10650
10650
    MASTERAPPLIANCECO(晨星半导体)
    14-16AWG,BLUE,1/4"STUD
10650 数据手册
Heat Seal Connectors & Shrink Tubing Resist water & condensation Resist salt & other contaminants Resist wire pull out & current leakage Who Uses Heat Shrink Connectors: • • • • • • • Heavy Duty Trucking Marine & RV Plant Maintenance Departments OEM & Automotive Aftermarket Heavy Duty Equipment Oil Fields & Mining Municipalities & Military Bases UL listed parts ask for a complete list of applicable part numbers The past few years have seen the advent of sweeping technological advances in the automotive, fleet, and marine industries. Many of these advances involve improved electrical systems, controlled by miniature onboard computers. Consequently, small variations in voltage can significantly affect vehicle performance. To combat these problems and increase longevity, the major manufacturers in these industries are using completely sealed electrical systems. Unfortunately, the repair and maintenance industry is lagging behind. The integrity of sealed electrical harnesses is often breached when repairs are made with inferior, unsealed electrical connectors. Master Appliance has the solution. The heat shrink connector is the innovative solution that allows the aftermarket to keep pace with changing technology. Each repair made with a heat shrink connector is individually protected from corrosion, contaminants, and current leakage. This ensures that the original integrity of the wiring harness is maintained. MULTISEAL™ Crimped Mechanical reliability • Holds wires in place Soldered Ultimate tensile strength • Superior conductivity Sealed Durable insulation • Watertight connection Crimped for mechanical reliability, soldered for strength and conductivity, and sealed for superior durablity. When there is no margin for error, choose Multi Seal... The ultimte connector. FEATURES & BENEFITS: • Seamless Butt Connectors & Brazed Seam Rings and Spades – Prevents opening of connector barrel for stronger crimp. • Low temperature pre-measured solder with flux for greater tensile strength and superior current flow. • Uniform adhesive flow does not overflow onto terminal to impede contact. • Heat shrink tubing does not reduce in length creating better insulation along with superior wire support and strain relief. • Translucent, adhesive-lined polyolefin shrink tubing – Allows visual inspection, prevents wire corrosion, and provides a water and contaminant resistant seal. • Color-coded tubing with wire gauge imprint – Provides easy identification of the correct part for the job. • Superior Integrity of electrical systems – Sealed electrical systems ensure the original integrity of wire connections and wiring harnesses and conforms with OEM standards. 103 lbs tensile strength. Crimp - Solder - Seal 1. Strip the wires 3/8" and slide the wires into the connector. 2. Crimp the wire strands and connector. Butt Connectors 10058 - Multiseal Butt Splice Connector Minipack Description 18-20 AWG, Butt Connector, Red 14-16 AWG, Butt Connector, Blue 10-12 AWG, Butt Connector Yellow Qty Temperature rating: -67°F to 230°F -55°C to 110°C Longitudinal change: +1, -10% Recovery temperature: 275°F/135°C Dialectic strength: 900 Volts/Mil. UL Voltage Rating: 600 Volts Corrosion resistance: Non-corrosive Fungus Resistance: Non-nutrient Water absorbtion:
10650 价格&库存
很抱歉,暂时无法提供与“10650”相匹配的价格&库存,您可以联系我们找货
