PDV-P9005-1
PDV-P9005-1
    LUNAOPTOELECTRONICS(Luna Optoelectronics)
    PHOTOCELL 48K-140K OHM 4.20MM
PDV-P9005-1 数据手册
CdS Photoconductive Photocells PDV-P9005-1 Precision – Control – Results WWW.LUNAINC.COM DESCRIPTION FEATURES The PDV-P9005-1 are (CdS), Photoconductive photocells designed to sense light from 400 to 700 nm. These light dependent resistors are available in a wide range of resistance values. They’re packaged in a two leaded plastic-coated ceramic header.    RELIABILITY APPLICATIONS This Luna high-reliability device is in principle able to meet military test requirements (Mil-STD-750, Mil-STD-883) after proper screening and group test. Contact Luna for recommendations on specific test conditions and procedures.    Visible light response Sintered construction Low cost Camera exposure Shutter controls Night light controls ABSOLUTE MAXIMUM RATINGS SYMBOL MIN MAX UNITS (TA)= 23°C UNLESS OTHERWISE NOTED Applied Voltage - - 150 V - Continuous Power Dissipation - - 90 mW/°C - -30 to +75 V - - - +260 °C - Operation and Storage Temperature Soldering Temperature* * 0.200 inch from base for 3 seconds with heat sink. Information in this technical datasheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications are subject to change without notice. REV 10-24-16 Page 1/2 © 2016 Luna Optoelectronics. All rights reserved. Luna Optoelectronics, 1240 Avenida Acaso, Camarillo CA 93012 • Phone (805) 987-0146 • Fax (805) 484-9935 CdS Photoconductive Photocells PDV-P9005-1 Precision – Control – Results WWW.LUNAINC.COM Ta = 23°C UNLESS NOTED OTHERWISE OPTO-ELECTRICAL PARAMETERS TEST CONDITIONS MIN TYP MAX UNITS Dark Resistance After 10 sec. @10 Lux @ 2856°K 20 - - MΩ Illuminated Resistance 10 Lux @ 2856°K 48 - 140 KΩ - 0.9 - Lux PARAMETER Sensitivity Spectral Application Range Flooded 400 - 700 nm Spectral Application Range Flooded - 520 - nm Rise Time 10 Lux @ 2856 °K - 60 - ms Fall Time After 10 Lux @ 2856 °K - 25 - MΩ **R100, R10: cell resistances at 100 Lux and 10 Lux at 2856 K respectively . ***E100, E10: luminances at 100 Lux and 10 Lux 2856 K respectively. TYPICAL PERFORMANCE CELL RESISTANCE vs. ILLUMINANCE Resistance in Kohms 1000 100 10 1 1 10 100 Illum inance in lux Information in this technical datasheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications are subject to change without notice. REV 10-24-16 Page 2/2 © 2016 Luna Optoelectronics. All rights reserved. Luna Optoelectronics, 1240 Avenida Acaso, Camarillo CA 93012 • Phone (805) 987-0146 • Fax (805) 484-9935
PDV-P9005-1
物料型号为 PDV-P9005-1,由 Luna Optoelectronics 生产的 CdS 光敏电阻光电池。
器件简介指出,这些光电池设计用于感测 400 至 700 纳米范围内的光,并且具有多种电阻值。
它们被封装在双引脚塑料涂层陶瓷头中。
引脚分配信息在文档中没有明确说明,但通常这类器件会有两引脚配置。
参数特性包括暗电阻、亮电阻、灵敏度、光谱应用范围、上升时间和下降时间。
例如,暗电阻在 10 勒克斯和 2856 开尔文下最小为 20 MOhms,亮电阻在 10 勒克斯和 2856 开尔文下典型值为 48 KOhms。
功能详解涉及光电池的可见光响应、烧结结构和低成本。
应用信息包括相机曝光、快门控制和夜间灯光控制。
该设备原则上能够满足军事测试要求(Mil-STD-750, Mil-STD-883),在适当的筛选和组合测试后。
封装信息指出,这些光电池被封装在塑料涂层的陶瓷包中,尺寸为 0.79 英寸(2.00 毫米)宽,最小长度为 1.75 英寸(2.39 毫米),最大长度为 2.00 英寸(50.80 毫米),环氧树脂在引脚上的最大厚度为 0.016 英寸(0.40 毫米)。
请注意,技术数据手册中提供的信息被认为是正确和可靠的,但 Luna Optoelectronics 不对可能的不准确或遗漏承担责任,规格如有更改,恕不另行通知。
PDV-P9005-1 价格&库存
很抱歉,暂时无法提供与“PDV-P9005-1”相匹配的价格&库存,您可以联系我们找货
