact our sales stuff. Parameter Symbol Min. Max Unit Temperature monitor absolute error DMI_Temp -3.0 3.0 degC Laser power monitor absolute error DMI_TX -3.0 3.0 dB RX power monitor absolute error DMI_RX -3 3 dB Supply voltage monitor absolute error DMI_VCC -0.1 0.1 V Bias current monitor DMI_Ibias -10% 10% mA Notes Over operating temp -7dBm to -24dBm range Full operating range Table 5: Digital diagnostic specification table Formerica Optoelectronics Inc . 4F, No.31, Xintai Rd, Zhubei City, Hsinchu County 302, Taiwan Ph: +886-3-5512858 Fax: +886-3-5537118 Version 03 Page 10 10GbE SFP+ ZR Transceiver PRODUCT NUMBER: TAS-A1NL1-Q11 Electrical Characteristics The following electrical characteristics are defined over the Recommended Operating Environment unless otherwise specified. Parameter Data Rate Power Consumption Single Ended Output Voltage Tolerance C common mode voltage tolerance Tx Input Diff Voltage Tx Fault Tx Disable Data Dependent Input Jitter Data Input Total Jitter Symbol Min. Typical 10.3125 1200 Transmitter Max 11.3 1800 Unit Gbps mW -0.3 - 4 V 15 - - mV VI 180 700 mV VoL Voh VoL Voh -0.3 2.0 Vee 2 0.4 Vcc+0.3 Vee+0.8 Vcc V V V V DDJ 0.1 UI TJ 0.28 UI 4 V 850 mV Notes Receiver Single Ended Output Voltage Tolerance Rx Output Diff Voltage Rx Output Rise and Fall Time Total Jitter Deterministic Jitter -0.3 Vo 300 Tr/Tf 30 TJ DJ - ps 0.7 0.42 20% to 80% UI UI Table 6: Electrical Characteristics Formerica Optoelectronics Inc . 4F, No.31, Xintai Rd, Zhubei City, Hsinchu County 302, Taiwan Ph: +886-3-5512858 Fax: +886-3-5537118 Version 03 Page 11 10GbE SFP+ ZR Transceiver PRODUCT NUMBER: TAS-A1NL1-Q11 Control And Status I/O Timing Characteristics Timing characteristics of control and status I/O are included in Table 9, which is also defined in SFF-8431. Table 7: Timing Characteristics Formerica Optoelectronics Inc . 4F, No.31, Xintai Rd, Zhubei City, Hsinchu County 302, Taiwan Ph: +886-3-5512858 Fax: +886-3-5537118 Version 03 Page 12 10GbE SFP+ ZR Transceiver PRODUCT NUMBER: TAS-A1NL1-Q11 Content in 2-Wire Address A0H Address 00 01 02 03 04 05 06 07 08 09 10 11 12 13 14 15 16 17 18 19 20 ~ 35 36 37 ~ 39 40 ~ 55 56 ~ 59 60 ~ 61 62 63 64 65 66 67 68 ~ 83 84 ~ 89 90 ~ 91 92 93 HEX 03 04 07 80 00 00 00 00 00 00 00 06 67 00 50 FF 00 00 00 00 46,4F,52,4D,45,52,49,43 ,41,4F,45,20,20,20,20,20 00 00,00,00 54,41,53,2D,41,31,4E,4C,31, 2D,51,31,31,20,20,20 00,00,00,00 06,0E 00 Name of Field Identifier Extended Identifier Connector type 10G Ethernet Compliance Codes SONET Compliance Codes SONET Compliance Codes Ethernet Compliance Codes Fiber Channel link length Fiber Channel transmitter technology Fiber Channel transmission media Fiber Channel speed Encoding codes: Nominal Bit Rate (units of 100Mbps) Rate identifier Link length supported for 9um fiber Link length supported for 9um fiber Link length supported for 50um,OM2 Link length supported for 62.5um,OM1 Link length supported for copper Link length supported for 50um,OM3 Description SFP SFP LC 10G Base ZR Not compliant Not compliant Not compliant Not compliant Not compliant Not compliant Not compliant 64B/66B 10.3Gbps Unspecified 80 (units of km) 800 (units of 100m) N/A (units of 10m) N/A (units of 10m) N/A (units of 1m) N/A (units of 10m) Vendor Name FORMERICAOE Unallocated Vendor IEEE company ID Unspecified Part Number TAS-A1NL1-Q11 Unspecified 1550nm 00 1A 00 00 Serial Number yy/mm/dd 20,20 68 Vendor Revision number Laser Wavelength Unallocated CC_BASE: Options Options Bit Rate, max. Bit Rate, min. Serial Number Date Code Vendor specific lot code Diagnostic Monitoring Type F0 Enhanced Options (soft) 94 04 95 96~127 SFF-8472 Compliance CC_EXT Vendor specific Formerica Optoelectronics Inc . 