High Density Card Edge
.050” [1.27 mm] Contact Centers, .610” [15.49 mm] Insulator Height,
Dip Solder/Card Extender/SMT for .031”[0.79 mm], .062”[1.57 mm] or .093”[2.36 mm] Mating PCB
SPECIFICATIONS
• Accommodates .031” ± .006” [0.79 mm ± 0.15 mm],
.062” ± .008” [1.57 mm ± 0.20 mm]
or .093” ± .008” [2.36 mm ± 0.20 mm] mating PCB
• PPS or PA9T insulator
• Molded-in key available
• High reliability/high cycle hairpin bellow & cantilever contacts
• 1 Amp current rating per contact for contacts fully energized
• UL Flammability Rating: 94V-0
• Operating Temperature: -65°C up to +200°C
TERMINATION TYPE
HAIR PIN POST
.018” [0.46] X
.012” [0.30]
L
R
L
POST
POST
L
POST
L
POST
R
L
R
POST
CANTILEVER
POST SIZE
.016” [0.41] SQ.
L
POST
R
L
POST
(P/N CODE)
TERMINATION
LAYOUT
ROW
SPACING
('R' DIM)
TAIL
LENGTH
('L' DIM)
(HH)
THRU HOLE
STRAIGHT
figure 1
3X
0.100”
[2.54]
0.125”
[3.18]
0.160”
[4.06]
(HF)
SURFACE
MOUNT
figure 3
N/A
0.100”
[2.54]
(HL)
THRU HOLE
STRAIGHT
figure 4
0.250”
[6.35]
(HN)
THRU HOLE
STRAIGHT
figure 4
0.100”
[2.54]
0.125”
[3.18]
(P/N CODE)
TERMINATION
LAYOUT
ROW
SPACING
('R' DIM)
TAIL
LENGTH
('L' DIM)
(YH)
THRU HOLE
STRAIGHT
figure 1
3X
0.100”
[2.54]
0.125”
[3.18]
R
POST
2X Ø .125” [3.18]
'D' OR 'T' MOUNTING
A
PIN B2
F
D
PCB LAYOUT RECOMMENDED (HH, YH)
FIGURE 2
.050”[1.27] TYP.
60°
.200”[5.08]
0.160”
[4.06]
.062” ±.008”[1.57±0.20] PCB
.020” [0.51]
A
.040” [1.02]
PCB LAYOUT, SOLDER END (HR, YR)
FIGURE 3
.050” [1.27 ] TYP.
.315”[8.00] MIN.
.040” [1.02] TYP. MAX.
ACCEPTS
.062” [1.57]
PCB
2X Ø .125”[3.18]
'D' OR 'T' MOUNTING
.185”[4.70] MAX.
N/A
2X Ø .096” [2.44]
'R' MOUNTING
A
F
D
0.175”
[4.45]
SURFACE MOUNT PCB LAYOUT (HF, YF)
FIGURE 4
PIN 1
(YS)
THRU HOLE
STRAIGHT
figure 4
2X Ø .096” [2.44]
'R' MOUNTING
PIN B1
0.100”
[2.54]
D
F
A
2X Ø .096”[2.44]
'R' MOUNTING
POST
L
Ø .040” [1.02] MIN. TYP.
PIN A2
3X .100” [2.54]
ACCEPTS
.062” [1.57]
PCB
(YF)
SURFACE MOUNT
figure 3
L
.050” [1.27] TYP.
PIN A1
(HR)
CARD
EXTENDER
figure 2
(YR)
CARD EXTENDER
figure 2
FIGURE 1
.100” [2.54] TYP.
2X Ø .125”[3.18]
'D' OR 'T' MOUNTING
R
0.200”
[5.08]
0.140”
[3.56]
.050”[1.27] TYP.
Ø .030”[0.76] MIN.
