PDV-P9002-1
PDV-P9002-1
    LUNAOPTOELECTRONICS(Luna Optoelectronics)
    PHOTOCELL 11K-27K OHM 4.20MM
PDV-P9002-1 数据手册
CDS Photoconductive Photocells PDV-P9002-1 Precision – Control – Results WWW.LUNAINC.COM DESCRIPTION FEATURES The PDV-P9002-1 are (CdS), Photoconductive photocells designed to sense light from 400 to 700 nm. These light dependent resistors are available in a wide range of resistance values. They’re packaged in a two leaded plastic-coated ceramic header.    RELIABILITY APPLICATIONS This Luna high-reliability device is in principle able to meet military test requirements (Mil-STD-750, Mil-STD-883) after proper screening and group test. Contact Luna for recommendations on specific test conditions and procedures.    Visible light response Sintered construction Low cost Camera exposure Shutter controls Night light controls ABSOLUTE MAXIMUM RATINGS SYMBOL MIN MAX UNITS (TA)= 23°C UNLESS OTHERWISE NOTED Applied Voltage - - 150 V - Continuous Power Dissipation - - 90 mW/°C - -30 to +75 V - - - +260 °C - Operation and Storage Temperature Soldering Temperature* * 0.200 inch from base for 3 seconds with heat sink. Information in this technical datasheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications are subject to change without notice. REV 01-04-16 Page 1/2 © 2016 Luna Optoelectronics. All rights reserved. Luna Optoelectronics, 1240 Avenida Acaso, Camarillo CA 93012 • Phone (805) 987-0146 • Fax (805) 484-9935 CDS Photoconductive Photocells PDV-P9002-1 Precision – Control – Results WWW.LUNAINC.COM Ta = 23°C UNLESS NOTED OTHERWISE OPTO-ELECTRICAL PARAMETERS TEST CONDITIONS MIN TYP MAX Dark Resistance After 10 sec. @10 Lux @ 2856°K 0.5 - - MΩ Illuminated Resistance 10 Lux @ 2856°K 11 - 27 KΩ 400 0.70 - Lux PARAMETER Sensitivity UNITS Spectral Application Range Flooded - - 700 nm Spectral Application Range Flooded - 570 - nm Rise Time 10 Lux @ 2856 °K - 60 - ms Fall Time After 10 Lux @ 2856 °K 0.5 25 - ms **R100, R10: cell resistances at 100 Lux and 10 Lux at 2856 K respectively . ***E100, E10: luminances at 100 Lux and 10 Lux 2856 K respectively. TYPICAL PERFORMANCE CELL RESISTANCE vs. ILLUMINANCE Information in this technical datasheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications are subject to change without notice. REV 01-04-16 Page 2/2 © 2016 Luna Optoelectronics. All rights reserved. Luna Optoelectronics, 1240 Avenida Acaso, Camarillo CA 93012 • Phone (805) 987-0146 • Fax (805) 484-9935
PDV-P9002-1 价格&库存
很抱歉,暂时无法提供与“PDV-P9002-1”相匹配的价格&库存,您可以联系我们找货