4F, No.31, Xintai Rd, Zhubei City, Hsinchu County 302, Taiwan Ph: +886-3-5512858 Fax: +886-3-5537118 Check sum of byte 0 ~ 62 TX-DIS, TX_FAULT, RX-LOS Unspecified Unspecified Unspecified Internal calibration Alarm/Warn thresholds TxDisable,control/monitoring TxFault monitoring LOS Unspecified Check sum of byte 64 ~ 94 Version 03 Page 13 10GbE SFP+ ZR Transceiver PRODUCT NUMBER: TAS-A1NL1-Q11 Content in 2-Wire Address A2H Add Bytes Name Hex Real Value 00-01 02-03 04-05 06-07 08-09 10-11 12-13 14-15 16-17 18-19 20-21 22-23 24-25 26-27 28-29 30-31 32-33 34-35 36-37 38-39 40-55 56-59 60-63 64-67 68-71 72-75 76-77 78-79 80-81 82-83 84-85 86-87 88-89 90-91 92-94 95 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 16 4 4 4 4 4 2 2 2 2 2 2 2 2 3 1 Temp High Alarm Temp Low Alarm Temp High Warning Temp Low Warning Voltage High Alarm Voltage Low Alarm Voltage High Warning Voltage Low Warning Bias High Alarm Bias Low Alarm Bias High Warning Bias Low Warning TX Power High Alarm TX Power Low Alarm TX Power High Warning TX Power Low Warning RX Power High Alarm RX Power Low Alarm RX Power High Warning RX Power Low Warning Reserved RX_PWR(4) RX_PWR(3) RX_PWR(2) RX_PWR(1) RX_PWR(0) TX_I(Slope) TX_I(Offset) TX_PWR(Slope) TX_PWR(Offset) T(Slope) T(Offset) V(Slope) V(Offset) Reserved Checksum 4E00 F800 4B00 FB00 9088 7170 8C70 7548 F424 1D4C EA60 2710 7B87 1394 621F 1F07 0C5A 0019 07CB 0020 FF 00000000 00000000 00000000 3F800000 00000000 0100 0000 0100 0000 0100 0000 0100 0000 00 78℃ -8℃ 75℃ -5℃ 3.7V 2.9V 3.5V 3V 125mA 15mA 120mA 20mA 5dBm -3dBm 4dBm -1dBm -5dBm -26dBm -7dBm -24dBm 0 0 0 1 0 1 0 1 0 1 0 1 0 - Formerica Optoelectronics Inc . 4F, No.31, Xintai Rd, Zhubei City, Hsinchu County 302, Taiwan Ph: +886-3-5512858 Fax: +886-3-5537118 Version 03 Page 14 10GbE SFP+ ZR Transceiver PRODUCT NUMBER: TAS-A1NL1-Q11 Mechanical Comply to SFF-8432 rev. 5.0, the improved Pluggable form factor specification. ESD This transceiver is specified as ESD threshold 2kV for all electrical input pins, tested per MIL-STD-883, Method 3015.4 /JESD22-A114-A (HBM). However, normal ESD precautions are still required during the handling of this module. This transceiver is shipped in ESD protective packaging. It should be removed from the packaging and handled only in an ESD protected environment. LASER Safety This is a Class 1 Laser Product according to IEC 608251:1993:+A1:1997+A2:2001. This product complies with 21 CFR 1040.10 and 1040.11 except for deviations pursuant to Laser Notice No. 50, dated (July 26, 2001) Formerica Optoelectronics Inc . 4F, No.31, Xintai Rd, Zhubei City, Hsinchu County 302, Taiwan Ph: +886-3-5512858 Fax: +886-3-5537118 Version 03 Page 15
TAS-A1NL1-Q11 价格&库存
很抱歉,暂时无法提供与“TAS-A1NL1-Q11”相匹配的价格&库存,您可以联系我们找货