PCB LAYOUT (HL, HN, YS)
MOUNTING STYLE
Ø .125” [3.18]
.134”
[3.40]
.250” [6.35]
#4-40
.250” [6.35]
.025” [0.64]
BOARD LOCK (R)
(with no mounting ears)
NO MOUNTING EARS (N)
FLUSH MOUNTING (D)
FLUSH MOUNTING
WITH THREADED INSERT (T)
.360”
[9.14]
.318”
[8.08]
.128”
[3.25]
.440”
[11.18]
.188”
[4.77]
.062”
[1.57]
Ø .078”
[1.98]
STRADDLE MOUNT (Q)
www.sullinscorp.com | 760-744-0125 | toll-free 888-774-3100 | fax 760-744-6081 | info@sullinscorp.com
Dip Solder/Card Extender/SMT for .031”[0.79mm], .062”[1.57mm] or .093”[2.36mm] Mating PCB
G B B 40 D HH D - Sxxx
PART NUMBER OPTIONS
CONTACT FINISH - RoHS Compliant
All platings are Lead Free and have .000050” Nickel underplate
Contact Surface
Termination
B = .000010” Gold
.000100” Pure Tin, Matte
C = .000030” Gold
***M = .000030” Gold
.000010” Gold Overall
***(YH, YR, YF & YS Termination only)
CONTACT CENTERS
B = .050” [1.27 mm]
NUMBER OF CONTACT POSITIONS
See Chart Below
MODIFICATION CODE (Consult Factory)
OMIT FOR STANDARD
-S1648 = .031”±.006” [0.79 ± 0.15] Mating PCB
-S1763 = .093”±.008” [2.36 ± 0.20] Mating PCB
(for HH, HR, HF, HN & HL Termination Only)
MOUNTING STYLE (Opposite Page)
D = Flush Mounting
N = No Mounting
T = Flush Mounting With Threaded Insert
Q = Straddle Mount (Card Extender Only)*
R = Metal Board Locks
TERMINATION TYPE (Opposite Page)
HH, YH = Staggered Dip Solder
HR, YR = Card Extender
HF, YF = Surface Mount
HL = Dip Solder
HN = Dip Solder
YS = Dip Solder
READOUT (Opposite Page)
D = Dual
MATERIALS (INSULATOR/CONTACT)
G = PA9T/Phosphor Bronze
R = PPS/Phosphor Bronze
J = PA9T/Beryllium Copper
A = PPS/Beryllium Copper
F = PPS/Spinodal**
Refer to Page 7 for Operating/Processing Temperatures
**Consult factory for special soldering guidelines. YH, YR, YF & YS termination with 'M' plating only.
DIMENSIONS Dimensions in [ ] are in millimeters, all others are in inches.
(D) MOUNTING SHOWN
.300 [7.62] INSERTION DEPTH
C
2X Ø .125 [3.18]
FIRST POSITION
INDICATOR
.610 [15.49]
.370 [9.40]
.250 [6.35]
A
B
D
E
POSITIONS/
CONTACTS
05/10
06/12
08/16
09/18
10/20
13/26
14/28
15/30
16/32
20/40
22/44
24/48
25/50
28/56
30/60
34/68
35/70
40/80
41/82*
44/88
45/90
50/100
55/110
60/120
62/124
64/128
65/130
66/132
70/140
75/150
80/160
81/162
85/170*
90/180
92/184*
95/190
96/192*
100/200
105/210
106/212
108/216*
110/220
120/240
A±.005
B±.005
0.200
0.250
0.350
0.400
0.450
0.600
0.650
0.700
0.750
0.950
1.050
1.150
1.200
1.350
1.450
1.650
1.700
1.950
2.000
2.150
2.200
2.450
2.700
2.950
3.050
3.150
3.200
3.250
3.450
3.700
3.950
4.000
4.200
4.450
4.550
4.700
4.750
4.950
5.200
5.250
5.350
5.450
5.950
0.300
0.350
0.450
0.500
0.550
0.700
0.750
0.800
0.850
1.050
1.150
1.250
1.300
1.450
1.550
1.750
1.800
2.050
2.100
2.250
2.300
2.550
2.800
3.050
3.150
3.250
3.300
3.350
3.550
3.800
4.050
4.100
4.300
4.550
4.650
4.800
4.850
5.050
5.300
5.350
5.450
5.550
6.050
INCHES
C±.015
D±.010
0.490
0.540
0.640
0.690
0.740
0.890
0.940
0.990
1.040
1.240
1.340
1.440
1.490
1.640
1.740
1.940
1.990
2.240
2.290
2.440
2.490
2.740
2.990
3.240
3.340
3.440
3.490
3.540
3.740
3.990
4.240
4.290
4.490
4.740
4.840
4.990
5.040
5.240
5.490
5.540
5.640
5.740
6.240
.060 [1.52]
.050 [1.27] TYP.
