CDS Photoconductive Photocells
PDV-P8107
Precision – Control – Results
WWW.LUNAINC.COM
DESCRIPTION
FEATURES
The PDV-P8107 are (CdS), Photoconductive photocells designed to
sense light from 400 to 700 nm. These light dependent resistors are
available in a wide range of resistance values. They’re packaged in a two
leaded plastic-coated ceramic header.
RELIABILITY
APPLICATIONS
Contact Luna for recommendations on specific test conditions and
procedures.
Visible light response
Sintered construction
Low cost
Camera exposure
Shutter controls
Night light controls
ABSOLUTE MAXIMUM RATINGS
SYMBOL
MIN
MAX
UNITS
(TA)= 23°C UNLESS OTHERWISE NOTED
Applied Voltage
150
V
Continuous Power Dissipation
100
mW/°C
-30
to
+75
V
+260
°C
Operation and Storage Temperature
Soldering Temperature*
* 0.200 inch from base for 3 seconds with heat sink.
Information in this technical datasheet is believed to
be correct and reliable. However, no responsibility is
assumed for possible inaccuracies or omission.
Specifications are subject to change without notice.
REV 10-24-16
Page 1/2
© 2016 Luna Optoelectronics. All rights reserved.
Luna Optoelectronics, 1240 Avenida Acaso, Camarillo CA 93012 • Phone (805) 987-0146 • Fax (805) 484-9935
PDV-P8107
WWW.LUNAINC.COM
Ta = 23°C UNLESS NOTED OTHERWISE
OPTO-ELECTRICAL PARAMETERS
TEST CONDITIONS
MIN
TYP
MAX
UNITS
Dark Resistance
After 10 sec. @10 Lux @ 2856°K
MΩ
Illuminated Resistance
10 Lux @ 2856°K
80
240
KΩ
0.9
Lux
PARAMETER
Sensitivity
Spectral Application Range
Flooded
400
700
nm
Flooded
520
nm
Rise Time
10 Lux @ 2856 °K
60
ms
Fall Time
After 10 Lux @ 2856 °K
25
ms
**R100, R10: cell resistances at 100 Lux and 10 Lux at 2856 K respectively.
***E100, E10: luminances at 100 Lux and 10 Lux 2856 K respectively.
TYPICAL PERFORMANCE
CELL RESISTANCE vs. ILLUMINANCE
Resistance in Kohms
1000
100
10
1
1
10
100
Illuminance in lux
REV 10-24-16
Page 2/2
很抱歉,暂时无法提供与“PDV-P8107”相匹配的价格&库存,您可以联系我们找货
