KIT0021
KIT0021
    DFROBOT
    WATERPROOF DS18B20 SENSOR KIT
KIT0021 数据手册
  Waterproof DS18B20 Sensor Kit SKU:KIT0021 INTRODUCTION If you are familiar with our product, you will find there is waterproof temperature sensor named DS18B20. This waterproof temperature sensor kit is using the same probe——DS18B20 probe AS . It contains a probe with a resister module. So it is easy to connect on the Arduino board. The DS18B20 temperature sensor provides 9 to 12-bit (configurable) temperature readings over a 1-Wire interface, so that only one wire (and ground) needs to be connected from a central microprocessor. Compatible with 3.0-5.5V systems. Check 27 Pcs Sensor Kit for Arduino to get more sensors for arduino. SPECIFICATION           Operating voltage: 3.0~ 5.5V o    o       Type A ±0.5°C Accuracy from -10°C to +85°C Usable temperature range: -55 to 125°C (-67°F to +257°F) 9 to 12 bit selectable resolution Uses 1-Wire interface- requires only one digital pin for communication Unique 64 bit ID burned into chip Multiple sensors can share one pin Temperature-limit alarm system Query time is less than 750ms 3 wires interface: Red wire - VCC Black wire - GND Yellow wire - DATA Type B Red wire - VCC Yellow wire - GND Green wire - DATA Stainless steel tube 6mm diameter by 35mm(1.34") long Cable diameter: 4mm(0.16") Length: 90cm(35.43") SHIPPING LIST    Waterproof DS18B20 Digital temperature sensor (DFR0198) x1 Terminal sensor adapter (DFR0055) x1 Digital sensor cable (FIT0011) Powered By DFRobot © 2008-2017 https://www.dfrobot.com/product-1354.html 5-2-17
KIT0021 价格&库存
很抱歉,暂时无法提供与“KIT0021”相匹配的价格&库存,您可以联系我们找货
