PDV-P5003
PDV-P5003
    LUNAOPTOELECTRONICS(Luna Optoelectronics)
    PHOTOCELL 12K-58K OHM 11MM
PDV-P5003 数据手册
CDS Photoconductive Photocells PDV-P5003 Precision – Control – Results WWW.LUNAINC.COM ±.010 [0.25] .366 [9.30] +.015 [0.38] -.010 [0.25] .079 [2.00] ±.010 [0.25] .433 [11.00] EPOXY ON LEADS 3mm MAX 2X Ø.023 [.58] MAX 2 .300 [7.62] PLASTIC COATED 1 2X 1.00 [25.4] MIN CERAMIC PACKAGE DESCRIPTION FEATURES The PDV-P5003 are (CdS), Photoconductive photocells designed to sense light from 400 to 700 nm. These light dependent resistors are available in a wide range of resistance values. They’re packaged in a two leaded plastic-coated ceramic header.    RELIABILITY APPLICATIONS This LUNA high-reliability device is in principle able to meet military test requirements (Mil-STD-750, Mil-STD-883) after proper screening and group test. Contact Luna for recommendations on specific test conditions and procedures.    Visible light response Sintered construction Low cost Camera exposure Shutter controls Night light controls ABSOLUTE MAXIMUM RATINGS SYMBOL Applied Voltage MIN MAX UNITS - - 350 V Operating Temperature -30 to +75 °C Storage Temperature -30 to +75 °C - - +260 °C 400 to 700 nm - - 400 mW/°C Soldering Temperature Wavelength Range Continuous power Dissipation Information in this technical datasheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications are subject to change without notice. (TA)= 23°C non condensing 0.2 inch from base for 3 sec with heat sink REV 10-24-16 Page 1/2 © 2016 Luna Optoelectronics. All rights reserved. Luna Optoelectronics, 1240 Avenida Acaso, Camarillo CA 93012 • Phone (805) 987-0146 • Fax (805) 484-9935 CDS Photoconductive Photocells PDV-P5003 Precision – Control – Results WWW.LUNAINC.COM Ta = 23°C UNLESS NOTED OTHERWISE OPTO-ELECTRICAL PARAMETERS TEST CONDITIONS PARAMETER MIN TYP MAX UNITS Dark Resistance After 10 sec. @10 Lux @ 2856°K 1 - - MΩ Illuminated Resistance 10 Lux @ 2856°K 12 - 58 KΩ - 0.7 - Lux Sensitivity Spectral Peak Flooded - 520 - nm Rise Time 10 Lux @ 2856 °K - 55 100 ms Fall Time After 10 Lux @ 2856 °K - 25 - ms **R100, R10: cell resistances at 100 Lux and 10 Lux at 2856 K respectively . ***E100, E10: luminances at 100 Lux and 10 Lux 2856 K respectively. Information in this technical datasheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications are subject to change without notice. REV 10-24-16 Page 2/2 © 2016 Luna Optoelectronics. All rights reserved. Luna Optoelectronics, 1240 Avenida Acaso, Camarillo CA 93012 • Phone (805) 987-0146 • Fax (805) 484-9935
PDV-P5003 价格&库存
很抱歉,暂时无法提供与“PDV-P5003”相匹配的价格&库存,您可以联系我们找货
PDV-P5003
    库存:1308
