PLS-75F25AL05-08
PLS-75F25AL05-08
    PEERLESS(PEERLESS扬声器)
    PLSFULL-RANGE3INCHALUMINUMCO
PLS-75F25AL05-08 数据手册
Driver Specification Sheet Model No: PLS-75F25AL05-08 1 Rev: Product Line: Tymphany Last Update: 2017-01-04 23:20:43 Product Description This 3 inch 8 ohm member of the PLS family sets a high standard for compact full range drivers intended for applications such as television soundbars and compact music systems. Design features in this family include a stiff steel basket with venting under the spider to aid cooling of the motor, a ferrite magnet motor with copper cap to lower coil inductance, providing low distortion at low frequencies and extended high frequency response. A black anodized aluminium cone is employed, along with a black anodized aluminium dust cap coupled directly to the voice coil. Additionally, the cones come equipped with special-designed large roll rubber surrounds, which allow for a dynamic linear response at high excursion. Mechanical Drawing Specifications DC Resistance Minimum Impedance Voice Coil Inductance Resonant Frequency Mechanical Q Factor Electrical Q Factor Total Q Factor Ratio Fs/Qts Half Space Sensitivity @2.83V Half Space Sensitivity @1W/1M Gap Height Maximum Linear Excursion Ferrofluid Type Driver Mass Revc Zmin Le Fs Qms Qes Qts F db@2.83V/1M db@1W/1M Gh Xmax FF Kg Ohms Ohms mH Hz 6.22 7.42 0.04 106.89 5.2 5.0% 7.5% 15% 0.75 Fs/Qts dB dB mm mm 0.66 162.45 84.87 84.5 4 2.1 +/- 1.0db +/- 1.0db Energy Bandwidth Product Moving Mass Suspension Compliance Effective Cone diameter Effective Piston Area Effective Volume Motor Force Factor Motor Efficiency Factor Voice coil former Material Voice coil inner diameter Rated Noise Power Test Spectrum Bandwidth Driver Size 0 Frequency and Impedance Response Tymphany HK LTD Address : Room 1307-8 Dominion Centre, 43-59 Queens Rd East, Wanchai, Hong Kong E-mail: sales@tymphany.com EBP Mms Cms D Sd Vas BL ß VCfm VCd P 100Hz~20KHz Inch (1/Qes)*fs g um/N cm cm^2 L Tm (T*M^2)/Ohms mm W 3 in 2.4 927.1 6 28.3 1.11 3.64 2.1 ASV 25.73 25
PLS-75F25AL05-08 价格&库存
很抱歉,暂时无法提供与“PLS-75F25AL05-08”相匹配的价格&库存,您可以联系我们找货
PLS-75F25AL05-08
  • 240+145.53456240+18.82878