REFER TO TERMINATION TYPE
E±.020
0.776
1.090
0.826
1.140
0.926
1.240
0.976
1.290
1.026
1.340
1.176
1.490
1.226
1.540
1.276
1.590
1.326
1.640
1.526
1.840
1.626
1.940
1.726
2.040
1.776
2.090
1.926
2.240
2.026
2.340
2.226
2.540
2.276
2.590
2.526
2.840
2.576
2.890
2.726
3.040
2.776
3.090
3.026
3.340
3.276
3.590
3.526
3.840
3.626
3.940
3.726
4.040
3.776
4.090
3.826
4.140
4.026
4.340
4.276
4.590
4.526
4.840
4.576
4.890
4.776
5.090
5.026
5.340
5.126
5.440
5.276
5.590
5.326
5.640
5.526
5.840
5.776
6.090
5.826
6.140
5.926
6.240
6.026
6.340
‘N’ Mounting Only
F±.010
A±0.13
B±0.13
0.350
0.400
0.500
0.550
0.600
0.750
0.800
0.850
0.900
1.100
1.200
1.300
1.350
1.500
1.600
1.800
1.850
2.100
2.150
2.300
2.350
2.600
2.850
3.100
3.200
3.300
3.350
3.400
3.600
3.850
4.100
4.150
4.350
4.600
4.700
4.850
4.900
5.100
5.350
5.400
5.500
5.600
6.100
5.08
6.35
8.89
10.16
11.43
15.24
16.51
17.78
19.05
24.13
26.67
29.21
30.48
34.29
36.83
41.91
43.18
49.53
50.80
54.61
55.88
62.23
68.58
74.93
77.47
80.01
81.28
82.55
87.63
93.98
100.33
101.60
106.68
113.03
115.57
119.38
120.65
125.73
132.08
133.35
135.89
138.43
151.13
7.62
8.89
11.43
12.70
13.97
17.78
19.05
20.32
21.59
26.67
29.21
31.75
33.02
36.83
39.37
44.45
45.72
52.07
53.34
57.15
58.42
64.77
71.12
77.47
80.01
82.55
83.82
85.09
90.17
96.52
102.87
104.14
109.22
115.57
118.11
121.92
123.19
128.27
134.62
135.89
138.43
140.97
153.67
MILLIMETERS
C±0.38
D±0.25
12.45
13.72
16.26
17.53
18.80
22.61
23.88
25.15
26.42
31.50
34.04
36.58
37.85
41.66
44.20
49.28
50.55
56.90
58.17
61.98
63.25
69.60
75.95
82.30
84.84
87.38
88.65
89.92
95.00
101.35
107.70
108.97
114.05
120.40
122.94
126.75
128.02
133.10
139.45
140.72
143.26
145.80
158.50
E±0.51
19.71
27.69
20.98
28.96
23.52
31.50
24.79
32.77
26.06
34.04
29.87
37.85
31.14
39.12
32.41
40.39
33.68
41.66
38.76
46.74
41.30
49.28
43.84
51.82
45.11
53.09
48.92
56.90
51.46
59.44
56.54
64.52
57.81
65.79
64.16
72.14
65.43
73.41
69.24
77.22
70.51
78.49
76.86
84.84
83.21
91.19
89.56
97.54
92.10
100.08
94.64
102.62
95.91
103.89
97.18
105.16
102.26
110.24
108.61
116.59
114.96
122.94
116.23
124.21
121.31
129.29
127.66
135.64
130.20
138.18
134.01
141.99
135.28
143.26
140.36
148.34
146.71
154.69
147.98
155.96
150.52
158.50
153.06
161.04
‘N’ Mounting Only
F±0.25
8.89
10.16
12.70
13.97
15.24
19.05
20.32
21.59
22.86
27.94
30.48
33.02
34.29
38.10
40.64
45.72
46.99
53.34
54.61
58.42
59.69
66.04
72.39
78.74
81.28
83.82
85.09
86.36
91.44
97.79
104.14
105.41
110.49
116.84
119.38
123.19
124.46
129.54
135.89
137.16
139.70
142.24
154.94
* Consult factory for availability.
21
很抱歉,暂时无法提供与“GBB05DYFT”相匹配的价格&库存,您可以联系我们找货
