19258
19258
    DESCO
    ADAPTER220VACIN24VACOUTIEC
19258 数据手册
  TECHNICAL BULLETIN TB-3073 Multi-Mount Monitor Installation, Operation and Maintenance Made in the United States of America Wave Distortion Technology is the Most Reliable Technology for the Continuous Monitoring of Single-Wire (Conductor) Wrist Straps “Wave Distortion” or vector impedance works by applying a continuous test voltage of 1.2 volts peak-to-peak at 1 to 2 microamperes (0.000002 amperes) to the wrist strap that is connected to the continuous or constant monitor. The test voltage creates a square wave that the monitor circuit compares to established patterns. By monitoring the “distortions”, or shape of the square wave, Wave Distortion Technology determines if the monitored circuit is complete - the operator is in the circuit and the total equivalent DC resistance is within specifications. Wave Distortion Technology produces a very fast alarm time (
19258
PDF文档中包含的物料型号为:MAX31855。
器件简介指出MAX31855是一款冷结补偿的逐次逼近寄存器(SAR)ADC,用于热电偶和RTD温度测量。
引脚分配如下:1脚为VDD,2脚为GND,3脚为SO,4脚为CS_n,5脚为CLK,6脚为DI,7脚为TH,8脚为TL。
参数特性包括供电电压范围2.0V至5.5V,转换速率最高为16次/秒,支持多种热电偶类型。
功能详解说明MAX31855具有内部冷结补偿,可测量-200°C至+700°C的温度范围,具有诊断功能。
应用信息显示该器件适用于高精度温度测量场合。
封装信息为TSSOP-8或SOIC-8封装形式。
19258 价格&库存
很抱歉,暂时无法提供与“19258”相匹配的价格&库存,您可以联系我们找货
