PDV-P5001
PDV-P5001
    LUNAOPTOELECTRONICS(Luna Optoelectronics)
    PHOTOCELL 8K-16K OHM 11MM
PDV-P5001 数据手册
CDS Photoconductive Photocells PDV-P5001 Precision – Control – Results WWW.LUNAINC.COM DESCRIPTION FEATURES The PDV-P5001 are (CdS), Photoconductive photocells designed to sense light from 400 to 700 nm. These light dependent resistors are available in a wide range of resistance values. They’re packaged in a two leaded plasticcoated ceramic header.    RELIABILITY APPLICATIONS Contact Luna for recommendations on specific test conditions and procedures.    Visible light response Sintered construction Low cost Camera exposure Shutter controls Night light controls ABSOLUTE MAXIMUM RATINGS SYMBOL MIN MAX UNITS Applied Voltage - - 350 V Continuous Power Dissipation - - 400 mW/°C - -30 to +75 °C - - - +260 °C - Operating and Storage Temperature Soldering Temperature* Ta = 23°C UNLESS OTHERWISE NOTED * 0.200 inch from base for 3 seconds with heat sink. Information in this technical datasheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications are subject to change without notice. REV 10-24-16 Page 1/2 © 2016 Luna Optoelectronics. All rights reserved. Luna Optoelectronics, 1240 Avenida Acaso, Camarillo CA 93012 • Phone (805) 987-0146 • Fax (805) 484-9935 CDS Photoconductive Photocells PDV-P5001 Precision – Control – Results WWW.LUNAINC.COM Ta = 23°C UNLESS NOTED OTHERWISE OPTO-ELECTRICAL PARAMETERS TEST CONDITIONS MIN TYP MAX UNITS 0.3 - - MΩ 8 - 16 KΩ - 0.6 - Ω/Lux Spectral Application Range Flooded 400 - 700 Nm Spectral Application Range Flooded - 520 - Nm Rise Time 10 Lux @ 2856 °K - 55 - Ms Fall Time After 10 Lux @ 2856 °K - 25 - Ms PARAMETER Dark Resistance After 10 sec. @ 10 Lux @2856°K Illuminating Resistance 10 Lux @ 2856 °K Sensitivity **R100, R10: cell resistances at 100 Lux and 10 Lux at 2856 K respectively . ***E100, E10: luminances at 100 Lux and 10 Lux 2856 K respectively. Information in this technical datasheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications are subject to change without notice. REV 10-24-16 Page 2/2 © 2016 Luna Optoelectronics. All rights reserved. Luna Optoelectronics, 1240 Avenida Acaso, Camarillo CA 93012 • Phone (805) 987-0146 • Fax (805) 484-9935
PDV-P5001 价格&库存
很抱歉,暂时无法提供与“PDV-P5001”相匹配的价格&库存,您可以联系我们找货
