PDV-P9004
PDV-P9004
    LUNAOPTOELECTRONICS(Luna Optoelectronics)
    PHOTOCELL 27K-60K OHM 4.20MM
PDV-P9004 数据手册
CdS Photoconductive Photocells PDV-P9004 Precision – Control – Results WWW.LUNAINC.COM         DESCRIPTION  FEATURES  The PDV-P9004 are (CdS), Photoconductive photocells designed to   sense light from 400 to 700 nm. These light dependent resistors are available in a wide range of resistance values. They’re packaged in a two leaded plastic-coated ceramic header.    Visible light response  Sintered construction  Low cost    RELIABILITY  APPLICATIONS  This device is in principle able to meet military test requirements (Mil-  STD-750, Mil-STD-883) after proper screening and group test. Contact Luna for recommendations on specific test conditions and procedures.       ABSOLUTE MAXIMUM RATINGS  SYMBOL Camera exposure  Shutter controls  Night light controls  MIN MAX UNITS (TA)= 23°C UNLESS OTHERWISE NOTED Applied Voltage - - 150 V - Continuous Power Dissipation - - 90 mW/°C - -30 to +75 V - - - +260 °C - Operation and Storage Temperature Soldering Temperature* * 0.200 inch from base for 3 seconds with heat sink.   Information in this technical datasheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications are subject to change without notice.  Page 1/2  REV 08/07/17 © 2017 Luna Optoelectronics. All rights reserved. Luna Optoelectronics, 1240 Avenida Acaso, Camarillo CA 93012 • Phone (805) 987-0146 • Fax (805) 484-9935   CdS Photoconductive Photocells PDV-P9004 Precision – Control – Results WWW.LUNAINC.COM   Ta = 23°C UNLESS NOTED OTHERWISE OPTO-ELECTRICAL PARAMETERS  TEST CONDITIONS  MIN  TYP  MAX  UNITS  Dark Resistance After 10 sec. @10 Lux @ 2856°K 2 - - MΩ Illuminated Resistance 10 Lux @ 2856°K 27 - 60 KΩ - .85 - Lux PARAMETER Sensitivity Log R100 Log R10 Log E100 Log E10 Spectral Application Range Flooded 400 - 700 nm Spectral Application Range Flooded - 520 - nm Rise Time 10 Lux @ 2856 °K - 60 - ms Fall Time After 10 Lux @ 2856 °K - 25 - ms **R100, R10: cell resistances at 100 Lux and 10 Lux at 2856 K respectively. ***E100, E10: luminance at 100 Lux and 10 Lux 2856 K respectively. TYPICAL PERFORMANCE CELL RESISTANCE vs. ILLUMINANCE     Information in this technical datasheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications are subject to change without notice.  Page 2/2  REV 08/07/17 © 2017 Luna Optoelectronics. All rights reserved. Luna Optoelectronics, 1240 Avenida Acaso, Camarillo CA 93012 • Phone (805) 987-0146 • Fax (805) 484-9935
PDV-P9004 价格&库存
很抱歉,暂时无法提供与“PDV-P9004”相匹配的价格&库存,您可以联系我们找货
